(2018-05-18, 08:30)Punkworld Wrote: [ -> ]This morning I upgraded my Pi 3 B+ to build#517. But since build #508 the "Play from here" function doesn't work and after the first chosen video (e.g. from a series season) kodi stops. and after that kodi doesn't Play anymore Video. also i Choose to Play only 1 Video file. after a restart of kodi it's the same again. the latest working "Play from here" Version was build #508.
Thanks, I've reproduced - it seems to be due to PR13721, I've reported it to the developer.
Milhouse After switching from Pi3 to Pi3+ I think.
No i do not have a manual eject. But the DVD plays fine. no issue there
This is the error I get.
Quote:LibreELEC:~ # eject -t
eject: /dev/cdrom: Input/output error
(2018-05-18, 00:28)smp1 Wrote: [ -> ]@bleep42
I just tested builds #0524 and #0525 with that file. Build #0524 does indeed perform much better.
build #0524 = ~10 skipped frames
build #0525 = ~40 skipped frames
Maybe @popcornmix could take a look at that?
Excuse my ignorance, but the last build I can find in this forum is #0517. Is there somewhere else that even newer builds are posted?
Double L
Edited my post. It is #0424 and #0425, of course.
New LibreELEC.tv Leia build #0518:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
9cccdf0a551a8dac3ce3c8d40bda7811c5b09857e8baf0a8db8ffe5a861d197e
(RPi)
SHA256 Checksum:
16913241fc69afb6df53222fba93fbfc7a746550358a2106fa286509aaa9f4f8
(RPi2)
text:
# uname -a
Linux rpi512 4.14.41 #1 Fri May 18 21:05:02 BST 2018 armv6l GNU/Linux
# vcgencmd version
May 18 2018 18:09:33
Copyright © 2012 Broadcom
version c75d403819718d12049aa2edd2009356a6cb592f (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20180518210307-#0518-gdf34f39 [Build #0518]
# Kodi version
(18.0-ALPHA2 Git:48f1632). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (df34f39,
changelog) and tip of
XBMC master (5afb532,
- Includes newclock5 patches
- Includes latest bcm2835-driver master (a46b1f9)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (6a33413, ahead +132)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (89a69b7, +4), inputstream.rtmp (8920456), peripheral.joystick (80224e1), pvr.argustv (0ed7cae), pvr.demo (20d81d8), pvr.dvblink (19c178e), pvr.dvbviewer (0ae6207), pvr.filmon (470ca1c), pvr.hdhomerun (4639740), pvr.hts (6455047), pvr.iptvsimple (c8356fc), pvr.mediaportal.tvserver (6fab703), pvr.mythtv (9d15025), pvr.nextpvr (5f8c614), pvr.njoy (5a2c2d3), pvr.octonet (54680a3), pvr.pctv (f0c28e2), pvr.stalker (a7f3e1c), pvr.teleboy (dbdc96e), pvr.vbox (48ffcba), pvr.vdr.vnsi (a2880c7), pvr.vuplus (aca7960), pvr.wmc (b62f80e), pvr.zattoo (94cc7dd), vfs.libarchive (1b00b57)
- Exclude [env] kodi-0100-temp-add-pr13594.patch: merged upstream
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: fix PR390
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2449 (perma): Adding support for AMD GPUs
- Include [env] PR:2679 (perma): eventlircd: don't grab power buttons
- Include [env] PR:2680 (perma): kodi: mid-May 2018
- Include [env] PR:2682 (perma): linux: update to linux-4.14.41
- Include [env] PR:2689 (perma): init: add sky42 enhancements/bug fixes
- Include [env] PR:2692 (perma): RPi, Generic: fix erratic IR timeout behaviour on Topseed mceusb receiver 1784:0011
- Include [env] PR:2694 (perma): Generic: allow lower IR timeouts on ITE CIR devices
- Include [env] PR:2696 (perma): linux: update ouya patch
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:13721 (perma): Std thread
- Include [pkg] PR:13904 (perma): Fix whitelistable resolutions on some platforms
Build Highlights:
- New firmware (fix rebooting, temperature reading)
- allow user to select resolutions
Build Details:
- Firmware (May 18):
- firmware: vc_image: vc_image_fill_yuv_uv sometimes overfilled the first column. See: link
- firmware: arm_loader: Add SET_NOTIFY_REBOOT message. See: link
- firmware: gencmd: Report temperature with read_ring_osc values
- LibreELEC.tv:
- buildsystem: use no-lto, when lto is disabled (PR:2685, 3 commits, 3 files changed)
- XBMC:
- allow user to select resolutions (PR:13899, 2 commits, 12 files changed)
- OSX: only load resolution of current display (PR:13903, 1 commit, 8 files changed)
- inputstream.adaptive:
- [JNI] use base JAVA class when loading DRMOnEventListener (44512f1)
- Fix decimal SSM first char / fix kidPos segfault (277fc8e)
- Fix KID length (32 -> 36), add pure hex KID (6375d29)
- Version bump 2.2.18 (89a69b7)
- Updated: [env] PR:2682 (perma): linux: update to linux-4.14.41
- Added: [pkg] PR:13904 (perma): Fix whitelistable resolutions on some platforms
the reboot errors on installing an add-on are gone with the newer version try 0518.
