Hi guys,
the addon service mpd is not starting in #0709 and nothing suspicious in the logs (
https://paste.ubuntu.com/p/BpHZY4S4Jb/)
I tried to start mpd manually and got the following error
bash:
LibreELEC:/ # /storage/.kodi/addons/service.multimedia.mpd/bin/mpd --no-daemon config/mpd.conf
/storage/.kodi/addons/service.multimedia.mpd/bin/mpd: error while loading shared libraries: libnfs.so.11: cannot open shared object file: No such file or directory
The installed version of libnfs is libnfs.so.12.
(2018-07-10, 20:41)sinkalip Wrote: [ -> ]The installed version of libnfs is libnfs.so.12.
Noted. You'll need to go back to the last working build, or wait for the next update of the LE9 repository (no, I don't know when that will be).
New LibreELEC.tv Leia build #0710:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
a60b3c385720a45f9338b7d8d226d6c141c90fc632bde457b4d92e0be10815af
(RPi)
SHA256 Checksum:
99d3426a27c9bdc970ea80585581fbcfd8858b9599d927d60953f2c9bd3e0810
(RPi2)
text:
# uname -a
Linux rpi512 4.14.54 #1 Tue Jul 10 21:04:57 BST 2018 armv6l GNU/Linux
# vcgencmd version
Jul 9 2018 19:40:55
Copyright © 2012 Broadcom
version daa7178a0900fd9a743c019f9dad7889d531e71d (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20180710210329-#0710-g2f5a3b0 [Build #0710]
# Kodi version
(18.0-ALPHA3 Git:5014160). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (2f5a3b0,
changelog) and tip of
XBMC master (93e34e5,
- Includes newclock5 patches
- Includes latest commits from kernel branch rpi-4.14.y
- Includes latest bcm2835-driver master (d3c3d03)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786)
- Includes latest libnfs master (3ba7c53, ahead +4)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (faf22f1, +9), inputstream.rtmp (bf5351e, +1), peripheral.joystick (dbdeded, +2), pvr.argustv (37a3a76), pvr.demo (481f2fa, +1), pvr.dvblink (c66203b, +1), pvr.dvbviewer (75e2447, +10), pvr.filmon (93ae10d, +2), pvr.hdhomerun (ced70bd, +2), pvr.hts (306fac5, +3), pvr.iptvsimple (55637c8, +3), pvr.mediaportal.tvserver (6439be6, +2), pvr.mythtv (c4d8899, +5), pvr.nextpvr (6f0515b, +4), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv (32d4b66, +2), pvr.stalker (6026419, +2), pvr.teleboy (0460536, +1), pvr.vbox (12e1304, +4), pvr.vdr.vnsi (18c7474), pvr.vuplus (75179a3, +2), pvr.wmc (ec652db, +1), pvr.zattoo (12134c8, +4), vfs.libarchive (1bc1517, +1)
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2772 (perma): linux (RPi): update to linux-4.14.54
- Include [env] PR:2788 (perma): kodi: July 2018
- Include [env] PR:2791 (perma): systemd: update to 239
- Include [env] PR:2798 (perma): linux (Generic): update to linux-4.17.5
- Include [env] PR:2799 (perma): [getedid] Add AMD support and react on used kernel
- Include [env] PR:2803 (perma): debug: dependencies don't build with debug by default. use + suffix to enable
- Include [env] PR:2816 (perma): bluez: bump version to 5.50
- Include [env] PR:2818 (perma): ConnMan: use UseGatewaysAsTimeservers option
- Include [pkg] PR:10 (perma): Add new ids (RTL8812AU)
- Include [pkg] PR:14137 (perma): addondb: avoid constraint violation
- Include [pkg] PR:14160 (perma): [JSON]Faster access to music library
- Include [pkg] PR:14166 (perma): Fix Install from zip from addon view
Build Highlights:
- kernel: overlay and vc4 fixes
Build Details:
- XBMC:
- Fix erratic input when entering cheat code (PR:14161, 1 commit, 4 files changed)
- peripheral.joystick:
- [cocoa] Add libretro mappings for all controllers (PR:146, 1 commit, 1 file changed)
- Optimize controller transformer memory usage (PR:147, 1 commit, 6 files changed)
- kernel 4.14.y:
- New commits in this build:
- overlays: Add addr parameter to i2c-rtc (& -gpio) (1fa25792)
- drm/vc4: Fix oops dereferencing DPI's connector since panel_bridge. (00ff5f4a)
- ARM: bcm2835: Add the DPI hardware to the device tree. (9f04eaef)
- ARM: BCM270X: Add the 18-bit DPI pinmux to the RPI DTs. (872c623a)
- overlays: Add an overlay for the Adafruit Kippah with their 7" panel (335b9e53)
- overlays: Remove stale notes about vc4's CMA alignment in the README. (b0d2d00a)
- drm/vc4: Advertise supported modifiers for planes (8b386830)
- drm/vc4: Add some missing HVS register definitions. (4a122984)
- drm/vc4: Add missing formats to vc4_format_mod_supported(). (69ee0743)
- drm/vc4: Add support for SAND modifier. (00254bf7)
- spi: Make GPIO CSs honour the SPI_NO_CS flag (94996038)
- Updated: [pkg] PR:14166 (perma): Fix Install from zip from addon view
I moved my pi3b+ to my bedroom and installed #710 and i'm amazed that playing hevc my pi stays nice at 60 degrees.
But i'm wondering bcmstat.sh shows 1200 mhz and core 500mhz while in config.txt arm_freq=1450 andĀ sdram_freq=580 gpu_freq=500 andĀ force_turbo=1
It looks like hevc playback is much more improved?
(2018-07-11, 09:38)Pienoet Wrote: [ -> ]I moved my pi3b+ to my bedroom and installed #710 and i'm amazed that playing hevc my pi stays nice at 60 degrees.
The ARM will now be limited to 1200MHz when the temperature reaches 60C. You can restore the original 70C limit by adding
temp_soft_limit=70
(2018-07-11, 17:52)Milhouse Wrote: [ -> ] (2018-07-11, 09:38)Pienoet Wrote: [ -> ]I moved my pi3b+ to my bedroom and installed #710 and i'm amazed that playing hevc my pi stays nice at 60 degrees.
The ARM will now be limited to 1200MHz when the temperature reaches 60C. You can restore the original 70C limit by adding temp_soft_limit=70
Thank you for this.
Is extra overclocking needed for this?
I have set my sdram to 580
(2018-07-11, 18:54)Pienoet Wrote: [ -> ]Is extra overclocking needed for this?
No, it just restores the old temperature limit.
Quote:(2018-07-08, 13:56)oztrained Wrote:Ā I am having an issue with audio Passthrough since #701 up to #707
ā¢ Using #630 when playing videos the amp indicates it is receiving Dolby Digital or DTS correctly
ā¢ Using #701 onwards the amp shows PCM for videos that are being correctly identified by #630.
However fromĀ #701 onwards
ā¢ If I disable audio Passthrough in Settings and then enable it again it makes no difference all shows are detected as PCM
ā¢ If I disable audio Passthrough in the playing video and then enable it again the audio is detected as Dolby Digital or DTS as appropriate
ā¢ After this If I stop the videoĀ and start it again the audio may be detected correctly some of the time but not always
I am using a RPI 3. I have been updating daily for some months and have only seen this issue since #701
The following PR added in #0701 has audio implications, so could be responsible:
(2018-07-02, 00:21)Milhouse Wrote:Ā Build Highlights:
XBMC:
VideoPlayer: handle tempo and realtime dynamically (PR:14134, 2 commits, 11 files changed)
Hello, is the error already fixed?
