Full Version: LibreELEC Testbuilds for x86_64 (Kodi 18.0)
(2017-11-14, 14:46)pacoma2610 Wrote: [ -> ]This "Then run ir-keytable -t, press a button for a short time, wait a second or two, then press another button for a bit longer (1 or 2 seconds). Post the output you got on the console, it should look like that:
Code:" has no effect to my system
Have you stopped kodi, xorg and eventlircd? If they are running you'll get no output from ir-keytable -t.
so long,
Hias
Hi Milhouse,
I posted here..  324008 (thread).
This issue only exists on the libreelec versions - has done for a while but used to work in kodi17 or a while ago, I tested one of the latest nightly builds (http://mirrors.kodi.tv/nightlies/windows/win64/master/) on my laptop and it works as expected so seems to be an issue solely with libreelec and not tvheadend or the addon.
This happens on all 3 kodi tv boxes I have, Acer revo 3700, Zotac ID-80 and Zotac ID-88 - all running #1112.
Let me know what you want to see to help understand why this might be..
@HiassofT
http://sprunge.us/haIP
LivingRoom:~ # ir-keytable
Found /sys/class/rc/rc0/ (/dev/input/event8) with:
        Driver ite-cir, table rc-rc6-mce
        Supported protocols: lirc rc-5 rc-5-sz jvc sony nec sanyo mce_kbd rc-6 sharp xmp
        Enabled protocols: lirc nec rc-6
        Name: ITE8708 CIR transceiver
        bus: 25, vendor/product: 1283:0000, version: 0x0000
        Repeat delay = 500 ms, repeat period = 125 ms
LivingRoom:~ # ir-keytable -t
Testing events. Please, press CTRL-C to abort.
1510680591.697657: event type EV_MSC(0x04): scancode = 0x800f041f
1510680591.697657: event type EV_KEY(0x01) key_down: KEY_DOWN(0x006c)
1510680591.697657: event type EV_SYN(0x00).
1510680591.867355: event type EV_KEY(0x01) key_up: KEY_DOWN(0x006c)
1510680591.867355: event type EV_SYN(0x00).
1510680591.935026: event type EV_MSC(0x04): scancode = 0x800f041f
1510680591.935026: event type EV_KEY(0x01) key_down: KEY_DOWN(0x006c)
1510680591.935026: event type EV_SYN(0x00).
1510680592.104100: event type EV_KEY(0x01) key_up: KEY_DOWN(0x006c)
1510680592.104100: event type EV_SYN(0x00).
1510680597.714055: event type EV_MSC(0x04): scancode = 0x800f0405
1510680597.714055: event type EV_KEY(0x01) key_down: KEY_NUMERIC_5(0x0205)
1510680597.714055: event type EV_SYN(0x00).
1510680597.819939: event type EV_MSC(0x04): scancode = 0x800f0405
1510680597.819939: event type EV_SYN(0x00).
1510680597.925614: event type EV_MSC(0x04): scancode = 0x800f0405
1510680597.925614: event type EV_SYN(0x00).
1510680598.032422: event type EV_MSC(0x04): scancode = 0x800f0405
1510680598.032422: event type EV_SYN(0x00).
1510680598.137163: event type EV_MSC(0x04): scancode = 0x800f0405
1510680598.137163: event type EV_SYN(0x00).
1510680598.240649: event type EV_KEY(0x01) key_down: KEY_NUMERIC_5(0x0205)
1510680598.240649: event type EV_SYN(0x00).
1510680598.243442: event type EV_MSC(0x04): scancode = 0x800f0405
1510680598.243442: event type EV_SYN(0x00).
1510680598.349097: event type EV_MSC(0x04): scancode = 0x800f0405
1510680598.349097: event type EV_SYN(0x00).
1510680598.370746: event type EV_KEY(0x01) key_down: KEY_NUMERIC_5(0x0205)
1510680598.370746: event type EV_SYN(0x00).
1510680598.456348: event type EV_MSC(0x04): scancode = 0x800f0405
1510680598.456348: event type EV_SYN(0x00).
1510680598.500591: event type EV_KEY(0x01) key_down: KEY_NUMERIC_5(0x0205)
1510680598.500591: event type EV_SYN(0x00).
