(2018-06-02, 03:01)vbat99 Wrote: [ -> ]I read this thread daily ( or more), and have a issue someone might have come across
Clean install of Libreelec 8.2.5 Pi2 ( for a new Pi 3B+).
Set up basics, ssh, host name.
Then placed new Milhouse 1st June 2018 rpi2 tar into update folder.
Reboot, and kodi updated successfully.
But, I can not install any add-ons. Every one fails with dependency failed. Does not matter if its a skin, HD Trailer addon, or Netflix (which is what I am after)
Rolled backwards a couple of Milhouse versions, but issue still exists.
So, placed LibreElec 8.2.5 into update folder, and rebooted.
Ta da, can install add-ons perfectly.
Update to #0601 Milhouse, and nope, fails any add-on with depencencys.
Oh, and on start of Milhouse #0601 I see a message remote communication server failed to start, but not on 8.2.5
I know, no log - didn't happen. Just damn tired right now, and thought someone might have an idea what the heck is going on with my system.
I am stumped.
Tried again this morning, clean install of LibreElec 8.2.5, left all settings as default but turned on SSH.
Dropped Milhouse Alpha #0601 into update folder and rebooted.
First error is
Remote Communication server failed to start
Then attempted to install addon HD-Trailer.Net, failed.
Log file here
http://ix.io/1c8h
As I mentioned above, clean install of 8.2.5 only and I do not get any error of remote communication, and I can install addon's without issue.
And by clean install, SD Card written with libreelec SD Creator.
Help me Obi-wan, someone...anyone?
(2018-06-02, 23:28)vbat99 Wrote: [ -> ]Tried again this morning, clean install of LibreElec 8.2.5, left all settings as default but turned on SSH.
First error is Remote Communication server failed to start
Log file here http://ix.io/1c8h
Can you try enabling "Wait for network" if you haven't already? Kodi is starting and you don't have a working network connection, so network requests are failing.
Omg, such a simple change and no error. And add-ons are installing.
Assume this something similar to window booting on ssd drive and network not up yet.
But, why this is OK on libreelec 8.2.5? Suppose cause these are alpha test builds.
Thank you so much.
New LibreELEC.tv Leia build #0602:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
e9a1b47487b248f47fdb86c7e3975c95cc420a71c9c113c9aedcdc432c7cc554
(RPi)
SHA256 Checksum:
2a54f99997412b5136cd8e0ac68ed240278dcce53f833b7f8e2cca6ff0f4c605
(RPi2)
text:
# uname -a
Linux rpi512 4.14.44 #1 Sat Jun 2 22:32:48 BST 2018 armv6l GNU/Linux
# vcgencmd version
Jun 1 2018 14:05:47
Copyright © 2012 Broadcom
version 478d13bd2bb41a9c77c03d981a23b31e872b3683 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20180602222909-#0602-g330aad4 [Build #0602]
# Kodi version
(18.0-ALPHA2 Git:593949a). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (330aad4,
changelog) and tip of
XBMC master (f3a810a,
- Includes newclock5 patches
- Includes latest commits from kernel branch rpi-4.14.y
- Includes latest bcm2835-driver master (0bef3cb, ahead +2)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (6a33413, ahead +132)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (babcca4), inputstream.rtmp (b8e3f39), peripheral.joystick (80224e1), pvr.argustv (2bce465), pvr.demo (20d81d8), pvr.dvblink (a87258b), pvr.dvbviewer (884b732), pvr.filmon (470ca1c), pvr.hdhomerun (4639740), pvr.hts (4f7196d), pvr.iptvsimple (e220777), pvr.mediaportal.tvserver (c4e32b0), pvr.mythtv (9d15025), pvr.nextpvr (78a80de), pvr.njoy (5a2c2d3), pvr.octonet (54680a3), pvr.pctv (17c1897), pvr.stalker (0700069), pvr.teleboy (3e9e537), pvr.vbox (48ffcba), pvr.vdr.vnsi (a2880c7), pvr.vuplus (6c94eec), pvr.wmc (a7ec576), pvr.zattoo (73891b1, +1), vfs.libarchive (84a4876)
- Exclude [env] kodi-0100-temp-add-pr13594.patch: merged upstream
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: fix PR390
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2449 (perma): Adding support for AMD GPUs
- Include [env] PR:2696 (perma): linux: update ouya patch
- Include [env] PR:2725 (perma): Python2: update to Python2-2.7.15, bump Python-related packages
- Include [env] PR:2729 (perma): linux: update to linux-4.14.44
- Include [env] PR:2731 (perma): enable LTO only for selected packages
- Include [env] PR:2742 (perma): scripts/image: add BUILDER_NAME, BUILDER_VERSION support
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:100 (perma): stats: Replace CPU 32/64 bit flag with GPU enumeration (service.libreelec.settings)
- Include [pkg] PR:13904 (perma): Fix whitelistable resolutions on some platforms
- Include [pkg] PR:13968 (perma): add video settings for HDR tone mapping
- Include [pkg] PR:13970 (perma): [guiinfo] Fix: 'Skin.String(string1, string2)' did not work if string2 was empty.
