2017-08-10, 20:53
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355
2017-08-10, 20:54
That's no problem. It sometimes helps to know if a problem is affecting both platforms as that can rule out any platform specific changes.
2017-08-10, 21:19
I would like to report that my RAR issue has been resolved with the most recent update.
Whatever you've done. Thanks!
2017-08-10, 22:15
@Milhouse
Same Problem here with Build #809 only Sound no Pictures on PVR Build #808 is running perfect
System is a NUC6CAYH
2017-08-11, 00:12
@Milhouse/@Everyone:
Since a few weeks I'm using an AMD Radeon HD6450 and a Radeon R5 230.
These cards give me a headache.
The problem I run into is a random black screen when it suppose to show video and even sometimes also locking up the HTPC when video starts.
The only solution is to reboot the system, and then it works for some time.
Most of the time the problem appears when switching from one video (mode) to another, as in: Youtube playlist or zapping PVR.
I've tried many builds without succes.
Problem is that it happens at radom so it takes a long time to test.
Questions:
Is anyone else using AMD videocards with these builds without problems, and is there a way to test another (older) driver like with the NVidia cards?
Could it be a PC problem (problem is with 2 old pc's with just Core2duo)?
@Milhouse: Does it make sence to start logging to find the problem or do you think I'm a loner using these cards and will the problems most likely never be resolved (maybe because were depending on AMD)?
Cause if so, I move on and get some other hardware to play with..
Edit: The "menu's" don't turn black, just the video.
Questions:
2017-08-11, 01:31
@rudrood there's no alternative driver for AMD.
You said here that you've had a problem since #0710, and that #0709 "fixes the problem" - are you still happy with #0709 or is this a different problem that you see in #0709? Obviously you should be able to use the latest builds but knowing that #0709 is working normally is good information and would suggest the driver is not the issue.
If #0709 is still good but #0710 has issues then in all likelihood the problem is the VPUpdate and I would suggest you add your details to https://trac.kodi.tv/ticket/17545 (or even open a new ticket as your issues are more severe than the so far unsolved Nvidia "adjust refresh rate" problem).
2017-08-11, 02:50
New LibreELEC.tv Leia build #0810: Generic
(Supercedes previous build)
Based on tip of LibreELEC.tv master (fb748cf4, changelog) and tip of XBMC master (0e9d82ea, changelog) with the following modifications:
# uname -a
Linux NUC 4.12.5 #1 SMP Fri Aug 11 00:51:22 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170811004959-#0810-gfb748cf [Build #0810]
# Kodi version
(18.0-ALPHA1 Git:0e9d82e). Platform: Linux x86 64-bit
- Includes latest kodi-platform master (36fb4937)
- Includes latest libcec master (8adc786b, ahead +26)
- Includes latest libnfs master (df94ae93, ahead +56)
- Includes latest p8-platform master (a822e196)
- Includes latest addons: inputstream.adaptive (2720bb51, +15), inputstream.rtmp (476bde07), peripheral.joystick (1815c0fb), pvr.argustv (310737e2), pvr.demo (9d0aa8fb), pvr.dvblink (7d9c181f, +1), pvr.dvbviewer (9faf2413), pvr.filmon (1c9d2ebe), pvr.hdhomerun (bf23dbc0, +6), pvr.hts (1ceadf1b), pvr.iptvsimple (0f4a453b, +1), pvr.mediaportal.tvserver (d7a9acdb), pvr.mythtv (d1f3ce50), pvr.nextpvr (03a3b714), pvr.njoy (79e8e653), pvr.octonet (a77cf111), pvr.pctv (00b76689), pvr.stalker (9e28f125), pvr.vbox (44f3d04e), pvr.vdr.vnsi (6e332b0b), pvr.vuplus (c5265ae5, +3), pvr.wmc (1d655540)
- Include [env] compare: linux: update to linux-4.12.5
- Include [env] patch: nss/nspr: include in main image [rfc][gcc7]
- Include [env] patch: rev hack for kodi
- Include [env] patch: tvheadend42: fixup ffmpeg patch
- Include [env] patch: pvr addons: disable broken addons
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:1664: buildsystem: update to gcc7
- Include [env] PR:1726: [WIP] lirc: update to 0.10.0
- Include [env] PR:1773: init: make break after behaviour really break after
- Include [env] PR:1776: Don't cause system to hang on halt/reboot when net-booting
- Include [env] PR:1835: add support for optional kernel modules in image and from addons
- Include [env] PR:1862: busybox: revert dd fsync change which makes no sense
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:12311: FIX: ensure real filename from videodb in playlists
- Include [pkg] PR:12656: keep extradata on stream-refresh if not given from demuxer
- Fix tvheadend issue (PR12656, thanks @peak3d)
- XBMC:
- [cleanup] silence compiler warnings (PR:12631, 5 commits, 35 files changed)
- Add xbmcgui.Control.isVisible method (PR:12563, 1 commit, 2 files changed)
- FIX: Database debug spew on demand only (PR:12534, 1 commit, 4 files changed)
- AESinkALSA: Return false if we don't know about our output channels (PR:12641, 2 commits, 3 files changed)
- inputstream.adaptive:
- Added: [pkg] PR:12656: keep extradata on stream-refresh if not given from demuxer
2017-08-12, 01:11
(2017-08-11, 01:31)Milhouse Wrote: [ -> ]@rudrood there's no alternative driver for AMD.