1510680598.562114: event type EV_MSC(0x04): scancode = 0x800f0405
1510680598.562114: event type EV_SYN(0x00).
1510680598.630641: event type EV_KEY(0x01) key_down: KEY_NUMERIC_5(0x0205)
1510680598.630641: event type EV_SYN(0x00).
1510680598.667906: event type EV_MSC(0x04): scancode = 0x800f0405
1510680598.667906: event type EV_SYN(0x00).
1510680598.760760: event type EV_KEY(0x01) key_down: KEY_NUMERIC_5(0x0205)
1510680598.760760: event type EV_SYN(0x00).
1510680598.837412: event type EV_KEY(0x01) key_up: KEY_NUMERIC_5(0x0205)
1510680598.837412: event type EV_SYN(0x00).
1510680598.905003: event type EV_MSC(0x04): scancode = 0x800f0405
1510680598.905003: event type EV_KEY(0x01) key_down: KEY_NUMERIC_5(0x0205)
1510680598.905003: event type EV_SYN(0x00).
1510680599.074092: event type EV_KEY(0x01) key_up: KEY_NUMERIC_5(0x0205)
1510680599.074092: event type EV_SYN(0x00).
1510680713.301514: event type EV_MSC(0x04): scancode = 0x800f0403
1510680713.301514: event type EV_KEY(0x01) key_down: KEY_NUMERIC_3(0x0203)
1510680713.301514: event type EV_SYN(0x00).
1510680713.470568: event type EV_KEY(0x01) key_up: KEY_NUMERIC_3(0x0203)
1510680713.470568: event type EV_SYN(0x00).
1510680713.538723: event type EV_MSC(0x04): scancode = 0x800f0403
1510680713.538723: event type EV_KEY(0x01) key_down: KEY_NUMERIC_3(0x0203)
1510680713.538723: event type EV_SYN(0x00).
1510680713.707404: event type EV_KEY(0x01) key_up: KEY_NUMERIC_3(0x0203)
1510680713.707404: event type EV_SYN(0x00).
1510680717.033630: event type EV_MSC(0x04): scancode = 0x800f0406
1510680717.033630: event type EV_KEY(0x01) key_down: KEY_NUMERIC_6(0x0206)
1510680717.033630: event type EV_SYN(0x00).
1510680717.200761: event type EV_KEY(0x01) key_up: KEY_NUMERIC_6(0x0206)
1510680717.200761: event type EV_SYN(0x00).
1510680717.271547: event type EV_MSC(0x04): scancode = 0x800f0406
1510680717.271547: event type EV_KEY(0x01) key_down: KEY_NUMERIC_6(0x0206)
1510680717.271547: event type EV_SYN(0x00).
1510680717.440758: event type EV_KEY(0x01) key_up: KEY_NUMERIC_6(0x0206)
1510680717.440758: event type EV_SYN(0x00).
1510680719.733105: event type EV_MSC(0x04): scancode = 0x800f041d
1510680719.733105: event type EV_KEY(0x01) key_down: KEY_NUMERIC_STAR(0x020a)
1510680719.733105: event type EV_SYN(0x00).
1510680719.900755: event type EV_KEY(0x01) key_up: KEY_NUMERIC_STAR(0x020a)
1510680719.900755: event type EV_SYN(0x00).
1510680722.724643: event type EV_MSC(0x04): scancode = 0x800f040d
1510680722.724643: event type EV_KEY(0x01) key_down: KEY_MEDIA(0x00e2)
1510680722.724643: event type EV_SYN(0x00).
1510680722.893881: event type EV_KEY(0x01) key_up: KEY_MEDIA(0x00e2)
1510680722.893881: event type EV_SYN(0x00).
1510680722.962228: event type EV_MSC(0x04): scancode = 0x800f040d
1510680722.962228: event type EV_KEY(0x01) key_down: KEY_MEDIA(0x00e2)
1510680722.962228: event type EV_SYN(0x00).
1510680723.130755: event type EV_KEY(0x01) key_up: KEY_MEDIA(0x00e2)
1510680723.130755: event type EV_SYN(0x00).
