(2017-01-28, 14:14)popcornmix Wrote: [ -> ] (2017-01-28, 09:01)polo_joe Wrote: [ -> ]I'm running kodi + tvh on my rpi3 and I'm experiencing recording errors, when tvh is recording and I'm streaming videos at the same time. If I'm watching the channels live, there's no problem at all.
Could this be a usb bandwith issue?
Most likely. Is the tvheadend backend on the same Pi?
Does disabling deinterlace make any difference?
tvh backend is on the same pi. today I made a recording without streaming (tv was off) and there were also coninuity errors. So should be a tvh problem. Watching livetv works for hours without issues. Anything I could do to dig deeper?
2017-01-28 11:20:10.846 [ INFO] dvr: "Der Doktor und das liebe Vieh" on "ServusTV HD Oesterreich" recorder starting
2017-01-28 11:20:10.847 [ INFO] mpegts: 11302.75H in Astra 19,2 - tuning on TechnoTrend S2-4600
2017-01-28 11:20:10.886 [ INFO] capmt: Oscam: Starting CAPMT server for service "ServusTV HD Oesterreich" on adapter 0
2017-01-28 11:20:10.887 [ INFO] subscription: 0033: "DVR: Der Doktor und das liebe Vieh" subscribing on channel "ServusTV HD Oesterreich", weight: 300, adapter: "TechnoTrend S2-4600", network: "Astra 19,2", mux: "11302.75H", provider: "ServusTV", service: "ServusTV HD Oesterreich", profile="pass"
2017-01-28 11:20:13.041 [ INFO] dvr: /storage/recordings/Der Doktor und das liebe Vieh.ts from adapter: "TechnoTrend S2-4600", network: "Astra 19,2", mux: "11302.75H", provider: "ServusTV", service: "ServusTV HD Oesterreich"
2017-01-28 11:20:13.041 [ INFO] dvr: # type lang resolution aspect ratio sample rate channels
2017-01-28 11:20:13.041 [ INFO] dvr: 1 H264 1920x1080 ?
2017-01-28 11:20:13.041 [ INFO] dvr: 2 MPEG2AUDIO ger ? ?
2017-01-28 11:20:13.041 [ INFO] dvr: 3 MPEG2AUDIO eng ? ?
2017-01-28 11:20:13.041 [ INFO] dvr: 4 AC3 ger ? ?
2017-01-28 11:20:13.041 [ INFO] dvr: 5 TELETEXT
2017-01-28 11:20:13.041 [ INFO] dvr: 6 EAC3 ger ? ?
2017-01-28 11:20:13.041 [ INFO] dvr: 7 CA
2017-01-28 11:20:13.041 [ INFO] dvr: 8 CA
2017-01-28 11:20:13.041 [ INFO] dvr: 9 CA
2017-01-28 11:20:13.041 [ INFO] dvr: 10 CA
2017-01-28 11:20:13.041 [ INFO] dvr: 11 CA
2017-01-28 11:20:13.041 [ INFO] dvr: 12 CA
2017-01-28 11:20:13.041 [ INFO] dvr: 13 CA
2017-01-28 11:26:09.216 [WARNING] TS: Astra 19,2/11302.75H/ServusTV HD Oesterreich: H264 @ #3583 Continuity counter error (total 1)
2017-01-28 11:26:09.216 [WARNING] TS: Astra 19,2/11302.75H/ServusTV HD Oesterreich: AC3 @ #3587 Continuity counter error (total 1)
2017-01-28 11:26:09.216 [WARNING] TS: Astra 19,2/11302.75H/ServusTV HD Oesterreich: EAC3 @ #3589 Continuity counter error (total 1)
2017-01-28 11:28:59.869 [ INFO] subscription: 0033: "DVR: Der Doktor und das liebe Vieh" unsubscribing from "ServusTV HD Oesterreich"
2017-01-28 11:28:59.872 [ INFO] dvr: "Der Doktor und das liebe Vieh" on "ServusTV HD Oesterreich": End of program: Completed OK
