(2017-09-07, 03:50)lrusak Wrote: [ -> ] (2017-09-07, 03:50)WaVe_99 Wrote: [ -> ]Hi all, is some music visualisation working? I used goom, but it is not working anymore, also others visualisation like PM, waveform etc (some kodi.binary.global.main 1.0.10 dependecies problem)... It was OK few builds ago, i think bere 09x builds...
Binary add-ons repo needs to be rebuilt
Thank you lrusak, you mean rebuilt by kodi team dev., right? Its nothing i can do with it on my side, if i understand correctly? Thank you again.
hi all,
an issue is haunting me since >0801 (tried 0906 also).
when i watch live-tv and want to switch over to viewing a recording, i have to press "Stop" (the live tv session) first, or else the recording won't play.
When i press "Stop" first, the live tv stops, i can then select a recording and it plays fine.
this is in the log (
pastebin ):
13:01:17.243 T:140439089485568 ERROR: Open - error probing input format, pvr://recordings/tv/active/Super 4/Super%204, TV%20(RTL%208%20HD), 20170907_102700, 1195485100.pvr
13:01:17.246 T:140439089485568 ERROR: Previous line repeats 9 times.
13:01:17.246 T:140439089485568 ERROR: OpenDemuxStream - Error creating demuxer
(2017-09-07, 04:19)Milhouse Wrote: [ -> ] (2017-09-06, 22:22)Milhouse Wrote: [ -> ] (2017-09-06, 01:42)Amra Wrote: [ -> ]I am, however, having a problem with Builds #830 and on up. Build #829 will play HEVC 10bit local files (via SW decoding) just fine but as of #830 only 8bit HEVC files will play fine (via HW decoding) while 10bit HEVC files will play but with very garbled video. Audio is fine on both types. I have an Intel Core i-3 6100 CPU if that helps. Please let me know if you would like any logs. Thanks in advance.
Yes, I can confirm (Skylake NUC). No idea what is causing that though.
I've narrowed it down and informed the developer, will mention in a future changelog once it is fixed. It's an ffmpeg patch, and affects all software decoded HEVC playback, 8-bit and 10-bit.
Thanks for looking into it. Much appreciated.
(2017-09-07, 12:35)jpeg73 Wrote: [ -> ]Hi Milhouse,
I used only few release since august ( in the past I was using only official version)
but I catch your idea, I don't beleive it"'s an HW issue because Ive 3 differents boards and the issue is the same
I tested on 3 differents screens & cables .. still the same again
I made some investigations and here is the result
LE Ver Result Kernel Ver
LE8.1.1 OK
#1130, 01-Dec-2016: Generic OK 4.8.1
#1215, 16-Dec-2016: Generic OK 4.9.0
#0116, 16-Jan-2017: Generic OK 4.9.4
#0327, 27-Mar-2017: Generic OK 4.10.6
#0422, 22-Apr-2017: Generic OK 4.10.12
#0507, 07-May-2017: Generic OK 4.11.0
#0615, 15-Jun-2017: Generic OK 4.11.5
#0706, 06-Jul-2017: Generic OK 4.11.9
#0713, 14-Jul-2017: Generic OK 4.11.10
#0714, 14-Jul-2017: Generic KO 4.12.1
#0805, 06-Aug-2017: Generic KO 4.12.4
#0905, 05-Sep-2017: Generic KO 4.13.0
I think you have to dig more on new kernel 4.12.1, because before I didn't observe any issue at all
Hope it helps
Regards
JP
We had 8 test releases for 4.12 (one for each release candidate, plus 4.12.0 as the cutover to the new kernel was delayed by an nvidia driver issue) - can you try the Generic builds linked in
PR:1629 as that should help narrow it down further.
I do the following
from #714 -> #0518x result KO
from #0518x -> #0628x result KO
from #0628x -> #713 result OK
Any test to advice ?
Regards
JP
(2017-09-07, 06:38)Milhouse Wrote: [ -> ] (2017-09-06, 22:56)Nekromantik Wrote: [ -> ]Anyone else on Apollo Lake NUC cant get 5ghz wifi channels past 48 to work?
On mine it hangs on black screen with mouse pointer after splash screen.
The 5GHz channels above 48, ie. 52+, are the DFS (Dynamic Frequency Selection) channels which can only be used if no other equipment (ie. radar) is using the same radio spectrum used by DFS, and it's the access point that must automatically move off the DFS channel if interference is detected hence it's a feature that not every access point vendor supports.
A DFS client will only transmit on a DFS channel if it is approved to do so by the access point - have you confirmed that your access point supports DFS? If it doesn't support DFS, or has a faulty implementation of DFS, then an Intel WiFi client won't transmit on a DFS channel.
