(2018-11-07, 22:02)Germeleon Wrote: [ -> ]I've noticed three bugs in build #1105 on my RPI3:
- Kodi needs about 3 minutes to open the libreelec settings menu and opens it slowly with a noticable lag. The CPU workload is about 123% in the meantime.
- Addon Amazon VOD doesn't work anymore. If you open it and select something like series or movies, it offers nothing than an emtpy folder. Will report this in the Amazon VOD addon section,too
Debug log here.
plus
- Kodi crashes at times. The crash logs are here and here.
Hope my findings and debug logs are helpful.
Kind Regards,
Germeleon
The crashes both seem to be Python related. I'd imagine the slow start of the LE Settings addon may be caused by other add-ons hogging all the CPU. Start testing with a clean installation, then install add-on until you can reproduce the problem.
New LibreELEC.tv Leia build #1107:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
462c67bb8175c2b4c04c0506ce7cb184f43d9d4e9ce224b2669754b238d3cd14
(RPi)
SHA256 Checksum:
dcdac517ace6af214fdbb8b3cb64f0363c6754807f9e9f1af8e1bd6e812ad5a3
(RPi2)
text:
# uname -a
Linux rpi512 4.19.1 #1 Wed Nov 7 21:03:37 GMT 2018 armv6l GNU/Linux
# vcgencmd version
Nov 4 2018 16:35:17
Copyright © 2012 Broadcom
version ed5baf9520a3c4ca82ba38594b898f0c0446da66 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20181107210229-#1107-g1a60beb [Build #1107]
# Kodi version
(18.0-RC1 Git:5a42446). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (1a60beb,
changelog) and tip of
XBMC master (5a42446,
- Includes newclock5 patches
- Includes latest commits from kernel branch rpi-4.19.y
- Includes latest bcm2835-driver master (55e5912, ahead +1)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (009d54b, ahead +4)
- Includes latest libnfs master (6dfc87d, ahead +10)
- Includes latest p8-platform master (1eb12b1, ahead +1)
- Includes latest addons: inputstream.adaptive (d1bb1eb, +3), inputstream.rtmp (ce7f559), peripheral.joystick (2008fdc, +1), peripheral.xarcade (f09a0e7, +1), pvr.argustv (609a2e7, +2), pvr.demo (964686d), pvr.dvblink (47cbff0, +2), pvr.dvbviewer (a9b204e, +8), pvr.filmon (f736ab4, +2), pvr.hdhomerun (a9d7309, +1), pvr.hts (f4ea60f, +2), pvr.iptvsimple (90a8d6f, +1), pvr.mediaportal.tvserver (e4a9dae, +2), pvr.mythtv (ca6620b, +2), pvr.nextpvr (7e36106, +2), pvr.njoy (4467cac, +1), pvr.octonet (203f800), pvr.pctv (e28a90f, +2), pvr.stalker (a99ad5e, +2), pvr.teleboy (484db31), pvr.vbox (6ed2f63, +2), pvr.vdr.vnsi (6bbdb78), pvr.vuplus (d77458b, +2), pvr.wmc (e00c895, +2), pvr.zattoo (41268ee), vfs.libarchive (6d39012), vfs.sftp (6749200)
- Include [env] compare (perma): TESTING: increase timeout to ensure OS is able to create core dump/crash log
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:3077 (perma): kodi: use project specific cputemp scripts for all projects
- Include [env] PR:3084 (perma): linux (RPi/Generic): update to linux-4.19.1
- Include [env] PR:3089 (perma): iptables: update to iptables-1.8.1
Build Highlights:
- Reintroduce crazycat: update to 2018-11-04
Build Details:
- LibreELEC.tv:
- HACK: fix audio for WP1 (PR:3080, 2 commits, 2 files changed)
- librespot: update to 96557b4 (PR:3086, 2 commits, 6 files changed)
- WeTek_Core/WeTek_Play: fixup libcec support (PR:3091, 1 commit, 2 files changed)
- crazycat: update to 2018-11-04 (PR:3088, 3 commits, 4 files changed)
- XBMC:
- [GUI] reinitialize addon path after returning with .. directory item (PR:14803, 1 commit, 1 file changed)
- libcec:
- Modifies NSIS script to call EventGhost to install the plugin (PR:375, 2 commits, 9 files changed)
- fixed: don't poll samsung TVs. issue #424 (f87328d)
- fixed: creating windows installer (009d54b)
- pvr.dvbviewer:
- Add file flags to StreamReader as suggested by FernetMenta (c2e97a1)
- Move more classes to dvbviewer namespace (f98999f)
- Add support for (on-the-fly) transcoding of recordings (0025954)
- appveyor: run apt-get update (8dd1ddb)
- fix 32 bits time_t (e801485)
- Bump version to 3.7.5 (a9b204e)
- Updated: [env] PR:3089 (perma): iptables: update to iptables-1.8.1
If I want a very clean instalation of your builds, what official Libreelec version would be best before I update your versions? The new Alpha versions or one of the 8.2.5 version?