(2017-11-14, 15:20)xxxnelly Wrote: [ -> ]Hi Milhouse,
Have you tried updating to the latest tvheadend42 addon? I don't know what version of the addon you are using. See here: http://milhouse.libreelec.tv/builds/addo...headend42/
If you can determine the first build from these test builds that exhibits this behaviour then that might shed more light on the issue.
Other than that I can only suggest continuing the discussion in your own thread, or on the LibreELEC forum.
Is there a command/setting that allows to change keyboard repeat rate in Kodi? I have tried xset and kbdrate but those are not available, and would they even work?  I'm using Flirc that simulates usb keyboard with ir-remote commands and repeat rate is a little too fast.
@pacoma2610 thanks a lot for the tests!
There's an interesting pattern, after the long-pressed "5" and after each short press another signals seems to be received ~236ms after the last one (which gets interpreted as a separate button press in 4.14 since the timeout changed from 250 to 164ms).
Would be interesting to know if this is coming from the kernel, from the IR receiver or from the remote.
Could you please repeat the ir-keytable -t test on the working build and post the output? A single short buttonpress and a longer one should be enough.
And please do another test with on working and the non working builds: run "mode2", do a short button press and post the output.
so long,
Hias
(2017-11-14, 21:49)TimoJ Wrote: [ -> ]Is there a command/setting that allows to change keyboard repeat rate in Kodi? I have tried xset and kbdrate but those are not available, and would they even work?  I'm using Flirc that simulates usb keyboard with ir-remote commands and repeat rate is a little too fast.
Create a file /storage/.config/udev.rules.d/70-input-repeat.rules with the following content:
ACTION=="add", SUBSYSTEM=="input", KERNEL=="event[0-9]*", GOTO="start"
GOTO="end"
LABEL="start"
# don't change eventlircd device settings
ATTRS{name}=="eventlircd", GOTO="end"
# increase repeat delay to 750ms, use 200ms repeat period
RUN+="/usr/bin/ir-keytable --delay=750 --period=200 --device=$devnode"
LABEL="end"
Change the delay and period parameters of ir-keytable to your likings. Note that this will affect all input devices of your system.
so long,
Hias
New LibreELEC.tv Leia build #1114: Generic
(Supercedes previous build)
SHA256 Checksum: 9bef46b0fd818ff4f6517b06a54ea75592262ce8a1a6996c25a103d5c17787b3 (Generic)
# uname -a
Linux NUC 4.14.0 #1 SMP Tue Nov 14 21:11:07 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20171114210940-#1114-gc7da506 [Build #1114]
# Kodi version
(18.0-ALPHA1 Git:052e881). Platform: Linux x86 64-bit
Based on tip of LibreELEC.tv master (c7da506, changelog) and tip of XBMC master (052e881, changelog) with the following modifications: Build Highlights:
  1. Bump jsoncpp 1.8.3
  2. Fix channel icons with pvr.vuplus
Build Details:
  1. LibreELEC.tv:
    • linux: update to linux-4.14.0 (PR:1991, 32 commits, 11 files changed)
    • dvb-fe-tool: fixed compile error issue (PR:2214, 1 commit, 1 file changed)
    • linux: automatically add CONFIG_INITRAMFS_ROOT_{U,G}ID=0 (PR:2211, 1 commit, 9 files changed)
    • Net-snmp addon : Avoid loading config two time (PR:2215, 1 commit, 2 files changed)
  2. XBMC:
    • VideoPlayer: add DRM PRIME video codec and renderer (PR:13044, 8 commits, 14 files changed)
    • [windows] Fix crash on win32 introduced by #13024 (PR:13048, 2 commits, 4 files changed)
  3. pvr.mediaportal.tvserver:
    • [win10] fix build for uwp (PR:78, 1 commit, 6 files changed)
  4. pvr.mythtv:
    • [win10] fix linkage with uwp CRT (PR:89, 1 commit, 1 file changed)
    • bump version 5.4.4 (ffaa1b5)
  5. pvr.pctv:
    • [depends] bump jsoncpp to 1.8.3 (PR:54, 1 commit, 4 files changed)
  6. pvr.stalker:
    • [depends] bump jsoncpp to 1.8.3 (PR:102, 1 commit, 4 files changed)
  7. pvr.vuplus:
    • [fix] wrong string replace syntax introduced at f445200 (PR:77, 1 commit, 3 files changed)
  8. Additional commits/pull requests/changes not yet merged upstream:
    • Updated: [env] PR:2138 (perma): removed OE mirror links
    • Added: [env] compare (perma): linux: update to linux-4.14.1-preliminary
    • Added: [env] PR:2218 (perma): heimdal: Disable OTP
    • Added: [pkg] PR:17 (perma): [depends] bump jsoncpp to 1.8.3 (pvr.octonet)
    • Added: [pkg] PR:70 (perma): [depends] bump jsoncpp to 1.8.3 (pvr.hdhomerun)
    • Added: [pkg] PR:74 (perma): [depends] bump jsoncpp to 1.8.3 (pvr.argustv)
    • Added: [pkg] PR:79 (perma): [depends] bump jsoncpp to 1.8.3 (pvr.filmon)
(2017-11-14, 23:13)HiassofT Wrote: [ -> ]
GOTO="end"
LABEL="start"
LABEL="end"
so long,
Hias
Why do I have, after it has worked for years incl up to build # 1111 without error, an additional file (which has no effect for me) create.
