Sorry if this has been asked, but does the channel manager not work in this build at the moment.
Just trying to update a few icons but its not loading..
Thankyou...
(2017-02-26, 00:58)bmonster Wrote: [ -> ]Hi,
Thankyou...
Post a debug log. When did it last work? You're the first to report anything.
(2017-02-26, 01:03)Milhouse Wrote: [ -> ] (2017-02-26, 00:58)bmonster Wrote: [ -> ]Hi,
Thankyou...
Sorry again,
Just deleted .kodi and enabled debug, rebooted and its working fine.
I'm guessing it a custom skin problem.
Cheers
Hello,
I am currently trying to get rid of an annoying CEC issue which I am facing for a long while now - hence I cannot tell when or with what version it started.
I am using an LG TV from 2012, a Yamaha AVR from 2015 and an RPi2. RPi and TV connected to AVR, using ARC.
As soon as I switch on my TV, a few seconds later the AVR starts up and always automatically switches the TV to the Kodi HDMI input. Well, I can switch to the usual TV channels afterwards, but that's not what it should be like...
All the CEC settings regarding "wake up..." or "show as active source..." are set to off as far as I can see at libcec input settings.
With enabled debug logging for CEC I created this log, currently with #0225:
http://pastebin.com/CqxPnQQg
I appreciate any help here - thanks a lot!
Waldgirgl
does anybody if libreelec have drivers for 5 ghz wlan sticks? i use such a stick but it only conncts to 2,4 ghz.
(2017-02-25, 12:05)linkinsoldier Wrote: [ -> ]Edit: is there any timeplan on the new inputstream drm method to watch Amazon video on rpi 2/3?
First there need to be VideoPlayer updates from agile branch merged to master which is expected soon.
Note this is a pretty big change which may cause some disruption and may take a while to be merged.
I've been working on getting mmal renderer to handle video form an external codec (e.g. inputstream+widevine)
in an efficient (zero-copy) way. That is looking promising.
You can be sure as soon the feature is ready you'll see it these builds.
I downgraded to Millhouse 8 latest beta and it is much better.
Videoplayer on Live-TV is better not perfect but nearly.
It uses less RAM
And my Recordings will show up.
Hope you improve Millhouse 9 on this issues.
popcornmix is it right that you trie to change the videoplay in the build?
Thank you for your great Work!
New LibreELEC.tv Leia build #0226:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.10.0 #1 Sun Feb 26 22:28:43 GMT 2017 armv6l GNU/Linux
# vcgencmd version
Feb 17 2017 20:41:51
Copyright (c) 2012 Broadcom
version 88b8ca93c6eb22e38531075a6d7e4f25f900af43 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170226222738-#0226-gfeb4c4e [Build #0226]
# Kodi version
(18.0-ALPHA1 Git:4c792db). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (feb4c4ef,
changelog) and tip of
XBMC master (a077d7b9,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.10.y
- Includes latest bcm2835-driver next (1a717bb3, ahead +659)
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (0a97062d, ahead +22)
- Includes latest libnfs master (2e0a67fc, ahead +49)
- Includes latest p8-platform master (2d90f986, ahead +9)
- Includes latest addons: inputstream.adaptive (a347296e), inputstream.rtmp (df64b9b2, +6), peripheral.joystick (110ddb71, +2), pvr.argustv (5a36c586), pvr.demo (f2075086, +1), pvr.dvblink (a669273e, +1), pvr.dvbviewer (9fb34b3c), pvr.filmon (5c6432db, +1), pvr.hdhomerun (98cb8d40), pvr.hts (1caa390d, +1), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (76ae28f6, +1), pvr.mythtv (18fe56e4, +11), pvr.nextpvr (cb1b5415), pvr.njoy (3d097117, +1), pvr.octonet (8549a31c), pvr.pctv (e0d9f175, +1), pvr.stalker (ea970851, +1), pvr.vbox (dea8335a), pvr.vdr.vnsi (7033621d), pvr.vuplus (6ff2eb28), pvr.wmc (5f1db43f)
