(2018-05-07, 02:45)mikeb8591 Wrote: [ -> ]Ok, the results of all the tests are here. It should be noted that I also see occasional, seemingly random key activity several seconds after I've stopped my keypress. Some of these are captured in the .txt file, inside this .zip. Each test captures one "normal" press of the OK button.
I also observed that the red led on the IR receiver is basically on solid for the duration of my keypress in the fixed_timeout=1 case (and with 0417 and earlier) but flashes rapidly in all the other test scenarios.
http://www.awen.com/~mburgett/kodi/ir-de..._tests.zip
This remote has performed flawlessly up til now, and indeed still works flawlessly with 0417 and earlier builds, so I'm not inclined to agree that I have worn out buttons.
Thanks a lot, these logs are very helpful! I can clearly see that the IR receiver is behaving very odd with the short timeout. It's not sending the messages we'd expect and also not at the times where we'd expect them - which messes up everything.
I'll discuss this with the IR kernel maintainer, it could be that we need to disable timeout configuration for this specific IR receiver.
As you mentioned that running "ir-ctl -t 100000" worked on newer builds there's one more interesting thing to find out - if only this timeout works or if some other timeouts work, too and we just happen to set some timeout value it doesn't like.
So, could you play a bit with ir-ctl -t values on any build newer than 0418? The value set by the kernel is 25650, so checking with 30000, 40000, ... 100000 would be a good start. If some of these work and some others don't it would also be interesting to test nearby values (eg if 30000 works and 40000 doesn't try 35000, 38000, 39000, 41000, 42000, 45000). Just run ir-ctl -t while kodi is running and watch out for the typical symptoms like "double-clicks" and spurious button-presses. The ir-ctl -t changes will take effect immediately but the very first button press after the change could still be messed up due to remains of the previous configuration.
Edit: testing with 20000 and 25000 would also be interesting.
BTW: the changes in the LED behaviour on the receiver are about to be expected, so this is nothing to worry about.
so long,
Hias
Can we get an option to disable the default jumping and floating text overlay with debug logs = enabled and please make the default disabled and let people turn it on if they want useless text jumping over the useful information.
(2018-05-07, 14:11)brunis Wrote: [ -> ]Can we get an option to disable the default jumping and floating text overlay with debug logs = enabled and please make the default disabled and let people turn it on if they want useless text jumping over the useful information.
Add
<loglevel>1</loglevel>
to advancedsettings.xml if you want to enable debugging without the overlay text.
(2018-05-07, 16:08)Milhouse Wrote: [ -> ] (2018-05-07, 14:11)brunis Wrote: [ -> ]Can we get an option to disable the default jumping and floating text overlay with debug logs = enabled and please make the default disabled and let people turn it on if they want useless text jumping over the useful information.
Add <loglevel>1</loglevel>
This adds the overlay text at all times regardless of logging settings.
Kodi crashlog for renaming a Music source and answering no to rescan it.
http://ix.io/19Gr
Also there are probably crashlogs in there for a few other things, like adding game addons from the repo.
rybawaw - your device violates our
piracy policy (wiki) and is not eligible for support here whilst the
banned addons (wiki) are in place.
The forum moderators have determined that
banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
(2018-05-07, 17:31)brunis Wrote: [ -> ] (2018-05-07, 16:08)Milhouse Wrote: [ -> ]Add <loglevel>1</loglevel>
Yes, you will always have logging enabled but you should not have the overlay text. I'm not sure why you are getting the overlay text at all times.
If you want to change this behaviour or add more settings please post in the Feature Request forum.
(2018-05-07, 18:10)brunis Wrote: [ -> ]Kodi crashlog for renaming a Music source and answering no to rescan it.
http://ix.io/19Gr
Thanks, I'm pretty sure that's busy dialog related.
Another Clean install and again a reboot.
Crashlog
What is with this Error in the Log?
Quote:20:53:44.909 T:1794081648 WARNING: Repository LibreELEC Add-ons uses plain HTTP for add-on downloads - this is insecure and will make your Kodi installation vulnerable to attacks if enabled!
(2018-05-07, 22:59)tjost Wrote: [ -> ]Another Clean install and again a reboot.
Crashlog
When did this error start, as it's crashing due to Audio Engine. Can you try a clean kodi (or at least clean guisettings.xml)?
Edit: You said it was a clean install, that's odd - I don't know what would be triggering this. @
popcornmix?
(2018-05-07, 22:59)tjost Wrote: [ -> ]Quote:20:53:44.909 T:1794081648 WARNING: Repository LibreELEC Add-ons uses plain HTTP for add-on downloads - this is insecure and will make your Kodi installation vulnerable to attacks if enabled!
Tin foil hat spam. It will be fixed eventually.
New LibreELEC.tv Leia build #0507:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
64158651f7c75afea419399d02ec177d450424cb8a6f448c8745a238e9df97f5
(RPi)
SHA256 Checksum:
7710076310b9a3954e1fe7b92d4d29ec6b7cd8d06cc013ac5dd53850c5735abc
(RPi2)
text:
# uname -a
Linux rpi512 4.14.39 #1 Mon May 7 21:12:20 BST 2018 armv6l GNU/Linux
# vcgencmd version
Apr 26 2018 23:18:12
Copyright © 2012 Broadcom
version 90a06d6c6299583cfbf40033bbf895a45920fa71 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20180507211020-#0507-g8463ee0 [Build #0507]
# Kodi version
(18.0-ALPHA2 Git:eb1e22e). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (8463ee0,
changelog) and tip of
XBMC master (331e5fd,
- Includes newclock5 patches
- Includes latest bcm2835-driver master (287af2a)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (6a33413, ahead +132)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (0f0ced4), inputstream.rtmp (8920456, +1), peripheral.joystick (80224e1), pvr.argustv (377f796), pvr.demo (d5e5cd1), pvr.dvblink (c61ea73), pvr.dvbviewer (098d23c), pvr.filmon (0ca1665), pvr.hdhomerun (484b91d), pvr.hts (9533cce), pvr.iptvsimple (77156cb), pvr.mediaportal.tvserver (9702684), pvr.mythtv (9d15025), pvr.nextpvr (de30ff2), pvr.njoy (bd6581f), pvr.octonet (54680a3), pvr.pctv (5e95300), pvr.stalker (da6f0f8), pvr.teleboy (dbdc96e, +3), pvr.vbox (3cf15ad), pvr.vdr.vnsi (d6fe796), pvr.vuplus (00a963f), pvr.wmc (2acca13), pvr.zattoo (1244e14), vfs.libarchive (1b00b57, +1)
- Exclude [env] kodi-0100-temp-add-pr13594.patch: merged upstream
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: fix PR390
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2449 (perma): Adding support for AMD GPUs
- Include [env] PR:2677 (perma): qemu: update to 2.12.0
- Include [env] PR:2679 (perma): eventlircd: don't grab power buttons
- Include [env] PR:2680 (perma): kodi: mid-May 2018
- Include [env] PR:2682 (perma): linux: update to linux-4.14.39
- Include [env] PR:2686 (perma): meson: update to 0.46.0
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:13814 (perma): Reusepython
- Include [pkg] PR:13854 (perma): [music]Fix fanart for library items on playback from file view
- Include [pkg] PR:13860 (perma): windowing: use desktop resolution as a fallback
Build Highlights:
- windowing: use desktop resolution as a fallback
Build Details:
- XBMC:
- fix cancel of GetDirectory (PR:13858, 1 commit, 12 files changed)
- [cmake] fix FindWaylandpp (PR:13810, 1 commit, 1 file changed)
- Updated: [env] PR:2682 (perma): linux: update to linux-4.14.39
- Added: [env] PR:2686 (perma): meson: update to 0.46.0
- Added: [pkg] PR:13860 (perma): windowing: use desktop resolution as a fallback
(2018-05-07, 22:06)DarrenHill Wrote: [ -> ]@rybawaw - your device violates our piracy policy (wiki) and is not eligible for support here whilst the banned addons (wiki) are in place.
The forum moderators have determined that banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
OK,
http://ix.io/19J0
Clean install + netflix repository.After choosing movie, Kodi freeze.
(2018-05-08, 00:34)rybawaw Wrote: [ -> ] (2018-05-07, 22:06)DarrenHill Wrote: [ -> ]@rybawaw - your device violates our piracy policy (wiki) and is not eligible for support here whilst the banned addons (wiki) are in place.
OK,
http://ix.io/19J0
try add this option in addon's "addon.xml". I solved video playback problem in youtube addon.
There is already have xml section, add line 2 only.
xml:
<extension point="xbmc.addon.metadata">
<reuselanguageinvoker>false</reuselanguageinvoker>
</extension>
Millhouse is .rar archive support broken again ? I notice you don't have a build of the addon in your collection at the moment ?
