(2018-06-29, 15:46)HiassofT Wrote: [ -> ] (2018-06-28, 18:13)ramis52 Wrote: [ -> ]Hi,
now my remote is acting wierd again. A reboot/powercycle will help. here are the log files.
lsusb http://ix.io/1fiv
dmesg and journalctl before the reboot
http://ix.io/1fig
http://ix.io/1fih
output from ssh1
https://pastebin.com/Nj41U98t
output from ssh2
LibreELEC:~ # ir-keytable -t
Can't open lirc device: Device or resource busy
LibreELEC:~ #
hope this helps a bit.
@ramis52 Thanks for the info!
The IR receiver indeed is doing weird things. It sends nonsense data (even when it seems to be working) and the ir-ctl -r output shows that it somehow "forgot" it's timeout setting.
Please do another test with the build you've been using (any current build up to and including #0628 will do):
use the IR remote for a while, verify that it's working fine, then ssh in, run
then press a button and post the output (no need to stop kodi etc). Please also upload dmesg again.
Tonight's build will contain a patch that disables the IR timeout optimizations for your IR receiver. Please test and report back if this build fixes the issues. If it fails, run the "ir-ctl -r" test and post dmesg and journal.
so long,
Hias
here a the outputs
https://pastebin.com/Uj4d16az
http://ix.io/1ft2
I ll try newest build now and report back when its acting wierd again.
(2018-06-08, 19:24)Milhouse Wrote: [ -> ] (2018-06-08, 19:06)germa18 Wrote: [ -> ]the latest working build = #0407
other newer build have this trouble = since #0415
I think i have found the problem, it's related to expression after the url that cause the bug
Exemple :
Link not working on LE : https://proxy-035.ix7.dailymotion.com/se...os_stail=1
Link working on LE : https://proxy-035.ix7.dailymotion.com/se...ac_hd.m3u8
The only difference is the expression after the .m3u8 is misinterpreted by kodi [#cell=core&qos_stail=1] , all the links on this plateform/website are generated like that, so to correct that we must force kodi to not took anything after .m3u8
original link of the video : https://www.dailymotion.com/video/x6law2...ist=x5uiot
You can easily reproduce this, i hope my explaination is understable
Can you post a complete debug log from #0607 (or whatever the latest test build is at the time) which shows you accessing the "not working" url?
Your non-working url is working for me (using JSON):
text:
texturecache.py playw "https://proxy-035.ix7.dailymotion.com/sec(x012cba8530cb5d575ec783f5b1b6ce0)/video/811/775/398577118_mp4_h264_aac_hd.m3u8#cell=core&qos_stail=1"
which might suggest it is an add-on issue or something else specific to your setup.
It's been a long time that i was stuck with #0407 firmware because of this issue and today i decided to test the #0628 build and now all works without any change by my side
but i noticed that in the changelog in the #0628 build that inpustream has been rework (with the change of kodi api), so there were a bug like i told you before
glad that all working fine now
New LibreELEC.tv Leia build #0630:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
eee8cdfae51c55e9429b3a8f7d5726c15897073c9682c20e71124983b20599e2
(RPi)
SHA256 Checksum:
9a0ac882208cf6df34a9bbbac84fea61acbbe921c6c44745ce45dbdef132a7fd
(RPi2)
text:
# uname -a
Linux rpi512 4.14.52 #1 Sat Jun 30 21:04:35 BST 2018 armv6l GNU/Linux
# vcgencmd version
Jun 29 2018 13:17:42
Copyright © 2012 Broadcom
version 97765855d9ae607d0e678171cf9d83b218f237dd (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20180630210315-#0630-g3e3cc3d [Build #0630]
# Kodi version
(18.0-ALPHA3 Git:95de5f5). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (3e3cc3d,
changelog) and tip of
XBMC master (8063088,
