(2017-03-14, 14:50)J_E_F_F Wrote: [ -> ]I do:
Okay, that was key information. Everything now makes sense.
The PWR led is directly connected to the undervoltage detection circuit (PWR led going off is direct signal of under-voltage).
Forcing the PWR led means we can no longer detect under-voltage.
A commit yesterday means we avoid displaying the under-voltage signal when arm has forced the PWR led.
(2017-03-14, 13:56)popcornmix Wrote: [ -> ] (2017-03-14, 00:41)J_E_F_F Wrote: [ -> ]So far, no lightning bolt with 0313, perhaps this was a firmware issue that was resolved.
Not explicitly but there was a change to the gpio expander which is used by the under-voltage detection, but nothing that looks like it would fix your issue.
It may be something a little random that comes and goes with builds.
Can you confirm if the symbol ever disappears and reappears?
Or is it just spuriously on at boot and either stays on permanently or disappears, never to return?
It does sound like spurious reporting of under-voltage rather than an actual under-voltage condition.
Also if you see the symbol again, can you report output of "vcgencmd get_throttled"
as posted before, it definitely is an erroneous under-voltage reporting, which happens right after rainbow screen on bootup or reboot and goes away after 2 seconds. The ac (original pi hut brand) was measured with a multimeter and is 100% providing stable 5v.
It is gone with 313, for now...
Different issue since ... any build going back to v17, the display calibration is always lost/slightly deplaced (a few pixel) on bootup and more so on upgrades (a few more pixels). nothing that bothers anyone much i guess.
(2017-03-14, 21:27)nuwonda Wrote: [ -> ]Different issue since ... any build going back to v17, the display calibration is always lost/slightly deplaced (a few pixel) on bootup and more so on upgrades (a few more pixels). nothing that bothers anyone much i guess.
Ae you able to narrow down when this issue started (likely to be very tedious, I know).
New LibreELEC.tv Leia build #0314:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.10.2 #1 Wed Mar 15 01:54:08 GMT 2017 armv6l GNU/Linux
# vcgencmd version
Mar 13 2017 20:38:22
Copyright (c) 2012 Broadcom
version 9e38ec4b6d95d3a769dc6f8d3d78ee2f9d043850 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170315015305-#0314-g1b38cb9 [Build #0314]
# Kodi version
(18.0-ALPHA1 Git:93e9d69). Platform: Linux ARM 32-bit
Based on tip of
LibreELEC.tv master (1b38cb92,
changelog) and tip of
XBMC master (93e9d695,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.10.y
- Includes latest bcm2835-driver master (509beaab)
- Includes latest kodi-platform master (36fb4937, ahead +1)
- Includes latest libcec master (0a97062d, ahead +22)
- Includes latest libnfs master (d501dc8a, ahead +55)
- Includes latest p8-platform master (2d90f986, ahead +9)
- Includes latest addons: inputstream.adaptive (aa0d5113, +1), inputstream.rtmp (6c1af46a, +7), peripheral.joystick (0c47f0e1, +9), pvr.argustv (5a36c586), pvr.demo (f2075086, +1), pvr.dvblink (4b902cd1, +3), pvr.dvbviewer (9fb34b3c), pvr.filmon (5c6432db, +1), pvr.hdhomerun (98cb8d40), pvr.hts (819129d5, +2), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (76ae28f6, +1), pvr.mythtv (a3e4a500, +12), pvr.nextpvr (cb1b5415), pvr.njoy (3d097117, +1), pvr.octonet (8549a31c), pvr.pctv (e0d9f175, +1), pvr.stalker (ea970851, +1), pvr.vbox (dea8335a), pvr.vdr.vnsi (7033621d), pvr.vuplus (6ff2eb28), pvr.wmc (7bb31db9, +1)
- Include [env] 31a41616: linux: Enable Fair Queue packet scheduling (TEST)
- Include [env] 2447ac86: linux: Default to CONFIG_TCP_CONG_BBR (TEST)
- Include [env] patch: tvheadend42: fix ffmpeg
- Include [env] patch: rapidjson: drop yajl, add rapidjson
- Include [env] patch: linux: enable in-tree rtl8192cu for RPi/RPi2
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] PR:1431: scripts/mkimage: align partitions to 4MiB
- Include [env] PR:1433: v4l-utils: properly fix streamzap issues, allow user rc_maps.cfg override
- Include [env] PR:1438: v4l-utils: cleanup locally added keymaps, remove crime against rc6_mce
- Include [pkg] PR:56: bluetooth: add missing 'Connect' option when device is Trusted (service.libreelec.settings)
- Include [pkg] PR:8008: JSON: replace YAJL with RapidJSON
- Include [pkg] PR:11668: FFmpegImage: Document and change alignment
- Include [pkg] PR:11849: [PVR] Fix trac17374: Settings deinitialized too early on app exit.
