First, hello
Second, could anyone help me? I'm having annoying problems with the most current versions. Whenever I upgrade from 8.2.5 to any trial version 9.0, I simply can not use anything else that involves the internet, even though I'm connected.
(2018-12-19, 04:10)uMarcello Wrote: [ -> ]First, hello
Without a log, nobody can help. Upload the output of
journalctl -a
and post the link.
Describe your setup - is it RPi0, RPi1, RPi2, RPi3, RPi3+? WiFi or wired ethernet? Static IP or DHCP?
Chances are it's a problem with your network. Try enabling "Wait for network" if you RPi is slow to get an IP address. If you're using a USB dongle for connectivity, maybe it's a firmware issue (journalctl output will help).
(2018-12-19, 07:10)Milhouse Wrote: [ -> ] (2018-12-19, 04:10)uMarcello Wrote: [ -> ]First, hello
Without a log, nobody can help. Upload the output of journalctl -a
and post the link.
Log Link:
http://ix.io/1wlr
I in case I use the RPi3. This started when I switched my broadband provider. All my devices just went crazy, but I went to my router and reconfigured and everything went back to normal. But Kodi / LibreELEC continues to bug, and in the stable / old version it works relatively well. Already upgrading to trial version, 9.0, it starts to give error after another. Another thing. I tested the OSMC and it worked perfectly well without any error.
(2018-12-19, 15:32)uMarcello Wrote: [ -> ]This started when I switched my broadband provider. All my devices just went crazy, but I went to my router and reconfigured and everything went back to normal.
Try disabling IPv6 support in your new broadband router.
Milhouse
Just wondering, do you recommend to generally disable IPv6 Support on RPi and Broadband Router?
(2018-12-19, 20:09)DTR81 Wrote: [ -> ]@Milhouse
There may be some unwanted IPv6/iptables interaction, which is being investigated.
Editing the connection and disabling IPv6 is probably the first thing to try (Settings > LibreELEC > Connections > (edit connection) > IPv6 -> Off)
But if that doesn't work, then disable IPv6 in the router, and see if that helps.
Disabling IPv6 is only a short-term solution, as we should be able to support IPv6 eventually.
uMarcello can you try disabling IPv6 support in the LibreELEC Settings add-on first, as that's likely to be the easiest solution for now.
(2018-12-19, 19:50)Milhouse Wrote: [ -> ] (2018-12-19, 15:32)uMarcello Wrote: [ -> ]This started when I switched my broadband provider. All my devices just went crazy, but I went to my router and reconfigured and everything went back to normal.
Unfortunately my modem does not support IPv6. As I said, OSMC and other OS work perfectly. Only LibreELEC has this problem.
UPDATE:
Just look here and I noticed that IPv6 is disabled.
(2018-12-19, 22:13)uMarcello Wrote: [ -> ] (2018-12-19, 19:50)Milhouse Wrote: [ -> ] (2018-12-19, 15:32)uMarcello Wrote: [ -> ]This started when I switched my broadband provider. All my devices just went crazy, but I went to my router and reconfigured and everything went back to normal.
Ok, then try disabling IPv6 support for the connection in the LibreELEC Settings add-on.
(2018-12-19, 22:44)Milhouse Wrote: [ -> ] (2018-12-19, 22:13)uMarcello Wrote: [ -> ] (2018-12-19, 19:50)Milhouse Wrote: [ -> ]Try disabling IPv6 support in your new broadband router.
The problem is already there. Only IPv4 with fixed IP is active. I looked the error deeper and he said something with "
certificate".
(2018-12-19, 22:58)uMarcello Wrote: [ -> ]I looked the error deeper and he said something with "certificate".
The certificate error is caused by a wrong system date - the logs showed your system is still back in june (which is before the begin of the certificate validity date).
The cause of the wrong system date is NTP failing - it's trying to get the current date from a bunch of NTP servers with IPv6 IPs which all fail.
Also check the NTP server section in LE settings - if all NTP server entries are blank the default servers are used which should work.
so long,
Hias
New LibreELEC.tv Leia build #1219:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
d179c1c6e018458bac2767129e9661856af2947f26354b9b81cb15b3bb57982c
(RPi)
SHA256 Checksum:
3d5c12f22b9894e15cc3fd9cccc76b851feca020519b377a2b7d6b16eddd878e
(RPi2)
text:
# uname -a
Linux rpi512 4.19.10 #1 Wed Dec 19 21:04:35 GMT 2018 armv6l GNU/Linux
# vcgencmd version
Dec 18 2018 00:00:23
Copyright © 2012 Broadcom
version da468960fe03ecbaa8e3f1ee01c7217c3bd01fa8 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20181219210322-#1219-g9bb4495 [Build #1219]
# Kodi version
(18.0-RC4 Git:76b5ba8). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (9bb4495,
changelog) and tip of
XBMC master (76b5ba8,
- Includes newclock5 patches
- Includes latest bcm2835-driver master (1ea8781)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (f759324)
- Includes latest libnfs master (84a4d97, ahead +11)
- Includes latest p8-platform master (1eb12b1)