Is the "hanging" you are seeing possibly "wait for network" (which will never connect), or Wake-on-LAN?
My router does support DFS. Im using DD WRT.
The NUC when booted to windows works fine so its just on LE.
I do have wait for network so yes its probably that.
Quick post here likely missing important info, so quite possibly useless. But while it's on my mind, here it is.
Up until a couple days ago I was running two systems, both on stable version of LibreELEC. One is on a Chromebox, the other is on a VM on my unRAID Server @ 4 MB RAM & 4 Cores.
I updated the Chromebox to #0903. No issues for my uses outside of the HDHR addon no longer working properly. The "thinking" rotating clock, and then logo were stuck on the screen and there wasn't anything I can do. No biggie as I rarely use this addon, only if the MythTV PVR backend is failing for whatever reason and I don't have time to reset it. I was able to install Netflix and Amazon Prime. Big plus.
Today, I did the upgrade to the VM. After the reboot, it was sluggish and unusable. Navigating the menu was clunky, a second or more behind, and videos would not stream properly. I realized I had installed #0906. I figured it was something with the VM not working well on these Alpha versions, but I decided to try again by downgrading to #0903, the working version on my Chromebox. To my pleasant surprise, it worked.
If there's any diagnostic logs you'd like me to run, or tests to try out, I'll keep my eye on this thread.
@Living Legend can you test #0904 and #0905 to determine if they're also affected with the same sluggish performance? The obvious candidate would be #0904 with the new 4.13 kernel, though I've no idea why...
(2017-09-07, 23:04)Living Legend Wrote: [ -> ]Quick post here likely missing important info, so quite possibly useless. But while it's on my mind, here it is.
What form of virtualization is it? You can only expect good performance if you are using qemu and passing through a dedicated gpu. Otherwise you are going to get software decoding of videos which won't work that we'll.
New LibreELEC.tv Leia build #0907:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.13.0 #1 SMP Thu Sep 7 23:23:33 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170907232205-#0907-g4c29a52 [Build #0907]
# Kodi version
(18.0-ALPHA1 Git:5b11de0). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (4c29a52,
changelog) and tip of
XBMC master (5b11de0,
- Includes latest kodi-platform master (36fb493)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (3ba2a2c, ahead +101)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (1656efc), inputstream.rtmp (e094fa3), peripheral.joystick (cc14287), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (8741c8b), pvr.filmon (34dca04), pvr.hdhomerun (ace19fa), pvr.hts (53118d8), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (c86ab35), pvr.mythtv (b46e5be), pvr.nextpvr (a855663), pvr.njoy (99874de), pvr.octonet (a77cf11), pvr.pctv (549f690), pvr.stalker (e15edca), pvr.vbox (b5da811), pvr.vdr.vnsi (f3f80d5, +1), pvr.vuplus (9bfd868), pvr.wmc (d820bf8), pvr.zattoo (a24879b)
- Include [env] 22775c5: include crazycat dvb drivers addon in image
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] patch: pvr addons: disable broken addons
- Include [env] PR:1773: init: make break after behaviour really break after
- Include [env] PR:1776: Don't cause system to hang on halt/reboot when net-booting
- Include [env] PR:1791: nss/nspr: include in main image [rfc]
- Include [env] PR:1835: add support for optional kernel modules in image and from addons
- Include [env] PR:1917: linux: enable ftrace
- Include [env] PR:1919: samba: don't restart smbd in samba-autoshare
- Include [env] PR:1947: package updates
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:234: implement intensity compensation for VC-1 decoding for Ivybridge and better (intel-vaapi-driver)
- Include [pkg] PR:260: Fix Seeking with VC1 after 6702b01ee3598017f05374bfc7956493f790361c (intel-vaapi-driver)
- Include [pkg] PR:12767: Partial revert of imdb crashfix due to a introduced bug
- Include [pkg] PR:12778: [PVR] CPVRClient::CloseStream must reset playing flags and playing recording/channel.
Build Highlights:
- Drop PR12311 (FIX: ensure real filename from videodb in playlists) - needs rebase
- Re-enable ftrace
- [PVR] Fix issue that required "Stop" before playback of a recording (@basco)
Build Details:
- LibreELEC.tv:
- dvb-apps: fix compilation with current perl versions (PR:1954, 1 commit, 1 file changed)
- XBMC:
- [videoinfoscanner] properly handle excludes (fixes #16444) (PR:12772, 1 commit, 1 file changed)
- Use applicationmessenger to show CGUIDialogOK with an helper (PR:10893, 4 commits, 64 files changed)
- Disable top bar: FullscreenGame version (PR:12761, 2 commits, 28 files changed)
- Added: [env] PR:1917: linux: enable ftrace
- Added: [pkg] PR:12778: [PVR] CPVRClient::CloseStream must reset playing flags and playing recording/channel.
