(2018-08-14, 22:41)syrell Wrote: [ -> ]Another, maybe stupid question, can I get the Milhouse Alphaversions also for a rPi3 Model B?
Nope. Post#1 on Page#1 says:
(2016-12-01, 06:34)Milhouse Wrote: [ -> ]RPi 3/RPi 3+ users: Use RPi2 builds.
Stupid questions are questions not asked.
Thanks, Milhouse, for the BusyBox update in #0814.
. I'll give it a try here shortly and see if it sorts out my problem.
I very much appreciate your efforts. I don't know what we'd do without you.
Thanks, again.
Have a good one.
Bob
RPI2 and RPI3 uses the same build as it says on the first post.
No joy in Mudville, it appears. Oh well. Maybe approach it from a different angle.
Again, thanks, Milhouse, for all your hard work. It is truly appreciated.
Best regards,
Bob
(2018-08-14, 23:57)Trespasser Wrote: [ -> ]Thanks, Milhouse, for the BusyBox update in #0814. . I'll give it a try here shortly and see if it sorts out my problem.
The update isn't going to help as the script you PM'd me isn't crashing because of wget, it's crashing because you're passing a massive single line of data (485KB) to sed, which then chokes (as I explained in my PM reply). The solution is to fix your script by adding some double quotes.
Hi Milhouse,
You're correct, it wasn't wget. It was the line directly below it that was causing the problem. I tried a different command and now my script is working perfectly again.
You're obviously a fine fellow.
Thanks for putting up with me.
Best regards,
Bob
New LibreELEC.tv Leia build #0815:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
2daa54d2129a9d2f13fd462bafa6880426fd22335afa09de685f75dc01cb677c
(RPi)
SHA256 Checksum:
481671557cba6f7301cfb9ad9e8b872cf68938feb3d7c05c7b0c2cae6a6921c9
(RPi2)
text:
# uname -a
Linux rpi512 4.14.62 #1 Wed Aug 15 21:09:07 BST 2018 armv6l GNU/Linux
# vcgencmd version
Aug 10 2018 11:25:06
Copyright © 2012 Broadcom
version ae4ae721c2518e45e5b0a0a7c73497b3dc1007d6 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20180815210704-#0815-gab31e8c [Build #0815]
# Kodi version
(18.0-BETA1 Git:fc9faf3). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (ab31e8c,
changelog) and tip of
XBMC master (a7fef8f,
- Includes newclock5 patches
- Includes latest bcm2835-driver master (953a339, ahead +1)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786)
- Includes latest libnfs master (322148b, ahead +6)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (430c440), inputstream.rtmp (0cc2da1), peripheral.joystick (08e4a1a), peripheral.xarcade (07be227), pvr.argustv (1459cea), pvr.demo (481f2fa), pvr.dvblink (c66203b), pvr.dvbviewer (c3ceb0b), pvr.filmon (93ae10d), pvr.hdhomerun (ced70bd), pvr.hts (0f06313), pvr.iptvsimple (55637c8), pvr.mediaportal.tvserver (ca4f4db, +15), pvr.mythtv (e61f47c), pvr.nextpvr (6f0515b), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (32d4b66), pvr.stalker (f84483c), pvr.teleboy (0460536), pvr.vbox (c115a14), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (75179a3), pvr.wmc (b5fe5a1), pvr.zattoo (12134c8), vfs.libarchive (fdc7441)
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:2872 (perma): update dvb addons
- Include [env] PR:2877 (perma): kodi: use HTTPS and SHA256 for LibreELEC repo addons
- Include [env] PR:2881 (perma): busybox: update to busybox-1.29.2
- Include [env] PR:2882 (perma): xorg-server: update to xorg-server-1.20.1
- Include [env] PR:2887 (perma): kodi: September 2018 update
- Include [pkg] PR:2647 (perma): Revert "mm: alloc_contig: re-allow CMA to compact FS pages" (linux)
- Include [pkg] PR:14297 (perma): fixed: add missing dependency for retroplayer messages
- Include [pkg] PR:14301 (perma): [json-rpc] Fix playback of pvr channels and pvr recordings - trac#17984.
Build Highlights:
- kernel: Revert "mm: alloc_contig: re-allow CMA to compact FS pages" (linux) (@smp1)
- RetroPlayer: Merge savestate metadata into .sav file (with external flatbuffers support)
- [json-rpc] Fix playback of pvr channels and pvr recordings - trac#17984.
