FIle : LibreELEC-RPi2.arm-9.0-Milhouse-20180610210406-#0610-g783ddf0.tar (skin Aeon MQ7) RPI3
Impossible to read a music directory.
When I go to context menu on the directory and I ask to play (all the directory) Kodi stops. LibreElec reboots after many seconds.
(2018-06-11, 14:31)Jacques56 Wrote: [ -> ]FIle : LibreELEC-RPi2.arm-9.0-Milhouse-20180610210406-#0610-g783ddf0.tar (skin Aeon MQ7) RPI3
Test with stock Estuary.
You should have a crashlog, please upload it.
New LibreELEC.tv Leia build #0611:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
ed2be0c2b62cdcddf0063bfb1e235a559ece5fe4117338299a6eeb4f644bd1b2
(RPi)
SHA256 Checksum:
c514199a8cface046cc569cbea701741378b863aa7d1cc955152a82a737e5943
(RPi2)
text:
# uname -a
Linux rpi512 4.14.48 #1 Mon Jun 11 21:45:50 BST 2018 armv6l GNU/Linux
# vcgencmd version
Jun 7 2018 15:37:30
Copyright © 2012 Broadcom
version 4800f08a139d6ca1c5ecbee345ea6682e2160881 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20180611214421-#0611-gb7a1c2c [Build #0611]
# Kodi version
(18.0-ALPHA2 Git:37f55e6). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (b7a1c2c,
changelog) and tip of
XBMC master (8e7b085,
- Includes newclock5 patches
- Includes latest commits from kernel branch rpi-4.14.y
- Includes latest bcm2835-driver master (7884178)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (6a33413, ahead +132)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (27ddff1, +2), inputstream.rtmp (b8e3f39), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (bcd8289), pvr.dvblink (1732e4b), pvr.dvbviewer (986b1ba), pvr.filmon (ba261c9), pvr.hdhomerun (379c62c), pvr.hts (f569808), pvr.iptvsimple (663040c), pvr.mediaportal.tvserver (01af5a0), pvr.mythtv (c18ca9e), pvr.nextpvr (fad3ca9), pvr.njoy (30743c6), pvr.octonet (1e44819), pvr.pctv (d0c7241), pvr.stalker (00f3fc4), pvr.teleboy (dfa68b0), pvr.vbox (d2e61a9), pvr.vdr.vnsi (18c7474), pvr.vuplus (bcfd34d), pvr.wmc (ce4b47a), pvr.zattoo (286ce5f, +1), vfs.libarchive (84a4876)
- Include [env] compare (perma): init: strip leading / from BOOT_IMAGE & DISK_IMAGE, normalising for all projects
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: fix PR390
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2449 (perma): Adding support for AMD GPUs
- Include [env] PR:2725 (perma): Python2: update to Python2-2.7.15, bump Python-related packages
- Include [env] PR:2742 (perma): scripts/image: add BUILDER_NAME, BUILDER_VERSION support
- Include [env] PR:2760 (perma): sqlite build shared
- Include [env] PR:2764 (perma): kodi: June 2018
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:100 (perma): stats: Replace CPU 32/64 bit flag with GPU enumeration (service.libreelec.settings)
Build Highlights:
- GUILib cleanups & optimizations & dead code removal
Build Details:
- LibreELEC.tv:
- mesa: change to use meson and update (PR:2739, 9 commits, 6 files changed)
- Xorg server 1.20 update (PR:2651, 4 commits, 47 files changed)
- XBMC:
- GUILib cleanups & optimizations & dead code removal (PR:14006, 19 commits, 29 files changed)
- VideoPlayer: vaapi - fix quirk for mesa (PR:14013, 1 commit, 1 file changed)
- Various CMatrixGL optimizations (PR:14014, 22 commits, 19 files changed)
- MMALCodec: Initialise iRepeatPicture (PR:13993, 1 commit, 1 file changed)
- Game OSD: Add "Advanced settings" button to settings list (PR:14008, 1 commit, 16 files changed)
- ADD: [droid] support for binary addons by repo (PR:13624, 1 commit, 5 files changed)
- inputstream.adaptive:
- XBMC_ANDROID_APK -> KODI_ANDROID_APK (f5b47e5)
- Version bump 2.2.22 (27ddff1)
- pvr.zattoo:
- Fix loading recordings data (286ce5f)
- newclock5:
- New commits in this build:
- ffmpeg: hevc: Latest updates from Ben (97e11fe6)
- Commits no longer in build:
- DVDVideoCodec: Initialise VideoPicture fields to zero (2c8c26bd)
- Revert "DVDVideoCodec: Initialise VideoPicture fields to zero" (b3bde719)
- DVDVideoCodec: Initialise VideoPicture fields to zero (simpler) (1bfe1587)
- MMALCodec: Initialise iRepeatPicture (e482c2a3)
- Revert "DVDVideoCodec: Initialise VideoPicture fields to zero (simpler)" (5fa5e500)
Milhouse
there is a problem with the keyboard layout. It stays at english qwerty, despite changes I made in settings.
