(2017-11-26, 17:10)Milhouse Wrote: [ -> ] (2017-11-26, 06:50)Qwijibo Wrote: [ -> ]Hi Milhouse,
My wireless USB keyboard is not allowing entry into input boxes. I've only just switched over to x86 and gone back a few builds to test but this problem seems to persist. Not an issue in 17.x.
All other keys work.
Will adding permissions to TTY solve this?
(2017-11-26, 15:26)Gismo112 Wrote: [ -> ]I can confirm the Problem with the Keyboard. This Problem i have also at Windows Kodi x64 after version KodiSetup-20171123-cc10efe-master-x64.exe (last working for me).
Yes, the issue with physical keyboard entry in dialogs is reproducible on Raspberry Pi builds also (since #1124). The most likely candidate is:
(2017-11-25, 00:49)Milhouse Wrote: [ -> ] - XBMC:
- kill g_Windowing, another nasty global (PR:13047, 6 commits, 172 files changed)
Must be a Kodi issue, Windows 64 builds have the same problem.
Hi everybody
I have low resolution when using Netflix. Do I have to customize the Netflix and/or the inputstream adaptive app? Or anything else? I only get 512x384 pixels.
Does noone else do have a wrong aspect ratio while using hdmi 2 on apollo lake boards (LSPCON 1.66)? In the menu everything looks fine, but when I start a clip, then native 16:9 movies do have a small black line (perhaps 20-30 pixels) on the bottom and on the top.
Can I find somewhere the original LSPCON Firmware which was on the board while buying? Because this didnt have this bug.
New LibreELEC.tv Leia build #1126:
Generic
(Supercedes previous build)
SHA256 Checksum:
d51558e5c6422cf9894048a2a7d97dca056a947e5581f0ec9382f212ba6ae2fd (Generic)
# uname -a
Linux NUC 4.14.2 #1 SMP Sun Nov 26 23:04:19 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20171126225234-#1126-g5d2d3a5 [Build #1126]
# Kodi version
(18.0-ALPHA1 Git:5ef3967). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (5d2d3a5,
changelog) and tip of
XBMC master (5ef3967,
- Includes latest kodi-platform master (36fb493)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (7c68a3d, ahead +106)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (d2081b2), inputstream.rtmp (c772497, +1), peripheral.joystick (33b43ce), pvr.argustv (5b9bdad), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (6129441), pvr.filmon (2dee2ca), pvr.hdhomerun (3af3e91), pvr.hts (67fe2df), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (6c35e88), pvr.mythtv (ffaa1b5), pvr.nextpvr (938bb48), pvr.njoy (4a5efef), pvr.octonet (c4af00a), pvr.pctv (6484615), pvr.stalker (44025a1), pvr.teleboy (e431126), pvr.vbox (619c32b), pvr.vdr.vnsi (0ec3e77), pvr.vuplus (7ea6b21), pvr.wmc (55e701b), pvr.zattoo (23d9993), vfs.libarchive (72bd12c, +5)
- Include [env] compare (perma): connman: timeserver: Retry NTP servers periodically on startup
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: media_build: disable due to conflicts
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2182 (perma): kodi: updates for Dec 2017
- Include [env] PR:2228 (perma): kodi: safe mode
- Include [env] PR:2242 (perma): linux: update to linux-4.14.2
- Include [env] PR:2243 (perma): NOOBS: shorten partition labels, add $DEVICE support
- Include [env] PR:2247 (perma): Refactor scripts/checkdeps, fix missing deps
- Include [env] PR:2250 (perma): scripts/get: avoid flip-flopping downloads
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:55 (perma): Fix deprecated function warnings (pvr.pctv)
- Include [pkg] PR:86 (perma): connman.py: More secure default password for tethering (service.libreelec.settings)
- Include [pkg] PR:87 (perma): add safe mode text (service.libreelec.settings)
- Include [pkg] PR:103 (perma): jsoncpp deprecated function change (pvr.stalker)
- Include [pkg] PR:13062 (perma): smbclient changes for smb minprotocol and legacysecurity
- Include [pkg] PR:13102 (perma): fix keyboard input of edit control
Build Highlights:
- Fix keyboard input
- Fix vfs.libarchive build
- drop incorrect locks of graphicsContext
Build Details:
- LibreELEC.tv:
- dispmanx_vnc: fix build problems (PR:2263, 1 commit, 4 files changed)
- vdr-addon update (PR:2262, 4 commits, 5 files changed)
- mumudvb: fix compiling (PR:2265, 1 commit, 2 files changed)
- update multimedia-tools (PR:2259, 4 commits, 6 files changed)
- XBMC:
- drop incorrect locks of graphicsContext (PR:13099, 1 commit, 7 files changed)
- wake on access - upnp support (v2) (PR:4940, 1 commit, 3 files changed)
- [JSON-RPC]Audio library Fixes (PR:13051, 1 commit, 10 files changed)
- kodi.sh: Properly quote eventually empty variables (PR:13103, 1 commit, 1 file changed)
- inputstream.rtmp:
- [depends] build zlib static (PR:30, 1 commit, 1 file changed)
- vfs.libarchive:
- [depends] libarchive & zlib optimizations (PR:7, 3 commits, 3 files changed)
Now I have 1280x720 pixels playing Netflix. Hence the name ...adaptive. Solved, I guess.