- Includes newclock5 patches
- Includes latest commits from kernel branch rpi-4.14.y
- Includes latest bcm2835-driver master (93683f1, ahead +2)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786)
- Includes latest libnfs master (fa6d63c, ahead +1)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (16a4043, +7), inputstream.rtmp (bf5351e, +1), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (481f2fa, +1), pvr.dvblink (1732e4b), pvr.dvbviewer (fccf48a, +7), pvr.filmon (b41ef25, +1), pvr.hdhomerun (29cb0df, +1), pvr.hts (f569808), pvr.iptvsimple (7db634b, +1), pvr.mediaportal.tvserver (6845fa4, +1), pvr.mythtv (c18ca9e), pvr.nextpvr (6f01a4b, +3), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv (d1aaaa9, +1), pvr.stalker (1a01bc9, +1), pvr.teleboy (0460536, +1), pvr.vbox (8244f9a, +1), pvr.vdr.vnsi (18c7474), pvr.vuplus (e2efab9, +1), pvr.wmc (ce4b47a), pvr.zattoo (baeb316, +3), vfs.libarchive (1bc1517, +1)
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2742 (perma): scripts/image: add BUILDER_NAME, BUILDER_VERSION support
- Include [env] PR:2772 (perma): linux (RPi): update to linux-4.14.52
- Include [env] PR:2788 (perma): kodi: July 2018
- Include [env] PR:2791 (perma): systemd: update to 239
- Include [env] PR:2798 (perma): linux (Generic): update to linux-4.17.3
- Include [env] PR:2799 (perma): [getedid] Add AMD support and react on used kernel
- Include [env] PR:2801 (perma): mesa: only build va tracker if using a gallium driver that uses it
- Include [env] PR:2803 (perma): debug: dependencies don't build with debug by default. use + suffix to enable
- Include [env] PR:2805 (perma): ffmpeg: install ffmpeg from ffmpeg-tools, don't include in image
- Include [env] PR:2807 (perma): linux (RPi): disable IR timeout improvement on Formosa e017 receiver
- Include [pkg] PR:100 (perma): stats: Replace CPU 32/64 bit flag with GPU enumeration (service.libreelec.settings)
Build Highlights:
- AESinkPULSE: Fix enumeration callback
- Fix ocassional playback in background
- VideoPlayer: fixes for discarding streams
Build Details:
- XBMC:
- AESinkPULSE: Fix enumeration callback (PR:14133, 1 commit, 1 file changed)
- Fix ocassional playback in background (PR:14130, 1 commit, 1 file changed)
- VideoPlayer: fixes for discarding streams (PR:14127, 1 commit, 2 files changed)
- kernel 4.14.y:
- New commits in this build:
- arm: dts: bcm2710-rpi-3-b-plus: fix hpd gpio pin (72f72b6c)
New LibreELEC.tv Leia build #0701:
RPi /
RPi2
SHA256 Checksum:
f862c4c080eb0318e493773ff10e6a623036983e1e37afeea896b87d85df2a80
(RPi)
SHA256 Checksum:
511cbddc3a4ae170e629db60324efac7431399dd09013185fa019ac8d99c740b
(RPi2)
text:
# uname -a
Linux rpi512 4.14.52 #1 Sun Jul 1 21:05:42 BST 2018 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20180701210317-#0701-g3e3cc3d [Build #0701]
# Kodi version
Based on tip of
XBMC master (17459bb,
- Include [env] PR:2808 (perma): Revert "dash: add package, configure as CONFIG_SHELL"
- Include [env] PR:2809 (perma): config/functions: store package caches in build dir
Build Highlights:
- Revert dash, fix package cache
Build Details:
- XBMC:
- VideoPlayer: handle tempo and realtime dynamically (PR:14134, 2 commits, 11 files changed)
- allow selecting resolutions with non standard aspect ratio (PR:14132, 1 commit, 5 files changed)
- Added: [env] PR:2808 (perma): Revert "dash: add package, configure as CONFIG_SHELL"
- Added: [env] PR:2809 (perma): config/functions: store package caches in build dir
New LibreELEC.tv Leia build #0702:
RPi /
RPi2
SHA256 Checksum:
c22daca7352ba5d87d4a307b2161e3c2c5e139687afa2f9529c88efe123b85b7
(RPi)
SHA256 Checksum:
477f9f7f90bb22872e18a40e750fe1f64812fc240a8a73c6809ac7fb95fb4b3a