Settings are "de" in LibreELEC settings panel and "german qwertz" in Kodi User-Interface.
So "z" becomes "y" and vice versa, no umlauts like "ö" which is ";" .
you have to deselect English in the settings I think
I've just done some fiddling with this.
I installed the latest build (#0611). At first, I had the same errors, along with the system crashing a couple of times when I loaded the add ons.
Then I got YouTube working (can't get the parental controls to shut off, but I that's nothing to do with the build).
I tried snapshotting the log files before I tried them all again, and for some reason Netflix started working. I installed the Chrome browser and after another crash, it worked fine. Trying running a video, and the playback is stuttering a quite a bit, but it is working. I've tried switching to thernet (was using wireless), and it's a little bit better but not great. (I've just done a quick speed test and I'm getting 52mbs download, so my internet is running fine through other devices).
Amazon Prime is now running absolutely perfectly with no stuttering so far, but I only watched a few minutes to check it worked.
PVR is also playing. The TV guide isn't showing the channel list on any of the channel lists I've found, but I'm happy with the full UK freeview list I found. It also stopped playing after a little while when I pressed back, but I've got it working once.
I haven't tried any emulators yet.
But so far, this build seems to be pretty good
(2018-06-12, 19:46)tjost Wrote: [ -> ]you have to deselect English in the settings I think
well, LE/Kodi is set to german, keyboard, gui language, etc.. It was working before, but I still had no time to dig deeper, to find the last working version. I stumbled over this because I pressed "z" for zoom but got the "videoplayer"popup (which pops up on "y").
(2018-06-10, 02:03)Milhouse Wrote: [ -> ] (2018-06-10, 01:05)Germeleon Wrote: [ -> ]@Milhouse: Was it possible for you to reproduce my issues? Is there anything I can do fixing it?
Which issue(s) are still an issue?
1) The keyboard layout? Question: What keyboard layout are you configuring?
2) Zattoo - sorry can't help, contact the addon maintainer via github
3) Amazon - is this still an issue? Working fine for me but I use plugin.video.prime_instant. Probably best to contact your Amazon addon maintainer if it's not working.
Milhouse :
Sorry for the delay, here are the answers to your "numeric bullet points" mentioned above (sorry for my bad english):
1.) In short, I have the same problem like @
-DH- : My kodi is set to german, the keyboard map is "de-latin1-nodeadkeys". But the keyboard map stucks/is being set to QWERTY.
2.) The problem has been fixed by rolapp (the "Zattoo HiQ" author).
3.) The Amazon issue is fixed, there are no freezes with build #0610 thanks!
New LibreELEC.tv Leia build #0612:
RPi /
RPi2
SHA256 Checksum:
ed498130e76232289c08ba269557cfd5ab37428607e82b4c1d04eb36d73f75e5
(RPi)
SHA256 Checksum:
7d5a1bbea06dfdbaeb1f5380ea52294b03a57d00f58b8c525c3cf0554040442b
(RPi2)
text:
# uname -a
Linux rpi512 4.14.48 #1 Tue Jun 12 21:06:06 BST 2018 armv6l GNU/Linux
# vcgencmd version
Jun 7 2018 15:37:30
# lsb_release
LibreELEC (Milhouse): devel-20180612210431-#0612-g5c61c7b [Build #0612]
# Kodi version
Based on tip of
LibreELEC.tv master (5c61c7b,
XBMC master (cb76728,
- Includes latest libcec master (8adc786)
- Includes latest addons: inputstream.adaptive (4705d59, +4), inputstream.rtmp (b8e3f39), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (bcd8289), pvr.dvblink (1732e4b), pvr.dvbviewer (986b1ba), pvr.filmon (ba261c9), pvr.hdhomerun (379c62c), pvr.hts (f569808), pvr.iptvsimple (663040c), pvr.mediaportal.tvserver (01af5a0), pvr.mythtv (c18ca9e), pvr.nextpvr (fad3ca9), pvr.njoy (30743c6), pvr.octonet (1e44819), pvr.pctv (d0c7241), pvr.stalker (00f3fc4), pvr.teleboy (dfa68b0), pvr.vbox (d2e61a9), pvr.vdr.vnsi (18c7474), pvr.vuplus (bcfd34d), pvr.wmc (ce4b47a), pvr.zattoo (e72598d, +2), vfs.libarchive (84a4876)
- Include [env] PR:2770 (perma): init: strip leading / from BOOT_IMAGE & DISK_IMAGE, normalising for all projects
Build Highlights:
- [PVR][VideoPlayer] Rework and simplify DVDInputStreamPVRManager.