New LibreELEC.tv Leia build #1127:
Generic
SHA256 Checksum:
21ccce42eed628052a09e177b51e41b9b0cad872bea42dda903ef66734491773 (Generic)
# uname -a
Linux NUC 4.14.2 #1 SMP Mon Nov 27 21:26:30 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20171127210408-#1127-g58a261f [Build #1127]
# Kodi version
(18.0-ALPHA1 Git:f1ab257). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (58a261f,
XBMC master (f1ab257,
- Includes latest libnfs master (82b3411, ahead +109)
- Includes latest addons: inputstream.adaptive (d2081b2), inputstream.rtmp (c772497, +1), peripheral.joystick (33b43ce), pvr.argustv (5b9bdad), pvr.demo (94c4817, +1), pvr.dvblink (816f90c), pvr.dvbviewer (6129441), pvr.filmon (2dee2ca), pvr.hdhomerun (3af3e91), pvr.hts (67fe2df), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (6c35e88), pvr.mythtv (ffaa1b5), pvr.nextpvr (938bb48), pvr.njoy (4a5efef), pvr.octonet (c4af00a), pvr.pctv (6484615), pvr.stalker (44025a1), pvr.teleboy (e431126), pvr.vbox (619c32b), pvr.vdr.vnsi (0ec3e77), pvr.vuplus (7ea6b21), pvr.wmc (55e701b), pvr.zattoo (23d9993), vfs.libarchive (72bd12c, +5)
- Include [pkg] PR:77 (perma): jsoncpp1.8.3 deprecated function update (pvr.argustv)
- Include [pkg] PR:80 (perma): update jsoncpp methods to non deprecated versions (pvr.filmon)
Build Highlights:
- Refactor info scanners
Build Details:
- LibreELEC.tv:
- RTL8189FS: new driver package (PR:2253, 1 commit, 1 file changed)
- scripts/get: avoid flip-flopping downloads (PR:2250, 2 commits, 1 file changed)
- XBMC:
- fix keyboard input of edit control (PR:13102, 1 commit, 1 file changed)
- A handful of low-hanging sca warning fixes (PR:13075, 6 commits, 10 files changed)
- Refactor info scanners (PR:13089, 2 commits, 7 files changed)
- added: let the text viewer dialog hold a monospace font as well (PR:13092, 2 commits, 11 files changed)
- added: view text files in file manager (PR:13093, 1 commit, 5 files changed)
- libnfs:
- examples/ld_nfs.c improvements (PR:233, 3 commits, 2 files changed)
- pvr.demo:
- Add menu hooks demo. (PR:55, 1 commit, 4 files changed)
- Added: [pkg] PR:55 (perma): Fix deprecated function warnings (pvr.pctv)
- Added: [pkg] PR:77 (perma): jsoncpp1.8.3 deprecated function update (pvr.argustv)
- Added: [pkg] PR:80 (perma): update jsoncpp methods to non deprecated versions (pvr.filmon)
New LibreELEC.tv Leia build #1128:
Generic
SHA256 Checksum:
3eede64cb596d0a9c96743d6a2c42607099ffa3cca89c2ecc5ae0a85c2a133e6 (Generic)
# uname -a
Linux NUC 4.14.2 #1 SMP Wed Nov 29 07:14:31 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20171129070245-#1128-g4524323 [Build #1128]
# Kodi version
(18.0-ALPHA1 Git:d5f9097). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (4524323,
XBMC master (d5f9097,
- Includes latest addons: inputstream.adaptive (d2081b2), inputstream.rtmp (c772497, +1), peripheral.joystick (33b43ce), pvr.argustv (5b9bdad), pvr.demo (94c4817, +1), pvr.dvblink (816f90c), pvr.dvbviewer (6129441), pvr.filmon (2dee2ca), pvr.hdhomerun (3af3e91), pvr.hts (67fe2df), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (6c35e88), pvr.mythtv (ffaa1b5), pvr.nextpvr (938bb48), pvr.njoy (4a5efef), pvr.octonet (c4af00a), pvr.pctv (6484615), pvr.stalker (44025a1), pvr.teleboy (e431126), pvr.vbox (619c32b), pvr.vdr.vnsi (0ec3e77), pvr.vuplus (7ea6b21), pvr.wmc (55e701b), pvr.zattoo (23d9993), vfs.libarchive (6e9da5c, +7)
Build Highlights:
- [videoplayer] Show stream flags in the gui and some fixes/improvements.
