(2018-03-18, 22:47)HiassofT Wrote: [ -> ] (2018-03-18, 22:37)Bosode Wrote: [ -> ]after doing several tests with your older builds I've found out, that the latest version from you with running full IPv6-Support is the "LibreELEC-RPi2.arm-9.0-Milhouse-20180102210315-#0102-gf115a20.tar" from the 2nd January 18. With the versions up from the 3rd January it's not always possible to connect to a WebDAV-Share using IPv6.
I don't know why - but it seems to look like a fault.
The most likelly change is addition of firewall/netfilter in #0103.
Could test if setting Firewall to "off" in LibreELEC Settings->Network fixes the IPv6 issue in current builds?
so long,
Hias
HiassofT -You'r my personal hero .
After switching the Firewall to "off" and doing a reboot - the connection could be build.
Great stuff and many thanks for such a fast and top support!
We'll look into the IPv6/firewall issue and try to fix that - thanks for the report (and thanks @
HiassofT for the temporary workaround!)
New LibreELEC.tv Leia build #0318:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
342c66456a949566ae403154be2398fb0566c06c2d6afe4c9ed04b50677dd2fd
(RPi)
SHA256 Checksum:
548be68f567882eb3a9a669f6d69f817e7614382028b2d0485e52b3dc0956db8
(RPi2)
text:
# uname -a
Linux rpi512 4.14.27 #1 Sun Mar 18 21:04:59 GMT 2018 armv6l GNU/Linux
# vcgencmd version
Mar 16 2018 16:21:29
Copyright © 2012 Broadcom
version db815f3ae3dc88cf21fed2765f3b25d9d2bea67a (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20180318210308-#0318-gf291881 [Build #0318]
# Kodi version
(18.0-ALPHA2 Git:258cf89). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (f291881,
changelog) and tip of
XBMC master (277d75c,
- Includes newclock5 patches
- Includes latest commits from kernel branch rpi-4.14.y
- Includes latest bcm2835-driver master (25cf637, ahead +1)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (54405d9, ahead +120)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (04eead7, +14), inputstream.rtmp (7fe7dde, +2), peripheral.joystick (8374cb4, +2), pvr.argustv (3556049), pvr.demo (8f62053), pvr.dvblink (594e062), pvr.dvbviewer (f1746c5, +1), pvr.filmon (c7243fb), pvr.hdhomerun (f3e0177), pvr.hts (095784b), pvr.iptvsimple (933a5c4), pvr.mediaportal.tvserver (74e2bea), pvr.mythtv (345f9a7, +2), pvr.nextpvr (aa1c8d2), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (5b47d9f), pvr.stalker (77eec69), pvr.teleboy (3ccd06f, +1), pvr.vbox (57f3198), pvr.vdr.vnsi (4db947c), pvr.vuplus (dc230dd), pvr.wmc (e0a9190), pvr.zattoo (3c46173), vfs.libarchive (6ce469f, +1)
- Exclude [env] kodi-0100-temp-add-pr13594.patch: merged upstream
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: fix PR390
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2511 (perma): kernel-firmware: use project specific firmwares and cleanup
- Include [env] PR:2529 (perma): buildsystem: support get handlers (archive, file, git)
- Include [env] PR:2533 (perma): graphics package updates
- Include [env] PR:2577 (perma): buildsystem: simplify SIMD support (neon/mmx/sse/sse2)
- Include [env] PR:2585 (perma): linux: update to linux-4.14.30
- Include [env] PR:2586 (perma): samba: update to samba-4.8.0
- Include [env] PR:2587 (perma): brcmfmac_sdio-firmware-rpi: cleanup wlan-firmware
- Include [env] PR:2594 (perma): xf86-video-nvidia: update to xf86-video-nvidia-390.42
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:13274 (perma): Mode whitelist
- Include [pkg] PR:13652 (perma): offload videodb task from mainthread to job
Build Highlights:
- GuiInfoManager: Restore Announcements
- inputstream.adaptive and pvr.mythtv fixes
Build Details:
- XBMC:
- windows: update patch utility to 2.7.6 (PR:13663, 1 commit, 2 files changed)
- fix deadlock caused by blocking cb method (PR:13664, 1 commit, 2 files changed)
- GuiInfoManager: Restore Announcements (PR:13667, 2 commits, 2 files changed)
- inputstream.adaptive:
- Allow NOTYPE containers for stream selection / container type will be determined late for HLS (7e86870)
- [Android] compile fix after decimal format changes (ef1926d)
- [Android] Add Header based license post body (bc40b07)
- Fix decrypter initialization (KID retrieval) / version bump 2.2.5 (04eead7)
- pvr.mythtv:
- [depends] bump zlib to 1.2.11 (PR:96, 1 commit, 3 files changed)
- bump version 5.7.1 (345f9a7)
The new RPi3 B+ has issues booting from various SD chips. Out of 6 SD cards that I have with various Kodi instllations, Ubuntu and security cameras, only 2 recent Kodi SD chips are booting. All 6 cards work fine on older RPi3.
