I had build from 30.10 or 31.10 but I downloaded the last build available and updated it now.
Morc
Can you test if
this build fixes your audio issue? It's a build with kernel downgraded to 4.8.16.
PVR does not work for some reason. I get only No free adapter available errors from TVHeadend HTSP Client.
EDIT: only some channels work in other devices and also locally in LibreELEC
New LibreELEC.tv Leia build #1102:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
9d432c1e15c973e091ca60276f50915994875b61e72a3cb9ee67af8375a96394
(RPi)
SHA256 Checksum:
c2a17b81d0950bc49134572643975062005b491646123ff6d1cea8a4063f2a5f
(RPi2)
text:
# uname -a
Linux rpi512 4.19.0 #1 Fri Nov 2 21:03:45 GMT 2018 armv6l GNU/Linux
# vcgencmd version
Oct 23 2018 14:41:50
Copyright © 2012 Broadcom
version 724d81b3f87eb71045e938e572eca140fb8828ab (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20181102210239-#1102-gebe6234 [Build #1102]
# Kodi version
(18.0-BETA5 Git:ea7cf67). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (ebe6234,
changelog) and tip of
XBMC master (ea7cf67,
- Includes newclock5 patches
- Includes latest commits from kernel branch rpi-4.19.y
- Includes latest bcm2835-driver master (45c6ee3)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (96ba7dd)
- Includes latest libnfs master (6dfc87d, ahead +10)
- Includes latest p8-platform master (f6a565e)
- Includes latest addons: inputstream.adaptive (51c94a7, +10), inputstream.rtmp (ce7f559, +6), peripheral.joystick (690d901, +1), peripheral.xarcade (91567dd), pvr.argustv (508dfbe, +3), pvr.demo (964686d, +3), pvr.dvblink (b65ef9d, +1), pvr.dvbviewer (f775c0a, +3), pvr.filmon (e47161e, +1), pvr.hdhomerun (d434788, +3), pvr.hts (4d0cb6d, +9), pvr.iptvsimple (c7c136a, +3), pvr.mediaportal.tvserver (0e0c137, +4), pvr.mythtv (441638a, +2), pvr.nextpvr (c0be082, +3), pvr.njoy (7c3c049, +3), pvr.octonet (203f800), pvr.pctv (33fe1b8, +1), pvr.stalker (e75db52, +2), pvr.teleboy (484db31), pvr.vbox (244adfd, +3), pvr.vdr.vnsi (6bbdb78), pvr.vuplus (6882acb, +8), pvr.wmc (c607458, +3), pvr.zattoo (41268ee, +1), vfs.libarchive (6d39012, +6), vfs.sftp (6749200, +7)
- Include [env] compare (perma): kodi: next (Nov 2018)
- Include [env] compare (perma): TESTING: increase timeout to ensure OS is able to create core dump/crash log
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:2993 (perma): Improve fs-resize, fix delay and simplify
- Include [env] PR:3057 (perma): kodi: Hack around 'not available' notification with built-in dependenies
- Include [env] PR:3072 (perma): mesa: update to mesa-18.2.4
- Include [env] PR:3077 (perma): kodi: use project specific cputemp scripts for all projects
Build Highlights:
- [GLES] VideoPlayer: more cleanup
- libcec, p8-platform updates
- cputemp fixes
Build Details:
- LibreELEC.tv:
- tinc: update to 1.1pre17 (PR:3074, 1 commit, 2 files changed)
- Inadyn 2.5 (PR:3075, 2 commits, 5 files changed)
- squeezelite: link instead dlopen again and update (PR:3062, 1 commit, 4 files changed)
- dispmanx_vnc: update to 5bde54b (PR:3076, 1 commit, 2 files changed)
- XBMC:
- [GLES] VideoPlayer: more cleanup (PR:14746, 1 commit, 5 files changed)
- [Android] Wait 2000 instead 500ms until videoview is created (PR:14770, 1 commit, 1 file changed)
- [xbmc][settings][GL][DX]: Remove test patterns (PR:14725, 1 commit, 16 files changed)
- Fix include auto-mounted drives remote access allowed check (PR:14758, 1 commit, 1 file changed)
- libcec:
- Fix Pulse-Eight USB CEC adapter detection on macOS Mojave (PR:434, 1 commit, 1 file changed)
- Fix LG TV always changing input when turned on #307 (PR:390, 1 commit, 1 file changed)
- Include C version of libCEC loader when installing (PR:397, 1 commit, 1 file changed)
- Fix build if tinfo library is not present. (PR:398, 1 commit, 1 file changed)
- Fix broken Python version check and failure to build on cmake < 3.7 (PR:409, 1 commit, 1 file changed)
- changed: disable autonomous mode when a Samsung TV is connected (2c41938)
- Revert "added: -std=c++11 to pkg-config" (e418800)
- cosmetics. thanks @MilhouseVH (a3bfedf)
- fixed: CRPiCECAdapterMessageQueue::Write() accessed the queue without locking (d62951c)
- changed: use sig_atomic_t for shared object between sig handler and main (0055a83)
- added links to examples for rpi (96ba7dd)
- p8-platform:
- p8-platform-config: fix lookup paths (PR:31, 1 commit, 1 file changed)
- Fix Win64 compile warnings (PR:34, 1 commit, 1 file changed)
- inputstream.adaptive:
- Check for invalid adaptationsets (20c18dc)
- Allow JSON array in license response (51c94a7)
- Updated: [env] compare (perma): kodi: next (Nov 2018)
- Added: [env] PR:3077 (perma): kodi: use project specific cputemp scripts for all projects
(2017-11-21, 02:33)smp1 Wrote: [ -> ]I'm getting intermittent Kodi crashes when switching from AVC encoded video to HEVC 10-bit video (the crash happens immediately when I start playing HEVC-10 video). Those crashes are easily reproducible and I believe the last good build is #0912 (I can reproduce the issue with #0913 and newer and can't reproduce with #0912 and older.).
How to reproduce:
1) Play Sample 1 (AVC).
2) During the playback of Sample 1 start the playback of Sample 2 (HEVC-10).
3) Repeat until it crashes (usually takes less that 10 attempts).
popcornmix
This is still unresolved - when skipping from an interlaced AVC video to a HEVC video - Kodi crashes. I believe
this commit introduced the issue.
on the same pi that is running Kodi as well?
(2018-11-01, 17:16)tjost Wrote: [ -> ]the Problem is that the pi is not fast enough intern to do booth. I use a second pi only as a tvheadend and samba server.
My PI2 was fine as server and player for 1080i 50hz DVB-S2 h.264 broadcasts under kodi 17.
Have to reboot it daily to stop glitching on playback for TV. However Blu-Ray rips no problem (not compressed).
Quick question for @
Milhouse
I need to patch my start.elf for something else each time I upgrade.
Is there a way to sideload it into the tarball?
I replace the file in /3rdparty/bootloader but it seems to ignore it and put a different start.elf. Possibly one from inside /target/SYSTEM ?
Yes, the start.elf
installed by the upgrade procedure is retrieved from within the SYSTEM file (/usr/share/bootloader/start.elf
) so you'll have to unsquash/squash the SYSTEM file before applying the update.
You could always add something to autostart.sh which compares /flash/start.elf
with /usr/share/bootloader/start.elf
(ie. md5sum) and if they're the same then you can patch /flash/start.elf
and reboot. The next reboot will see that the two files are no longer the same and continue as normal.
I must ask though - why are you patching start.elf
? I'm not sure what problems this could cause, and might not be a good basis when reporting problems as you're no longer using the stock firmware.
(2018-11-03, 15:34)Milhouse Wrote: [ -> ]Yes, the start.elf
Thanks for the info, I’ll give the startup script a try as will be quicker than unpacking/repacking SYSTEM.