(2018-11-09, 03:13)Luck Wrote: [ -> ]If I want a very clean instalation of your builds, what official Libreelec version would be best before I update your versions? The new Alpha versions or one of the 8.2.5 version?
The latest LE9 Alpha will be closer to these builds than 8.2.5. If you want to install directly from these builds then
1) Write 8.90.00x to a USB memory stick
Either:
2a) Boot the memory stick into
run
mode and copy the tar into the Update folder and reboot (again using
run
mode) so that the USB memory stick is upgraded to my build
or
2b) Copy the KERNEL and SYSTEM files from a Milhouse tar file to the root of the USB memory stick
Then:
3) Boot from the memory stick using the
installer
mode to install my build to your HDD/SSD
Edit: Forgot this was the RPi thread. Ignore this list as the instructions only apply to a Generic install. For RPi, write the LE9 alpha image to your SD card, boot it in the RPi and then update it with a Milhouse build.
New LibreELEC.tv Leia build #1108:
RPi /
RPi2
SHA256 Checksum:
377c25c17bbfccb4532bb541806e09a577af86cb8cb835160ec73f17cb37f6f3
(RPi)
SHA256 Checksum:
be1ffbdb44eb65c69caf06f10b3e81e573640af35be08ccb77213dd92c0c8a79
(RPi2)
text:
# uname -a
Linux rpi512 4.19.1 #1 Thu Nov 8 21:03:54 GMT 2018 armv6l GNU/Linux
# vcgencmd version
Nov 4 2018 16:35:17
# lsb_release
LibreELEC (Milhouse): devel-20181108210234-#1108-ge8e2816 [Build #1108]
# Kodi version
(18.0-RC1 Git:c674db0). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (e8e2816,
XBMC master (c674db0,
- Includes latest libcec master (d57d3ac, ahead +7)
- Includes latest addons: inputstream.adaptive (d1bb1eb, +3), inputstream.rtmp (ce7f559), peripheral.joystick (2008fdc, +1), peripheral.xarcade (f09a0e7, +1), pvr.argustv (609a2e7, +2), pvr.demo (964686d), pvr.dvblink (47cbff0, +2), pvr.dvbviewer (a9b204e, +8), pvr.filmon (f736ab4, +2), pvr.hdhomerun (a9d7309, +1), pvr.hts (f4ea60f, +2), pvr.iptvsimple (90a8d6f, +1), pvr.mediaportal.tvserver (e4a9dae, +2), pvr.mythtv (db3e73b, +4), pvr.nextpvr (7e36106, +2), pvr.njoy (4467cac, +1), pvr.octonet (203f800), pvr.pctv (e28a90f, +2), pvr.stalker (a99ad5e, +2), pvr.teleboy (484db31), pvr.vbox (6ed2f63, +2), pvr.vdr.vnsi (6bbdb78), pvr.vuplus (d77458b, +2), pvr.wmc (e00c895, +2), pvr.zattoo (41268ee), vfs.libarchive (6d39012), vfs.sftp (6749200)
- Include [env] PR:3092 (perma): samba: update to samba-4.9.2
Build Highlights:
- samba: update to samba-4.9.2
- libcec 4.0.3
- [Settings] Implement FindIntInList in CSettingList
Build Details:
- LibreELEC.tv:
- lcdd: build with optimization (PR:3094, 1 commit, 2 files changed)
- XBMC:
- windowing/gbm: fallback to non-alpha visual id (PR:14785, 3 commits, 7 files changed)
- [Settings] Implement FindIntInList in CSettingList (PR:14815, 1 commit, 3 files changed)
