(2016-12-08, 04:14)zaphod24 Wrote: [ -> ]As info, my RPi3 plugs directly into the HDMI port of my Vizio TV
I note you don't have "hdmi_ignore_cec_init=1" in config.txt which is a default option for LibreELEC.
Any reason why that has been removed? Does adding it back help?
(2016-12-08, 11:22)Aux_ Wrote: [ -> ]If I want to watch the movie "Sherlock Holmes: A Game of Shadows" at Amazon, the Kodi crashes. Here crash logs
It seems to be trying to play the file /storage/.kodi/addons/plugin.video.amazon/resources/dummy.avi
Can you check if that is present after the crash?
Does it also crash if you copy that file and try to play it through videos menu?
What does mediainfo report for that file?
(2016-12-08, 04:01)Milhouse Wrote: [ -> ] (2016-12-08, 02:15)brimur Wrote: [ -> ]I am currently trying to compile from source for imx6 but I am getting an error building the dvbhdhomerun driver.
OT post - you should start a thread on the LibreELEC.tv forum where there will be someone familiar with imx6 able to help.
Thank. Will do, I just hoped you might know from your own compiling how I can exclude the dvbhdhomerun driver?
Is it possible to update withe the .update-folder from an Kodi 17.0 Milhouse-Build ?
(2016-12-08, 14:38)Aux_ Wrote: [ -> ]Dummy.avi has only 10KB
Does dummy.avi crash for you if played through file interface?
It doesn't crash for me, nor do you see any video.
At 10K you are not going to have video in there - I guess it's some sort of placeholder when the Amazon stream can't be played.
dummy.avi doesn't show any frames with vlc or mplayer either.
General
Complete name : /home/dc4/Downloads/dummy.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 10.0 KiB
Writing application : VirtualDubMod 1.5.10.2 (build 2542/release)
Writing library : VirtualDubMod build 2542/release
Video
Format : RGB
Codec ID : 0x00000000
Codec ID/Info : Basic Windows bitmap format. 1, 4 and 8 bpp versions are palettised. 16, 24 and 32bpp contain raw RGB samples
Width : 640 pixels
Height : 352 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Bit depth : 8 bits
(2016-12-08, 13:12)popcornmix Wrote: [ -> ] (2016-12-08, 04:14)zaphod24 Wrote: [ -> ]As info, my RPi3 plugs directly into the HDMI port of my Vizio TV
Thanks! I'll try that tonight. The reason that option isn't set is because my config.txt is actually from the Milhouse builds of OpenELEC and I'm guessing it was commented out by default in OpenELEC
(2016-12-08, 16:30)zaphod24 Wrote: [ -> ]Thanks! I'll try that tonight. The reason that option isn't set is because my config.txt is actually from the Milhouse builds of OpenELEC and I'm guessing it was commented out by default in OpenELEC
It was a default in OpenELEC for quite some time. Maybe it was a very old OE that had been upgraded.
Since the Kodi 18 updates I have problems moving large files via network onto Pi3 attached hard drive.
Any suggestions on how to fix this?
Amazon Prime comes closer to working on this build. I can get audio but no video. No crashes.
09:07:57.782 T:1744155552 NOTICE: Opening stream: 1 source: 256
09:07:57.783 T:1744155552 NOTICE: Opening stream: 2 source: 256
09:07:57.783 T:1744155552 NOTICE: Finding audio codec for: 86018
09:07:57.796 T:1379668896 NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
09:08:18.390 T:1744155552 ERROR: AddOnLog: InputStream Adaptive: Decrypt Sample returns failure!
09:08:23.669 T:1961914368 ERROR: Control 54 in window 10025 has been asked to focus, but it can't
09:08:48.509 T:1961914368 NOTICE: CVideoPlayer::CloseFile()
09:08:48.510 T:1961914368 NOTICE: VideoPlayer: waiting for threads to exit
09:08:48.516 T:1744155552 NOTICE: CVideoPlayer::OnExit()
09:08:48.516 T:1744155552 NOTICE: Closing stream player 1
09:08:48.517 T:1744155552 NOTICE: Waiting for audio thread to exit
09:08:48.522 T:1379668896 NOTICE: thread end: CVideoPlayerAudio::OnExit()
09:08:48.523 T:1744155552 NOTICE: Closing audio device
09:08:48.548 T:1744155552 NOTICE: Deleting audio codec
09:08:48.548 T:1744155552 NOTICE: Closing stream player 2
09:08:48.548 T:1744155552 NOTICE: waiting for video thread to exit
09:08:48.548 T:1475531680 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
09:08:48.549 T:1475531680 NOTICE: thread end: video_thread
09:08:48.549 T:1744155552 NOTICE: deleting video codec
(2016-12-08, 15:54)popcornmix Wrote: [ -> ] (2016-12-08, 14:38)Aux_ Wrote: [ -> ]Dummy.avi has only 10KB
If I want to play dummy.avi on file interface nothing happens.
Quote:At 10K you are not going to have video in there - I guess it's some sort of placeholder when the Amazon stream can't be played.
Understand, but what explains the crashes?
EDIT: Just now I tried to play the video again, Kodi does not crash anymore hmm..
popcornmix
Looks like one of those 2 settings may cause random crashes with Live TV:
Resample quality = GPU accelerated
Threshold for pitch correction = 2 (Not sure about this one. Pitch correction kicks in right after the channel change but that's not when the crashes occur.)
I ran Kodi with Resample quality = Low, Threshold for pitch correction = 100 for a couple of months without a single crash.
Then I decided to switch those settings back to default. Today I got Kodi crash/restart when watching Live TV:
http://sprunge.us/ViXh
