2017-01-13, 20:28
Tried a clean build, same issue with the plugin. If i try a different slideshow plugin, I don't get the overlay.
(2017-01-13, 19:00)khaoohs Wrote: [ -> ]1209b is the last version to NOT show this behavior, it starts in 1210.
I can install a newer version and see the issue, then revert back to 1209b and have no problems.
Link to a video of the issue
I will try the suggestions below and report back.
(2017-01-13, 03:57)Milhouse Wrote: [ -> ]I assume you mean this addon?
Any chance of a video of this behaviour?
So you don't have this problem with #1208, and the problem is first seen with #1209b? In #1209b there appears to be only a kernel bump and and minor Kodi updates.
To me, #1209b doesn't seem likely as the cause of this issue, so either it first appeared in an earlier build, or is an add-on issue (is the add-on still Kodi 18 compatible?), or maybe even a corrupt setting.
Can you also test with a clean .kodi - this will help eliminate corrupt setting and influence of any other addons:
then configure your pictures and test the slideshow.Code:systemctl stop kodi
mv .kodi .kodi.bak
reboot
Assuming you still have the issue, please identify the first build with the abnormal behaviour, as we should then hopefully be able to narrow down the issue.
Pinging @ronie.