(RPi2)
text:
# uname -a
Linux rpi512 4.14.52 #1 Mon Jul 2 23:37:31 BST 2018 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20180702233607-#0702-g6bd47f0 [Build #0702]
# Kodi version
Based on tip of
LibreELEC.tv master (6bd47f0,
XBMC master (a44e6e2,
- Includes latest addons: inputstream.adaptive (16a4043, +7), inputstream.rtmp (bf5351e, +1), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (481f2fa, +1), pvr.dvblink (c66203b, +1), pvr.dvbviewer (89344b4, +9), pvr.filmon (93ae10d, +2), pvr.hdhomerun (ced70bd, +2), pvr.hts (83451d3, +2), pvr.iptvsimple (c721c03, +2), pvr.mediaportal.tvserver (6439be6, +2), pvr.mythtv (c4d8899, +5), pvr.nextpvr (6f0515b, +4), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv (32d4b66, +2), pvr.stalker (6026419, +2), pvr.teleboy (0460536, +1), pvr.vbox (325774b, +2), pvr.vdr.vnsi (18c7474), pvr.vuplus (75179a3, +2), pvr.wmc (ec652db, +1), pvr.zattoo (baeb316, +3), vfs.libarchive (1bc1517, +1)
- Include [pkg] PR:14137 (perma): addondb: avoid constraint violation
Build Highlights:
- Fix segfault on shutdown caused by busy python addons
- Loadsa lang updates
Build Details:
- LibreELEC.tv:
- config/functions: store package caches in build dir (PR:2809, 1 commit, 1 file changed)
- Revert "dash: add package, configure as CONFIG_SHELL" (PR:2808, 1 commit, 4 files changed)
- mesa: only build va tracker if using a gallium driver that uses it (PR:2801, 1 commit, 1 file changed)
- valgrind: add patch to enable armv8 (PR:2802, 1 commit, 1 file changed)
- XBMC:
- Fix segfault on shutdown caused by busy python addons (PR:14138, 1 commit, 3 files changed)
- RetroPlayer: Fix segfault on subsequent failure (PR:14101, 1 commit, 1 file changed)
- [lang][kodi.core] automatic syntax corrections for the en_GB language file (2656577)
- [lang][skin.estuary] automatic syntax corrections for the en_GB language file (39f9bd5)
- [lang][skin.estuary] updated language files from Transifex (e66ca5d)
- pvr.dvblink:
- [lang] updated language files from Transifex (c66203b)
- pvr.dvbviewer:
- [lang] automatic syntax corrections for the en_GB language file (4c60fc2)
- [lang] updated language files from Transifex (89344b4)
- pvr.filmon:
- [lang] updated language files from Transifex (93ae10d)
- pvr.hdhomerun:
- [lang] updated language files from Transifex (ced70bd)
- pvr.hts:
- [lang] automatic syntax corrections for the en_GB language file (7500796)
- [lang] updated language files from Transifex (83451d3)
- pvr.iptvsimple:
- [lang] updated language files from Transifex (c721c03)
- pvr.mediaportal.tvserver:
- [lang] updated language files from Transifex (6439be6)
- pvr.mythtv:
- [lang] updated language files from Transifex (3a04d2c)
- [lang] updated language files from Transifex (c9a14a7)
- [lang] updated language files from Transifex (6a0f2a2)
- [lang] updated language files from Transifex (f0f7e6d)
- bump version 5.8.1 (c4d8899)
- pvr.nextpvr:
- [lang] updated language files from Transifex (6f0515b)
- pvr.pctv:
- [lang] updated language files from Transifex (32d4b66)
- pvr.stalker:
- [lang] updated language files from Transifex (6026419)
- pvr.vbox:
- [lang] updated language files from Transifex (325774b)
- pvr.vuplus:
- [lang] updated language files from Transifex (75179a3)
- pvr.wmc:
- [lang] updated language files from Transifex (ec652db)
- kernel 4.14.y:
- Add device tree overlay for HD44780 (a2546395)
- Add hd44780 module to defconfig (11efe457)
- Added: [pkg] PR:14137 (perma): addondb: avoid constraint violation
New LibreELEC.tv Leia build #0703:
RPi /
RPi2
SHA256 Checksum:
cc1ba7cd6efe32ff8ee9b2d1c746d4a1526f639846979bf9d87fce5663425603
(RPi)
SHA256 Checksum:
c24dd3fcb0c7284ed1ea5af503cb1494a1640826011164d6c0972008b6630ea0
(RPi2)
text:
# uname -a
Linux rpi512 4.14.52 #1 Wed Jul 4 00:20:18 BST 2018 armv6l GNU/Linux
# vcgencmd version
Jul 3 2018 14:21:36
version 47b05c853342eb6e4ea5b017d981e0ef247fb8be (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20180704001901-#0703-g6bd47f0 [Build #0703]
# Kodi version
(18.0-ALPHA3 Git:f0dda3a). Platform: Linux ARM 32-bit
Based on tip of
XBMC master (f0dda3a,
- Includes latest bcm2835-driver master (36ecc7f, ahead +3)
- Includes latest libnfs master (37d4980, ahead +3)
- Includes latest addons: inputstream.adaptive (16a4043, +7), inputstream.rtmp (bf5351e, +1), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (481f2fa, +1), pvr.dvblink (c66203b, +1), pvr.dvbviewer (89344b4, +9), pvr.filmon (93ae10d, +2), pvr.hdhomerun (ced70bd, +2), pvr.hts (83451d3, +2), pvr.iptvsimple (c721c03, +2), pvr.mediaportal.tvserver (6439be6, +2), pvr.mythtv (c4d8899, +5), pvr.nextpvr (6f0515b, +4), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv (32d4b66, +2), pvr.stalker (6026419, +2), pvr.teleboy (0460536, +1), pvr.vbox (48a1ac1, +3), pvr.vdr.vnsi (18c7474), pvr.vuplus (75179a3, +2), pvr.wmc (ec652db, +1), pvr.zattoo (baeb316, +3), vfs.libarchive (1bc1517, +1)
- Include [env] PR:2798 (perma): linux (Generic): update to linux-4.17.4
- Include [pkg] PR:10 (perma): Add new ids (RTL8812AU)
Build Highlights:
- New firmware (pwm_sdm fixes)
- reusepython off by default
- [gui][pvr][fix] Prevent the modification of the provider list while using its iterator.
Build Details:
- Firmware (Jul 3):
- firmware: pwm_sdm: fix an edge case when reading back DMA source addresses
- firmware: pwm_sdm: fix write handle refcounting See: link
- XBMC:
- [gui][pvr][fix] Prevent the modification of the provider list while using its iterator. (PR:14139, 1 commit, 2 files changed)
- [modernize] use default member initializers (PR:14111, 30 commits, 300 files changed)
- reusepython off by default (PR:14136, 1 commit, 1 file changed)
- Kodi's new and improved git docs (PR:14072, 27 commits, 72 files changed)
- libnfs:
- Wrap use of SOCK_CLOEXEC with __linux__ (PR:260, 1 commit, 1 file changed)
- conditionally include sys/time.h from libnfs.c (5c1444f)
- Merge branch 'master' of github.comahlberg/libnfs (37d4980)
- pvr.vbox:
- Fixed wrong size caused crash in Android Oreo (8) (#211) (48a1ac1)
- kernel 4.14.y:
- Arm: mm: ftrace: Only set text back to ro after kernel has been marked ro (786b6ff1)
- Updated: [env] PR:2788 (perma): kodi: July 2018
- Updated: [env] PR:2798 (perma): linux (Generic): update to linux-4.17.4
- Added: [pkg] PR:10 (perma): Add new ids (RTL8812AU)
@remis52
What happen if you turn your lights off?
Sometimes the IR sensors devices do weird things when lights on, because the frecuency filter circuit is falling or it just blown up, if it stops doing weird things or if the frequence of them decreases, your sensor is faulty, if it do the same things with lights off, it is a hw-sw realtionship issue...
Need a little help for downgrading from #703 to #702.
Copied the LibreELEC-RPi2.arm-9.0-Milhouse-20180702233607-#0702-g6bd47f0.tar to the update folder on my sdcard.
Reboot but nothing happens. No update process. Boots to Kodi #703 and crashes with a reboot.
Edit: Solution is copy *.tar to the .update folder not update folder on the sdcard!
Installed #0703 and kodi crash after short period of idle inactivity after 1st boot
kodi crashlog
kodi does not appear to be constantly crashing for me with #0703 so will attempt to use normally this evening to watch local media and internet streams.
The PR that is causing the crash will be reverted in #0704.
Thnx for all the hard work!!
