2017-09-16, 11:59
(2017-09-16, 10:34)caribo Wrote: [ -> ]Hi Milhouse, any chance you could build projectm and asteroids as well?
Thanks in advance!
Updated.
Thanks in advance!
(2017-09-16, 05:03)Milhouse Wrote: [ -> ](2017-09-16, 04:55)Guilouz Wrote: [ -> ]Does anyone have issue with playback ?
Randomly playback hangs on image, if I wait nothing happens. If I stop playback, Kodi freeze few seconds before go back to files list.
Something else, when I use backward/forward, Kodi always caching and take many seconds to resume playback.
This happens since 2/3 builds ago. No issue with Kodi on OSX with same files.
debug log (wiki).
(2017-09-16, 16:46)extremeaudio Wrote: [ -> ]Not able to access samba shares from a Windows PC. Upgraded from Krypton to Leia. Krypton access was fine. Now I get username password prompt and cant bypass using guest: [blank]
Anything I can do?
# This file is part of LibreELEC - https://libreelec.tv
# Copyright (C) 2017-present Team LibreELEC
# LibreELEC is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 2 of the License, or
# (at your option) any later version.
# LibreELEC is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with LibreELEC. If not, see <http://www.gnu.org/licenses/>.
# samba.conf v4 (do not remove)
# This configuration file allows you to customize the samba shares
# available from your machine
[global]
server string = LibreELEC
browseable = yes
writeable = yes
printable = no
deadtime = 30
mangled names = no
name resolve order = host bcast
printcap name = /dev/null
load printers = no
encrypt passwords = true
enable core files = no
passdb backend = smbpasswd
smb encrypt = disabled
# samba share options
map to guest = Bad User
guest account = root
security = user
# samba tuning options
socket options = TCP_NODELAY IPTOS_LOWDELAY
min receivefile size = 16384
aio read size = 16384
aio write size = 16384
use sendfile = yes
# The following are default values for the master selection process
# local master = yes
# preferred master = auto
# domain master = auto
# os level = 20
# "strict allocate = yes" breaks large network transfers to external hdd
# Force this to "no" in case "yes" becomes the default in future
strict allocate = no
allocation roundup size = 0
# Using the following configurations as a template allows you to add
# writable shares of disks and paths under /storage
[Update]
path = /storage/.update
available = yes
browsable = yes
public = yes
writable = yes
root preexec = mkdir -p /storage/.update
[Videos]
path = /storage/videos
available = yes
browsable = yes
public = yes
writable = yes
root preexec = mkdir -p /storage/videos
[Music]
path = /storage/music
available = yes
browsable = yes
public = yes
writable = yes
root preexec = mkdir -p /storage/music
[TV Shows]
path = /storage/tvshows
available = yes
browsable = yes
public = yes
writable = yes
root preexec = mkdir -p /storage/tvshows
[Recordings]
path = /storage/recordings
available = yes
browsable = yes
public = yes
writable = yes
root preexec = mkdir -p /storage/recordings
[Downloads]
path = /storage/downloads
available = yes
browsable = yes
public = yes
writable = yes
root preexec = mkdir -p /storage/downloads
[Pictures]
path = /storage/pictures
available = yes
browsable = yes
public = yes
writable = yes
root preexec = mkdir -p /storage/pictures
[Emulators]
path = /storage/emulators
available = yes
browsable = yes
public = yes
writable = yes
root preexec = mkdir -p /storage/emulators
[Configfiles]
path = /storage/.config
available = yes
browsable = yes
public = yes
writable = yes
root preexec = mkdir -p /storage/.config
[Userdata]
path = /storage/.kodi/userdata
available = yes
browsable = yes
public = yes
writable = yes
root preexec = mkdir -p /storage/.kodi/userdata
[Screenshots]
path = /storage/screenshots
available = yes
browsable = yes
public = yes
writable = yes
root preexec = mkdir -p /storage/screenshots
[Logfiles]
path = /storage/logfiles
available = yes
browsable = yes
public = yes
writable = yes
root preexec = mkdir -p /storage/logfiles
root preexec = createlog
[Backup]
path = /storage/backup
available = yes
browsable = yes
public = yes
writable = yes
root preexec = mkdir -p /storage/backup
[Picons]
path = /storage/picons
available = yes
browsable = yes
public = yes
writable = yes
root preexec = mkdir -p /storage/picons/tvh /storage/picons/vdr
[KODI]
available = yes
browsable = yes
public = yes
writable = yes
(2017-09-16, 16:46)extremeaudio Wrote: [ -> ]Not able to access samba shares from a Windows PC. Upgraded from Krypton to Leia. Krypton access was fine. Now I get username password prompt and cant bypass using guest: [blank]Yes, add a username and password on your Windows PC. Anonymous access isn't supported any longer.