When reporting bugs I do test on stock firmware 👍
Retroplayer has been broken for a week or so. I know the repo was moved recently so I have been being patient but I also don’t want it to get forgotten. It is saying the version of the libretro library is incompatible. Is this a LibreELEC thing or a @
garbear thing?
(2018-11-03, 18:47)quig Wrote: [ -> ]Retroplayer has been broken for a week or so. I know the repo was moved recently so I have been being patient but I also don’t want it to get forgotten. It is saying the version of the libretro library is incompatible. Is this a LibreELEC thing or a @garbear thing?
Games will be fixed when LE releases alpha 007 in a week or two. Until then, you can stick to build #1021, which is the last build before the Game API bumped in #1022.
New LibreELEC.tv Leia build #1103:
RPi /
RPi2
SHA256 Checksum:
b6b3e48beae3735f3d44328863fd239d51af1ef32ccfbe0a55f11880dd67b2cc
(RPi)
SHA256 Checksum:
209144a11adfcec89aae296acedfd7df08e4a6f16fb9d7b79cc9496be10b3d23
(RPi2)
text:
# uname -a
Linux rpi512 4.19.0 #1 Sat Nov 3 21:05:06 GMT 2018 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20181103210245-#1103-gebe6234 [Build #1103]
# Kodi version
(18.0-RC1 Git:4dda45c). Platform: Linux ARM 32-bit
Based on tip of
XBMC master (4dda45c,
- Includes latest addons: inputstream.adaptive (51c94a7, +10), inputstream.rtmp (ce7f559, +6), peripheral.joystick (690d901, +1), peripheral.xarcade (91567dd), pvr.argustv (508dfbe, +3), pvr.demo (964686d, +3), pvr.dvblink (b65ef9d, +1), pvr.dvbviewer (f775c0a, +3), pvr.filmon (e47161e, +1), pvr.hdhomerun (d434788, +3), pvr.hts (4d0cb6d, +9), pvr.iptvsimple (c7c136a, +3), pvr.mediaportal.tvserver (56d2478, +8), pvr.mythtv (4d07281, +7), pvr.nextpvr (c0be082, +3), pvr.njoy (7c3c049, +3), pvr.octonet (203f800), pvr.pctv (33fe1b8, +1), pvr.stalker (e75db52, +2), pvr.teleboy (484db31), pvr.vbox (244adfd, +3), pvr.vdr.vnsi (6bbdb78), pvr.vuplus (6882acb, +8), pvr.wmc (c607458, +3), pvr.zattoo (41268ee, +1), vfs.libarchive (6d39012, +6), vfs.sftp (6749200, +7)
Build Highlights:
- bump to v18.0 RC1
- FFmpeg: Bump to 4.0.3-Leia-Beta5 (in Kodi PR)
Build Details:
- XBMC:
- [python-scrapers] extended music artwork (PR:14752, 1 commit, 1 file changed)
- [windows] bump OpenSSL to 1.1.1 (PR:14777, 3 commits, 12 files changed)
- whitelist movie set artwork from scrapers/NFO files (PR:14667, 3 commits, 5 files changed)
- FFmpeg: Bump to 4.0.3-Leia-Beta5 (PR:14782, 1 commit, 4 files changed)
- Fix remote access to images accidentally blocked by Cve 2017 5982 patch (PR:14783, 1 commit, 2 files changed)
- Revert "windowing/gbm: add VT handler" (PR:14776, 1 commit, 5 files changed)
- bump to v18.0 RC1 (PR:14516, 1 commit, 2 files changed)
- [droid] bump version_code in version.txt because of Play Store (27705c9)
- pvr.mediaportal.tvserver:
- Update to v3.5.11 (PR:97, 4 commits, 5 files changed)
- pvr.mythtv:
- update Danish translation (PR:105, 1 commit, 1 file changed)
- handle damaged recordings (a5058f0)
- revert part of commit 66311a6e5479cf739b6598dd502cf73e7a6fa829 (8147f82)
- bump version 5.8.12 (5232720)
- bump version 5.8.13 (4d07281)