- [macos] [filemanager] Removable storage fixes/improvements (PR:14818, 2 commits, 6 files changed)
- [osx/windowing] - fix "blank other displays" (PR:14822, 1 commit, 1 file changed)
- [macos] CDarwinStorageProvider::Eject: Fix crash due to double release of DADiskRef instance. (PR:14827, 2 commits, 1 file changed)
- libcec:
- changed/fixed: install cec-client by default. correct vs redist (6c76f5f)
- changed: build with vs 2015 (d8bd948)
- bump to 4.0.3 (d57d3ac)
- pvr.mythtv:
New LibreELEC.tv Leia build #1109:
RPi /
RPi2
SHA256 Checksum:
c4265dc52004fd20d3e6197c4aefa759e137b0ef18df6b8ec91ad1be48c6906d
(RPi)
SHA256 Checksum:
38ef5b04a53bf3fb202727c733e89fb2b04b3a07aff75423fc35525aacb63973
(RPi2)
text:
# uname -a
Linux rpi512 4.19.1 #1 Fri Nov 9 21:04:26 GMT 2018 armv6l GNU/Linux
# vcgencmd version
Nov 4 2018 16:35:17
# lsb_release
LibreELEC (Milhouse): devel-20181109210312-#1109-ge8e2816 [Build #1109]
# Kodi version
(18.0-RC1 Git:a948f99). Platform: Linux ARM 32-bit
Based on tip of
XBMC master (a948f99,
- Includes latest addons: inputstream.adaptive (0bd5159, +5), inputstream.rtmp (ce7f559), peripheral.joystick (2008fdc, +1), peripheral.xarcade (f09a0e7, +1), pvr.argustv (609a2e7, +2), pvr.demo (964686d), pvr.dvblink (47cbff0, +2), pvr.dvbviewer (a9b204e, +8), pvr.filmon (f736ab4, +2), pvr.hdhomerun (a9d7309, +1), pvr.hts (f4ea60f, +2), pvr.iptvsimple (90a8d6f, +1), pvr.mediaportal.tvserver (e4a9dae, +2), pvr.mythtv (8150695, +8), pvr.nextpvr (7e36106, +2), pvr.njoy (4467cac, +1), pvr.octonet (203f800), pvr.pctv (e28a90f, +2), pvr.stalker (a99ad5e, +2), pvr.teleboy (484db31), pvr.vbox (6ed2f63, +2), pvr.vdr.vnsi (6bbdb78), pvr.vuplus (d77458b, +2), pvr.wmc (e00c895, +2), pvr.zattoo (278d4be, +4), vfs.libarchive (6d39012), vfs.sftp (6749200)
Build Highlights:
- pvr.zattoo: Fix segfault strlen
Build Details:
- XBMC:
- windowing/gbm: set default plane formats and use the getter methods (PR:14821, 1 commit, 3 files changed)
- windowing/gbm: use the drm render node fd for the vaapi proxy (PR:14820, 3 commits, 9 files changed)
- [cmake] fix building with internal fmt (PR:14830, 1 commit, 1 file changed)
- inputstream.adaptive:
- [WVD] Implement full body encoding (395b7b4)
- [WVD] fix placeholder offsets (0bd5159)
- pvr.mythtv:
- remove special characters in label of built in recording group (2c0289a)
- rename formattedTitle to groupingTitle (bb446c0)
- update travis.yml (8a94280)
- bump version 5.8.16 (8150695)
- pvr.zattoo:
- Fix segfault strlen (PR:30, 3 commits, 4 files changed)
- Update version and changelog (278d4be)
Hi Milhouse,
pvr.zattoo seems to be broken, but it's already fixed in version 18.0.57 upstream (
https://github.com/rbuehlma/pvr.zattoo/issues/31). Would it be possible to have a new build including those changes? If you don't have time for it, no problem, I will wait for the next release.
