The Teleboy PVR doesn't work anymore since release #313. Works with #312. Stream opens and immediately closes again. I can currently only provide a log from Nvidia Shield but I had the same error with my RPi3 (both on #314).
New LibreELEC.tv Leia build #0315:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
77d9748ae2d4df1c9293c95f778464a67d7d5f01801a01a8778dfc5feae0f8ff
(RPi)
SHA256 Checksum:
df618f0c452cb576ca9639e19829fb8cd92700eff4bab1346e3b2ad51f257617
(RPi2)
text:
# uname -a
Linux rpi512 4.14.26 #1 Thu Mar 15 23:15:01 GMT 2018 armv6l GNU/Linux
# vcgencmd version
Mar 14 2018 16:55:36
Copyright © 2012 Broadcom
version 5afe871e8e58f66e0a39531895d09ed692893267 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20180315231318-#0315-gf291881 [Build #0315]
# Kodi version
(18.0-ALPHA2 Git:258cf89). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (f291881,
changelog) and tip of
XBMC master (aedcf10,
- Includes newclock5 patches
- Includes latest bcm2835-driver master (086a848, ahead +1)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (54405d9, ahead +120)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (373f726), inputstream.rtmp (f4e45e0, +1), peripheral.joystick (d68e78c), pvr.argustv (3556049), pvr.demo (8f62053), pvr.dvblink (594e062), pvr.dvbviewer (f1746c5, +1), pvr.filmon (c7243fb), pvr.hdhomerun (f3e0177), pvr.hts (095784b), pvr.iptvsimple (933a5c4), pvr.mediaportal.tvserver (74e2bea), pvr.mythtv (85c33c4), pvr.nextpvr (aa1c8d2), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (5b47d9f), pvr.stalker (77eec69), pvr.teleboy (3ccd06f, +1), pvr.vbox (57f3198), pvr.vdr.vnsi (4db947c), pvr.vuplus (dc230dd), pvr.wmc (e0a9190), pvr.zattoo (3c46173), vfs.libarchive (e74a3ab)
- Exclude [env] kodi-0100-temp-add-pr13594.patch: merged upstream
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: fix PR390
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2511 (perma): kernel-firmware: use project specific firmwares and cleanup
- Include [env] PR:2529 (perma): buildsystem: support get handlers (archive, file, git)
- Include [env] PR:2533 (perma): graphics package updates
- Include [env] PR:2577 (perma): buildsystem: simplify SIMD support (neon/mmx/sse/sse2)
- Include [env] PR:2585 (perma): linux: update to linux-4.14.30
- Include [env] PR:2586 (perma): samba: update to samba-4.8.0
- Include [env] PR:2587 (perma): brcmfmac_sdio-firmware-rpi: cleanup wlan-firmware
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:13274 (perma): Mode whitelist
- Include [pkg] PR:13652 (perma): offload videodb task from mainthread to job
Build Highlights:
- offload videodb task from mainthread to job
Build Details:
- LibreELEC.tv:
- SHA256sum fixes (PR:2591, 3 commits, 3 files changed)
- XBMC:
- [swig] Revert PR #12490 now Trusty is no longer supported/able to build (PR:13573, 1 commit, 20 files changed)
- pvr.dvbviewer:
- pvr.teleboy:
- Fix null pointer exception (3ccd06f)
- Added: [pkg] PR:13652 (perma): offload videodb task from mainthread to job
No, still the same problem meccs mentioned.
Didn't have time for a log, only update and check.
Switching TV channels on the remote control with the arrow keys (down / up) does not work, TVheadend HTSP client reports "Tuning failed". But if I press stop and select a channel then it works.
Just have to find out from which build this error is there.
(2018-03-16, 00:47)3DBuff Wrote: [ -> ]What would be default set for Pi3+ if it reads both sets [pi3] and [pi3+] not to overclock or change anything?
Setting any options to 0 should give the default value. e.g.
[pi3+]
arm_freq=0
etc
(2018-03-16, 16:26)popcornmix Wrote: [ -> ] (2018-03-16, 00:47)3DBuff Wrote: [ -> ]What would be default set for Pi3+ if it reads both sets [pi3] and [pi3+] not to overclock or change anything?
[pi3+]
arm_freq=0
etc
Great, thanks.
Over few years I ended up with different versions of Pi's at different locations in the house. This helps to test SD chips without editing config files.
(2018-03-16, 13:54)Aux_ Wrote: [ -> ]Switching TV channels on the remote control with the arrow keys (down / up) does not work, TVheadend HTSP client reports "Tuning failed". But if I press stop and select a channel then it works.
Working fine here.
According to the error message, I'd say "fix your tvheadend server."
(2018-03-16, 18:11)ksooo Wrote: [ -> ]Working fine here.
Latest build includes
PR13652. Any chance that could affect things?
Need to get @
Aux_ to confirm if this problem is new in latest build to narrow it down.
I have a problem with PVR playback in the HEVC codec with this version of LibreELEC and KODI 18 (streak appears in the middle of the video). when I used the official version of LIBREELEC 8.2.3 playback is OK no streak.