Off topic:
(2017-09-07, 11:31)Milhouse Wrote: [ -> ] (2017-09-07, 09:46)nexusle Wrote: [ -> ]General question:
How to use PSX ISOs in this build?
There's a dedicated retroplayer thread that might be the best place to ask: https://forum.kodi.tv/showthread.php?tid=173361
Try to add this to: advancedsettings.xml in userdata:
<advancedsettings>
<videoextensions>
<remove>.iso|.bin|.img|.zip</remove>
</videoextensions>
<musicextensions>
<remove>.cue|.zip</remove>
</musicextensions>
<pictureextensions>
<remove>.zip</remove>
</pictureextensions>
</advancedsettings.xml>
(2017-09-07, 21:48)Nekromantik Wrote: [ -> ]My router does support DFS. Im using DD WRT.
Can you install the "network tools" add-on from the LibreELEC repository as this will install the iw utility, reboot, then run:
iw list | pastebinit
iw reg get | pastebinit
iw dev wlan0 scan | pastebinit
iw dev wlan0 info | pastebinit
iw dev wlan0 link | pastebinit
and paste the links.
running 0907 build
renders the interface unusable on my hardware.
regarding interface build 0904 still works
as of 09XX build the addon game.libretro is no longer compatible
can I fix this somehow?
Found an issue with IPTV simple pvr addon.
Starting with build 0808 (the first build with a working IPTV simple addon after the PVR api to 5.4.0 update) Kodi displays the "ends at" time on the OSD the same as the current time.
The progress bar at the bottom of the OSD is oke, but the times underneath it are also weird.
Images attached:
first: build 0722 (last working version before PVR api update).
second: build 0808 and up.
watch gallery
Hi Milhouse,
seit #905 - #907 große Performance Probleme, ein CPU Kern immer mit 100% ausgelastet. #904 OK
since # 905 - # 907 great performance problems, a CPU core always loaded with 100%. # 904 OK
top - 19:23:22 up 14 min, 1 user, load average: 1.08, 1.02, 0.69
Tasks: 96 total, 2 running, 93 sleeping, 0 stopped, 1 zombie
%Cpu(s): 49.8 us, 0.8 sy, 0.7 ni, 48.7 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
KiB Mem : 3199624 total, 2007232 free, 374944 used, 817448 buff/cache
KiB Swap: 0 total, 0 free, 0 used. 2527980 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
665 root 20 0 1933336 377340 77988 R 102.0 11.8 14:45.00 kodi.bin
202 root 20 0 33728 4548 4188 S 0.3 0.1 0:00.57 systemd-journal
513 root 20 0 127564 15868 10584 S 0.3 0.5 0:06.81 Xorg
1 root 20 0 20240 5796 4568 S 0.0 0.2 0:01.19 systemd
2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd
3 root 20 0 0 0 0 S 0.0 0.0 0:00.54 kworker/0:0
4 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0H
5 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kworker/u8:0
6 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 mm_percpu_wq
7 root 20 0 0 0 0 S 0.0 0.0 0:00.16 ksoftirqd/0
8 root 20 0 0 0 0 S 0.0 0.0 0:00.08 rcu_sched
9 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcu_bh
10 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/0
11 root rt 0 0 0 0 S 0.0 0.0 0:00.00 watchdog/0
12 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/0
13 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/1
14 root rt 0 0 0 0 S 0.0 0.0 0:00.00 watchdog/1
15 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/1
16 root 20 0 0 0 0 S 0.0 0.0 0:00.14 ksoftirqd/1
17 root 20 0 0 0 0 S 0.0 0.0 0:00.43 kworker/1:0
18 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/1:0H
19 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kdevtmpfs
20 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 netns
22 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kworker/0:1
23 root 20 0 0 0 0 S 0.0 0.0 0:00.00 khungtaskd
24 root 20 0 0 0 0 S 0.0 0.0 0:00.00 oom_reaper
25 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 writeback
26 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kcompactd0
27 root 39 19 0 0 0 S 0.0 0.0 0:00.00 khugepaged
28 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 crypto
29 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kblockd
30 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 ata_sff
31 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 rpciod
32 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 xprtiod
33 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kswapd0
34 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 nfsiod
35 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 cifsiod
36 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 cifsoplockd
66 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 acpi_thermal_pm
67 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 ttm_swap
69 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 knbd-recv
70 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 iscsi_eh
71 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 nvme-wq
72 root 20 0 0 0 0 S 0.0 0.0 0:00.00 scsi_eh_0
73 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 scsi_tmf_0
74 root 20 0 0 0 0 S 0.0 0.0 0:00.00 scsi_eh_1