Thanks Milhouse for thinking with me.
You're right about my comment that 0709 was oke. The problem is that the error is random or after some time, and I think I was lucky at the moment I wrote the comment.
Today I stress tested 0709 with the setting: adjust display refresh rate at start/stop. Most of the time it works oke, but I found a way to sort of reproduce the problem.
1 out of a few times the pc restarts or stalls when I open a certain playlist in Youtube. As a matter of fact I ran into this ages ago (2017-03-31) but then it wasn't happening with the stock Estaury but only with the Estaury mod skin.
Problem is that I can't create a debug log cause the pc fully locks or restarts.
What I can provide is a crashlog, but I doubt if this is off any help as far as I can see.
http://sprunge.us/gdSE
Problem doesn't occour when adjust display refresh rate is off.
Edit: Checked, the problem at 2017-03-31 was also a pc with AMD card.
2017-08-12, 15:23
FYI: starting with build 0811 the additional "CrazyCat" DVB drivers are now an addon, included in the image.
To use these go to Add-ons->My add-ons->Services and enable "DVB drivers for TBS (CrazyCat)", then reboot.
so long,
Hias
so long,
Hias
2017-08-12, 18:18
New LibreELEC.tv Leia build #0811: Generic
Based on tip of LibreELEC.tv master (fb748cf4, changelog) and tip of XBMC master (69f283b1, changelog) with the following modifications:
# uname -a
Linux NUC 4.12.5 #1 SMP Fri Aug 11 21:06:52 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170811210530-#0811-gfb748cf [Build #0811]
# Kodi version
(18.0-ALPHA1 Git:69f283b). Platform: Linux x86 64-bit
- Includes latest addons: inputstream.adaptive (2720bb51, +15), inputstream.rtmp (476bde07), peripheral.joystick (1815c0fb), pvr.argustv (310737e2), pvr.demo (9d0aa8fb), pvr.dvblink (7d9c181f, +1), pvr.dvbviewer (9faf2413), pvr.filmon (1c9d2ebe), pvr.hdhomerun (bf23dbc0, +6), pvr.hts (1ceadf1b), pvr.iptvsimple (d6a92951, +3), pvr.mediaportal.tvserver (d7a9acdb), pvr.mythtv (d1f3ce50), pvr.nextpvr (03a3b714), pvr.njoy (79e8e653), pvr.octonet (a77cf111), pvr.pctv (00b76689), pvr.stalker (9e28f125), pvr.vbox (44f3d04e), pvr.vdr.vnsi (6e332b0b), pvr.vuplus (c5265ae5, +3), pvr.wmc (1d655540)
- Include [env] PR:1871: buildsystem: enable custom colours (or none at all)
- Include [pkg] PR:12659: [addons] log version of installed addons
- CrazyCat users: This is now an addon in Add-ons > Services > DVB drivers for TBS (CrazyCat)
Please enable this add-on if you require dual-tuners
- Kernel overlays installed sooner - hopefully fixes issue with FUSE module (ie. exFAT drive mounting)
- XBMC:
- [PVR] Clean the mess. Refactor channel navigation/selection, incl. channel preview. (PR:12653, 4 commits, 23 files changed)
- [CEC] add hibernate on TV standby (PR:12650, 1 commit, 2 files changed)
- [depends][osx] prioritize unix-style packages over OS X Frameworks (PR:12647, 1 commit, 2 files changed)
- VideoPlayer: fix demux client (PR:12657, 1 commit, 6 files changed)
- pvr.iptvsimple:
- Support multiple groups per channel (PR:117, 2 commits, 3 files changed)
2017-08-12, 22:33
New LibreELEC.tv Leia build #0812: Generic
Based on tip of LibreELEC.tv master (fb748cf4, changelog) and tip of XBMC master (a9ea915e, changelog) with the following modifications:
# uname -a
Linux NUC 4.12.5 #1 SMP Sat Aug 12 21:05:01 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170812210337-#0812-gfb748cf [Build #0812]
# Kodi version
(18.0-ALPHA1 Git:a9ea915). Platform: Linux x86 64-bit
- lirc updated to lirc-0.10 (PR:1726 updated)
2017-08-13, 21:42
I'm running 2017-08-11 and I notice that on LiveTV with TvHeadend plugin the system crashes after about 20-30 minutes of watching TV. System becomes completely unresponsive and the only thing I can do is restart it.
