(2018-09-24, 18:21)deltree Wrote: [ -> ]hello
after latest kodi update .my keyboard channel change buttons for pvr don't work .why? this butttons worked well on august updates.please solve this problem.
Thank you for your helps and updates
Identify the last working build.
(2018-09-24, 20:28)Milhouse Wrote: [ -> ] (2018-09-24, 18:21)deltree Wrote: [ -> ]hello
You can fix this youself. I bet you are using the 'prev' and 'next' keys on your keyboard to switch channels, this worked formerly, but now those keys act like for normal videos and skip to the next/prev programme in the timeshift buffer. You can either remap those keys to work as before or you can use page+/page- to switch channels.
Hello @
Milhouse
I can confirm that my Toshiba CT-90405 CEC remote isn't working with kodi anymore.
Pre #920er Build I was able to move inside kodi with the remote's arrov (ring) buttons round the OK button (see image). Now the remote doesn't work at all.
Image:
Plus m kodi freezes at times on my raspberry 3, mostly when I'm looking netflix.
I can attach a debug log, if you need it.
LibreELEC-RPi2.arm-9.0-Milhouse-20180718212158-#0718-g873d2c9
New LibreELEC.tv Leia build #0924:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
835c859bfc24fcc98a77127976ce4b209ed56bd15a0c894f71ae97e4f545d999
(RPi)
SHA256 Checksum:
e0b08c37238bb1d605fca2e00f19f7aad60997253bd13bb5a4b7aa671d15978d
(RPi2)
text:
# uname -a
Linux rpi512 4.18.9 #1 Mon Sep 24 21:05:11 BST 2018 armv6l GNU/Linux
# vcgencmd version
Sep 21 2018 15:48:28
Copyright © 2012 Broadcom
version 07f57128b8491ffdefcdfd13f7b4961b3006d9a9 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20180924210357-#0924-g1bed946 [Build #0924]
# Kodi version
(18.0-BETA3 Git:3af76f1). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (1bed946,
changelog) and tip of
XBMC master (3af76f1,
- Includes newclock5 patches
- Includes latest commits from kernel branch rpi-4.18.y
- Includes latest bcm2835-driver master (2ecdfe7, ahead +1)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786)
- Includes latest libnfs master (9454d9f, ahead +9)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (8d49b9d, +2), inputstream.rtmp (0cc2da1), peripheral.joystick (81fd01a, +1), peripheral.xarcade (91567dd), pvr.argustv (c57a5c4), pvr.demo (481f2fa), pvr.dvblink (72ef8a0), pvr.dvbviewer (dd9c518, +13), pvr.filmon (93ae10d), pvr.hdhomerun (7a607c9), pvr.hts (21d6d70, +1), pvr.iptvsimple (e8effad), pvr.mediaportal.tvserver (b17d5ad), pvr.mythtv (22aa23b), pvr.nextpvr (441edde), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (9d95bab), pvr.stalker (2eb66d1), pvr.teleboy (0f3ccfd), pvr.vbox (40ca81f), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (bfce893, +17), pvr.wmc (0aea001, +4), pvr.zattoo (8de69a1), vfs.libarchive (f93a5f3), vfs.sftp (e69acc9)
- Include [env] compare (perma): kodi-next
- Include [env] compare (perma): TESTING: increase timeout to ensure OS is able to create core dump/crash log
- Include [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:2908 (perma): linux (Generic): update to linux-4.18.9
- Include [env] PR:2913 (perma): linux (RPi): update to linux-4.18.9
- Include [env] PR:2916 (perma): ffmpegx and tvh
- Include [env] PR:2985 (perma): llvm: update to 7.0.0
- Include [env] PR:2986 (perma): cmake: update to cmake-3.12.2
- Include [env] PR:2987 (perma): nano: update to nano-3.0
- Include [env] PR:2990 (perma): mesa: update to mesa-18.2.1
- Include [env] PR:2992 (perma): scripts/image: use 256kb blocksize for squashfs images
- Include [env] PR:2993 (perma): Improve fs-resize, fix delay and simplify
- Include [env] PR:2994 (perma): samba-config.service: fix destroying .cache structure
- Include [env] PR:2999 (perma): Kernel support for recent Dell notebook Alps trackpads
- Include [pkg] PR:14341 (perma): input: libinput: add setting to allow changing keymap layout
- Include [pkg] PR:14460 (perma): [linux] allow overriding the userdata dir
- Include [pkg] PR:14465 (perma): DVDDemuxFFmpeg: correctly set probeBuffer size matching avioread chunk
Build Highlights:
- samba: update to samba-4.9.1
Build Details:
- LibreELEC.tv:
- supporting sabayon host distro, quite straightforward, as a flavour of gentoo (PR:2998, 1 commit, 1 file changed)
- fix crossbuilding heimdal by adding dependency to host-ncurses (PR:2970, 1 commit, 1 file changed)
- Emby: update to 3.5.3.0 (PR:2996, 7 commits, 9 files changed)
- busybox: drop NFS support for linux < 2.6.23 (enable NFSv4) (PR:2991, 1 commit, 3 files changed)