New LibreELEC.tv Leia build #1110:
RPi /
RPi2
SHA256 Checksum:
080567f6a0adff4ebae7d17640fc5786bd3c67f2809a485b7ef0cde3170c64b1
(RPi)
SHA256 Checksum:
16e9f4ab49fb372e515437c4c869274b36a6a1d181a00171e9f5e8220aec1822
(RPi2)
text:
# uname -a
Linux rpi512 4.19.1 #1 Sat Nov 10 21:03:47 GMT 2018 armv6l GNU/Linux
# vcgencmd version
Nov 4 2018 16:35:17
# lsb_release
LibreELEC (Milhouse): devel-20181110210238-#1110-ge8e2816 [Build #1110]
# Kodi version
(18.0-RC1 Git:0364561). Platform: Linux ARM 32-bit
Based on tip of
XBMC master (0364561,
- Includes latest addons: inputstream.adaptive (0bd5159, +5), inputstream.rtmp (ce7f559), peripheral.joystick (2008fdc, +1), peripheral.xarcade (f09a0e7, +1), pvr.argustv (609a2e7, +2), pvr.demo (964686d), pvr.dvblink (47cbff0, +2), pvr.dvbviewer (a9b204e, +8), pvr.filmon (f736ab4, +2), pvr.hdhomerun (a9d7309, +1), pvr.hts (f4ea60f, +2), pvr.iptvsimple (90a8d6f, +1), pvr.mediaportal.tvserver (e4a9dae, +2), pvr.mythtv (bf90418, +10), pvr.nextpvr (7e36106, +2), pvr.njoy (4467cac, +1), pvr.octonet (203f800), pvr.pctv (e28a90f, +2), pvr.stalker (a99ad5e, +2), pvr.teleboy (bdbd6b2, +3), pvr.vbox (6ed2f63, +2), pvr.vdr.vnsi (6bbdb78), pvr.vuplus (d77458b, +2), pvr.wmc (e00c895, +2), pvr.zattoo (8ddb060, +7), vfs.libarchive (6d39012), vfs.sftp (6749200)
Build Highlights:
- [PVR] New PVR playback setting: 'Delay mark last watched'.
Build Details:
- XBMC:
- Add missing epoll header (PR:14570, 1 commit, 1 file changed)
- [PVR] New PVR playback setting: 'Delay mark last watched'. (PR:14836, 2 commits, 7 files changed)
- [PVR] Make 'Simple Timeshift OSD' an advanced setting; remove corresponding standard setting. (PR:14840, 1 commit, 6 files changed)
- [filemanager] Fix crash due to multiple busy dialog request. (PR:14839, 1 commit, 2 files changed)
- pvr.mythtv:
- fix unusable wstring_convert for my platform ;-) (52d22cf)
- bump version 5.8.17 (bf90418)
- pvr.teleboy:
- Reduce logging to LOG_NOTICE (c6c4e53)
- Port GetStringOrEmpty from pvr.zattoo (fbf26cb)
- Update version and changelog (bdbd6b2)
- pvr.zattoo:
- modernize & bugfixing (#28) (6188857)
- Fix channels not loading (1831339)
- Update version and changelog (8ddb060)
(2018-11-11, 01:24)goggle Wrote: [ -> ]Hi Milhouse,
pvr.zattoo seems to be broken, but it's already fixed in version 18.0.57 upstream (https://github.com/rbuehlma/pvr.zattoo/issues/31). Would it be possible to have a new build including those changes? If you don't have time for it, no problem, I will wait for the next release.
