nuwonda, I had that problem pop up on the nightlies a few weeks ago, oddly enough I bumped up the over_voltage (from 2 to 4) on my overclock settings and the yellow lightning bold went away and I've not had a problem since. I don't think it is suppose to work that way, but it did for me. I also use a Rpi3 w/2.5amp PSU.
(2017-03-03, 19:16)Milhouse Wrote: [ -> ] (2017-03-03, 11:40)Aux_ Wrote: [ -> ]Have been able to find something about this phenomenon on the Internet.
The issue seems to be the new kernel (more than 4.8.13?) The DVB C / T stick MN88473 (dvb-demod-mn88473-01.fw) does not seem to work properly.
Under this link I had found help -->> https://forum.libreelec.tv/thread-5537.h...ht=MN88473
Now all is well again.
Is that known? If yes, I am reassured.
But if it does not, maybe someone would like to pass it on to the right place?
Thanks for the attention!
Yes, it's known that 4.9.y and later kernels are causing some issues - @CvH has been producing builds in an effort to narrow down the regression.
Thanx @
Milhouse for your answer,
but is generic build not only for pc?
http://cvh.libreelec.tv/Test/dvbskys960/
Temporary, I have solved it as already described by me.
But calms me that the problem is known
(2017-03-03, 20:38)J_E_F_F Wrote: [ -> ]nuwonda, I had that problem pop up on the nightlies a few weeks ago, oddly enough I bumped up the over_voltage (from 2 to 4) on my overclock settings and the yellow lightning bold went away and I've not had a problem since. I don't think it is suppose to work that way, but it did for me. I also use a Rpi3 w/2.5amp PSU.
ya, I'd rather not. besides my multimeter says the psu is providing 5.2v, no fluctuations, so I would say it's more likely a code issue or maybe its the rp3 board.
(2017-03-03, 19:06)nuwonda Wrote: [ -> ]build 302, first time I noticed a yellow flash icon top right corner of the screen when booting up.
Only for Info: I just updated my Pi3 to 302 and have also the yellow flash icon at boot.
I never noticed it before with my hardware.
Edit: Also my 2nd Pi3 shows for half a second the flash icon during boot after updating to 302.
(2017-03-03, 02:21)Sholander Wrote: [ -> ] (2017-03-02, 02:07)Milhouse Wrote: [ -> ]- firmware: Redo CEC code cleanup 3: Removed CEC topology computation
- firmware: Redo CEC code cleanup 4: Removed unused functions
- firmware: Redo CEC code cleanup 5: Removed Rx processing
- firmware: Redo CEC code cleanup 6: Logging changed to VCOS
- firmware: Redo CEC code cleanup 7: Removed hdmi_state_machine_clock_changed
- firmware: Redo CEC code cleanup 8: fixed hdmi state machine clk
- firmware: Redo CEC code cleanup 10: misc cosmetic changes
- firmware: Fixup CEC code cleanup 8: fixed hdmi state machine clk
- firmware: hdmi: Add way of forcing logging for hdmi and cec from boot
- firmware: Redo CEC code cleanup 11: cec_release_logical_addr
CEC is fixed, and works for me (RPi3 & PanaTV) as it should.
I can also acknowledge that CEC is fixed, and works for me (Pi3 & AVR & PanaTV) as it should.
(In all previous versions in the last x month my Pana does not switch to AVR automatically when Kodi wakes up the TV & AVR explicit. With 302 it do as with the very old versions before.)
(2017-03-03, 21:33)Aux_ Wrote: [ -> ]Thanx @Milhouse for your answer,
but is generic build not only for pc? http://cvh.libreelec.tv/Test/dvbskys960/
Yes "Generic" is the PC/x86 build, as this regression isn't RPi specific.
(2017-03-04, 01:33)Milhouse Wrote: [ -> ] (2017-03-03, 21:33)Aux_ Wrote: [ -> ]Thanx @Milhouse for your answer,
I do not think, because the problem occurs on RPi2 and RPi3.
after installing build of user @smp, [
here ] both RPi2 and RPi3 are working properly.
Builds with the newer kernel DVB-C works briefly, then there is no connection with HTCP Server. When I pulled out shortly DVB Stick from USB port, DVB-C working again for some time.
