(2017-09-23, 09:57)debutanker Wrote: [ -> ]Many thanks for trying to fix the channel preselection issue ( PR 12823 ), sadly theres no new behaviour in this case.
I can confirm that there is no change in behaviour.
(2017-09-23, 01:30)rudrood Wrote: [ -> ]@Milhouse,
When you can find the time, is it possible to update vis. waveform for RPI2, and vis. spectrum for generic?
Rebuilt and updated, but totally untested.
New LibreELEC.tv Leia build #0923:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.13.3 #1 SMP Sat Sep 23 21:55:29 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170923215403-#0923-gea8fa96 [Build #0923]
# Kodi version
(18.0-ALPHA1 Git:ec3fc3d). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (ea8fa96,
changelog) and tip of
XBMC master (ec3fc3d,
- Includes latest kodi-platform master (36fb493)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (3ba2a2c, ahead +101)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (dde3921, +12), inputstream.rtmp (e094fa3), peripheral.joystick (cc14287), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (8741c8b), pvr.filmon (34dca04), pvr.hdhomerun (ace19fa), pvr.hts (53118d8), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (c86ab35), pvr.mythtv (b46e5be), pvr.nextpvr (03933e9, +3), pvr.njoy (cc1cb56, +1), pvr.octonet (a77cf11), pvr.pctv (549f690), pvr.stalker (e15edca), pvr.teleboy (8280157, +16), pvr.vbox (ff01396, +1), pvr.vdr.vnsi (f3f80d5, +1), pvr.vuplus (5e154bc, +4), pvr.wmc (7e2cb4b, +1), pvr.zattoo (47cf5db, +11)
- Include [env] 22775c5: include crazycat dvb drivers addon in image
- Include [env] compare: dmidecode: initial package
- Include [env] compare: kodi updates (ffmpeg-3.3.4)
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: tvheadend42: fix makefile patch
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] patch: pvr addons: disable broken addons
- Include [env] PR:1776: Don't cause system to hang on halt/reboot when net-booting
- Include [env] PR:1791: nss/nspr: include in main image [rfc]
- Include [env] PR:1835: add support for optional kernel modules in image and from addons
- Include [env] PR:1978: linux: update to linux-4.13.4
- Include [env] PR:2002: linux: include HBR and ELD fixes for Intel
- Include [pkg] e5dbcce3: X11: fix getting visual (kodi)
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:234: implement intensity compensation for VC-1 decoding for Ivybridge and better (intel-vaapi-driver)
- Include [pkg] PR:260: Fix Seeking with VC1 after 6702b01ee3598017f05374bfc7956493f790361c (intel-vaapi-driver)
- Include [pkg] PR:12823: [PVR] Fix channel OSD dialog channel preselection.
Build Highlights:
- Fix visuals with xf86-video-nvidia
- Updated OSD channel preselection PR:12823
Build Details:
- LibreELEC.tv:
- projects/WeTek_Hub: build media support drivers as modules (PR:2029, 2 commits, 2 files changed)
- projects/Odroid_C2: build media support drivers as modules (PR:2031, 2 commits, 2 files changed)
- projects/WeTek_Play_2: build media support drivers as modules (PR:2030, 3 commits, 3 files changed)
- scripts: update checkdeps for openjdk and libjson-perl on Arch (ea8fa96)
- XBMC:
- [addons] add blocked addon call event to prevent problems after disable (PR:12473, 4 commits, 7 files changed)
- VideoPlayer: send cb notifications on exit via a job (PR:12817, 1 commit, 1 file changed)
- pvr.zattoo:
- Added: [pkg] e5dbcce3: X11: fix getting visual (kodi)
Updated PR:12823 fixed my problems with OSD channel preselection!
Thanks a lot @ksooo!
Running #0923 it's not possible to install addons from repositories, doesn't matter whether it's official Kodi repository or Libreelec repository.
I get this message when trying to install boblight from Libreelec repo.
https://ibb.co/gjkdr5
Ah, ok.
I should read the pr's till the end...
So, I have a question. Not sure if this is a common bug or just me.
I have GUI issues, like when I start a movie and stop let's say half way. Normally that would instantly show up on started movies under the movies category. But for me it does not show up until a do a reboot of kodi.
I also have this bug where if I change the cateory of a folder, let's say movie to nothing, the change is not reflected.
This could be because I have upgraded and upgraded my database from back in the day. Is there any other way to fix it then a complete re-initalize my db?
