(2019-02-13, 18:47)Malocher Wrote: [ -> ]My TV picture is after the run up of kodi often once short black. In the build # 0212 the TV picture was synonymous after the end of a movie briefly black.
I think something happens in the background with the resolution of the TV screen.
I'm not really sure what you are saying, but is the problem present in #0211? If not when does it start?
Assuming English is not your first language and that you've used Google translate, it might be best to post again in your spoken language and we can try to find someone to translate it.
I have a Raspi 3 on a Philips TV and sometimes when I boot the Raspi Libreelec does not recognize the HD Resolution of the TV. In some cases I cannot change the resolution as it is grayed out (in most cases a reboot does the trick), but in some other cases I then can change the resolution to 1080x1920.
Is there any file I can edit to have the resolution hard set, so the Raspi does not forget it?
(2019-02-13, 22:49)Ich-bin-Knuffi Wrote: [ -> ]I have a Raspi 3 on a Philips TV and sometimes when I boot the Raspi Libreelec does not recognize the HD Resolution of the TV. In some cases I cannot change the resolution as it is grayed out (in most cases a reboot does the trick), but in some other cases I then can change the resolution to 1080x1920.
Most likely you are switching on the RPi before the TV and it's not reading the edid correctly from the TV. You could try creating a static edid as explained
here. Use
mount -o remount,rw /flash
to make
/flash
read-write.
New LibreELEC.tv Leia build #0213:
RPi /
RPi2
(Supercedes previous build)
SHA256 Checksum:
5fcc3ad3ac1c26df9f5a4517f448c8990974c124f67405dfde9ba69a1a208a57
(RPi)
SHA256 Checksum:
0f59ecb7e9cf07fa663ff1e74f5d12d24d2bc51ac32d0c564722ef405a962ee2
(RPi2)
text:
# uname -a
Linux rpi512 4.19.20 #1 Wed Feb 13 21:25:08 GMT 2019 armv6l GNU/Linux
# vcgencmd version
Feb 12 2019 19:46:13
Copyright © 2012 Broadcom
version 8eff5e4023657a8b3b59e1f90dc966f62d74908c (clean) (release) (start_x)
# lsb_release
LibreELEC (Milhouse): devel-20190213212111-#0213-gab0e387 [Build #0213]
# Kodi version
Kodi (18.1-RC1 Git:379f5f9). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (ab0e387,
changelog) and tip of
XBMC master (379f5f9,
- Includes newclock5 patches
- Includes latest bcm2835-driver master (83977fe, ahead +2)
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (3bbd432)
- Includes latest libnfs master (0308145, ahead +4)
- Includes latest p8-platform master (1eb12b1)
- Includes latest addons: inputstream.adaptive (9a1f5d6, +7), inputstream.rtmp (6065923, +2), peripheral.joystick (dbb8a90, +3), peripheral.xarcade (f09a0e7), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (d0bd868, +2), pvr.dvbviewer (1ff63d4), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (e394c79, +3), pvr.iptvsimple (73feb2f), pvr.mediaportal.tvserver (931afab), pvr.mythtv (c954c7e, +10), pvr.nextpvr (78c6633), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv (b60b971), pvr.stalker (d0170c5), pvr.teleboy (1956113), pvr.vbox (ea20464), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (253f5d8, +12), pvr.wmc (7b28be3), pvr.zattoo (6ef1a56, +5), vfs.libarchive (6d39012), vfs.rar (45a0cec, +2), vfs.sftp (b9fbb22, +1)
- Include [env] compare (perma): TESTING: increase timeout to ensure OS is able to create core dump/crash log
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:3238 (perma): kodi/openssl: fix crash using vfs.sftp
- Include [env] PR:3260 (perma): linux (RPi/Generic): update to linux-4.19.20/21
- Include [env] PR:3290 (perma): openssl: update SSL CA trust store (sync with Kodi PR15441
- Include [env] PR:3296 (perma): kodi: cleanup Lircmap.xml patch
- Include [pkg] PR:182 (perma): Crash loop fix (pvr.vuplus)
- Include [pkg] PR:14571 (perma): Remove ARB postfix from GL functions
- Include [pkg] PR:15164 (perma): TexturePacker: Fix memory / resource leak the ugly way
- Include [pkg] PR:15356 (perma): Optimize locking in ApplicationMessenger
- Include [pkg] PR:15434 (perma): [python] fix usage of line-breaks in ok dialog
- Include [pkg] PR:15491 (perma): wake on access: fix crash on startup
Build Highlights:
- Minors
Build Details:
- LibreELEC.tv:
- buildsystem: fixes as required (PR:3294, 17 commits, 19 files changed)
- pvr.zattoo:
- Add swb TV as reseller (PR:37, 1 commit, 4 files changed)
- vfs.sftp:
- Fix build issues due to libssh bug (PR:24, 1 commit, 1 file changed)
(2019-02-14, 00:23)Milhouse Wrote: [ -> ] (2019-02-13, 22:49)Ich-bin-Knuffi Wrote: [ -> ]I have a Raspi 3 on a Philips TV and sometimes when I boot the Raspi Libreelec does not recognize the HD Resolution of the TV. In some cases I cannot change the resolution as it is grayed out (in most cases a reboot does the trick), but in some other cases I then can change the resolution to 1080x1920.