- Includes latest addons: inputstream.adaptive (efd4b4f), inputstream.rtmp (ce7f559), peripheral.joystick (1f4225a), peripheral.xarcade (f09a0e7), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (4ae42fe), pvr.dvbviewer (cda813e), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (73512af, +1), pvr.iptvsimple (90a8d6f), pvr.mediaportal.tvserver (25e3e7d), pvr.mythtv (d3a5af2), pvr.nextpvr (ccdfd63), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv (b60b971), pvr.stalker (2245b0d), pvr.teleboy (50689bd), pvr.vbox (6ed2f63), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (1207082), pvr.wmc (81e2090), pvr.zattoo (4688f45), vfs.libarchive (6d39012), vfs.rar (0f56401), vfs.sftp (6749200)
- Include [env] compare (perma): TESTING: increase timeout to ensure OS is able to create core dump/crash log
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:3156 (perma): web: update to libmicrohttpd-0.9.61/curl-7.62.0
- Include [env] PR:3164 (perma): ffmpegx: disable nonfree
- Include [env] PR:3166 (perma): linux (RPi/Generic): update to linux-4.19.11
- Include [env] PR:3171 (perma): buildsystem: centralise package sourcing
- Include [env] PR:3174 (perma): linux (RPi) config: enable bcm2835 miniuart
- Include [pkg] PR:10 (perma): DSF: Upstream picks (ffmpeg)
- Include [pkg] PR:109 (perma): change LE urls (service.libreelec.settings)
- Include [pkg] PR:137 (perma): Load config if enabled (pvr.vuplus)
- Include [pkg] PR:14924 (perma): [games] Fix crash in PCSX ReARMed with BIOS
- Include [pkg] PR:15016 (perma): Resolution: Don't add half refreshrates by default
Build Highlights:
- Fix watched items in plugins after updating Kodi
Build Details:
- LibreELEC.tv:
- tini: fix typos (PR:3176, 1 commit, 1 file changed)
- XBMC:
- Fix watched items in plugins after updating Kodi (PR:14992, 1 commit, 1 file changed)
- [macos] Remove storage mount/unmount popups (PR:15088, 2 commits, 2 files changed)
- Updated: [env] PR:3166 (perma): linux (RPi/Generic): update to linux-4.19.11
- Updated: [pkg] PR:109 (perma): change LE urls (service.libreelec.settings)
New LibreELEC.tv Leia build #1220:
RPi /
RPi2
SHA256 Checksum:
11711f48ca5b13837bcf9311b8d7b32ee89ea188f5c2d59ea3b2cfe72b80b93e
(RPi)
SHA256 Checksum:
262bae59b6f75909244148f53cc033197d8f7cadc64b784df1f752d0871194b5
(RPi2)
text:
# uname -a
Linux rpi512 4.19.10 #1 Thu Dec 20 21:28:41 GMT 2018 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20181220212731-#1220-g9bb4495 [Build #1220]
# Kodi version
(18.0-RC4 Git:7439ef5). Platform: Linux ARM 32-bit
Based on tip of
XBMC master (7439ef5,
- Includes latest addons: inputstream.adaptive (efd4b4f), inputstream.rtmp (ce7f559), peripheral.joystick (1f4225a), peripheral.xarcade (f09a0e7), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (4ae42fe), pvr.dvbviewer (0aa6070, +1), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (d35dfcd, +2), pvr.iptvsimple (90a8d6f), pvr.mediaportal.tvserver (25e3e7d), pvr.mythtv (d3a5af2), pvr.nextpvr (450caeb, +1), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv (b60b971), pvr.stalker (2245b0d), pvr.teleboy (50689bd), pvr.vbox (6ed2f63), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (c3d984b, +1), pvr.wmc (2697409, +1), pvr.zattoo (4688f45), vfs.libarchive (6d39012), vfs.rar (0f56401), vfs.sftp (6749200)
- Include [env] compare (perma): kodi (RPi/Generic): next
- Include [env] PR:3178 (perma): samba: update to samba-4.9.4
- Include [pkg] PR:15099 (perma): Do not list non-repo add-ons as "unavailable" in info dialog
Build Highlights:
- samba: update to samba-4.9.4
- Kodi: Do not list non-repo add-ons as "unavailable" in info dialog
- Kodi: Inhibit screensaver in a later initialization stage
- Update LibreELEC Settings addon (wording, in Kodi PR)
Build Details:
- XBMC:
- Inhibit screensaver in a later initialization stage (PR:15094, 1 commit, 1 file changed)
- Update README.FreeBSD.md (PR:15074, 1 commit, 1 file changed)
- Replace kodi_temp_key.pfx (PR:15098, 1 commit, 1 file changed)
- Update sqlite to 3.26.0 (PR:15091, 1 commit, 2 files changed)
- Add missing dirty region update in GUIFadeLabelControl (PR:15097, 1 commit, 1 file changed)
- [json-rpc][pvr] Fix 'PVR.Record'. (PR:15093, 1 commit, 2 files changed)
- python scripts: add missing icons (PR:15100, 1 commit, 2 files changed)
- [lang][skin.estuary] updated language files from Transifex (dab30ad)
- [lang][skin.estouchy] updated language files from Transifex (7439ef5)
- pvr.dvbviewer:
- [lang] updated language files from Transifex (0aa6070)
- pvr.hts:
- [lang] updated language files from Transifex (d35dfcd)
- pvr.nextpvr:
- [lang] updated language files from Transifex (450caeb)
- pvr.vuplus:
- [lang] updated language files from Transifex (c3d984b)
- pvr.wmc:
- [lang] updated language files from Transifex (2697409)
- Added: [env] compare (perma): kodi (RPi/Generic): next
- Added: [env] PR:3178 (perma): samba: update to samba-4.9.4
- Added: [pkg] PR:15099 (perma): Do not list non-repo add-ons as "unavailable" in info dialog
Currently have an android box (905x) and have used Libreelec and Kodi. Everything works with the exception of Blu-ray Iso menu. With Kodi 18, I understand that under windows, Blu-ray iso works showing the menu as it has java.
I was reading on the Libreelec forum that the Raspberry Pi using Libreelec also shows proper Blu-ray menu including BR-J. I am happy to buy a Raspberry Pi 3 Model B+ if it does both DVD and Blu-ray iso and shows full menu. Looking for some advice whether that is the case.