- Reusepython (#13814)
Build Details:
- LibreELEC.tv:
- fix updating on android bootloader devices (PR:2767, 1 commit, 1 file changed)
- sqlite build shared (PR:2760, 3 commits, 4 files changed)
- iptables: fix README for saving rules (PR:2768, 1 commit, 1 file changed)
- debug_strip: use strip in PKG_BUILD_FLAGS (PR:2771, 1 commit, 2 files changed)
- XBMC:
- [PVR][VideoPlayer] Rework and simplify DVDInputStreamPVRManager. (PR:14015, 1 commit, 18 files changed)
- Space out order value of library nodes (PR:11017, 1 commit, 79 files changed)
- Header cleanup (PR:14020, 9 commits, 1645 files changed)
- Whitespace (PR:14021, 8 commits, 925 files changed)
- RendererDRMPRIME: release video buffers after flush (PR:13978, 3 commits, 4 files changed)
- [Estuary] Fix header of rating dialog in skin settings (PR:14025, 1 commit, 1 file changed)
- Reusepython (#13814) (57d64c1)
- pvr.zattoo:
- Fix deadlock due to missing mutex.unlock() (e72598d)
- newclock5:
- [ffmpeg] Add GPU acceleration to hevc (58f1d2ea)
- ffmpeg: hevc: Rebase to ffmpeg 4 (cf4d88a5)
- ffmpeg: hevc: Latest updates from Ben (02c6e500)
- ffmpeg: hevc: Fixes for ffmpeg 4 (73cfcd5b)
- ffmpeg: MVC: fixup for ffmpeg4 (6132fe95)
- ffmpeg: hevc: Fix performance regression + latest ben optimisations (1941a05f)
- ffmpeg: Add -mfpu=neon to configure (077b6b8a)
- kernel 4.14.y:
- config: Add CONFIG_SPI_GPIO (6d887d03)
- config: Add CONFIG_NET_IPVTI=m (22cd4eaa)
- Updated: [env] PR:2764 (perma): kodi: June 2018
- Added: [env] PR:2770 (perma): init: strip leading / from BOOT_IMAGE & DISK_IMAGE, normalising for all projects
(2018-06-12, 20:43)-DH- Wrote: [ -> ] (2018-06-12, 19:46)tjost Wrote: [ -> ]you have to deselect English in the settings I think
Can you compare build
#0429 with
#0428? #0429 is when we
updated libinput.
Can you also compare
#0423 with
#0422? #0423 includes
PR13176 which adds the libinput backend for non window system platforms.
You may need to confirm or reconfigure your keyboard settings with each build, as the settings may not migrate correctly when upgrading or downgrading. It may also be worth rebooting after changing keyboard layout.
Edit: Also try comparing
#0302 with
#0301 but be warned: these #030x builds will not boot the Pi3+ (as they pre-date the Pi3+ launch).
I’m getting menu problems on some of my addons again with the latest build. I’m assuming it’s due to the python reuse thing. On github it says there is a way to disable it in addon.xml. But which addon.xml, and what is the command?
EDIT: nevermind, figured it out.
My addon searches are working again. Not sure exactly which build, but one of the last few.
If I "Resume at xx:xx:xx" a DVD/ISO movie (using OMXplayer), the OMXplayer crash.
This problem is very old. Hope someone can fix it.
All movie format played and resumed with MMAL is working fine.
The problem is only when resuming a DVD/ISO, and using OMXplayer.
Best regards
Crash & restart when playing folder with FLAC music files. #0611
I've been experiencing this on and off over the past couple of weeks but haven't been able to repeat reliably it until now. I go to Music > Files > Music NAS (the name I gave the Music folder on my SMB NAS) and then select an album folder and try to play it by pressing the 'P' key. KODI looks like it is going to play the first track but then the screen goes dark and a few seconds later reboots. I can play the same files OK if I open the folder and then select the first track.
Kodi log:
http://ix.io/1dd9
Kodi crash log:
http://ix.io/1dda
