Problem with builds #812 to #822 on my Acer Revo RL100 (with Nvidia ION GPU). Maybe previous builds too (but did not try).
Does not play movies with VC1 codec. Just get a black screen.
Audio is present and so are subtitles.
(2017-08-24, 01:29)macnb Wrote: [ -> ]Problem with builds #812 to #822 on my Acer Revo RL100 (with Nvidia ION GPU). Maybe previous builds too (but did not try).
Have you tried disabling Player > Videos > Adjust display refresh rate? Set it to "Off", it's currently broken with pretty much all Nvidia, and some AMD GPUs, no ETA on a fix.
(2017-08-24, 01:33)Milhouse Wrote: [ -> ] (2017-08-24, 01:29)macnb Wrote: [ -> ]Problem with builds #812 to #822 on my Acer Revo RL100 (with Nvidia ION GPU). Maybe previous builds too (but did not try).
Ah ha. Forgot about that.
Yes setting "Adjust display refresh rate" to OFF gets around the issue. Thx.
BTW, from the log file, I see "unsupported stream" warning:
23:12:22.430 T:140085777389312 INFO: ffmpeg[7F6842FFD700]: Duration: 02:40:56.19, start: 600.000000, bitrate: 16523 kb/s
23:12:22.430 T:140085777389312 INFO: ffmpeg[7F6842FFD700]: Program 1
23:12:22.430 T:140085777389312 INFO: ffmpeg[7F6842FFD700]: Stream #0:0[0x1011]: Video: vc1 (Advanced) (VC-1 / 0x312D4356), yuv420p(progressive), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc
23:12:22.430 T:140085777389312 INFO: ffmpeg[7F6842FFD700]: Stream #0:1[0x1100](eng): Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, 5.1(side), fltp, 640 kb/s
23:12:22.431 T:140085777389312 INFO: ffmpeg[7F6842FFD700]: Stream #0:2[0x1200](eng): Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
23:12:22.431 T:140085777389312 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 0
23:12:22.431 T:140085777389312 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 1
23:12:22.431 T:140085777389312 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 2
23:12:22.431 T:140085777389312 NOTICE: Opening stream: 0 source: 256
23:12:22.431 T:140085777389312 WARNING: OpenStream - Unsupported stream 0. Stream disabled.
23:12:22.431 T:140085777389312 NOTICE: Opening stream: 1 source: 256
23:12:22.431 T:140085777389312 NOTICE: Finding audio codec for: 86019
23:12:22.431 T:140085777389312 NOTICE: Creating audio thread
23:12:22.431 T:140085777389312 NOTICE: Opening stream: 0 source: 1024
23:12:22.431 T:140085794174720 DEBUG: Thread VideoPlayerAudio start, auto delete: false
23:12:22.431 T:140085794174720 NOTICE: running thread: CVideoPlayerAudio::Process()
How is that related to "Adjust refresh rate" setting ?
(2017-08-24, 01:49)macnb Wrote: [ -> ]How is that related to "Adjust refresh rate" setting ?
Not really sure. I don't know if it's limited to VC-1 or not.
Edit: Yes, it does seem to affect mainly (only?) VC-1 content. So you could leave "Adjust display refresh rate" enabled, so long as you don't watch any VC-1 content... There's a
trac ticket for this issue.
resently. (Can't say exactly what build it started with yet) playback of recordings on VU Plus pvr client fails.
I get this error in the client. Just don't know if it is the libreelec build or the addon that is giving me the problems.