Most likely you are switching on the RPi before the TV and it's not reading the edid correctly from the TV. You could try creating a static edid as explained here. Use mount -o remount,rw /flash
to make /flash
read-write.
Thanks, I will try that. The TV was always on at reboot ...
New LibreELEC.tv Leia build #0214:
RPi /
RPi2
SHA256 Checksum:
3b935028b85650078aa04f6127ff8130c865033d0219eb6a4b228cb6434a9ab8
(RPi)
SHA256 Checksum:
65e1ced40ced0d8cfb65f75c6a0b5ea9d91831de36f0ef4c5b4207ed2ba436be
(RPi2)
text:
# uname -a
Linux rpi512 4.19.20 #1 Thu Feb 14 21:09:25 GMT 2019 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20190214210512-#0214-gab0e387 [Build #0214]
# Kodi version
Based on tip of
- Includes latest addons: inputstream.adaptive (9a1f5d6, +7), inputstream.rtmp (6065923, +2), peripheral.joystick (dbb8a90, +3), peripheral.xarcade (f09a0e7), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (d0bd868, +2), pvr.dvbviewer (1ff63d4), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (e394c79, +3), pvr.iptvsimple (73feb2f), pvr.mediaportal.tvserver (931afab), pvr.mythtv (c954c7e, +10), pvr.nextpvr (78c6633), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv (b60b971), pvr.stalker (d0170c5), pvr.teleboy (1956113), pvr.vbox (ea20464), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (253f5d8, +12), pvr.wmc (7b28be3), pvr.zattoo (6ef1a56, +5), vfs.libarchive (2ba1102, +3), vfs.rar (45a0cec, +2), vfs.sftp (b9fbb22, +1)
- Include [env] PR:3312 (perma): buildsystem: fix debug broken by #3171
Build Highlights:
- Minors
- No tvheadend42 today, a bad tvheadend merge has made it unbuildable
Build Details:
- vfs.libarchive:
- Add Exists() implementation (PR:28, 3 commits, 2 files changed)
- Added: [env] PR:3312 (perma): buildsystem: fix debug broken by #3171
New LibreELEC.tv Leia build #0215:
RPi /
RPi2
SHA256 Checksum:
a941ffcb4178de316a6003b54e6be3f606542b206b83901d86313ddabbb9d4a3
(RPi)
SHA256 Checksum:
f597e4c11bea4666f67d0f8ddccda13d391734b97c58549b7a5800b2c320770a
(RPi2)
text:
# uname -a
Linux rpi512 4.19.20 #1 Sat Feb 16 00:33:57 GMT 2019 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20190216003223-#0215-gab0e387 [Build #0215]
# Kodi version
Kodi (18.1-RC1 Git:112d310). Platform: Linux ARM 32-bit
Based on tip of
XBMC master (112d310,
- Includes latest addons: inputstream.adaptive (9a1f5d6, +7), inputstream.rtmp (6065923, +2), peripheral.joystick (dbb8a90, +3), peripheral.xarcade (f09a0e7), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (d0bd868, +2), pvr.dvbviewer (1ff63d4), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (e394c79, +3), pvr.iptvsimple (73feb2f), pvr.mediaportal.tvserver (931afab), pvr.mythtv (c954c7e, +10), pvr.nextpvr (78c6633), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv (b60b971), pvr.stalker (d0170c5), pvr.teleboy (1956113), pvr.vbox (ea20464), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (253f5d8, +12), pvr.wmc (7b28be3), pvr.zattoo (30868ce, +7), vfs.libarchive (2ba1102, +3), vfs.rar (45a0cec, +2), vfs.sftp (b9fbb22, +1)
- Include [env] PR:3260 (perma): linux (RPi/Generic): update to linux-4.19.20/23
- Include [pkg] PR:15516 (perma): [Windowing] Build complete strmode for RES_DESKTOP
Build Highlights:
- fixed: NFO/tag loading for http/https sources was broken
- [Windowing] Build complete strmode for RES_DESKTOP
Build Details:
- XBMC:
- fixed: NFO/tag loading for http/https sources was broken (fixes #15481) (PR:15492, 1 commit, 1 file changed)
- pvr.zattoo:
- Updated: [env] PR:3260 (perma): linux (RPi/Generic): update to linux-4.19.20/23
- Updated: [pkg] PR:182 (perma): Crash loop fix (pvr.vuplus)
- Added: [pkg] PR:15516 (perma): [Windowing] Build complete strmode for RES_DESKTOP
(2019-02-07, 00:23)Milhouse Wrote: [ -> ][...]