I think that's what changed from Build # 1112 and higher and should eliminate this again.
If i go Back to Build #1111 everything works fine
(2017-11-15, 02:36)pacoma2610 Wrote: [ -> ]Why do I have, after it has worked for years incl up to build # 1111 without error, an additional file (which has no effect for me) create.
@pacoma2610 you seem to have misinterpreted @HiassofTs reply to @TimoJ as a reply to yourself. That reply has nothing to do with your issue.
As for why you are experiencing a problem with the 4.14 kernel, I provided the link to the change in one of my previous posts (post 1952 in case you missed it). I can only assume right now that the kernel developers didn't test with your particular brand of remote control, or your remote control is "out of spec". Since this is a fairly new issue and one which may or may not be widespread we need to take some time to consider the best solution. Please continue to work with @HiassofT.
Hi all, please forgive me if this is the wrong place for this or if it has already been dealt with elsewhere.  I am very new to this and just trying to figure things out (I'm a biologist, not a computer guy).  I have two issues.  A little background first.  I want to use my QNAP NAS as the backend to run tvheadend and use kodi as the frontend and run tvheadend as an add-on in order to use my NAS as a DVR.  I have HDHomerun working and setup with Tvheadend.  I can watch live tv through the HDhomerun app (on my comp, phone, ipad).  I can also watch live tv through kodi.  I was previously able to go into tvheadend through the web on my NAS, and record, and then watch a show (I did this one time with one of the world series games) on my computer.  Problems: I can't figure out how to set up something to record going from Kodi.  When I have pushed record nothing worked.  And now, recently, when I tried to go back into the tvheadend app on the NAS from the web using my computer, it won't let access. It says 'authentication required' http://192.168.1.130:9981 your connection to this site is not private.  Username_________ Password ____________.  I have tried my normal passwords.  xbmc/xbmc.  So, I am hoping you can help me get back in to the app, and to get it setup to record from Kodi.  Thanks, Brian
@ellis22b please start a new thread in the tvheadend sub-forum: https://forum.kodi.tv/forumdisplay.php?fid=168
ok, thanks
(2017-11-14, 21:47)Milhouse Wrote: [ -> ]
Hi Milhouse,
I am using a shared tvheadend server for all my 3 Kodi clients, this is in the loft and so I don't use addon - so its defo not that.
After alot of trial and error I found the breaking build - its build #0124, the last working one is #0117. I assume it will be the kernel update then or what more info would confirm the issue?
#0124, 24-Jan-2017: Generic -- Release post (New 4.9.5 kernel; libcec, libnfs, kodi updates; updated media_build package)
#0117, 18-Jan-2017: Generic -- Release post (Bump e2fsprogs and populatefs; default to CONFIG_TCP_CONG_BBR; disable ADSP support)
@pacoma2610 I think I figured out what's going on / wrong.
Could you run the following command and report back if this fixes the "bouncing button" issue?
ir-ctl -t 100000
so long,
Hias