Anything I can do?
(2017-09-16, 18:19)Guilouz Wrote: [ -> ](2017-09-16, 16:46)extremeaudio Wrote: [ -> ]Not able to access samba shares from a Windows PC. Upgraded from Krypton to Leia. Krypton access was fine. Now I get username password prompt and cant bypass using guest: [blank]
Anything I can do?
Same issue on OSX.
When I start LibreELEC, I see SMB share in Finder but I can't access in guest mode.
I need to enable login and password in LibreELEC settings, so I can access with them. Then I disable them and I can access in guest mode.
I need to do this every time I quit and restart Kodi.
Note : I use latest samba.conf
# uname -a
Linux NUC 4.13.2 #1 SMP Sat Sep 16 21:06:35 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170916210509-#0916-g4218aca [Build #0916]
# Kodi version
(18.0-ALPHA1 Git:6772aeb). Platform: Linux x86 64-bit
(2017-09-16, 22:06)Milhouse Wrote: [ -> ](2017-09-16, 18:19)Guilouz Wrote: [ -> ](2017-09-16, 16:46)extremeaudio Wrote: [ -> ]Not able to access samba shares from a Windows PC. Upgraded from Krypton to Leia. Krypton access was fine. Now I get username password prompt and cant bypass using guest: [blank]
Anything I can do?
Same issue on OSX.
That's not the same issue - he's talking about Kodi accessing a Windows PC (using libsmbclient, which no longer supports anonymous access due to security changes made by Microsoft), you are talking about Finder accessing the LibreELEC Samba Server (smbd) using whatever (potentially broken) client your Mac uses.
Anonymous access *is* still supported and working in the LE Samba Server. If your Mac is having a problem then it's a Mac-specific issue. Have you tried changing min protocol to SMB1 in LE Settings, maybe your Mac doesn't work well with SMB2?
(2017-09-17, 06:17)Guilouz Wrote: [ -> ]Since OSX Yosemite it's SMB3 used. I'm on High Sierra on a new install with iMac Retina 5K. This issue appear since recently change with samba.conf. No problem before.
cat /storage/.config/samba.conf | pastebinit
cat /run/samba/smb.conf | pastebinit
journalctl -a | pastebinit
(2017-09-17, 13:29)Milhouse Wrote: [ -> ](2017-09-17, 06:17)Guilouz Wrote: [ -> ]Since OSX Yosemite it's SMB3 used. I'm on High Sierra on a new install with iMac Retina 5K. This issue appear since recently change with samba.conf. No problem before.
How are you customising your samba.config?
The stock samba config is unchanged by the recent validation - it only updates the header and adds a version, which are all comments so ignored. The config itself is identical to the previous version.
Run the following:
and paste the links, please.Code:cat /storage/.config/samba.conf | pastebinit
(2017-09-17, 15:45)Guilouz Wrote: [ -> ]This is my samba.conf, just add path to have access to Kodi folder :
https://pastebin.com/8ZdEMzbY
(2017-09-17, 23:13)WaVe_99 Wrote: [ -> ]Hi Milhouse, debug log about the problem with fast forward and rewind issues which starts on 0910 build - nothing changed to latest build, tested on latest build. I tried one mkv on nfs share and one stream video... Log was too big on pastebin, so... The first movie name was Dira.U.Hanusovic.2014.1080p.mkv, for easier searching at log... At 0909 was everything fine...
https://drive.google.com/file/d/0B5JccsH...sp=sharing
22:54:23.967 T:140234368100480 DEBUG: ------ Window Deinit (DialogSeekBar.xml) ------
22:54:24.014 T:140231584388864 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
22:54:25.790 T:140231493801728 ERROR: Previous line repeats 1 times.
22:54:25.790 T:140231493801728 DEBUG: CVideoPlayer::SetCaching - caching state 0
22:54:25.790 T:140231493801728 DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000
22:54:27.233 T:140231584388864 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
22:54:28.843 T:140231584388864 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
22:54:32.451 T:140233232348928 ERROR: Previous line repeats 2 times.
22:54:33.672 T:140231584388864 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
22:54:37.454 T:140233232348928 ERROR: Previous line repeats 2 times.
22:54:38.503 T:140231584388864 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
22:54:42.456 T:140233232348928 ERROR: Previous line repeats 2 times.
22:54:43.333 T:140231584388864 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
22:54:47.332 T:140234349168384 ERROR: Previous line repeats 2 times.
# uname -a
Linux NUC 4.13.2 #1 SMP Sun Sep 17 21:05:03 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170917210336-#0917-gb98a31e [Build #0917]
# Kodi version