Getting it both on rpi3 and x86
13:31:26.766 T:1942986864 NOTICE: VideoPlayer: Opening: pvr://recordings/tv/active/Property ladder/Property%20ladder, TV%20(TV8), 20170711_134000, 1:0:0:0:0:0:0:0:0:0:/media/hdd/movie/20170711_1540_-_TV8_-_PROPERTY_LADDER.ts.pvr
13:31:26.767 T:1117774736 NOTICE: Creating InputStream
13:31:26.768 T:1117774736 ERROR: CVideoPlayer::OpenInputStream - error opening [pvr://recordings/tv/active/Property ladder/Property%20ladder, TV%20(TV8), 20170711_134000, 1:0:0:0:0:0:0:0:0:0:/media/hdd/movie/20170711_1540_-_TV8_-_PROPERTY_LADDER.ts.pvr]
13:31:26.768 T:1117774736 NOTICE: CVideoPlayer::OnExit()
13:31:26.769 T:1942986864 ERROR: Playlist Player: skipping unplayable item: 0, path [pvr://recordings/tv/active/Property ladder/Property%20ladder, TV%20(TV8), 20170711_134000, 1:0:0:0:0:0:0:0:0:0:/media/hdd/movie/20170711_1540_-_TV8_-_PROPERTY_LADDER.ts.pvr]
13:31:26.773 T:1942986864 NOTICE: CVideoPlayer::CloseFile()
13:31:26.773 T:1942986864 NOTICE: VideoPlayer: waiting for threads to exit
13:31:26.773 T:1942986864 NOTICE: VideoPlayer: finished waiting
13:31:26.774 T:1942986864 NOTICE: VideoPlayer: waiting for threads to exit
13:31:26.774 T:1942986864 NOTICE: VideoPlayer: finished waiting
New LibreELEC.tv Leia build #0824:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.12.8 #1 SMP Thu Aug 24 21:58:22 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170824215655-#0824-gab9d8bf [Build #0824]
# Kodi version
(18.0-ALPHA1 Git:beb2913). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (ab9d8bf1,
changelog) and tip of
XBMC master (beb29133,
- Includes latest kodi-platform master (36fb4937)
- Includes latest libcec master (8adc786b, ahead +26)
- Includes latest libnfs master (df94ae93, ahead +56)
- Includes latest p8-platform master (a822e196)
- Includes latest addons: inputstream.adaptive (be77f9f8, +55), inputstream.rtmp (e094fa38, +1), peripheral.joystick (cc14287c, +3), pvr.argustv (310737e2), pvr.demo (f07d898c, +1), pvr.dvblink (0b66c640, +4), pvr.dvbviewer (313339bf, +8), pvr.filmon (1c9d2ebe), pvr.hdhomerun (b89c2be4, +9), pvr.hts (a1de6329, +1), pvr.iptvsimple (260434e4, +5), pvr.mediaportal.tvserver (f5ee2000, +5), pvr.mythtv (a17a3a4f, +1), pvr.nextpvr (03a3b714), pvr.njoy (79e8e653), pvr.octonet (a77cf111), pvr.pctv (00b76689), pvr.stalker (df492d27, +1), pvr.vbox (44f3d04e), pvr.vdr.vnsi (07172ed0, +1), pvr.vuplus (921b14f6, +5), pvr.wmc (1d655540)
- Include [env] compare: kodi: updates for September
- Include [env] compare: brcmfmac_sdio-firmware-rpi: set BT MAC as new firmware uses a fixed MAC
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: tvheadend42: fixup ffmpeg patch
- Include [env] patch: tvheadend42: add bzip dependency when transcoding
- Include [env] patch: inputstream.adaptive: don't build it twice...
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] patch: pvr addons: disable broken addons
- Include [env] PR:1773: init: make break after behaviour really break after
- Include [env] PR:1776: Don't cause system to hang on halt/reboot when net-booting
- Include [env] PR:1791: nss/nspr: include in main image [rfc]
- Include [env] PR:1835: add support for optional kernel modules in image and from addons
- Include [env] PR:1876: linux: update to linux-4.12.8
- Include [env] PR:1915: xf86-video-nvidia: update to xf86-video-nvidia-384.69
- Include [env] PR:1917: linux: enable ftrace
- Include [env] PR:1918: Package Updates: intel-vaapi-driver, libva and libva-utils to 1.8.3
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:12311: FIX: ensure real filename from videodb in playlists
- Include [pkg] PR:12710: [DemuxClient] transport flags
Build Highlights:
- New 4.12.8 kernel
- Update intel-vaapi-driver, libva and libva-utils to 1.8.3
- inputstream.adaptive: add search list for libssd_wv.so
- inputstream.adaptive: sort impaired (audio description) streams last
- inputstream.adaptive: build improvements
Build Details:
- LibreELEC.tv:
- oscam: update to 11391 (PR:1912, 1 commit, 2 files changed)
- XBMC:
- [depends] bump libcdio-gplv3 to 0.94 (PR:12709, 1 commit, 2 files changed)
- Change search path logiv for decrypter (b856defb)
- Change search path logiv for decrypter (2) (5adc0312)
- [DASH] Support SegmentList in AdaptationSets (fd103b8c)
- New adaptationset sorting order (impaired last) (be77f9f8)
- Added: [env] patch: tvheadend42: add bzip dependency when transcoding
- Added: [env] patch: inputstream.adaptive: don't build it twice...
- Added: [env] PR:1876: linux: update to linux-4.12.8
- Added: [env] PR:1918: Package Updates: intel-vaapi-driver, libva and libva-utils to 1.8.3
- Added: [pkg] PR:12710: [DemuxClient] transport flags
Just tested a Nvidia GT430.
#0821 with driver 384.59 hangs when playing MPEG2 TS files and SD live TV.