I tried the latest Amazon Prime Instant on my Revo 3700 (x86_64, Nvidia ION2) with #0205 and for movies I have only audio (no video), but for tvshows I have both audio and video (ie. working fine). Yet with RPi3+, both movies and tvshows are working normally.
Whether this is an Amazon or inputstream.adaptive issue I don't really know, but I feel it's unlikely to be a LibreELEC specific issue. Probably best to open an issue on inputstream.adaptive.
FYI I yesterday tried to play some TV series and it worked. I tried one of the movies that didn't work right now and it is playing as well. I didn't do any (manual) update in between and plugin.video.amazon-test is still 0.6.6. Very strange ...
New LibreELEC.tv Leia build #0216:
RPi /
RPi2
SHA256 Checksum:
37d62fe09faaeafbda7329172bd67221b531dc1e16fe22da88584e59435b8112
(RPi)
SHA256 Checksum:
0a3e5fe77f5f8778683ff17e9d9f50dc12ad041ba485c378496176ae9db2d6f3
(RPi2)
text:
# uname -a
Linux rpi512 4.19.20 #1 Sat Feb 16 21:05:16 GMT 2019 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20190216210339-#0216-g8dfe7d7 [Build #0216]
# Kodi version
Kodi (18.1-RC1 Git:69af734). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (8dfe7d7,
XBMC master (69af734,
- Includes latest bcm2835-driver master (83977fe)
Build Highlights:
- Minors
Build Details:
- LibreELEC.tv:
- emby4: update to 4.0.2.0 (PR:3314, 1 commit, 2 files changed)
- nano: disable line wrapping (PR:3308, 1 commit, 1 file changed)
- XBMC:
- Set m_bRenderGUI in RenderManager:reInit (PR:15524, 1 commit, 1 file changed)
New LibreELEC.tv Leia build #0217:
RPi /
RPi2
SHA256 Checksum:
275bb53ff2e508f63f4298e001ec32f1878ea5e5d2c762d241630fe956d0fe5c
(RPi)
SHA256 Checksum:
1b565c532487c293b90ea3d0e7d080522292425acdfe4202022aaf9f7d1e5416
(RPi2)
text:
# uname -a
Linux rpi512 4.19.20 #1 Sun Feb 17 21:06:28 GMT 2019 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20190217210453-#0217-ge9f8a46 [Build #0217]
# Kodi version
Kodi (18.2-RC1 Git:46f2c88). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (e9f8a46,
XBMC master (46f2c88,
- Includes latest libnfs master (0308145)
- Includes latest addons: inputstream.adaptive (b76c81f, +8), inputstream.rtmp (6065923, +2), peripheral.joystick (dbb8a90, +3), peripheral.xarcade (f09a0e7), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (d0bd868, +2), pvr.dvbviewer (1ff63d4), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (2b7348a, +4), pvr.iptvsimple (73feb2f), pvr.mediaportal.tvserver (931afab), pvr.mythtv (c954c7e, +10), pvr.nextpvr (78c6633), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv (b60b971), pvr.stalker (d0170c5), pvr.teleboy (1956113), pvr.vbox (ea20464), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (253f5d8, +12), pvr.wmc (7b28be3), pvr.zattoo (30868ce, +7), vfs.libarchive (2ba1102, +3), vfs.rar (45a0cec, +2), vfs.sftp (b9fbb22, +1)
Build Highlights:
- Kodi 18.2rc1
Build Details:
- LibreELEC.tv:
- buildsystem: add multithreaded ad-hoc package build (PR:3318, 2 commits, 2 files changed)
- buildsystem: fix debug broken by #3171 (PR:3312, 1 commit, 2 files changed)
- libnfs: update to libnfs-4.0.0 (PR:3304, 1 commit, 1 file changed)
- libnfs: update to libnfs-4.0.0 [backport] (PR:3305, 1 commit, 1 file changed)