Try #1110, it includes all the latest pvr.zattoo commits.
Thank you, now it works again as it did before.
New LibreELEC.tv Leia build #1111:
RPi /
RPi2
SHA256 Checksum:
e3ee68349f06cb84a0f91d4e5d5cf3d79c6d7f08a11cdcad213137399e196d6c
(RPi)
SHA256 Checksum:
ec30be5c88c5d0b1efd89278c97b38c672afb277f72634abededdfd97a44d8a4
(RPi2)
text:
# uname -a
Linux rpi512 4.19.1 #1 Sun Nov 11 21:04:04 GMT 2018 armv6l GNU/Linux
# vcgencmd version
Nov 4 2018 16:35:17
# lsb_release
LibreELEC (Milhouse): devel-20181111210220-#1111-ge496bf6 [Build #1111]
# Kodi version
(18.0-RC1 Git:c895e84). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (e496bf6,
XBMC master (c895e84,
- Includes latest addons: inputstream.adaptive (0bd5159, +5), inputstream.rtmp (ce7f559), peripheral.joystick (2008fdc, +1), peripheral.xarcade (f09a0e7, +1), pvr.argustv (609a2e7, +2), pvr.demo (964686d), pvr.dvblink (47cbff0, +2), pvr.dvbviewer (a9b204e, +8), pvr.filmon (f736ab4, +2), pvr.hdhomerun (a9d7309, +1), pvr.hts (f4ea60f, +2), pvr.iptvsimple (90a8d6f, +1), pvr.mediaportal.tvserver (e4a9dae, +2), pvr.mythtv (0517d4b, +17), pvr.nextpvr (7e36106, +2), pvr.njoy (4467cac, +1), pvr.octonet (203f800), pvr.pctv (e28a90f, +2), pvr.stalker (a99ad5e, +2), pvr.teleboy (bdbd6b2, +3), pvr.vbox (6ed2f63, +2), pvr.vdr.vnsi (6bbdb78), pvr.vuplus (d77458b, +2), pvr.wmc (e00c895, +2), pvr.zattoo (8ddb060, +7), vfs.libarchive (6d39012), vfs.sftp (6749200)
- Include [env] compare (perma): kodi: next
- Include [pkg] PR:14852 (perma): LinuxRenderGL: Properly draw black quads on area we manage
Build Highlights:
- [PVR] Remove 'Use simple Timeshift OSD' setting from settings.xml.
Build Details:
- LibreELEC.tv:
- kodi: use project specific cputemp scripts for all projects (PR:3077, 1 commit, 18 files changed)
- samba: update to samba-4.9.2 (PR:3092, 1 commit, 1 file changed)
- projects/WeTek_Core: Load amlvideodri module at startup (PR:3100, 1 commit, 1 file changed)
- XBMC:
- [PVR] Remove 'Use simple Timeshift OSD' setting from settings.xml. (PR:14846, 1 commit, 1 file changed)
- [cmake] Rework FindJsonSchemaBuilder on the model of FindTextureBuilder (PR:14774, 1 commit, 1 file changed)
- Fix screensaver/DPMS interaction (PR:14845, 3 commits, 1 file changed)
- Allow StartPercent property to be 0 (PR:14649, 1 commit, 1 file changed)
- [skin.estouchy] Fix order in Recent Movies (PR:14837, 1 commit, 1 file changed)
- pvr.mythtv:
- fill date of airdate as needed (b00d18d)
- show status of recording (630e0de)
- show status of broadcast (e00e0a0)
- include fr_FR map for eit categories (73b3218)
- bump version 5.8.18 (bd697d5)
- Non zero startTime for recording stream breaks played position (303158e)
- bump version 5.8.19 (0517d4b)
- Added: [env] compare (perma): kodi: next
- Added: [pkg] PR:14852 (perma): LinuxRenderGL: Properly draw black quads on area we manage
New LibreELEC.tv Leia build #1112:
RPi /
RPi2
SHA256 Checksum:
a3c2ed1a39ad66d2283d63e4c12ccc48e42a0438f7fdab2f3526809c58d1de33
(RPi)
SHA256 Checksum:
0a8a1d35ab06f1e0062253663046d96f2c983ce49cc6c61a38ee64f97b976558
(RPi2)
text:
# uname -a
Linux rpi512 4.19.1 #1 Mon Nov 12 21:33:50 GMT 2018 armv6l GNU/Linux
# vcgencmd version
Nov 4 2018 16:35:17
# lsb_release
LibreELEC (Milhouse): devel-20181112213214-#1112-ge700f53 [Build #1112]
# Kodi version
(18.0-RC1 Git:b3a7d3c). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (e700f53,
XBMC master (b3a7d3c,
- Includes latest bcm2835-driver master (86e3ccc, ahead +2)
- Includes latest addons: inputstream.adaptive (7f28ac0, +7), inputstream.rtmp (ce7f559), peripheral.joystick (2008fdc, +1), peripheral.xarcade (f09a0e7, +1), pvr.argustv (609a2e7, +2), pvr.demo (964686d), pvr.dvblink (47cbff0, +2), pvr.dvbviewer (a9b204e, +8), pvr.filmon (f736ab4, +2), pvr.hdhomerun (a9d7309, +1), pvr.hts (f4ea60f, +2), pvr.iptvsimple (90a8d6f, +1), pvr.mediaportal.tvserver (e4a9dae, +2), pvr.mythtv (0517d4b, +17), pvr.nextpvr (7e36106, +2), pvr.njoy (4467cac, +1), pvr.octonet (203f800), pvr.pctv (e28a90f, +2), pvr.stalker (a99ad5e, +2), pvr.teleboy (bdbd6b2, +3), pvr.vbox (6ed2f63, +2), pvr.vdr.vnsi (cbb75ab, +3), pvr.vuplus (d77458b, +2), pvr.wmc (e00c895, +2), pvr.zattoo (8ddb060, +7), vfs.libarchive (6d39012), vfs.sftp (6749200)
Build Highlights:
- inputstream-adaptive, pvr.vdr.vnsi updates
Build Details:
- LibreELEC.tv:
- kodi: use relative sym link path to keep page build happy (PR:3101, 1 commit, 6 files changed)
- u-boot: Bump to 2018.09 (PR:3096, 1 commit, 3 files changed)
- XBMC:
- [settings] fix typo in UPNP setting description (PR:14851, 1 commit, 1 file changed)
- pvr.vdr.vnsi:
- fix ubuntu packaging (PR:19, 1 commit, 2 files changed)
- fix failing load of vnsi caused by failing call to WakeOnLan (8627064)
- bump version to 3.6.2 (11df9b4)
- Updated: [env] PR:3084 (perma): linux (RPi/Generic): update to linux-4.19.1
(2018-10-28, 00:40)garbear Wrote: [ -> ] (2018-10-27, 19:26)Milhouse Wrote: [ -> ]The problem is I don't have the bandwidth to build all the game addons and keep them in sync with the core APIs so this type of breakage is inevitable I'm afraid. You'll have to wait until the LE 9.0 repository is updated with new game add-ons, but I don't know when that will happen.
Good news, Game API is now frozen for Leia so no more bumps until we branch for M*.
LE Alpha7 - still not able to play a game because of
The dependency for kodi.binary.instance.game in version 1.0.38 couldn't be resolved
Thx in advance for updating the game-addons
I have a problem with Kodi stop responding after a few days when not used. I use a RPi 3 with power adapter bought from the "The Pi Hut".
This is the log zip file that is produced after manual reboot, removing power.
https://drive.google.com/open?id=1EE7OWU...QOUlBMud3f
I don't know if a reason to the problem is that I have both Kodi and a STB using the same remote. So when I don't use Kodi I open some window that hopefully will catch all possible input from the remote, but wont start or delete anything in Kodi. It usually is in search addons, and IP address input.