New LibreELEC.tv Leia build #0303:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.10.1 #1 Fri Mar 3 21:03:33 GMT 2017 armv6l GNU/Linux
# vcgencmd version
Mar 2 2017 15:37:10
Copyright (c) 2012 Broadcom
version a867bcec14cd829107be1c03c0953a076919f4d7 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170303210226-#0303-gb6b7064 [Build #0303]
# Kodi version
(18.0-ALPHA1 Git:4c792db). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (b6b70647,
changelog) and tip of
XBMC master (1af50b2c,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.10.y
- Includes latest bcm2835-driver master (78c49833)
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (0a97062d, ahead +22)
- Includes latest libnfs master (70df81c1, ahead +52)
- Includes latest p8-platform master (2d90f986, ahead +9)
- Includes latest addons: inputstream.adaptive (a347296e), inputstream.rtmp (df64b9b2, +6), peripheral.joystick (d45ed3fe, +4), pvr.argustv (5a36c586), pvr.demo (f2075086, +1), pvr.dvblink (1b756eec, +2), pvr.dvbviewer (9fb34b3c), pvr.filmon (5c6432db, +1), pvr.hdhomerun (98cb8d40), pvr.hts (819129d5, +2), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (76ae28f6, +1), pvr.mythtv (a3e4a500, +12), pvr.nextpvr (cb1b5415), pvr.njoy (3d097117, +1), pvr.octonet (8549a31c), pvr.pctv (e0d9f175, +1), pvr.stalker (ea970851, +1), pvr.vbox (dea8335a), pvr.vdr.vnsi (7033621d), pvr.vuplus (6ff2eb28), pvr.wmc (5f1db43f)
- Exclude [env] kodi-999.99-PR11662.patch: kodi: merged upstream
- Include [env] afbd134f: linux: Enable Fair Queue packet scheduling (TEST)
- Include [env] e533a8be: linux: Default to CONFIG_TCP_CONG_BBR (TEST)
- Include [env] patch: repository.retroplayer.libreelec.addons: add temp repo for testing
- Include [env] patch: iwlwifi-firmware: update to iwlwifi-firmware-ba301aa
- Include [env] patch: linux: update to linux-4.10.1
- Include [env] patch: linux: enable in-tree rtl8192cu for RPi/RPi2
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] PR:1287: virtio-gpu support (qemu/kvm)
- Include [env] PR:1348: kodi: adjust cputemp/gputemp script
- Include [env] PR:1401: libdrm: adjust default options
- Include [env] PR:1404: pycryptodome: add package, remove pycrypto
- Include [pkg] patch: alsa-lib: conf: Add card config for Intel HDMI/DP LPE audio (alsa-lib)
- Include [pkg] PR:56: bluetooth: add missing 'Connect' option when device is Trusted (service.libreelec.settings)
- Include [pkg] PR:11668: FFmpegImage: Document and change alignment
- Include [pkg] PR:11801: [Fix][Backport]Music cleanup hanging on large MySQL databases
Build Highlights:
- Include brcmfmac_sdio-firmware-rpi in RPi builds (for RPi0W)
- Fix IR decoder modules not loading automatically (media_build)
- socket: Limit reconnect retries to 10 (libnfs)
- [Fix][Backport]Music cleanup hanging on large MySQL databases
Build Details:
- LibreELEC.tv:
- brcmfmac_sdio-firmware-rpi: Implement Raspbian udev rules and btuart (PR:1413, 1 commit, 4 files changed)
- Fix IR decoder modules not loading automatically (PR:1416, 2 commits, 3 files changed)
- RPi: build brcmfmac_sdio-firmware-rpi for Pi0W (PR:1418, 1 commit, 1 file changed)
- XBMC:
- pvr: fix playing items from library (PR:11794, 1 commit, 1 file changed)
- [Android] Controller fixes (PR:11793, 4 commits, 2 files changed)
- [PVR] Guide window: Feature: 'Smart selection' of epg events." (PR:11782, 1 commit, 4 files changed)
- [Win32] installer: added checks for required updates and SPs during installation + fix (PR:11796, 2 commits, 2 files changed)
- [Fix]Speedup Songs node by skipping pointless fetch of cuesheet data (PR:11785, 1 commit, 1 file changed)
- libnfs:
- socket: Limit reconnect retries to 10 (PR:173, 1 commit, 2 files changed)
- peripheral.joystick:
- [cmake] Disable linux and udev drivers on Android (PR:88, 1 commit, 1 file changed)
- pvr.dvblink:
- pvr.dvblink (master) version 4.1.0 (PR:72, 1 commit, 24 files changed)
- Added: [pkg] PR:11801: [Fix][Backport]Music cleanup hanging on large MySQL databases
I posted this bug too:
305809 (thread). FernetMenta said that it's a known bug for a long time. Seems to be independent from PVR backend.
