am currently running libreelec 8.02 on intel nuc 5cpyh with aeon nox silvo skin.... is it possible to use your leia builds or is it better to wait for an official release of leia
sorry if it is a stupid question
(2017-08-18, 09:25)normy62 Wrote: [ -> ]am currently running libreelec 8.02 on intel nuc 5cpyh with aeon nox silvo skin.... is it possible to use your leia builds or is it better to wait for an official release of leia
It is possible, but these are alpha builds and much is changing at the moment so if you want stability (particularly with third-party skins and add-ons that may not yet be Leia compatible) then wait for an official release towards the end of the year.
New LibreELEC.tv Leia build #0818:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.12.7 #1 SMP Fri Aug 18 21:04:54 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170818210326-#0818-g32406a7 [Build #0818]
# Kodi version
(18.0-ALPHA1 Git:e6b0c83). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (32406a74,
changelog) and tip of
XBMC master (e6b0c83d,
- Includes latest kodi-platform master (36fb4937)
- Includes latest libcec master (8adc786b, ahead +26)
- Includes latest libnfs master (df94ae93, ahead +56)
- Includes latest p8-platform master (a822e196)
- Includes latest addons: inputstream.adaptive (3a9bda1a, +41), inputstream.rtmp (e094fa38, +1), peripheral.joystick (cc14287c, +3), pvr.argustv (310737e2), pvr.demo (f07d898c, +1), pvr.dvblink (0b66c640, +4), pvr.dvbviewer (a1e4bb0c, +5), pvr.filmon (1c9d2ebe), pvr.hdhomerun (b89c2be4, +9), pvr.hts (a1de6329, +1), pvr.iptvsimple (260434e4, +5), pvr.mediaportal.tvserver (d7a9acdb), pvr.mythtv (a17a3a4f, +1), pvr.nextpvr (03a3b714), pvr.njoy (79e8e653), pvr.octonet (a77cf111), pvr.pctv (00b76689), pvr.stalker (df492d27, +1), pvr.vbox (44f3d04e), pvr.vdr.vnsi (07172ed0, +1), pvr.vuplus (921b14f6, +5), pvr.wmc (1d655540)
- Include [env] compare: linux: update to linux-4.12.7
- Include [env] patch: nss/nspr: include in main image [rfc][gcc7]
- Include [env] patch: rev hack for kodi
- Include [env] patch: tvheadend42: fixup ffmpeg patch
- Include [env] patch: buildsystem: update to gcc (to 7.2), glibc and binutils
- Include [env] patch: pvr addons: disable broken addons
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:1773: init: make break after behaviour really break after
- Include [env] PR:1776: Don't cause system to hang on halt/reboot when net-booting
- Include [env] PR:1821: use 7zip for addon.zip creation
- Include [env] PR:1835: add support for optional kernel modules in image and from addons
- Include [env] PR:1862: busybox: revert dd fsync change which makes no sense
- Include [env] PR:1896: config/functions: fix bash-4.4 issue, and empty 2nd param behaviour
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:12311: FIX: ensure real filename from videodb in playlists
Build Highlights:
- Use 7zip to create addon archives (should make them a little smaller)
- Add audio description stream identification - still needs add-on changes (ie. Netflix addon - hopefully this weekend)
Build Details:
- LibreELEC.tv:
- add xmlstarlet to toolchain depends (PR:1883, 3 commits, 8 files changed)
- XBMC:
- VideoPlayer - PVR: allow GetTimes for recordings (PR:12686, 1 commit, 1 file changed)
- [utils] fix component log functions introduced at 06bbead (PR:12685, 2 commits, 2 files changed)
- Add EFlags to inputstream API interface (PR:12690, 1 commit, 3 files changed)
- inputstream.adaptive:
- [HLS] break segment refresh loop rep based (b405f991)
- [HLS] use swaplist for periodic fetched segments (a50742d8)
- request manifest updates directly before segment change / implement mpd::impaired for audio (3a9bda1a)
- Added: [env] PR:1821: use 7zip for addon.zip creation
I updated from LE 8.0.2 to the latest Milhouse #0818 Version and having trouble with some Live-TV channels. Some just work fine, but others freeze the complete system. I didn't have any problems on 8.0.2 as everything works like a charm there.