- Exclude [env] kodi-999.99-PR11662.patch: kodi: merged upstream
- Include [env] afbd134f: linux: Enable Fair Queue packet scheduling (TEST)
- Include [env] e533a8be: linux: Default to CONFIG_TCP_CONG_BBR (TEST)
- Include [env] patch: ffmpeg: add extra RPi lib required when building ffmpeg command line with gpu service hevc patches
- Include [env] patch: kodi: fix PR:1348
- Include [env] patch: repository.retroplayer.libreelec.addons: add temp repo for testing
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: iwlwifi-firmware: update to iwlwifi-firmware-ba301aa
- Include [env] patch: linux: enable in-tree rtl8192cu for RPi/RPi2
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] PR:1287: virtio-gpu support (qemu/kvm)
- Include [env] PR:1348: kodi: adjust cputemp/gputemp script
- Include [env] PR:1379: projectM: remove glew [LE9]
- Include [env] PR:1387: buildsystem: Create unpack stamps for packages without sources
- Include [env] PR:1391: mesa: update to mesa-17.0.0 with llvm-3.9.1 bump
- Include [pkg] patch: alsa-lib: conf: Add card config for Intel HDMI/DP LPE audio (alsa-lib)
- Include [pkg] PR:56: bluetooth: add missing 'Connect' option when device is Trusted (service.libreelec.settings)
- Include [pkg] PR:11668: FFmpegImage: Document and change alignment
Build Highlights:
- Fix rumble always enabled
- [addons] fix InstallUpdatesAndWait
Build Details:
- LibreELEC.tv:
- Python: use -j1 for makeinstall_host (PR:1392, 1 commit, 1 file changed)
- amlogic: remove kodi patch and instead disable suspend via systemd (PR:1377, 1 commit, 4 files changed)
- Addon stripping improvements (PR:1370, 3 commits, 2 files changed)
- xorg-server: clean package when nvidia drivers are bumped (PR:1355, 1 commit, 1 file changed)
- Changed links inside README.md to 'https://...' if possible (PR:1353, 1 commit, 1 file changed)
- odroid-c2: linux add meson_pwm support (PR:1339, 1 commit, 1 file changed)
- imagedecoder.raw: add add-on (PR:1329, 2 commits, 2 files changed)
- scripts/image: print depmod errors (PR:1371, 1 commit, 1 file changed)
- Build system scripts cleanup (PR:1326, 4 commits, 3 files changed)
- Amlogic: Disable POST_PROCESS_MANAGER_3D_PROCESS in kernel config (PR:1175, 1 commit, 3 files changed)
- linux: update to linux-4.10.0 (PR:1121, 9 commits, 14 files changed)
- XBMC:
- [PVR] Fix crash in CPVRGUIActions:rocessMenuHooks. (PR:11750, 1 commit, 1 file changed)
- [depends] fix taglib after boost removal (PR:11762, 1 commit, 2 files changed)
- Fix rumble always enabled (PR:11707, 3 commits, 18 files changed)
- [addons] fix InstallUpdatesAndWait (c91962dc)
- peripheral.joystick:
- Peripheral API v1.3.1 - Report rumble and power-off capabilities (PR:86, 1 commit, 10 files changed)
- pvr.demo:
- fix install path (PR:39, 1 commit, 1 file changed)
- pvr.dvblink:
- fix install path (PR:67, 1 commit, 1 file changed)
- pvr.filmon:
- fix install path (PR:63, 1 commit, 1 file changed)
- pvr.mediaportal.tvserver:
- fix install path (PR:59, 1 commit, 1 file changed)
- pvr.njoy:
- fix install path (PR:32, 1 commit, 1 file changed)
- pvr.pctv:
- fix install path (PR:41, 1 commit, 1 file changed)
- pvr.stalker:
- fix install path (PR:84, 1 commit, 1 file changed)
- Added: [env] PR:1348: kodi: adjust cputemp/gputemp script
- Added: [env] patch: kodi: fix PR:1348
(2017-02-26, 21:27)popcornmix Wrote: [ -> ] (2017-02-25, 12:05)linkinsoldier Wrote: [ -> ]Edit: is there any timeplan on the new inputstream drm method to watch Amazon video on rpi 2/3?
Awesome, thank you! Looking forward to do the testing [emoji6] [emoji106]
I wanted to update RPi2 from # 0210 to # 0226, but had to realize that tvheadend works only to # 0212, with higher versions as # 0212, HTSP always comes no connectivity.
If necessary I will make a log but later.
Now crazy # 0212 also still
Crashlog this morning:
http://pastebin.com/Evrsp7xb
EDIT:
Problem solved, Have official Libreelec 8.0 on it, now all goes perfectly.
I can not do the stress my wife
I used it until version 0224 no problems with tvheadend.
(2017-02-26, 11:23)Waldgirgl Wrote: [ -> ]Hello,
Waldgirgl
Build 117 is the last one I have with CEC working.
Sent while on the move
Hi there, I've been long term user of this builds, but Im having hard time trying to adjusting subtitles. Im unable to moving subitles up/down to place them at the picture frame bottom. Some 2:35 movies are encoded as 16:9 with black bars at top/bottom, and subtitles shows at the black bottom bar. Im willing to adjust subtitles a little up, so they're displayed just at the bottom of the picture frame (the 2:35 frame).
Any ideas?
(2017-02-27, 20:47)kerman Wrote: [ -> ]Hi there, I've been long term user of this builds, but Im having hard time trying to adjusting subtitles. Im unable to moving subitles up/down to place them at the picture frame bottom. Some 2:35 movies are encoded as 16:9 with black bars at top/bottom, and subtitles shows at the black bottom bar. Im willing to adjust subtitles a little up, so they're displayed just at the bottom of the picture frame (the 2:35 frame).
Any ideas?
Is this a new issue? When did it start? Maybe Estuary sync pt1 or pt2 changed something?
New LibreELEC.tv Leia build #0227:
RPi /
RPi2
# uname -a
Linux rpi512 4.10.0 #1 Mon Feb 27 21:30:08 GMT 2017 armv6l GNU/Linux
# vcgencmd version
Feb 26 2017 21:23:25
version 6e74add571c9691b108c68f29c3f45374cac24e6 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170227212650-#0227-ged1a60d [Build #0227]
# Kodi version
Based on tip of
LibreELEC.tv master (ed1a60dd,
XBMC master (85ec9751,
- Includes latest bcm2835-driver next (f85646a8, ahead +660)
- Includes latest libnfs master (f95fa8ef, ahead +51)
- Include [env] patch: RBP: Add support for Dion Audio LOCO-V2 DAC-AMP
Build Highlights:
- New firmware (dtoverlay, arm_loader, gpuserv, MMAL/IL)
- sound: Support for Dion Audio LOCO-V2 DAC-AMP HAT
Build Details:
- Firmware (Feb 26):
- firmware: dtoverlay: find symbols, write properties. See: link
- firmware: arm_loader: Clean up cmdline, add local-mac-address to DT. See: link
- firmware: gpuserv: Boost gpu frequencies when in use
- firmware: ILCamera: Add option to disable ISP processing stages
- firmware: MMAL/IL: Allow video render to take non aligned sliceheight
- firmware: IL ISP: Support unaligned nSliceHeight on input
- LibreELEC.tv:
- gpu-aml: Do not use Mali Utilization (PR:1390, 1 commit, 1 file changed)
- mesa: update to mesa-17.0.0 with llvm-3.9.1 bump (PR:1391, 2 commits, 2 files changed)
- projectM: remove glew [LE9] (PR:1379, 2 commits, 2 files changed)
- XBMC:
- [PVR] Fix inconsistent TimerSettings 'Enable/Disable' (PR:11769, 1 commit, 1 file changed)
- [PVR] Trac 17359: Fix crash in CPVRTimers::GetTimerRule(const CFileItem *item). (PR:11748, 1 commit, 1 file changed)
- [xbmc] Start work on getting rid of our emulated GetDiskFreeSpaceEx method (PR:11741, 3 commits, 9 files changed)
- libnfs:
- Here are some changes to resolve some conflicts with MinGW and fuse_dokan (PR:174, 2 commits, 4 files changed)
- kernel 4.10.y:
- New commits in this build:
- config: Add ads1015 driver to config (1a5e21bb)
- config: add slcan kernel module (a028d936)
- sound: Support for Dion Audio LOCO-V2 DAC-AMP HAT (532e7bed)
- Added: [env] patch: RBP: Add support for Dion Audio LOCO-V2 DAC-AMP