New LibreELEC.tv Leia build #0519:
RPi /
RPi2
SHA256 Checksum:
adb15d713e47490dd10e63ae470e15c3d8ce3b40241299d1ca7e4bda6d460b74
(RPi)
SHA256 Checksum:
7a002b069819c79e431db770cee192d27435c74ba247d6ae1f9afddf97ed1e9a
(RPi2)
text:
# uname -a
Linux rpi512 4.14.41 #1 Sat May 19 21:05:05 BST 2018 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20180519210311-#0519-g85b8697 [Build #0519]
# Kodi version
(18.0-ALPHA2 Git:5afb532). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (85b8697,
XBMC master (efe0763,
- Includes latest addons: inputstream.adaptive (eb7795e, +1), inputstream.rtmp (8920456), peripheral.joystick (80224e1), pvr.argustv (0ed7cae), pvr.demo (20d81d8), pvr.dvblink (19c178e), pvr.dvbviewer (0ae6207), pvr.filmon (470ca1c), pvr.hdhomerun (4639740), pvr.hts (6455047), pvr.iptvsimple (c8356fc), pvr.mediaportal.tvserver (6fab703), pvr.mythtv (9d15025), pvr.nextpvr (5f8c614), pvr.njoy (5a2c2d3), pvr.octonet (54680a3), pvr.pctv (f0c28e2), pvr.stalker (a7f3e1c), pvr.teleboy (dbdc96e), pvr.vbox (48ffcba), pvr.vdr.vnsi (a2880c7), pvr.vuplus (aca7960), pvr.wmc (b62f80e), pvr.zattoo (94cc7dd), vfs.libarchive (1b00b57)
Build Highlights:
- Minors
Build Details:
- LibreELEC.tv:
- create_addon: changes for jenkins specific quirks (PR:2706, 1 commit, 1 file changed)
- XBMC:
- remove --legacy-res command line argument (PR:13906, 1 commit, 3 files changed)
- remove -d (delay) command line argument (PR:13907, 1 commit, 1 file changed)
- SegmentTemplate in adpset cleanups (eb7795e)
Libreelec Leia build #518 freezes or reboot when you choose an emulator or Retroarch addon from Gamestarter. I can confirm that in build #407 was working properly.
Here my crash log
https://pastebin.com/XDJAnJwB
Greeetings
New LibreELEC.tv Leia build #0520:
RPi /
RPi2
SHA256 Checksum:
05d9a2932c0be6cfdb039b10663bc494f21264d0159a463d369ad23efdc5d2b8
(RPi)
SHA256 Checksum:
f589fece058a6a0f76e88dbb74577c90e8f52ac441676dc4d99c3611ab5df912
(RPi2)
text:
# uname -a
Linux rpi512 4.14.41 #1 Sun May 20 21:05:05 BST 2018 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20180520210312-#0520-g6a26f5d [Build #0520]
# Kodi version
Based on tip of
LibreELEC.tv master (6a26f5d,
XBMC master (f0e5a25,
- Includes latest commits from kernel branch rpi-4.14.y
- Include [pkg] PR:13909 (perma): [curl] add url option to disable peer verification
- Include [pkg] PR:13910 (perma): Media source dialog tidyup
Build Highlights:
- Resolution: Allow deviation of max 0.01 instead of 0.005
- [curl] add url option to disable peer verification
- Media source dialog tidyup
Build Details:
- LibreELEC.tv:
- RPi, Generic: fix erratic IR timeout behaviour on Topseed mceusb receiver 1784:0011 (PR:2692, 2 commits, 2 files changed)
- Generic: allow lower IR timeouts on ITE CIR devices (PR:2694, 1 commit, 1 file changed)
- rust: rework (PR:2709, 2 commits, 2 files changed)
- addon/librespot: Update to 431be (#2712) (2820ec6)
- XBMC:
- Resolution: Allow deviation of max 0.01 instead of 0.005 (PR:13908, 1 commit, 1 file changed)
- kernel 4.14.y:
- New commits in this build:
- config: Add CONFIG_MTD_BLOCK2MTD=m (3197e556)
- config: Add LZ4 compression support to arm64 kernel (#2559) (2766c5d1)
- config: Add KEYBOARD_MATRIX=m (82c4c8e6)
- Added: [pkg] PR:13909 (perma): [curl] add url option to disable peer verification
- Added: [pkg] PR:13910 (perma): Media source dialog tidyup
There are three issues for me at the moment with latest build #0520:
1. Kodi (not libreelec itself) crashed during mp3 stream playback, without any user interference:
crashlog
2. Opening local mp3 files takes several seconds, up to half a minute. Playback is fine though.
3. I've created some .pls playlists containing audio streams with let's say 4 entries. If the end of the playlist is reached (by pressing "next track") Kodi states correctly "cannot play next item", but at the same time the whole (local) playlist is wiped and I have to reopen it.
Tell me if I can give more details about the issues.
Best regards.
(2018-05-21, 15:19)thent Wrote: [ -> ]2. Opening local mp3 files takes several seconds, up to half a minute. Playback is fine though.
Is this a new issue in latest build?
If not then was it better in an older build? Identifying the first build with the issue is very useful.
(2018-05-21, 16:23)popcornmix Wrote: [ -> ]Is this a new issue in latest build?
Sorry, my bad. Files are shared with SMB, first affected build is #0329.
New LibreELEC.tv Leia build #0521:
RPi /
RPi2
SHA256 Checksum:
7d47a34cd14b822aa49bb2b69a3873aef3671e8794177044f032558d29a3802f
(RPi)
SHA256 Checksum:
65390ea3fe56e0f8e844554c0d43a5703d46085d4b8110df41939245dfa4364d
(RPi2)
text:
# uname -a
Linux rpi512 4.14.42 #1 Tue May 22 00:37:54 BST 2018 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20180522003559-#0521-g1626fdb [Build #0521]
# Kodi version
(18.0-ALPHA2 Git:19eb19e). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (1626fdb,
XBMC master (19eb19e,
- Includes latest bcm2835-driver master (6a3ac30)
- Includes latest addons: inputstream.adaptive (afa81ef, +3), inputstream.rtmp (8920456), peripheral.joystick (80224e1), pvr.argustv (0ed7cae), pvr.demo (20d81d8), pvr.dvblink (19c178e), pvr.dvbviewer (0ae6207), pvr.filmon (470ca1c), pvr.hdhomerun (4639740), pvr.hts (6455047), pvr.iptvsimple (c8356fc), pvr.mediaportal.tvserver (6fab703), pvr.mythtv (9d15025), pvr.nextpvr (5f8c614), pvr.njoy (5a2c2d3), pvr.octonet (54680a3), pvr.pctv (f0c28e2), pvr.stalker (a7f3e1c), pvr.teleboy (dbdc96e), pvr.vbox (48ffcba), pvr.vdr.vnsi (a2880c7), pvr.vuplus (aca7960), pvr.wmc (b62f80e), pvr.zattoo (94cc7dd), vfs.libarchive (1b00b57)
- Include [env] PR:2682 (perma): linux: update to linux-4.14.42
- Include [env] PR:2714 (perma): Xorg package bumps
- Include [env] PR:2715 (perma): multimedia-tools: add-on update
Build Highlights:
- New 4.14.42 kernel
- Bump alsa-utils, alsa-lib, xorg
Build Details:
- LibreELEC.tv:
- config/graphic: reset variables when calling get_graphicsdrivers() (PR:2711, 4 commits, 1 file changed)
- XBMC:
- [GUI] Invalidate underlying windows if modal dialog close (PR:13905, 2 commits, 2 files changed)
- Fixed for Limited Range (PR:13912, 4 commits, 5 files changed)
- AE: Reenable AESinkOSS on FreeBSD (PR:13793, 2 commits, 10 files changed)
- [DASH] fix double base path (a9dbb2b)
- Parse Audio adaptationset default and original attributes (afa81ef)
- Updated: [env] PR:2680 (perma): kodi: mid-May 2018
- Updated: [env] PR:2682 (perma): linux: update to linux-4.14.42
- Added: [env] PR:2714 (perma): Xorg package bumps
- Added: [env] PR:2715 (perma): multimedia-tools: add-on update
- Updated: [pkg] PR:13909 (perma): [curl] add url option to disable peer verification
(2018-05-21, 17:18)thent Wrote: [ -> ]Sorry, my bad. Files are shared with SMB, first affected build is #0329.
Only change in that build that looks possible is
PR13699
Anyone else seeing the slow opening of mp3 files?