Here's the log. Hope someone can help:
http://sprunge.us/QCSf
Milhouse
Problem with Build # 818 When I look at a first 4k medium, is used up to a reboot of Kodi always this resolution synonymous when I a 1080p or another low resolution, LE Build # 818 always use the resolution of 4k
(2017-08-19, 19:57)pacoma2610 Wrote: [ -> ]@Milhouse
Not really sure I understand what you are saying. If Kodi is crashing ("up to a reboot"), can you post the crashlog? And did this start only with #0818?
Please excuse my hasty interpretation, I could not adjust the error again, forget my last Post
New LibreELEC.tv Leia build #0819:
Generic
# uname -a
Linux NUC 4.12.7 #1 SMP Sat Aug 19 21:05:44 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170819210414-#0819-g32406a7 [Build #0819]
# Kodi version
(18.0-ALPHA1 Git:0f9abae). Platform: Linux x86 64-bit
Based on tip of
XBMC master (0f9abae6,
- Includes latest addons: inputstream.adaptive (0c7e9754, +42), inputstream.rtmp (e094fa38, +1), peripheral.joystick (cc14287c, +3), pvr.argustv (310737e2), pvr.demo (f07d898c, +1), pvr.dvblink (0b66c640, +4), pvr.dvbviewer (a1e4bb0c, +5), pvr.filmon (1c9d2ebe), pvr.hdhomerun (b89c2be4, +9), pvr.hts (a1de6329, +1), pvr.iptvsimple (260434e4, +5), pvr.mediaportal.tvserver (d7a9acdb), pvr.mythtv (a17a3a4f, +1), pvr.nextpvr (03a3b714), pvr.njoy (79e8e653), pvr.octonet (a77cf111), pvr.pctv (00b76689), pvr.stalker (df492d27, +1), pvr.vbox (44f3d04e), pvr.vdr.vnsi (07172ed0, +1), pvr.vuplus (921b14f6, +5), pvr.wmc (1d655540)
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: switch back to standard ncurses
Build Highlights:
- switch back to standard ncurses
Build Details:
- XBMC:
- [Fix] Add .m4v to music tag loader factory as valid extension (PR:12682, 1 commit, 2 files changed)
- Add system/lcms2.dll to .gitignore (PR:12694, 1 commit, 1 file changed)
- [wayland] Fix compilation with older gcc (PR:12693, 1 commit, 1 file changed)
- Integrate Wayland build into buildsteps (PR:12691, 1 commit, 10 files changed)
- reduce #psshsets by using use_count (0c7e9754)
- Added: [env] patch: switch back to standard ncurses
- Added: [env] patch: libcec: don't link non-existant libtinfo
(2017-08-19, 17:12)Freakaaa Wrote: [ -> ]Hi,
Here's the log. Hope someone can help: http://sprunge.us/QCSf
No one any ideas on this issue??
@Milhouse:Just a cosmetic remark I noticed after upgrading your build.
The Kodi boot splash is still displaying Kodi 18 L********* .
I believe the Kodi 18 version name has not been a secret for some time now :-p
We haven't made a new splash yet [emoji1]
New LibreELEC.tv Leia build #0820:
Generic
# uname -a
Linux NUC 4.12.7 #1 SMP Sun Aug 20 21:33:02 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170820213134-#0820-g32406a7 [Build #0820]
# Kodi version
(18.0-ALPHA1 Git:7fd8f0b). Platform: Linux x86 64-bit
Based on tip of
XBMC master (7fd8f0b5,
Build Highlights:
- Minors
Build Details:
- XBMC:
- [cleanup] silence compiler warnings (PR:12696, 4 commits, 4 files changed)