Build Details:
- LibreELEC.tv:
- mesa: update to mesa-18.1.6 (PR:2879, 1 commit, 1 file changed)
- samba: update to samba-4.8.4 (PR:2884, 1 commit, 1 file changed)
- linux (RPi): update to linux-4.14.62 (PR:2837, 11 commits, 7 files changed)
- libdrm: update to libdrm-2.4.93 (PR:2888, 1 commit, 1 file changed)
- nano: update to 2.9.8; .tar.xz package (PR:2885, 1 commit, 1 file changed)
- libssh: update to libssh-0.8.1 (PR:2889, 1 commit, 2 files changed)
- XBMC:
- RetroPlayer: Merge savestate metadata into .sav file (PR:14209, 6 commits, 71 files changed)
- [win10] filesystem - fix crash on stat remote device. (PR:14300, 1 commit, 1 file changed)
- VideoPlayer: fix video rotation (PR:14298, 2 commits, 3 files changed)
- changed: auto-enable disabled add-ons which are dependencies of another (PR:14296, 1 commit, 1 file changed)
- pvr.mediaportal.tvserver:
- Various updates for v18 (PR:90, 15 commits, 53 files changed)
- newclock5:
- Commits no longer in build:
- ffmpeg: hevc: Update to latest ben optimisations (79c8d745)
- fixup: ilog bit mask (b9af3e0c)
- ffmpeg: hevc: latest optimisations from Ben (2b6422b0)
- Added: [env] PR:2887 (perma): kodi: September 2018 update
- Added: [pkg] PR:2647 (perma): Revert "mm: alloc_contig: re-allow CMA to compact FS pages" (linux)
- Added: [pkg] PR:14297 (perma): fixed: add missing dependency for retroplayer messages
- Added: [pkg] PR:14301 (perma): [json-rpc] Fix playback of pvr channels and pvr recordings - trac#17984.
(2018-08-15, 22:58)Milhouse Wrote: [ -> ][*]kernel: Revert "mm: alloc_contig: re-allow CMA to compact FS pages" (linux) (@smp1)
This is a potential fix for audio dropouts when pi is busy (e.g. live TV recording and playback or when running background jobs like torrents)
that appeared between the 4.9 and 4.14 kernels. If you've had this issue then please test and report.
(2018-07-30, 21:18)smp1 Wrote: [ -> ]Same issue as with previous kernel 4.18 builds. VDR/VNSI does not seem to function (not a DVB Driver Addons issue - I don't use those).
I dug deeper into this and the issue appears to be a buggy dvbsky.c driver. Reverting commit
7d95fb7 fixed it.
(2018-08-16, 17:26)smp1 Wrote: [ -> ]Reverting commit 7d95fb7 fixed it.
pls try to report this "upstream", a fix might take a while :/
meanwhile we could revert this
New LibreELEC.tv Leia build #0816:
RPi /
RPi2
SHA256 Checksum:
cb5cc7d1ff93ea971546f5a972ce991b6409f22c321b5a7ad7bdea920ef81916
(RPi)
SHA256 Checksum:
f8684c155afba4053324c87f0c8b90378269abff1c983126dbde529cb2b5821b
(RPi2)
text:
# uname -a
Linux rpi512 4.14.62 #1 Thu Aug 16 21:06:53 BST 2018 armv6l GNU/Linux
# vcgencmd version
Aug 16 2018 17:35:18
version 31e0613622dc2f2463bf3dd74e6c897d91201a4d (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20180816210328-#0816-geef941c [Build #0816]
# Kodi version
Based on tip of
LibreELEC.tv master (eef941c,
XBMC master (dc210c7,
- Includes latest bcm2835-driver master (ebbecf9, ahead +2)
- Include [env] compare (perma): RPi: enable CMA debugging
- Include [pkg] compare (perma): improve BT/WiFi coexistence, preventing BT audio stutter (brcmfmac_sdio-firmware-rpi)
Build Highlights:
- New firmware (video_encode, arm_dt fixes)
- RPi: enable CMA debugging
- improve BT/WiFi coexistence, preventing BT audio stutter (link)
Build Details:
- Firmware (Aug 16):
- firmware: video_encode: Drop back to software conversion if stride is not mod32. See: link
- firmware: arm_dt: Break out GPIO save/restore from HAT code as needed for PoE
- LibreELEC.tv:
- script/image: cleanup (PR:2886, 6 commits, 5 files changed)
- busybox: update to busybox-1.29.2 (PR:2881, 2 commits, 4 files changed)
- vfs.sftp: rebuild (PR:2891, 1 commit, 1 file changed)
- XBMC:
- [json-rpc] Fix playback of pvr channels and pvr recordings - trac#17984. (PR:14301, 1 commit, 2 files changed)
- fixed: add missing dependency for retroplayer messages (PR:14297, 1 commit, 1 file changed)
- Updated: [env] PR:2887 (perma): kodi: September 2018 update
- Added: [env] compare (perma): RPi: enable CMA debugging
- Added: [pkg] compare (perma): improve BT/WiFi coexistence, preventing BT audio stutter (brcmfmac_sdio-firmware-rpi)