#0823 with 384.69 works fine.
Sample file can be found on
http://www.pjdaniel.org.uk/mpeg/
Weekly Linux 4.13-rc6 build #0824x:
Generic
Packages added/updated:
Latest Intel WIFi firmware for 4.13.y
(2017-08-25, 00:05)mglae Wrote: [ -> ]Just tested a Nvidia GT430.
Sample file can be found on http://www.pjdaniel.org.uk/mpeg/
That's good to know, thanks. Surprising as there's no mention of it in the 384.69 driver release notes, but I'm not complaining!
Running that video untouched it will play from start to finish.
Does the video still work fine for you when doing one or more skip backs?
The display freezes here, but the video plays on, even beyond its video length. All stops when pressing 'x' to stop the video.
Running MH#824/384.69 with a GT1030.
(2017-08-25, 07:23)Klojum Wrote: [ -> ]Does the video still work fine for you when doing one or more skip backs?
Can confirm the behavior.
Seems only to be an issue with MPEG-TS/MPEG2 video. Does not occur on the GT430 with other formats, not even MPEG-ES/MPEG2 or MPEG-TS/H.264.
I created a pull request for the XBox One Digital TV Tuner support
https://github.com/LibreELEC/LibreELEC.tv/pull/1925
Furthermore i created a driver package for Kernel 4.12.8 (Current used kernel) using kernel-overlays. This addon can be used in the meantime.
https://www.dropbox.com/s/tmwq9ndqile95s...2.zip?dl=0
Download and install the above addon and reboot. After the reboot the the tuner should be usable.
!! only usable with Kernel 4.12.8, this means you have to update to Testbuild with Kernel 4.12.8 ==> 0824!!
New LibreELEC.tv Leia build #0825:
Generic
# uname -a
Linux NUC 4.12.9 #1 SMP Fri Aug 25 22:24:42 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170825222320-#0825-g1ca3686 [Build #0825]
# Kodi version
(18.0-ALPHA1 Git:e35491d). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (1ca3686d,
XBMC master (e35491d8,
- Includes latest addons: inputstream.adaptive (be77f9f8, +55), inputstream.rtmp (e094fa38, +1), peripheral.joystick (cc14287c, +3), pvr.argustv (310737e2), pvr.demo (97d9462f, +2), pvr.dvblink (386088b5, +5), pvr.dvbviewer (d88ef8b3, +9), pvr.filmon (1c9d2ebe), pvr.hdhomerun (af02b933, +12), pvr.hts (ecab985b, +2), pvr.iptvsimple (1b803470, +6), pvr.mediaportal.tvserver (f327ab96, +6), pvr.mythtv (b46e5be2, +2), pvr.nextpvr (03a3b714), pvr.njoy (79e8e653), pvr.octonet (a77cf111), pvr.pctv (00b76689), pvr.stalker (df492d27, +1), pvr.vbox (44f3d04e), pvr.vdr.vnsi (7e6e3854, +2), pvr.vuplus (b8316b4c, +6), pvr.wmc (1d655540)
- Include [env] patch: samba: only hup if pid available
- Include [env] PR:1876: linux: update to linux-4.12.9
- Include [env] PR:1919: samba: don't restart smbd in samba-autoshare
- Include [env] PR:1922: brcmfmac_sdio-firmware-rpi: Consolidate firmware files
- Include [env] PR:1923: mesa: update to 17.2.0-rc5
Build Highlights:
- New 4.12.9 kernel
- Fix for FUSE when mounting exFAT
- Avoid restarting Samba when auto-sharing
- Consolidate RPi0W/RPi3 WiFI & BT firmware files - drop brcmfmac43430-sdio.{bin,txt} from non-RPi builds
- Update mesa to mesa-17.2.0-rc5
- PVR Addon API 5.7.0: New functions for EPG tags
- pvr.octonet joins pvr.argustv/filmon/nextpvr/njoy/pctv/stalker/vbox/wmc on the "not building" step.