I upgraded to the latest version I could before I left Kodi alone for a couple of days. But since it take some time it would be impossible to always use the latest.
New LibreELEC.tv Leia build #1113:
RPi /
RPi2
SHA256 Checksum:
3cd1f88906cea5ea79cd0fff97b6b9ae3eabbf82048cdd55e7cb7e0b0d18d591
(RPi)
SHA256 Checksum:
aa2b825f8b7d5244ca8091bedb794d0bbc0b1ded5dd68817af104c6aa62c71f6
(RPi2)
text:
# uname -a
Linux rpi512 4.19.1 #1 Tue Nov 13 22:13:27 GMT 2018 armv6l GNU/Linux
# vcgencmd version
Nov 4 2018 16:35:17
# lsb_release
LibreELEC (Milhouse): devel-20181113220935-#1113-gfcca549 [Build #1113]
# Kodi version
(18.0-RC1 Git:fce4d88). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (fcca549,
XBMC master (fce4d88,
- Includes latest libcec master (d57d3ac)
- Includes latest addons: inputstream.adaptive (1261018, +10), inputstream.rtmp (ce7f559), peripheral.joystick (2008fdc, +1), peripheral.xarcade (f09a0e7, +1), pvr.argustv (609a2e7, +2), pvr.demo (964686d), pvr.dvblink (47cbff0, +2), pvr.dvbviewer (a9b204e, +8), pvr.filmon (f736ab4, +2), pvr.hdhomerun (a9d7309, +1), pvr.hts (f4ea60f, +2), pvr.iptvsimple (90a8d6f, +1), pvr.mediaportal.tvserver (e4a9dae, +2), pvr.mythtv (0517d4b, +17), pvr.nextpvr (7e36106, +2), pvr.njoy (4467cac, +1), pvr.octonet (203f800), pvr.pctv (e28a90f, +2), pvr.stalker (a99ad5e, +2), pvr.teleboy (bdbd6b2, +3), pvr.vbox (6ed2f63, +2), pvr.vdr.vnsi (cbb75ab, +3), pvr.vuplus (d77458b, +2), pvr.wmc (e00c895, +2), pvr.zattoo (8ddb060, +7), vfs.libarchive (6d39012), vfs.sftp (6749200)
- Include [env] PR:3098 (perma): Buildsystem: mkimage / get cleanup
Build Highlights:
- [pvr] Fix channel sorting. Fixes #14854
- libcec-4.0.3
Build Details:
- LibreELEC.tv:
- silence jenkins (PR:3103, 1 commit, 4 files changed)
- hyperion: update to 1d125d8 (PR:3095, 1 commit, 3 files changed)
- XBMC:
- [pvr] Fix channel sorting. Fixes #14854. (PR:14864, 1 commit, 4 files changed)
- fix: ass subtitle render wrong when play half-sbs/half-ou 3d movie (PR:14853, 1 commit, 3 files changed)
- [video] Fix #14847 - Take 3 ;-) (PR:14863, 1 commit, 1 file changed)
- LinuxRenderGL: Properly draw black quads on area we manage (PR:14852, 1 commit, 1 file changed)
- [GLES] cleanup vsync implementation (PR:14834, 1 commit, 6 files changed)
- windowing/gbm: rename planes (PR:14848, 1 commit, 6 files changed)
- Separate shown plots for unwatched items (PR:14489, 1 commit, 5 files changed)
- [WebVTT] rlm / lrm marker conversion (d713b95)
- [MPD] read role from subtitle adaptationset (forced) (74dcee4)
- [WebVTT] rlm -> rle hack for right to left languages (1261018)
- newclock5:
- New commits in this build:
- Revert "FIX: Only handle 3D bitmap subs in TAB" (86854b6d)
- Updated: [env] compare (perma): kodi: next
- Added: [env] PR:3098 (perma): Buildsystem: mkimage / get cleanup