SAMPLE VIDEO
(2018-03-16, 18:30)Aladar85 Wrote: [ -> ]I have a problem with PVR playback in the HEVC codec with this version of LibreELEC and KODI 18 (streak appears in the middle of the video). when I used the official version of LIBREELEC 8.2.3 playback is OK no streak.
SAMPLE VIDEO
Can you produce a sample HEVC recording that has this issue? e.g. a 1 minute long clip and upload to a hosting site. (e.g. google drive or dropbox).
(2018-03-16, 18:11)ksooo Wrote: [ -> ] (2018-03-16, 13:54)Aux_ Wrote: [ -> ]Switching TV channels on the remote control with the arrow keys (down / up) does not work, TVheadend HTSP client reports "Tuning failed". But if I press stop and select a channel then it works.
Working fine here.
In DVB-C source settings, "Fast input switch" was checked. That was the cause, thanks for the hint @
ksooo !
New LibreELEC.tv Leia build #0316:
RPi /
RPi2
SHA256 Checksum:
179015b5761071dfca0ca121b73fd9dae7ca9cc723435ac8ae787a496ad9ba77
(RPi)
SHA256 Checksum:
c2c1ebf62de88c33032c2036facaf11af426ddc49722b9f87096175e7f1349d4
(RPi2)
text:
# uname -a
Linux rpi512 4.14.27 #1 Fri Mar 16 21:05:45 GMT 2018 armv6l GNU/Linux
# vcgencmd version
Mar 16 2018 16:21:29
version db815f3ae3dc88cf21fed2765f3b25d9d2bea67a (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20180316210354-#0316-gf291881 [Build #0316]
# Kodi version
Based on tip of
XBMC master (a897fc5,
- Includes latest commits from kernel branch rpi-4.14.y
- Includes latest bcm2835-driver master (25cf637, ahead +1)
- Includes latest addons: inputstream.adaptive (1c89c3b, +3), inputstream.rtmp (7fe7dde, +2), peripheral.joystick (8374cb4, +2), pvr.argustv (3556049), pvr.demo (8f62053), pvr.dvblink (594e062), pvr.dvbviewer (f1746c5, +1), pvr.filmon (c7243fb), pvr.hdhomerun (f3e0177), pvr.hts (095784b), pvr.iptvsimple (933a5c4), pvr.mediaportal.tvserver (74e2bea), pvr.mythtv (85c33c4), pvr.nextpvr (aa1c8d2), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (5b47d9f), pvr.stalker (77eec69), pvr.teleboy (3ccd06f, +1), pvr.vbox (57f3198), pvr.vdr.vnsi (4db947c), pvr.vuplus (dc230dd), pvr.wmc (e0a9190), pvr.zattoo (3c46173), vfs.libarchive (6ce469f, +1)
Build Highlights:
- New firmware
- New 4.14.27 kernel
- fix playing video strm files with autoplay
- More PVR/guiinfo fixes
Build Details:
- Firmware (Mar 16):
- firmware: video_decode: Allow setting the resolution on the output port
- firmware: arm_loader: Fall back to stored frequency for clocks platform doesn't have fixed values for. See: link
- XBMC:
- fix playing video strm files with autoplay (PR:13648, 3 commits, 4 files changed)
- [guiinfo][PVR] Another bunch of (PVR) guiinfo fixes and improvements (PR:13651, 7 commits, 13 files changed)
- VideoPlayer: DirectX - fix rendering 10bit video on hw/os which doesn (PR:13655, 1 commit, 4 files changed)
- Fix thread naming on Linux and Darwin (PR:13569, 1 commit, 2 files changed)
- [AddonVideoCodec] (Re)initialize all VideoPicture members (PR:13653, 1 commit, 1 file changed)
- AudioEngine: XAudio - rework delay calculation based on currently pla (PR:13656, 1 commit, 2 files changed)
- inputstream.adaptive:
- inputstream.rtmp:
- peripheral.joystick:
- linux: Add support for WeTek Gamepad (PR:142, 2 commits, 2 files changed)
- vfs.libarchive:
- kernel 4.14.y:
- New commits in this build:
- Fix for Pisound's MIDI Input getting blocked for a while in rare cases. (4d78845f)
- Updated: [env] PR:2585 (perma): linux: update to linux-4.14.30
- Updated: [pkg] PR:13652 (perma): offload videodb task from mainthread to job
(2018-03-12, 00:23)Milhouse Wrote: [ -> ] (2018-03-11, 18:36)Bosode Wrote: [ -> ]Full IPv6 - Support missing
Can you test LibreELEC 8.2.3 and if that has the same problem it should be reported on the LibreELEC forum.
Hi Milhouse,
sorry for my delay - I wasn't at home last week so I couldn't test it just in time.
Right now I have downloaded the LibreElec Version you mentioned (8.2.3) and IPv6 is working correct and the WenDav connection though it could be enabled. I just have had to enable IPv6-Support at the beginning an set to "auto" - than all works fine... Even in the previously Version 8.2.2...
Do you have any other idea what could be the root cause?
(2018-03-17, 11:50)Bosode Wrote: [ -> ]Do you have any other idea what could be the root cause?
No, not at this time. Would it be possible for you to now identify the last of these builds that has working ipv6?