New LibreELEC.tv Leia build #0711:
RPi /
RPi2
SHA256 Checksum:
b33591c632dd59edb7172285f7d7f79e24f3faf3aa654781103eeb2b020cc3ba
(RPi)
SHA256 Checksum:
0e2cd86bb9b12114b7d2b0fca9cc7b28a510e976adaa03695134fa340f00cc8d
(RPi2)
text:
# uname -a
Linux rpi512 4.14.54 #1 Wed Jul 11 22:01:52 BST 2018 armv6l GNU/Linux
# vcgencmd version
Jul 9 2018 19:40:55
# lsb_release
LibreELEC (Milhouse): devel-20180711220031-#0711-g15061ee [Build #0711]
# Kodi version
Based on tip of
LibreELEC.tv master (15061ee,
XBMC master (b88fe4c,
- Includes latest bcm2835-driver master (418b77e, ahead +1)
- Include [env] PR:2822 (perma): graphics: update libva/libva-utils/intel-vaapi-driver to 2.2.0, mesa to 18.1.3
Build Highlights:
- net: lan78xx: Fix race in tx skb size calculation
Build Details:
- LibreELEC.tv:
- retroplayer addons (PR:2817, 22 commits, 22 files changed)
- XBMC:
- Fix Install from zip from addon view (PR:14166, 1 commit, 4 files changed)
- kernel 4.14.y:
- net: lan78xx: Fix race in tx skb size calculation (#2614) (db81c14c)
- Updated: [env] PR:2798 (perma): linux (Generic): update to linux-4.17.5
- Added: [env] PR:2822 (perma): graphics: update libva/libva-utils/intel-vaapi-driver to 2.2.0, mesa to 18.1.3
(2018-07-11, 22:50)ManiacKill Wrote: [ -> ]Hello, is the error already fixed?
Are you saying you have the same issue? I guess it will help if others can reproduce. To my knowledge nobody has looked into it (yet) - they undoubtedly have other priorities.
Yes, have the problem since 701
New LibreELEC.tv Leia build #0712:
RPi /
RPi2
SHA256 Checksum:
173ddb6d9717fcdc71067bc85b10f0b42dd9221b97330f5bb230ca9f2d169e73
(RPi)
SHA256 Checksum:
09e07f61ba285260b461a1d2d67711196b3aa177eaa813bef521ec990273a666
(RPi2)
text:
# uname -a
Linux rpi512 4.14.54 #1 Thu Jul 12 21:04:46 BST 2018 armv6l GNU/Linux
# vcgencmd version
Jul 9 2018 19:40:55
# lsb_release
LibreELEC (Milhouse): devel-20180712210328-#0712-gb10020d [Build #0712]
# Kodi version
Based on tip of
LibreELEC.tv master (b10020d,
XBMC master (65f9261,
- Includes latest libnfs master (322148b, ahead +6)
Build Highlights:
- AE: fix sync for transcoding
Build Details:
- LibreELEC.tv:
- snapcast: update to 0.15.0 (PR:2716, 8 commits, 11 files changed)
- ConnMan: use UseGatewaysAsTimeservers option (PR:2818, 1 commit, 4 files changed)
- videolan: fix download url for various videolan packages (PR:2823, 4 commits, 4 files changed)
- XBMC:
- AE: fix sync for transcoding (PR:14173, 1 commit, 1 file changed)
- Fix android resolution selection (PR:14172, 1 commit, 1 file changed)
- libnfs:
- libnfs.c: include <time.h> in libnfs.c (PR:263, 1 commit, 1 file changed)
- fix bug in nfsv4 opendir where it stripped off the final path component (21e208b)
- Merge branch 'master' of github.comahlberg/libnfs (2b93fcf)
- Updated: [pkg] PR:14160 (perma): [JSON]Faster access to music library
Maybe a silly question but I have an older build from June (been out of town). If I choose the latest build from 'Available Versions', does it install all updates from between my installed version and the build I chose? Or do I have to install every update one by one ever since?
If one by one, can I place all updates from between my installed version and the latest build to the 'Updates' folder via Samba? So it would install them all in next reboot?
Just choose the latest build version. Libreelec will be updated to that nightly.