Build Highlights:
- Reorganise project hierarchy, support devices
- Drop LibreSSL, switch back to OpenSSL (this will break some addons until updates are available, but should fix DAZN/post-2038 cert expiry etc.)
- Remove all kodi project and arch specific patches (note: I'll continue including them as long as I'm able)
- tvheadend42 and vdr-addon updated (see addons)
Build Details:
- LibreELEC.tv:
- linux: update to linux-4.10.2 (PR:1440, 8 commits, 7 files changed)
- libfmt: add package, add as a new kodi dependency (PR:1426, 2 commits, 2 files changed)
- pycryptodome: add package, remove pycrypto (PR:1404, 4 commits, 3 files changed)
- kodi: adjust cputemp/gputemp script (PR:1348, 1 commit, 1 file changed)
- $DEVICE naming changes (PR:1356, 2 commits, 2 files changed)
- merge xml files during installation of kodi (PR:1347, 2 commits, 13 files changed)
- virtio-gpu support (qemu/kvm) (PR:1287, 2 commits, 4 files changed)
- move back to openssl (PR:1312, 4 commits, 31 files changed)
- kodi: update to 93e9d69 (PR:1443, 1 commit, 3 files changed)
- RPi add RPi and RPi2 devices (PR:1358, 3 commits, 11 files changed)
- RPi add Slice and Slice3 devices (PR:1357, 9 commits, 57 files changed)
- remove all kodi project and arch specific patches (PR:1317, 7 commits, 20 files changed)
- linux: Fix slice patch - needed rebase (PR:1444, 1 commit, 1 file changed)
- openssl: remove $ROOT prefix (PR:1445, 1 commit, 1 file changed)
- buildystem: Cleanup fixes (PR:1449, 2 commits, 2 files changed)
- tools: fixup RPi gen scripts after devices (PR:1448, 1 commit, 2 files changed)
- XBMC:
- [settings] revert default of epg.selectaction back to show info (PR:11848, 1 commit, 1 file changed)
- Adding keyboard layout: Thai Kedmanee (#11844) (85d866eb)
- newclock5:
- New commits in this build:
- MMAL: Remove periodic prime calls and handle from buffer destructor (87083871)
- MMALCodec: Include a timeout of GetPicture in default debug logging (26611de3)
- kernel 4.10.y:
- BCM270X_DT: Add lm75 to i2c-sensor overlay (ec8d93b9)
- bcm2835-gpio-exp: Copy/paste error adding base twice (bb0ff9d0)
(2017-03-15, 00:03)Milhouse Wrote: [ -> ] (2017-03-14, 21:27)nuwonda Wrote: [ -> ]Different issue since ... any build going back to v17, the display calibration is always lost/slightly deplaced (a few pixel) on bootup and more so on upgrades (a few more pixels). nothing that bothers anyone much i guess.
Going to be tricky, not even sure i can downgrade back far enough due to db changes. Are there any logs that might help?
latest update....
while playing a movie, hit info, and the local time and end time of the movie, that's on the top right of the screen is no longer there anymore
(2017-03-15, 09:59)MidKnight Wrote: [ -> ]latest update....
Here everything seems OK.
hrmmm. must of been a hiccup, I rebooted it and its ok now...
