(2018-08-21, 23:36)Milhouse Wrote: [ -> ] (2018-08-21, 01:24)komerdoor Wrote: [ -> ]I solved it by adding some amixer commands to autostart.sh. The Allo firmware was also missing but I added a command to autostart.sh to copy them to /lib/firmware
Care to share? What commands, what firmware (link?)?
The firmware for Allo's Piano 2.1, 2.1-mode can be found at:
https://github.com/allocom/piano-firmware
My settings for the Piano 2.1 are as follows (the Dual-Mono-mode does not require the above firmware):
bash:
# Added simple test to detect if the Piano 2.1 is used
if grep -q PianoDACPlus /proc/asound/cards; then
amixer sset "Subwoofer" 207
amixer sset "Master" 207
amixer sset "Digital" 207
amixer sset "Dual Mode" "Dual-Mono"
fi
The above are also the default settings as mentioned in the Allo Piano 2.1 documentation:
https://www.amazon.com/clouddrive/share/..._link_copy
Somehow those default settings are not used in LibreELEC (I think wrongly set by the default start script as mentioned by HiassofT). When using Raspbian there is no need to run the above commands at all to get the default settings.
People that have the Piano 2.1 should add the following to their config.txt:
dtoverlay=allo-piano-dac-plus-pcm512x-audio
People that have the Piano 2.1 + Kali Reclocker should add the following to their config.txt:
dtoverlay=allo-piano-dac-plus-pcm512x-audio,glb_mclk
Note: With the recent Linux kernels the Kali Reclocker sometimes outputs noise. This is solved by forcing the output to 16 or 32bit:
https://volumio.org/forum/kali-reclocker...t9828.html
Note 2: The Kali Reclocker adds a delay to the sound that is different depending on the played audio/video. I found a solution (just as a reference for people that find this post):
http://www.diyaudio.com/forums/pc-based/...ssues.html
(2018-08-19, 11:17)HiassofT Wrote: [ -> ] (2018-08-18, 11:46)komerdoor Wrote: [ -> ]A suggestion: by default when using some of the RPi DSP boards the volume is set to > 255. This will cause distortion. I think it is better to set the volume on all channel on 255 by default, but not higher.
Please tell us which card you are using and which mixer control should be adjusted.
Post the output of
I noticed that the script to initialize the audio card mixers sets a lot of controls to 100% instead of 0dB - which can result in clipping if the maximum value is greater than 0dB.
https://github.com/LibreELEC/LibreELEC.t...oundconfig
so long,
Hias
The
aplay -l
output:
**** List of PLAYBACK Hardware Devices ****
card 0: PianoDACPlus [PianoDACPlus], device 0: PianoDACPlus multicodec-0
Subdevices: 1/1
Subdevice #0: subdevice #0
The
amixer
output:
https://pastebin.com/3ULFyy4d
(2018-08-19, 02:26)Milhouse Wrote: [ -> ]Look forward to your log - please make sure debug logging is enabled.
21:53:17.130 T:1541403504 ERROR: GetDirectory - Error getting
21:53:40.485 T:1938919440 ERROR: Previous line repeats 5 times.
21:53:40.486 T:1938919440 NOTICE: VideoPlayer::OpenFile: /storage/Games/roms/arcade/snk/alpham2.zip
21:53:40.486 T:1487926128 NOTICE: Creating InputStream
21:53:49.938 T:1487926128 NOTICE: Creating Demuxer
21:53:50.447 T:1487926128 ERROR: Open - error probing input format, /storage/Games/roms/arcade/snk/alpham2.zip
21:53:50.447 T:1487926128 ERROR: OpenDemuxStream - Error creating demuxer
21:53:50.447 T:1487926128 NOTICE: CVideoPlayer::OnExit()
21:53:50.617 T:1938919440 WARNING: OnMessage: Suspiciously long time to handle GUI_MSG_PLAYBACK_STARTED (10.12s)
Apparently it thinks that a game rom is a video and tries to play it. Garbear's his settings below fixed it:
<advancedsettings>
<videoextensions>
<remove>.bin|.img|.iso|.zip</remove>
</videoextensions>
<musicextensions>
<remove>.cue|.zip</remove>
</musicextensions>
<pictureextensions>
<remove>.zip</remove>
</pictureextensions>
</advancedsettings>
Games play well, but there is still stutter that is solved by pausing the game and then resuming.
Another question. Is there a way to disable the startup animation? I only want to see the LibreELEC boot logo.