Build Highlights:
- VideoPlayer: update renderer after a resolution change
- add video settings for HDR tone mapping
Build Details:
- LibreELEC.tv:
- Move partition labels to distro options (PR:2730, 6 commits, 11 files changed)
- NSS/NSPR update to 3.37.1/4.19 (PR:2733, 1 commit, 5 files changed)
- openssl: fix host build (PR:2743, 1 commit, 1 file changed)
- kodi: mid-May 2018 (PR:2680, 13 commits, 41 files changed)
- scripts/image: pass BOOTLABEL and DISKLABEL to mkimage (PR:2746, 1 commit, 1 file changed)
- busybox: assign copyright to Team LE (PR:2747, 1 commit, 1 file changed)
- XBMC:
- Games: Compiler warning and typo fixes (PR:13962, 5 commits, 24 files changed)
- VideoPlayer: vdpau - fix deepcopy of VideoPictue (PR:13964, 1 commit, 1 file changed)
- VideoPlayer: update renderer after a resolution change (PR:13971, 1 commit, 1 file changed)
- pvr.zattoo:
- Improve handling of recordings (73891b1)
- Updated: [env] PR:2725 (perma): Python2: update to Python2-2.7.15, bump Python-related packages
- Updated: [env] PR:2742 (perma): scripts/image: add BUILDER_NAME, BUILDER_VERSION support
- Updated: [pkg] PR:100 (perma): stats: Replace CPU 32/64 bit flag with GPU enumeration (service.libreelec.settings)
- Added: [pkg] PR:13968 (perma): add video settings for HDR tone mapping
- Added: [pkg] PR:13970 (perma): [guiinfo] Fix: 'Skin.String(string1, string2)' did not work if string2 was empty.
(2018-06-02, 15:20)smp1 Wrote: [ -> ] (2018-06-02, 12:06)popcornmix Wrote: [ -> ]Does adding safe_mode_gpio=16 to config.txt and rebooting make any difference?
No, still very unstable.
Can you instead try sdram_schmoo=0x0200002b for now. We think we know which change caused the issue and this change should undo it.
(2018-06-03, 01:39)popcornmix Wrote: [ -> ]Can you instead try sdram_schmoo=0x0200002b for now. We think we know which change caused the issue and this change should undo it.
I ran 1 pass of memtester, it seem to be stable with sdram_schmoo=0x0200002b.
(2018-06-02, 21:03)smp1 Wrote: [ -> ] (2018-06-02, 20:53)polo_joe Wrote: [ -> ]Is there anything that can be done to solve the issue with artefacts in livetv when bt audio is activated?
Does this happen with 8.2.5?
Yes, same behaviour with 8.2.5.
(2018-06-03, 02:18)smp1 Wrote: [ -> ]I ran 1 pass of memtester, it seem to be stable with sdram_schmoo=0x0200002b.
Okay, the change has now been reverted for now. Make sure you remove the "2b" change when updating tonight.
(2018-05-31, 23:37)Milhouse Wrote: [ -> ]New LibreELEC.tv Leia build #0531:
I don’t know what changed it, but since this build the wifi stability is a 100% better!
aaaahhhhhh, installed #0206 and i get this:
is teure a way to to rescue the system? i use it for about one year and it is complex conifgurated.
thx
Just installed #602 on my RaPi2. Everything seems to run fine, exect the shortcuts in "videos" and "programs" are gone. No possibility to create them. So I downgraded to #601 and they are back again.
Regards oliaros
(2018-06-03, 11:56)heinzgruber Wrote: [ -> ]aaaahhhhhh, installed #0206 and i get this:
thx
I assume you mean #0602- see
this post.
Edit: Put your SD card in a PC, edit config.txt (root of the SD card) and add
. This issue will be fixed in #0603, when you can remove the line from config.txt.
Since 602 I cannot change the view type of my fullscreen info in live TV
bevor it was possible.
Also on AEON.Nox.5 it did not work anymore. Going back to 601 and it work again.
I haven't been following daily updates recently - 3D ISO wasn't working for a while. Today I updated to current #0602. My old problems 3D ISO playback and 1080i video stuttering are solved
I have new problem. Don't know if this was discussed earlier but on the upgrade Kodi updated my local movie database. Some new movies were not scanned into database at all. I try to rename files, select both scrapers The Movie Database and Universal Movie Scraper without any success. If I select Info in file browser I'm getting pup up with "Loading movie details" and "No information found" and file name. I used to get manual entry box where I could adjust title. All I can do now is click OK and back for file list. Those movies don't show up in movie list. The same applies to #0601.
Any ideas?