New LibreELEC.tv Leia build #0315:
RPi /
RPi2
# uname -a
Linux rpi512 4.10.2 #1 Wed Mar 15 21:03:29 GMT 2017 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170315210225-#0315-g1b38cb9 [Build #0315]
# Kodi version
Based on tip of
XBMC master (77f3bff1,
- Includes latest libcec master (8563411d, ahead +30)
- Include [env] PR:1450: create_addon: add device support
Build Highlights:
- libcec updates
- RenderManager: Force frames to output when reconfiguring renderer
Build Details:
- XBMC:
- [PVR] Fix trac17374: Settings deinitialized too early on app exit. (PR:11849, 1 commit, 3 files changed)
- libcec:
- added: log a warning when we detect that RPi's CEC service is used by something else, blocking libCEC. issue #191 (5469da23)
- changed: const IAdapterCommunication::GetLogicalAddresses(), making the mutex mutable for now without changing the platform lib. closes #259 (0cf3f0fe)
- fixed: cross compile includes (50f1179d)
- fixed: detect debian based distros properly when installing python. closes #314 (f4e2ed77)
- fixed: don't filter out broadcast in HandleDeviceVendorCommandWithId(). issue #309 (e1df683b)
- fixed: send an active source message when a routing change has been received with libCEC's address as new route and no active source message has been sent yet. issue #309 #205 #233 (67d444dd)
- fixed 67d444dd944192a31ab07637a4b57d27c890ede4 (d1a708b9)
- fixed: vs2015 c++ redistributables (8563411d)
- newclock5:
- RenderManager: Force frames to output when reconfiguring renderer (ccb2d792)
- Added: [env] PR:1450: create_addon: add device support
(2017-03-15, 08:52)nuwonda Wrote: [ -> ]Going to be tricky, not even sure i can downgrade back far enough due to db changes. Are there any logs that might help?
Unfortunately I don't think there's anything relevant that is written to the logs.
Do you need databases to test if calibration settings are saved? Try with a clean .kodi (rename your existing .kodi folder), identify the first build with the calibration saving issue, then you can restore your old .kodi folder and return to latest builds.
After some time i have tested the build on pi and i have found two problems.
First one is that since 0211 back button and exit does not work on some addons. For example it does not work on libreelec dev updater. I assume that this
https://github.com/xbmc/xbmc/pull/11645 commit has change that behaviour.
The other one is with Confluence skin. I know it is not official one anymore but will there be an update for the problem reported here
http://forum.kodi.tv/showthread.php?tid=...pid2546644
TNX
(2017-03-16, 00:20)Milhouse Wrote: [ -> ] (2017-03-15, 08:52)nuwonda Wrote: [ -> ]Going to be tricky, not even sure i can downgrade back far enough due to db changes. Are there any logs that might help?
I may have some time for this during the weekend, i'll try a fresh install first with latest build and if the issue persists start with 17 and do boundary testing from there.
New LibreELEC.tv Leia build #0316:
RPi /
RPi2
# uname -a
Linux rpi512 4.10.2 #1 Thu Mar 16 21:10:36 GMT 2017 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170316210756-#0316-g1b38cb9 [Build #0316]
# Kodi version
Based on tip of
XBMC master (25de4115,
Build Highlights:
- Python error (eg. plugin.video.youtube) caused by PR11814 - notified on github
Build Details:
- XBMC:
- [win] use 64-bit toolset if available (PR:11845, 1 commit, 5 files changed)
- RenderManager: Force frames to output when reconfiguring renderer (PR:11855, 1 commit, 1 file changed)
- [bluray] Improve Blu-ray playback (PR:11836, 10 commits, 8 files changed)
- Fix allocation of 0-length array (PR:11814, 3 commits, 2 files changed)
- newclock5:
- Commits no longer in build:
- Build add-ons with jom to speed up the windows binary add-ons builds (cf2272ff)
Just installed #0316 (over #0315) and Tvheadend HTSP Client, CU LRC Lyrics and Backup addons all recorded a failure to start on 1st and subsequent reboot
Kodi.log on 1st boot after installation of #0316