(2018-08-23, 22:06)komerdoor Wrote: [ -> ]Another question. Is there a way to disable the startup animation? I only want to see the LibreELEC boot logo.
text:
touch /storage/.config/splash.disable
New LibreELEC.tv Leia build #0823:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
cce0880217969d8e76598fe672fd015d3d751c9d72cdc88f11a2d5c608611bbe
(RPi)
SHA256 Checksum:
279e95d10681c74392d10fb174e825adcd6cd67cc967139a99cf926507899981
(RPi2)
text:
# uname -a
Linux rpi512 4.18.4 #1 Thu Aug 23 22:30:55 BST 2018 armv6l GNU/Linux
# vcgencmd version
Aug 16 2018 17:35:18
Copyright © 2012 Broadcom
version 31e0613622dc2f2463bf3dd74e6c897d91201a4d (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20180823222245-#0823-gb56a1af [Build #0823]
# Kodi version
(18.0-BETA1 Git:1cbdec1a78a35985d8959a3f43dbb3c5b0db6f7f). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (b56a1af,
changelog) and tip of
XBMC master (964e573,
- Includes newclock5 patches
- Includes latest commits from kernel branch rpi-4.18.y
- Includes latest bcm2835-driver master (ebbecf9, ahead +2)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786)
- Includes latest libnfs master (322148b, ahead +6)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (430c440), inputstream.rtmp (0cc2da1), peripheral.joystick (08e4a1a), peripheral.xarcade (91567dd), pvr.argustv (1459cea), pvr.demo (481f2fa), pvr.dvblink (c66203b), pvr.dvbviewer (c3ceb0b), pvr.filmon (93ae10d), pvr.hdhomerun (ced70bd), pvr.hts (0f06313), pvr.iptvsimple (55637c8), pvr.mediaportal.tvserver (e8b0a9c, +4), pvr.mythtv (e61f47c), pvr.nextpvr (6f0515b), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (32d4b66), pvr.stalker (f84483c), pvr.teleboy (0f3ccfd, +2), pvr.vbox (c115a14), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (75179a3), pvr.wmc (b5fe5a1), pvr.zattoo (12134c8), vfs.libarchive (f93a5f3, +5), vfs.sftp (e69acc9, +6)
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:2872 (perma): update dvb addons
- Include [env] PR:2892 (perma): scripts/image: use maximum lzo and zstd compression level for images
- Include [env] PR:2907 (perma): config/functions: clean up recursion test
- Include [env] PR:2908 (perma): linux (Generic): update to linux-4.18.4
- Include [env] PR:2909 (perma): kodi: next (Sept || kodi bump)
- Include [env] PR:2913 (perma): linux (RPi): update to linux-4.18.4
- Include [env] PR:2914 (perma): Fix compilation issues with glibc 2.28 on host
Build Highlights:
- [videoplayer] Fix dvd resume, mouse selection in disc menus, caching in menus
Build Details:
- XBMC:
- [windowing][vp] Fix mouse selection in disc menus. (PR:14338, 1 commit, 1 file changed)
- [videoplayer] Fix dvd resume (PR:14343, 2 commits, 5 files changed)
- [videoplayer] Always report "not caching" while browsing disc menus. (PR:14340, 1 commit, 1 file changed)
- kernel 4.18.y:
- New commits in this build:
- config: fix media device defconfigs (595de934)
- Updated: [env] PR:2909 (perma): kodi: next (Sept || kodi bump)
- Added: [env] PR:2914 (perma): Fix compilation issues with glibc 2.28 on host
hi all. ( sorry for my english)
I follow this theard with plesure
I have update my kodi 17 to the last kody 18 ans i have a problem.
Befor my keybord is AZERTY and now it's QWERTY.
I precise, on the screen i see a AZERTY keybord but when i press on my physical keybord Rii8 i have qwerty result.
Have you a solution please ?
Maybe you have to deselect the english keyboard first
I have not select engligh keybord
I have take french azerty and in libreelec menu I take on Fr keybord
I have test 2 time, un kodi 17 it's in fr with this paramètre and on kodi 18 ( I test 3/4 update) i'm qwerty
(2018-08-24, 09:16)poiuytrezaaa Wrote: [ -> ]hi all. ( sorry for my english)
This is a known issue with LE9 at this time - we're very close to a solution, hopefully in a few more days it will appear in a test build.
ok
Thanks you for your reponse
i stop to search au solution
I have some strange lines in kernel log.