- openssl: update SSL CA trust store (sync with Kodi PR15441) (PR:3290, 1 commit, 1 file changed)
- XBMC:
- [Android] Queue AMEDIACODEC_BUFFER_FLAG_END_OF_STREAM buffer only >= API 26 (PR:15534, 1 commit, 1 file changed)
- bump for 18.1 final (PR:15486, 1 commit, 2 files changed)
- bump to 18.2rc1 (PR:15535, 1 commit, 2 files changed)
- [python] fix usage of line-breaks in ok dialog (PR:15434, 1 commit, 1 file changed)
- [PVR] Document implict call to CloseXXXStream() before OpenXXXStream() (PR:15479, 1 commit, 1 file changed)
- [estuary] Fix visual glitch when PVR info dialog activated from PVR channels OSD. (PR:15489, 1 commit, 1 file changed)
- [Windowing] Build complete strmode for RES_DESKTOP (PR:15516, 1 commit, 9 files changed)
- [wayland] Fix startup crash (e287cb6)
- [wayland] Fix startup crash (#15531) (33be1ec)
- inputstream.adaptive:
- [HLS] effective URL for license (b76c81f)
- pvr.hts:
- 4.4.14 Fix HTSPDemuxer::IsRealTimeStream to always return true if subscription is active. (PR:403, 1 commit, 3 files changed)
any way to install spectrum or waveform visualisations on 18.1/18.2 as /builds/addons/ folders for them are empty and they fail from the base kodi repo also.
New LibreELEC.tv Leia build #0218:
RPi /
RPi2
SHA256 Checksum:
3a313398e15f1e3607a0fb06d0ca11673458ed26f96ebd2838567ca62069faae
(RPi)
SHA256 Checksum:
e4618324605d70a6b883985c72c31888cbe9f025b0d5c74d9b6d851eda42c495
(RPi2)
text:
# uname -a
Linux rpi512 4.19.23 #1 Mon Feb 18 21:32:13 GMT 2019 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse): devel-20190218213051-#0218-geef940c [Build #0218]
# Kodi version
Kodi (18.2-RC1 Git:5e82ff9). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (eef940c,
XBMC master (5e82ff9,
- Includes latest bcm2835-driver master (d095b96)
- Include [env] PR:3260 (perma): linux (RPi/Generic): update to linux-4.19.23
- Include [env] PR:3316 (perma): openssh: drop support for ssh-dss keys
- Include [env] PR:3321 (perma): CrazyCat TBS 5520SE fix
- Include [pkg] PR:15518 (perma): [GLES] Improve subtitle rendering
Build Highlights:
- New 4.19.23 kernel
- [GLES] Improve subtitle rendering
- openssh: drop support for ssh-dss keys
- CrazyCat TBS 5520SE fix
Build Details:
- LibreELEC.tv:
- [le92] kodi: update to 18.1 (PR:3300, 2 commits, 1 file changed)
- buildsystem: more fixes as required (PR:3319, 2 commits, 2 files changed)
- XBMC:
- [PVR] Correct interface documentation for PVR API GetStreamProperties() function (PR:15480, 1 commit, 1 file changed)
- [docs] Update style guidelines (PR:14665, 1 commit, 1 file changed)
- Updated: [env] PR:3260 (perma): linux (RPi/Generic): update to linux-4.19.23
- Added: [env] PR:3316 (perma): openssh: drop support for ssh-dss keys
- Added: [env] PR:3321 (perma): CrazyCat TBS 5520SE fix
- Added: [pkg] PR:15518 (perma): [GLES] Improve subtitle rendering
(2019-02-18, 02:57)SharpCoder Wrote: [ -> ]any way to install spectrum or waveform visualisations on 18.1/18.2 as /builds/addons/ folders for them are empty and they fail from the base kodi repo also.
I have uploaded RPi, RPi2 and Generic versions of visualization.spectrum and visualization.waveform.
Weekly Linux 5.0-rc7 build #0218x:
RPi /
RPi2
Known issues:
text:
No dvb-latest or crazycat drivers