- samba: update to samba-4.9.1 (PR:3000, 1 commit, 1 file changed)
- XBMC:
- [guiinfo] redact user/pass in debug logging (PR:14467, 1 commit, 1 file changed)
- kodi.sh: add apport support (PR:14464, 1 commit, 1 file changed)
- [droid] bump the target API to 26 defined in androidmanifest. (PR:14466, 1 commit, 1 file changed)
- [PVR] Fix CPVRItem::GetNextEpgInfoTag to use the more flexible metho (PR:14469, 1 commit, 5 files changed)
- [android] use ndk 18 (PR:14463, 4 commits, 6 files changed)
- [Android] Fix rounding / type issue when adding VSYNC offset (PR:14470, 1 commit, 1 file changed)
- Added: [env] PR:2999 (perma): Kernel support for recent Dell notebook Alps trackpads
- Updated: [pkg] PR:14341 (perma): input: libinput: add setting to allow changing keymap layout
- Updated: [pkg] PR:14465 (perma): DVDDemuxFFmpeg: correctly set probeBuffer size matching avioread chunk
(2018-09-25, 02:22)deltree Wrote: [ -> ]LibreELEC-RPi2.arm-9.0-Milhouse-20180718212158-#0718-g873d2c9
Is that just the last version you were using? That isn't what I asked for. Identify the last working version - it's somewhere between whatever version you were last using (which may have been #0718) and latest #0924. Or listen to what @
ksooo is saying.
(2018-09-25, 00:15)Germeleon Wrote: [ -> ]I can confirm that my Toshiba CT-90405 CEC remote isn't working with kodi anymore.
So you're saying that with #0920 those buttons no longer work, but with #0919 they do work?
Can you provide a debug log from #0919 which shows you pushing those four buttons, and then the same from #0920.
I don't see any change in #0920 that should have affected those buttons.
(2018-09-25, 00:15)Germeleon Wrote: [ -> ]Plus m kodi freezes at times on my raspberry 3, mostly when I'm looking netflix.
Not really sure what this is due to, maybe a separate debug log for that.
(2018-09-25, 05:58)Milhouse Wrote: [ -> ] (2018-09-25, 02:22)deltree Wrote: [ -> ]LibreELEC-RPi2.arm-9.0-Milhouse-20180718212158-#0718-g873d2c9
Is that just the last version you were using? That isn't what I asked for. Identify the last working version - it's somewhere between whatever version you were last using (which may have been #0718) and latest #0924. Or listen to what @ksooo is saying.
No need for further investigations. Works as designed.
this version is my keyboard keys working version.
and LibreELEC-RPi2.arm-9.0-Milhouse-20180923210325-#0923-g442e2de this version my keyboard keys not work
did ı explain which version was worked?
(2018-09-25, 08:14)deltree Wrote: [ -> ]this version is my keyboard keys working version.
Again, no need to investigate. Read what I wrote! This works as designed. No bug.
(2018-09-25, 08:14)deltree Wrote: [ -> ]did ı explain which version was worked?
You've told me about *a* version that worked but what I wanted to know is the *last* version of all these test builds that worked - you would need to check every build to determine that.
However from what @
ksooo says, the new behaviour is by design so there's no point identifying the point at which the change occurred.
For reference @
ksooo has told me it is this change in #0905 (so the last "working" build would have been #0904):
(2018-09-06, 00:36)Milhouse Wrote: [ -> ]Build Details:
- XBMC:
- [PVR][Estuary] Add support for ACTION_(PREV|NEXT)_ITEM for timeshift buffer navigation (PR:14387, 5 commits, 17 files changed)
After yesterdays update (LibreELEC.tv Leia build #0923) I rebooted my Pi3, everything looks fine (booting, logo's etc) but after that the screen turns black and keeps that way. Before the update my default skin (Eminence) just loaded correctly.
(2018-09-25, 14:42)SkywalkerPD Wrote: [ -> ]Hi,
Post your crash log. Check if profiles.xml has gone walkabout.
(2018-09-17, 02:15)smp1 Wrote: [ -> ]7d95fb74
Yes it must be a module problem. The tuner was working for years. in older day there was a buggy driver in kernel too, then it worked for years and now we go a step back and hav the buggy driver again.
Is it possible to revert this shitty patch or does it something usefull too? can milhouse revert it for me to watch dvbs again?
please?
(2018-09-25, 16:20)Milhouse Wrote: [ -> ] (2018-09-25, 14:42)SkywalkerPD Wrote: [ -> ]Hi,
I would if I could get to it... After reading some, I deleted the addons27.db file. It know keeps rebooting, and eventually ends up in safe mode. I can't get my original setup to startup again....
Still hoping to get this fixes, there is so much work in this setup, If I have to do everything again......
