2018-09-26, 22:05
(2018-09-26, 17:28)quew Wrote: [ -> ](2018-09-26, 16:06)phunkyfish Wrote: [ -> ]I'm on the latest VTi 13.0.12 (enigma2-plugin-extensions-openwebif - 1.2.8-vti-20180829-r0).(2018-09-26, 13:56)quew Wrote: [ -> ]Hi @phunkyfish, I also have problems since you introduced Autotimers. I believe the function TimerUpdatesAuto() has a problem here as my timers are loaded correctly.Hmm, what distribution and version of Enigma2 are you running? Also the the OpenWebIf version. I see that searchType not a valid value for the version I'm running.
Please find the logfile here: https://pastebin.com/BH2CBYj8
This is my autotimer output from Uno 4k SE:
xml:
<autotimer version="7">
<defaults id="-1"> </defaults>
<timer name="Lena Lorenz" match="Lena Lorenz" enabled="yes" id="1" allow_duplicate="0" autoadjust="1" searchType="title_shortdesc" overrideAlternatives="1">
<e2service>
<e2servicereference>1:0:19:283D:3FB:1:C00000:0:0:0:</e2servicereference>
<e2servicename>Das Erste HD</e2servicename>
</e2service>
<e2service>
<e2servicereference>1:0:19:2B66:3F3:1:C00000:0:0:0:</e2servicereference>
<e2servicename>ZDF HD</e2servicename>
</e2service>
</timer>
<timer name="Bauer sucht Frau" match="Bauer sucht Frau" enabled="yes" id="2" allow_duplicate="0" autoadjust="1" searchType="title_shortdesc" overrideAlternatives="1">
<e2service>
<e2servicereference>1:0:19:EF10:421:1:C00000:0:0:0:</e2servicereference>
<e2servicename>RTL HD</e2servicename>
</e2service>
</timer>
</autotimer>
Unfortunately I'll be on vacation the next 2 weeks but I will also try to dig into the Github code and test after my holidays!
Greetings and thank you very much for your vuplus contributions,
Christian
It may be that you need a newer version of OpenWebIf. The docs are not good for it so it was difficult to pick a minimum version.
I'll also add a feature switch so you can turn autotimer support on/off. I think I know what the issue is though so should have a fix by the time you are back.
Thank you in advance, looking forward to a testrun when I return!
Just PM me once you’re back. This may not work well until you are on version 1.3.x of OpenWebif.
Have a great holiday.
I did a bit more digging but even though you are on the latest VTI image it's using an old version of OpenWebIf which uses version 7 of the autotimer config. Not sure how you get that upgraded it would need to be version 8 of the config. I'll probably need to set the feature to only work on version 1.3.3 and higher as I can't test anything older than that.
Drop me a note when your back from vacation and we'll see about support for your version of OpenWebIf. Hopefully you can upgrade to 1.3.x but if not maybe you can help get the info I need to add support for it.
What I would need would be a set of autotimer XML files showing the different configurations. It would mean playing with the HTTP requests to figure out how to set/unset the different values. Hopefully it's not too different from the latest API config version.