Build Details:
- LibreELEC.tv:
- xf86-video-nvidia: update to xf86-video-nvidia-384.69 (PR:1915, 1 commit, 2 files changed)
- inadyn: update to 2.2 (PR:1894, 3 commits, 4 files changed)
- build system: drop .img extension for the open virtual appliance (PR:1893, 1 commit, 1 file changed)
- XBMC:
- Explicitly disable guile in GnuTLS build (PR:12638, 1 commit, 1 file changed)
- [PVR][addons][guiinfo][Estuary] PVR Addon API 5.7.0: New functions for EPG tags. (PR:12689, 6 commits, 35 files changed)
- FIX: [droid] update avail stream during state update (PR:12712, 1 commit, 1 file changed)
- Game OSD: New dialog for video settings (PR:12639, 13 commits, 51 files changed)
- pvr.demo:
- PVR API 5.7.0: Add IsEPGTagRecordable, IsEPGTagPlayable, GetEPGTagStr (PR:54, 1 commit, 3 files changed)
- pvr.dvblink:
- PVR API 5.7.0: Add IsEPGTagRecordable, IsEPGTagPlayable, GetEPGTagStr (PR:96, 1 commit, 4 files changed)
- pvr.dvbviewer:
- Final PVR API 5.7.0 (PR:69, 1 commit, 3 files changed)
- pvr.hdhomerun:
- update to PVR API 5.7.0 (PR:58, 1 commit, 4 files changed)
- Set libhdhomerun git tree to master (PR:59, 2 commits, 1 file changed)
- pvr.hts:
- PVR API 5.7.0: Add IsEPGTagRecordable, IsEPGTagPlayable, GetEPGTagStr (PR:324, 1 commit, 5 files changed)
- pvr.iptvsimple:
- PVR API 5.7.0: Add IsEPGTagRecordable, IsEPGTagPlayable, GetEPGTagStr (PR:155, 1 commit, 4 files changed)
- pvr.mediaportal.tvserver:
- PVR API 5.7.0: Add IsEPGTagRecordable, IsEPGTagPlayable, GetEPGTagStr (PR:75, 1 commit, 4 files changed)
- pvr.mythtv:
- PVR API 5.7.0: Add IsEPGTagRecordable, IsEPGTagPlayable, GetEPGTagStr (PR:83, 1 commit, 4 files changed)
- pvr.vdr.vnsi:
- PVR API 5.7.0: Add IsEPGTagRecordable, IsEPGTagPlayable, GetEPGTagStr (PR:8, 1 commit, 3 files changed)
- pvr.vuplus:
- PVR API 5.7.0: Add IsEPGTagRecordable, IsEPGTagPlayable, GetEPGTagStr (PR:73, 1 commit, 4 files changed)
- Updated: [env] patch: pvr addons: disable broken addons
- Added: [env] patch: samba: only hup if pid available
- Added: [env] PR:1919: samba: don't restart smbd in samba-autoshare
- Added: [env] PR:1922: brcmfmac_sdio-firmware-rpi: Consolidate firmware files
- Added: [env] PR:1923: mesa: update to 17.2.0-rc5
New LibreELEC.tv Leia build #0826:
Generic
# uname -a
Linux NUC 4.12.9 #1 SMP Sat Aug 26 23:03:11 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170826230147-#0826-g1ca3686 [Build #0826]
# Kodi version
(18.0-ALPHA1 Git:eeed730). Platform: Linux x86 64-bit
Based on tip of
XBMC master (eeed7305,
- Includes latest addons: inputstream.adaptive (b96e503a, +58), inputstream.rtmp (e094fa38, +1), peripheral.joystick (cc14287c, +3), pvr.argustv (310737e2), pvr.demo (97d9462f, +2), pvr.dvblink (386088b5, +5), pvr.dvbviewer (d88ef8b3, +9), pvr.filmon (1c9d2ebe), pvr.hdhomerun (8afbcd23, +13), pvr.hts (ecab985b, +2), pvr.iptvsimple (1b803470, +6), pvr.mediaportal.tvserver (f327ab96, +6), pvr.mythtv (b46e5be2, +2), pvr.nextpvr (03a3b714), pvr.njoy (79e8e653), pvr.octonet (a77cf111), pvr.pctv (00b76689), pvr.stalker (df492d27, +1), pvr.vbox (44f3d04e), pvr.vdr.vnsi (7e6e3854, +2), pvr.vuplus (b8316b4c, +6), pvr.wmc (1d655540)
Build Highlights:
- inputstream.adaptive and RetroPlayer fixes
Build Details:
- XBMC:
- RetroPlayer fixes (PR:12665, 4 commits, 20 files changed)
- [depends] bump libxml2 to 2.9.4 (PR:12718, 1 commit, 1 file changed)
- [AE/OSXSink] - fixed c&p in scoring algorithm - thx to dcb314 - fixes #17580 (PR:12716, 1 commit, 1 file changed)
- compile issue fixed (issue: 57) (a1d7d2ef)
- IGNOREDISPLAY settings option (to get 4K on FHD displays) (d8a579af)
- Check for HEV instead HEVC to support hev1* streams (b96e503a)
- pvr.hdhomerun:
- Use .tar.gz instead off commit number to get libhdhomerun (PR:60, 1 commit, 1 file changed)