Any quick solution to fix the chips without reloading new images?
I have various issues from Red LED blinking probably 5x, Green blinking 6x and nothing blinking stuck in rainbow screen. It's all OK with previous Pi 3.
(2018-03-19, 03:33)3DBuff Wrote: [ -> ]The new RPi3 B+ has issues booting from various SD chips. Out of 6 SD cards that I have with various Kodi instllations, Ubuntu and security cameras, only 2 recent Kodi SD chips are booting. All 6 cards work fine on older RPi3.
You need to have firmware that supports the Pi3+.
Updating the LE image on a Pi3 then switching the card to a Pi3+ is the recommended procedure.
While in theory you could just update the firmware to get the Pi to boot, without an updated linux kernel you won't have working ethernet, wifi or bluetooth.
Can I swap a file on Kodi or Ubuntu Mate image to make it boot?
(2018-03-19, 15:19)3DBuff Wrote: [ -> ]Can I swap a file on Kodi or Ubuntu Mate image to make it boot?
Kodi needs no changes to support the Pi3+, but the OS does (Ubuntu Mate).
Best to ask on an Ubuntu Mate forum for how to update the firmware/kernel to support Pi3+.
No solutions for Pi3 B+ with other builds yet. New Kodi works
Major LAN network improvement with USB to external hard drive as usable solution.
We broke 100 Mbps barrier with B+. It's around
350 Mbps now.
New LibreELEC.tv Leia build #0319:
RPi /
RPi2
SHA256 Checksum:
9a8ba9a240396ad9f98892cbf13dc6860c4c431a96899cb0a3b438338b4ba2a3
(RPi)
SHA256 Checksum:
4e260b7b5ccc484b9d3ced91e20a61879c3246418aa51b524f964b246342e377
(RPi2)
text:
# uname -a
Linux rpi512 4.14.27 #1 Mon Mar 19 21:17:02 GMT 2018 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20180319211511-#0319-gc2a0368 [Build #0319]
# Kodi version
Based on tip of
LibreELEC.tv master (c2a0368,
XBMC master (2c8eac2,
- Include [env] PR:2599 (perma): brcmfmac_sdio-firmware-rpi: update to brcmfmac_sdio-firmware-rpi-18d7c93
- Include [pkg] patch: st/va: Make the vendor string more descriptive (mesa)
- Include [pkg] patch: st/va: Enable vaExportSurfaceHandle() (mesa)
Build Highlights:
- Update Pi3+ WiFI firmware to v7.45.154
- ffmpeg: hevc: fixup: Fix for segfault and more neon scheduling optimisations
Build Details:
- LibreELEC.tv:
- xf86-video-nvidia: update to xf86-video-nvidia-390.42 (PR:2594, 1 commit, 1 file changed)
- brcmfmac_sdio-firmware-rpi: cleanup wlan-firmware (PR:2587, 2 commits, 2 files changed)
- samba: update to samba-4.8.0 (PR:2586, 1 commit, 2 files changed)
- XBMC:
- Support for vaExportSurfaceHandle (PR:13333, 13 commits, 20 files changed)
- [cmake][addons] make pdb installation & packaging multi config aware (PR:13666, 2 commits, 2 files changed)
- newclock5:
- New commits in this build:
- ffmpeg: hevc: fixup: Fix for segfault and more neon scheduling optimisations (8e37101b)
- Added: [env] PR:2599 (perma): brcmfmac_sdio-firmware-rpi: update to brcmfmac_sdio-firmware-rpi-18d7c93
- Added: [pkg] patch: st/va: Make the vendor string more descriptive (mesa)
- Added: [pkg] patch: st/va: Enable vaExportSurfaceHandle() (mesa)
Teleboy is working again with #319. Thank you
I noticed an annoying random glitch. Sometimes when switching from a file playback directly to a live TV channel the video/audio gets stalled - I see just a frozen frame. I have to switch the channel again to "unfreeze" it. Another workaround is to always stop the file playback before trying to switch to a live TV. Never noticed this with Kodi 17 and old Kodi 18 builds.
Using #318/319, I can't read a film located on my NAS. (Series are working well):
Quote:22:09:30.860 T:1941738064 NOTICE: VideoPlayer::OpenFile: smb://192.168.1.18/video/Mes Films/Justice.League.2017.TRUEFRENCH.BDRip.XviD.avi
22:09:30.860 T:1492956032 NOTICE: Creating InputStream
22:09:31.005 T:1492956032 NOTICE: Creating Demuxer
22:09:31.415 T:1941738064 WARNING: OnMessage: Suspiciously long time to handle GUI_MSG_PLAYBACK_STARTED (0.48s)
22:09:31.615 T:1405916032 ERROR: Read - Error( -1, 103, Software caused connection abort )
22:09:33.120 T:1492956032 NOTICE: Opening stream: 0 source: 256
22:09:33.120 T:1492956032 NOTICE: Creating video codec with codec id: 13
22:09:33.132 T:1492956032 NOTICE: Creating video thread
22:09:33.133 T:1510978432 NOTICE: running thread: video_thread
22:09:33.459 T:1492956032 NOTICE: Opening stream: 1 source: 256
22:09:33.459 T:1492956032 NOTICE: Finding audio codec for: 86017
22:09:33.459 T:1492956032 NOTICE: Creating audio thread
22:09:33.460 T:1284494208 NOTICE: running thread: CVideoPlayerAudio:rocess()
22:09:33.471 T:1284494208 NOTICE: Creating audio stream (codec id: 86017, channels: 2, sample rate: 48000, no pass-through)
22:09:35.121 T:1789846400 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:14
@popcornmix:
A little offtopic, but I found a video on YouTube saying that: over_voltage= when overclocking is done dynamicly by the RPI3b+ making it not needed to set it in config.txt.
Is this correct?
(2018-03-20, 23:14)HpNoTiQ Wrote: [ -> ]Hi,
You're saying this worked normally in #0317? Can you provide a sample video?
New LibreELEC.tv Leia build #0320:
RPi /
RPi2
SHA256 Checksum:
1641e435e7ffc4d416bbb51b2a3499d33cf5f73357289cd5b8dd08fe4fad4f46
(RPi)
SHA256 Checksum:
3fb635e208e8dd1c0da389011b4c840f5e47aa692b8e35dda29717784c0cf25d
(RPi2)
text:
# uname -a
Linux rpi512 4.14.27 #1 Tue Mar 20 21:54:45 GMT 2018 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20180320215252-#0320-gb289c90 [Build #0320]
# Kodi version
Based on tip of
LibreELEC.tv master (b289c90,
XBMC master (384bd17,
- Includes latest addons: inputstream.adaptive (622d59d, +16), inputstream.rtmp (7fe7dde, +2), peripheral.joystick (8374cb4, +2), pvr.argustv (3556049), pvr.demo (8f62053), pvr.dvblink (594e062), pvr.dvbviewer (f1746c5, +1), pvr.filmon (c7243fb), pvr.hdhomerun (f3e0177), pvr.hts (095784b), pvr.iptvsimple (933a5c4), pvr.mediaportal.tvserver (74e2bea), pvr.mythtv (345f9a7, +2), pvr.nextpvr (aa1c8d2), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (5b47d9f), pvr.stalker (77eec69), pvr.teleboy (3ccd06f, +1), pvr.vbox (57f3198), pvr.vdr.vnsi (4db947c), pvr.vuplus (dc230dd), pvr.wmc (e0a9190), pvr.zattoo (3c46173), vfs.libarchive (6ce469f, +1)
- Include [env] patch: libva: remove recursive mesa dependency
- Include [env] PR:2403 (perma): allow using vaapi with r600 and radeonsi
Build Highlights:
- ffmpeg: hevc: fixup: Fix issue with caching and tiles
Build Details:
- LibreELEC.tv:
- Improvements to the service.fd628 add-on (PR:2481, 2 commits, 14 files changed)
- samba: fix noman patch (PR:2603, 1 commit, 1 file changed)
- XBMC:
- [win32] fixes for display mode switching issues (PR:13674, 3 commits, 5 files changed)
- VideoPlayer: OpenGL - fix source rect for stereo (PR:13669, 1 commit, 1 file changed)
- VideoPlayer: do an accurate seek for auto-resume (PR:13665, 1 commit, 1 file changed)
- threads: let the app die on exceptions (PR:13670, 1 commit, 1 file changed)
- Use first matching adaptationset for key check (f05aa80)
- travis: xcode 9.2 / version bump 2.2.6 (622d59d)
- newclock5:
- ffmpeg: hevc: fixup: Fix issue with caching and tiles (b1e40166)
- Added: [env] PR:2403 (perma): allow using vaapi with r600 and radeonsi
- Added: [env] patch: libva: remove recursive mesa dependency