http://ix.io/1l8g
[ 54.439282] eth0: hw csum failure
[ 54.439312] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.18.4 #1
[ 54.439315] Hardware name: BCM2835
[ 54.439318] Backtrace:
[ 54.439337] [<8010eaa8>] (dump_backtrace) from [<8010ee0c>] (show_stack+0x20/0x24)
[ 54.439342] r7:ffffffff r6:00000000 r5:600b0113 r4:80f86dd4
[ 54.439351] [<8010edec>] (show_stack) from [<8090d058>] (dump_stack+0xcc/0x110)
[ 54.439359] [<8090cf8c>] (dump_stack) from [<807dc2ec>] (netdev_rx_csum_fault+0x44/0x48)
[ 54.439365] r10:00000002 r9:a336006e r8:80f7d0c0 r7:00000014 r6:1e1dd9c3 r5:aabebf00
[ 54.439368] r4:a9f66000 r3:a5e88d20
Anything to worry about?
(2018-08-24, 19:43)polo_joe Wrote: [ -> ]I have some strange lines in kernel log.
http://ix.io/1l8g
Could you create an issue here:
https://github.com/raspberrypi/linux/issues
as this is a kernel issue rather than kodi/LE issue.
Include link to your kernel log, and describe if you have anything unusual in network setup (e.g. VPN).
New LibreELEC.tv Leia build #0824:
RPi /
RPi2
SHA256 Checksum:
b3363f6eefbcc7396afef126120039cc50ebacb75a6bebb421212750450f037b
(RPi)
SHA256 Checksum:
93d34b2866d04b3c8275dc6c53ebf142d1ad15041bc572d16c217712046a9afc
(RPi2)
text:
# uname -a
Linux rpi512 4.18.4 #1 Fri Aug 24 21:06:33 BST 2018 armv6l GNU/Linux
# vcgencmd version
Aug 24 2018 16:43:02
version 99c203bd98263761d3c99c7784a5d76deeea804d (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20180824210517-#0824-gae62e44 [Build #0824]
# Kodi version
Based on tip of
LibreELEC.tv master (ae62e44,
XBMC master (6854871,
- Includes latest bcm2835-driver master (200c2f4, ahead +3)
- Include [env] PR:2908 (perma): linux (Generic): update to linux-4.18.5
- Include [env] PR:2915 (perma): linux: fix Module.symvers generation
- Include [env] PR:2919 (perma): samba: update to samba-4.8.5
- Include [env] PR:2920 (perma): mesa: update to mesa-18.1.7
- Include [pkg] PR:14316 (perma): [pvr][guiinfo][guilib][estuary] PVR timeshift GUI v2.
Build Highlights:
- New firmware
- linux: fix Module.symvers generation
- Update samba-4.8.5
- [pvr][guiinfo][guilib][estuary] PVR timeshift GUI v2.
Build Details:
- Firmware (Aug 24):
- firmware: rawcam: Fix double buffer return issue
- firmware: rawcam: Code cleanup
- firmware: host_apps: Fixup partially merged commit from userland. See: link
- firmware: mmal: Add KEEP_PORT_FORMATS flag to mmal connection. See: link
- firmware: RaspiStill: Apply gpsd info as EXIF tags. See: link
- LibreELEC.tv:
- Fix compilation issues with glibc 2.28 on host (PR:2914, 4 commits, 4 files changed)
- XBMC:
- VideoPlayer: VDPAU - whitelist AV_PIX_FMT_YUVJ420P (PR:14346, 1 commit, 1 file changed)
- Updated: [env] PR:2908 (perma): linux (Generic): update to linux-4.18.5
- Added: [env] PR:2915 (perma): linux: fix Module.symvers generation
- Added: [env] PR:2919 (perma): samba: update to samba-4.8.5
- Added: [env] PR:2920 (perma): mesa: update to mesa-18.1.7
- Added: [pkg] PR:14316 (perma): [pvr][guiinfo][guilib][estuary] PVR timeshift GUI v2.
Did you find anything in the logs that I posted that would cause the freeze when it drops to about 60mb of free memory. I tried to use plugins like embycon to play the movies and tvshows with nothing in the kodi database and it does not run out of memory. The free memory hovers around 150mb and 250mb after 9 days.
Hi Milhouse,
sorry, there is a little bug in #824:
In system / audio is no adjustment for ALSA: snd_rpi_hifiberry_digi, S/PDIF.
It appears only ALSA: snd_rpi_hifiberry_digi, Analog
I'm back to #818 and sound works in DD and DTS (multichannel).
Tank You for Your Work
Harald
(2018-08-25, 17:19)doldi Wrote: [ -> ]sorry, there is a little bug in #824:
Please post the output of
aplay -l
dmesg | paste
both on the working and non-working build
so long,
Hias