- [PVR] Cleanup: No more GUI stuff in class CPVRTimerInfoTag
- ffmpeg hevc patch cleanup
Build Details:
- LibreELEC.tv:
- [Net-snmp] add openssl build dependency (PR:2271, 1 commit, 1 file changed)
- Fix image creation for WeTek Devices (PR:2269, 1 commit, 7 files changed)
- eventlircd: add support for OSMC 2nd generation remote (PR:2272, 1 commit, 2 files changed)
- XBMC:
- [videoplayer] Show stream flags in the gui and some fixes/improvements. (PR:13058, 10 commits, 34 files changed)
- [PVR] Cleanup: No more GUI stuff in class CPVRTimerInfoTag (PR:13098, 2 commits, 9 files changed)
- vfs.libarchive:
- [depends] lz4 & lzo2 disable building executables (PR:8, 2 commits, 2 files changed)
Milhouse, visualisation waveform isn't working with the latest build, no error message though.
Does it need, and if so can you rebuild it please?
New LibreELEC.tv Leia build #1129:
Generic
SHA256 Checksum:
a2bb7c3ffa8c0e1858fe987d20de0b521a74d1152686a2fb8686acb4d87f82c5 (Generic)
# uname -a
Linux NUC 4.14.2 #1 SMP Wed Nov 29 22:30:08 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20171129221453-#1129-g4524323 [Build #1129]
# Kodi version
(18.0-ALPHA1 Git:68f4f43). Platform: Linux x86 64-bit
Based on tip of
XBMC master (68f4f43,
- Includes latest addons: inputstream.adaptive (d2081b2), inputstream.rtmp (c772497, +1), peripheral.joystick (33b43ce), pvr.argustv (1a48789, +2), pvr.demo (94c4817, +1), pvr.dvblink (816f90c), pvr.dvbviewer (6129441), pvr.filmon (2dee2ca), pvr.hdhomerun (3af3e91), pvr.hts (67fe2df), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (6c35e88), pvr.mythtv (ffaa1b5), pvr.nextpvr (938bb48), pvr.njoy (4a5efef), pvr.octonet (c4af00a), pvr.pctv (6484615), pvr.stalker (44025a1), pvr.teleboy (e431126), pvr.vbox (619c32b), pvr.vdr.vnsi (0ec3e77), pvr.vuplus (7ea6b21), pvr.wmc (55e701b), pvr.zattoo (23d9993)
Build Highlights:
- Drop vfs.libarchive while testing some build issues
- pvr.argustv with authenticated smb support
Build Details:
- XBMC:
- remove accidential left-over prototype (PR:13108, 1 commit, 1 file changed)
- [MediaManager/gui] Cache disc label (PR:13107, 2 commits, 2 files changed)
- VideoPlayer: drop some outdated and unsafe(threading) code (PR:13110, 1 commit, 9 files changed)
- pvr.argustv:
- add account info for smb shares (PR:76, 1 commit, 7 files changed)
- jsoncpp1.8.3 deprecated function update (PR:77, 1 commit, 4 files changed)
- Updated: [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Updated: [env] PR:2182 (perma): kodi: updates for Dec 2017
(2017-11-30, 00:24)rudrood Wrote: [ -> ]@Milhouse, visualisation waveform isn't working with the latest build, no error message though.
New version uploaded, no idea if it works.
Not a direct LE question. But since you can run LE without lirc and get all the buttons to work using my RC6. On my ubuntu box this doesn't work. Is it some mapping file or something that I need to pull from one of my LE boxes to make it work the same in ubuntu? Using ir-keytable instead of lirc that is total bonkers on my machine.
(2017-11-30, 09:43)laric Wrote: [ -> ]Not a direct LE question. But since you can run LE without lirc and get all the buttons to work using my RC6. On my ubuntu box this doesn't work. Is it some mapping file or something that I need to pull from one of my LE boxes to make it work the same in ubuntu? Using ir-keytable instead of lirc that is total bonkers on my machine.
You have to run inputlirc or lirc in devinput mode to translate the linux input events into lirc events. Both xorg and Kodi can't quite cope with all the input keycodes generated by remotes (eg KEY_OK, KEY_CHANNELUP).
so long,
Hias
(2017-11-30, 03:19)Milhouse Wrote: [ -> ] (2017-11-30, 00:24)rudrood Wrote: [ -> ]@Milhouse, visualisation waveform isn't working with the latest build, no error message though.
Not working on Kodi builds (OSX) too since many builds.
Thanks very much. FYI can't make it work either. Will stay on spectrum for now.