#303 cant wake kodi from dimmed state, need to use phone app. seems that old issue is back.
btw the yellow flash icon from #302 after rainbow splash screen is gone now in #303.
New LibreELEC.tv Leia build #0304:
RPi /
RPi2
# uname -a
Linux rpi512 4.10.1 #1 Sat Mar 4 23:40:42 GMT 2017 armv6l GNU/Linux
# vcgencmd version
Mar 2 2017 15:37:10
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170304233937-#0304-gb6b7064 [Build #0304]
# Kodi version
Based on tip of
XBMC master (2bbf02dd,
- Includes latest addons: inputstream.adaptive (a347296e), inputstream.rtmp (df64b9b2, +6), peripheral.joystick (0c47f0e1, +9), pvr.argustv (5a36c586), pvr.demo (f2075086, +1), pvr.dvblink (1b756eec, +2), pvr.dvbviewer (9fb34b3c), pvr.filmon (5c6432db, +1), pvr.hdhomerun (98cb8d40), pvr.hts (819129d5, +2), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (76ae28f6, +1), pvr.mythtv (a3e4a500, +12), pvr.nextpvr (cb1b5415), pvr.njoy (3d097117, +1), pvr.octonet (8549a31c), pvr.pctv (e0d9f175, +1), pvr.stalker (ea970851, +1), pvr.vbox (dea8335a), pvr.vdr.vnsi (7033621d), pvr.vuplus (6ff2eb28), pvr.wmc (5f1db43f)
- Include [pkg] patch: ffmpeg: Call get_format to fix an issue with MMAL rendering [temp hack] (ffmpeg)
- Include [pkg] PR:11803: [Fix]Music cleanup hanging on large MySQL databases
Build Highlights:
- ffmpeg: Call get_format to fix an issue with MMAL rendering
Build Details:
- XBMC:
- [xbmc][depends][fix] New build of libass and freetype to try and fix subtitle font issues (PR:11800, 1 commit, 1 file changed)
- [cmake/windowing] fix dependencies X11/XRandR/OpenGLES (PR:11805, 1 commit, 3 files changed)
- Some Android button maps (PR:89, 5 commits, 8 files changed)
- Added: [pkg] patch: ffmpeg: Call get_format to fix an issue with MMAL rendering [temp hack] (ffmpeg)
Can you update libreelec repo 9? I can't use addons section!
Please!
Did anyone else notice that shadertoy performance degraded somewhere in the latest build (using #304 atm). Using the lava shadertoy screensaver it heavily stutters for me. Also a subjective feeling tells me that overall UI performance regressed a bit. (This is rbpi3 stock clocks)
(2017-03-05, 12:23)ezar Wrote: [ -> ]Can you update libreelec repo 9? I can't use addons section!
Please!
Seems like the Repo (is) was offline atm :
Quote:server:~# dig milhouse.libreelec.tv
;; ANSWER SECTION:
milhouse.libreelec.tv. 299 IN A 163.172.166.199
C:\Users\Sysiphus>ping 163.172.166.199
Ping wird ausgeführt für 163.172.166.199 mit 32 Bytes Daten:
Zeitüberschreitung der Anforderung.
Edit:
Already fixed while i was writing
server:~# ping milhouse.libreelec.tv
PING milhouse.libreelec.tv (163.172.166.199) 56(84) bytes of data.
64 bytes from web03.libreelec.tv (163.172.166.199): icmp_seq=1 ttl=53 time=31.1 ms