New LibreELEC.tv Leia build #0705:
RPi /
RPi2
SHA256 Checksum:
3ac74b770c40594f8a0f26a5d41bded8b4e4c32c437d9d37a8ea2a6a4c470e61
(RPi)
SHA256 Checksum:
55fddf328f841db7eb6f948f1b7f9f4906d7e338099aa7198f66801899b37da6
(RPi2)
text:
# uname -a
Linux rpi512 4.14.52 #1 Thu Jul 5 21:41:40 BST 2018 armv6l GNU/Linux
# vcgencmd version
Jul 3 2018 14:21:36
# lsb_release
LibreELEC (Milhouse): devel-20180705213937-#0705-g60ee116 [Build #0705]
# Kodi version
(18.0-ALPHA3 Git:5014160). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (60ee116,
XBMC master (b5230a8,
- Includes latest addons: inputstream.adaptive (aa6c3f4, +8), inputstream.rtmp (bf5351e, +1), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (481f2fa, +1), pvr.dvblink (c66203b, +1), pvr.dvbviewer (89344b4, +9), pvr.filmon (93ae10d, +2), pvr.hdhomerun (ced70bd, +2), pvr.hts (83451d3, +2), pvr.iptvsimple (55637c8, +3), pvr.mediaportal.tvserver (6439be6, +2), pvr.mythtv (c4d8899, +5), pvr.nextpvr (6f0515b, +4), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv (32d4b66, +2), pvr.stalker (6026419, +2), pvr.teleboy (0460536, +1), pvr.vbox (48a1ac1, +3), pvr.vdr.vnsi (18c7474), pvr.vuplus (75179a3, +2), pvr.wmc (ec652db, +1), pvr.zattoo (baeb316, +3), vfs.libarchive (1bc1517, +1)
- Include [pkg] PR:101 (perma): remove all attempts to open/close the busydialog which is now verboten (service.libreelec.settings)
Build Highlights:
- Revert cause of crash in #0703
Build Details:
- LibreELEC.tv:
- retroplayer updates (PR:2810, 8 commits, 135 files changed)
- sapphire: fix build (PR:2811, 1 commit, 1 file changed)
- XBMC:
- VideoPlayer: fix c/p error in GetRGBYuvCoefs for BT2020 (PR:14142, 1 commit, 1 file changed)
- VideoPlayer: fix switching to resample method (PR:14141, 1 commit, 2 files changed)
- display resolutions: drop iScreen (PR:14140, 1 commit, 31 files changed)
- VideoPlayer: vaapi - fix potential segfault if deinterlace method is (PR:14145, 1 commit, 3 files changed)
- Revert "[gui][pvr][fix] Prevent the modification of the provider list while using its iterator." (PR:14147, 1 commit, 2 files changed)
- [Estuary] fix mono font (PR:14150, 1 commit, 1 file changed)
- display resolutions: fix after 6aaa0fa013518053105ee55da37af430b7534579 (PR:14151, 1 commit, 5 files changed)
- win10: update python package with a small fix in uwp part (PR:14153, 2 commits, 4 files changed)
- Prevent Basecontainer to scroll animated after reset (PR:14148, 1 commit, 1 file changed)
- inputstream.adaptive:
- [MPD] check MPS::type==dynamic for LIVE streams (aa6c3f4)
- pvr.iptvsimple:
- Add support for #EXT-X-PLAYLIST-TYPE in M3U (PR:189, 1 commit, 4 files changed)
- kernel 4.14.y:
- BCM283x DT: Add CSI nodes to the device tree. (7462714a)
- BCM270X_DT: Add CSI defines for all the downstream Pi platforms (e33ef2c4)
- arm: dt: Add DT overlays for ADV7282M, OV5647, and TC358743 (36d224f4)
- Updated: [pkg] PR:100 (perma): stats: Replace CPU 32/64 bit flag with GPU enumeration (service.libreelec.settings)
- Added: [pkg] PR:101 (perma): remove all attempts to open/close the busydialog which is now verboten (service.libreelec.settings)
I can not use media files within RAR, even with Archive support (999.1.0.0) and RAR archive (999.2.0.3).
I'm running build # 702 on a RPi2, but I've had this problem since I switched to the Milhouse-9.0 update channel.
Is it a known bug or is there something wrong on my side?