New LibreELEC.tv Leia build #0924:
Generic
# uname -a
Linux NUC 4.13.3 #1 SMP Mon Sep 25 01:03:59 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170925010233-#0924-g6843ee6 [Build #0924]
# Kodi version
(18.0-ALPHA1 Git:208431e). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (6843ee6,
XBMC master (208431e,
- Includes latest addons: inputstream.adaptive (dde3921, +12), inputstream.rtmp (e094fa3), peripheral.joystick (cc14287), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (8741c8b), pvr.filmon (34dca04), pvr.hdhomerun (ace19fa), pvr.hts (53118d8), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (c86ab35), pvr.mythtv (8965048, +4), pvr.nextpvr (03933e9, +3), pvr.njoy (cc1cb56, +1), pvr.octonet (a77cf11), pvr.pctv (549f690), pvr.stalker (e15edca), pvr.teleboy (a799d13, +17), pvr.vbox (ff01396, +1), pvr.vdr.vnsi (f3f80d5, +1), pvr.vuplus (5e154bc, +4), pvr.wmc (7e2cb4b, +1), pvr.zattoo (dddc4b2, +18)
- Include [pkg] PR:12715: RetroPlayer: Add renderer for Windows, OpenGL, OpenGLES and MMAL
- Include [pkg] PR:12826: Linux: add missing wrapper functions to fix playing DVD folders over network
Build Highlights:
- RetroPlayer: Add renderer for Windows, OpenGL, OpenGLES and MMAL
Build Details:
- LibreELEC.tv:
- kodi: switch to using find to avoid argument limit (PR:2034, 1 commit, 1 file changed)
- XBMC:
- VideoPlayer: fixes (PR:12828, 2 commits, 4 files changed)
- [PVR] Fix channel OSD dialog channel preselection. (PR:12823, 1 commit, 2 files changed)
- [ios/tvos] - added latest apple devices to allow retina support (PR:12832, 1 commit, 1 file changed)
- [windows][x64] add pillow (PR:12830, 1 commit, 1 file changed)
- pvr.mythtv:
- [lang] automatic syntax corrections for the en_GB language file (9553cd2)
- [lang] updated language files from Transifex (d9b517a)
- fix compilation warning since g++ 7.2.0 (738c8f4)
- bump version 5.4.1 (8965048)
- pvr.teleboy:
- pvr.zattoo:
- ubuntu/debian packaging fixes (PR:8, 4 commits, 4 files changed)
- [debian packaging] add pkg-config dependency (PR:9, 1 commit, 1 file changed)
- Remove tinyxml2 (aa7eca8)
- Update version and changelog (dddc4b2)
- Added: [pkg] PR:12715: RetroPlayer: Add renderer for Windows, OpenGL, OpenGLES and MMAL
- Added: [pkg] PR:12826: Linux: add missing wrapper functions to fix playing DVD folders over network
New LibreELEC.tv Leia build #0925:
Generic
# uname -a
Linux NUC 4.13.3 #1 SMP Mon Sep 25 21:05:16 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170925210347-#0925-g6843ee6 [Build #0925]
# Kodi version
(18.0-ALPHA1 Git:617a394). Platform: Linux x86 64-bit
Based on tip of
XBMC master (617a394,
- Includes latest addons: inputstream.adaptive (dde3921), inputstream.rtmp (e094fa3), peripheral.joystick (cc14287), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (8741c8b), pvr.filmon (34dca04), pvr.hdhomerun (ace19fa), pvr.hts (53118d8), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (c86ab35), pvr.mythtv (8965048), pvr.nextpvr (03933e9), pvr.njoy (cc1cb56), pvr.octonet (a77cf11), pvr.pctv (549f690), pvr.stalker (e15edca), pvr.teleboy (fd032f1, +2), pvr.vbox (ff01396), pvr.vdr.vnsi (f3f80d5), pvr.vuplus (5e154bc), pvr.wmc (7e2cb4b), pvr.zattoo (dddc4b2)
- Include [env] PR:2037: samba: update to samba-4.7.0
Build Highlights:
- samba: update to samba-4.7.0
Build Details:
- XBMC:
- X11: fix getting visual (PR:12835, 1 commit, 1 file changed)
- [music] SortByTrackNumber as default sort for "songs" (PR:12834, 1 commit, 1 file changed)
- [windows][x64] add pycryptodome (PR:12836, 1 commit, 1 file changed)
- pvr.teleboy:
- Added: [env] PR:2037: samba: update to samba-4.7.0
Audio passtrough on Kaby Lake is nightmare :-) HBR is working now, but stereo for example sometimes doesnt... And more things... Anyone with KL and same experience?
Sent from my iPad
New LibreELEC.tv Leia build #0926:
Generic
# uname -a
Linux NUC 4.13.3 #1 SMP Tue Sep 26 21:05:04 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170926210340-#0926-g195c4b1 [Build #0926]
# Kodi version
(18.0-ALPHA1 Git:6f99b6e). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (195c4b1,
XBMC master (6f99b6e,
- Includes latest addons: inputstream.adaptive (dde3921), inputstream.rtmp (e094fa3), peripheral.joystick (cc14287), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (8741c8b), pvr.filmon (34dca04), pvr.hdhomerun (ace19fa), pvr.hts (53118d8), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (c86ab35), pvr.mythtv (8965048), pvr.nextpvr (03933e9), pvr.njoy (cc1cb56), pvr.octonet (e9b4c05, +1), pvr.pctv (549f690), pvr.stalker (e15edca), pvr.teleboy (fd032f1, +2), pvr.vbox (ff01396), pvr.vdr.vnsi (f3f80d5), pvr.vuplus (5e154bc), pvr.wmc (7e2cb4b), pvr.zattoo (dddc4b2)
Build Highlights:
- Re-enable pvr.octonet
- Fix addon installation broken in #0923
Build Details:
- LibreELEC.tv:
- options: fix addon path for projects with devices (PR:2038, 1 commit, 1 file changed)
- XBMC:
- [addons] update vfs addon interface doxygen docu (PR:12838, 1 commit, 1 file changed)
- [addons] fix addon install if not present before (PR:12825, 3 commits, 5 files changed)
- pvr.octonet:
- Update to PVR API version 5.7.0 (e9b4c05)
- Added: [env] patch: pvr addons: disable broken addons