What logs do you want/need? Do I need to turn on debug-logging and see if I can reproduce a crash with it turned on or something ?
2017-08-13, 21:56
(2017-08-13, 21:42)lejose Wrote: [ -> ]I'm running 2017-08-11 and I notice that on LiveTV with TvHeadend plugin the system crashes after about 20-30 minutes of watching TV. System becomes completely unresponsive and the only thing I can do is restart it.
Your crashlog (if Kodi is really crashing, but it doesn't sound like it is - see note #4 in OP), or your debug log (wiki) if Kodi simply hangs.
2017-08-13, 22:50
New LibreELEC.tv Leia build #0813: Generic
Based on tip of LibreELEC.tv master (fb748cf4, changelog) and tip of XBMC master (36b44e45, changelog) with the following modifications:
# uname -a
Linux NUC 4.12.7 #1 SMP Sun Aug 13 21:04:50 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170813210328-#0813-gfb748cf [Build #0813]
# Kodi version
(18.0-ALPHA1 Git:36b44e4). Platform: Linux x86 64-bit
- Includes latest addons: inputstream.adaptive (d0d24a5c, +26), inputstream.rtmp (476bde07), peripheral.joystick (1815c0fb), pvr.argustv (310737e2), pvr.demo (9d0aa8fb), pvr.dvblink (7d9c181f, +1), pvr.dvbviewer (9faf2413), pvr.filmon (1c9d2ebe), pvr.hdhomerun (bf23dbc0, +6), pvr.hts (1ceadf1b), pvr.iptvsimple (0b7b308c, +4), pvr.mediaportal.tvserver (d7a9acdb), pvr.mythtv (d1f3ce50), pvr.nextpvr (03a3b714), pvr.njoy (79e8e653), pvr.octonet (a77cf111), pvr.pctv (00b76689), pvr.stalker (9e28f125), pvr.vbox (44f3d04e), pvr.vdr.vnsi (6e332b0b), pvr.vuplus (c5265ae5, +3), pvr.wmc (1d655540)
- Include [env] compare: linux: update to linux-4.12.7
- New 4.12.7 kernel
- CEC labels fixed (thanks @ksooo)
- inputstream.adaptive updates
- XBMC:
- Various Android improvments (PR:12662, 4 commits, 27 files changed)
- [XCode] - removed xcconfig files. (PR:12669, 1 commit, 6 files changed)
- VideoPlayer (vpv): do not process decoder output if we can not delive (PR:12667, 1 commit, 1 file changed)
- [settings] Fix missing CEC settings dialog labels. (PR:12668, 1 commit, 1 file changed)
- [AML/MediaCodec] release Outputbuffers in case no RenderBuffer is ava (PR:12666, 1 commit, 4 files changed)
- thread skeleton (a50d2b99)
- MT step (82d1d108)
- StreamOn/Off after ProgramChange (596fa05a)
- Reset SegmentData in Demux Thread (157e1cec)
- [HLS] Implement block decryption (546b7f21)
- Implement SPS Frame parser to get fps before first packet is send (a98e8777)
- Make TimeSeek multithread safe / Fix segfault when AP4_Sample's seek fails (double free) (0e6bb853)
- [Live] Disallow seek to expired segments / fix presentationTimeOffset / compile issue fixed (25b96fa2)
- Sync segment downloader thread startup (61c233f6)
- Version bump 2.0.8 (7e569b29)
- [HLS] implement key rotation / classify MediaSequence:0 as VOD (d0d24a5c)
- pvr.iptvsimple:
- Fix links in the README (PR:150, 1 commit, 1 file changed)
2017-08-14, 10:54
I'm getting the following error for pvr.dvbviewer since build #0804
Kodi (18.0-ALPHA1 Git:36b44e4). Platform: Linux x86 64-bit (Milhouse Generic #0813)
Latest working Version: #0803
Log:
ERROR: Unable to load /usr/lib/kodi/addons/pvr.dvbviewer/pvr.dvbviewer.so.3.1.0, reason: /usr/lib/kodi/addons/pvr.dvbviewer/pvr.dvbviewer.so.3.1.0: undefined symbol: GetStreamTimes
Log:
