Wow I just tried 1004 and it looks perfect with everything enabled in render options...
What changed to cause that problem to be reintroduced?
(2017-12-23, 03:50)wheemer Wrote: [ -> ]Wow I just tried 1004 and it looks perfect with everything enabled in render options...
I scrolled back 5 pages now - I cannot find a single
Debug Log of yours. Therefore nothing can be said.
Hi fritsch,
Could you have a look on this ... & let me know some advice ?
THX in advance
JP
I'm using 1219 LE nightly build on Sony 4K TV
(in the past Amlogic with LE8 was working well with 4K Resolution on this TV & with the same cable)
Now with LE9 , only HD resolutions are listed in LE
I tried to manually define with
xrandr --newmode $(gtf 3840 2160 30 | sed -ne 's/"//g;s/ Modeline //p')
xrandr --addmode HDMI1 3840x2160_30.00
because this data sheet define the max resolution
https://www.solid-run.com/intel-braswell...fications/
I'm using exactly this Braswell HW
With these commands, the resolution list contain the 4K but after the selection , the screen still black ...
Did you have something to advice ?
(2017-12-23, 11:48)jpeg73 Wrote: [ -> ]Hi fritsch,
THX in advance
JP
because this data sheet define the max resolution https://www.solid-run.com/intel-braswell...fications/
Are You sure that 30Hz is the correct number?
(2017-12-23, 13:46)jpeg73 Wrote: [ -> ] (2017-12-23, 12:31)nicram Wrote: [ -> ] (2017-12-23, 11:48)jpeg73 Wrote: [ -> ]Hi fritsch,
Are You sure that 30Hz is the correct number?According to the SolidRun D.S., yes
grander --prop return this
VIC 93 3840x2160@24Hz 16:9 HorFreq: 54000 Hz Clock: 297.000 MHz
VIC 94 3840x2160@25Hz 16:9 HorFreq: 56250 Hz Clock: 297.000 MHz
VIC 95 3840x2160@30Hz 16:9 HorFreq: 67500 Hz Clock: 297.000 MHz
New LibreELEC.tv Leia build #1222:
Generic
(Supercedes previous build)
SHA256 Checksum:
6dc96cef4d1f34e68fd2c4cf161cc7bddeb0101ed9c3a2cec6c949dc1aaa2f87 (Generic)
# uname -a
Linux NUC 4.14.7 #1 SMP Fri Dec 22 21:05:23 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20171222210348-#1222-gc6298e2 [Build #1222]
# Kodi version
(18.0-ALPHA1 Git:7b1ff23). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (c6298e2,
changelog) and tip of
XBMC master (fb8cfe1,
- Includes latest kodi-platform master (36fb493)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (82b3411, ahead +109)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (fcf6695, +1), inputstream.rtmp (c772497), peripheral.joystick (33b43ce), pvr.argustv (1aa4ddc), pvr.demo (744d8ef), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (17e8193), pvr.hdhomerun (8b931e8), pvr.hts (2f39155), pvr.iptvsimple (cbd4f5a, +2), pvr.mediaportal.tvserver (8f11874), pvr.mythtv (8f214cd), pvr.nextpvr (11dfdbb), pvr.njoy (f7a9913), pvr.octonet (c4af00a), pvr.pctv (7b1c634), pvr.stalker (fad6ed4), pvr.teleboy (e431126), pvr.vbox (1ed3fd2), pvr.vdr.vnsi (0ec3e77), pvr.vuplus (b090f73), pvr.wmc (920ade6), pvr.zattoo (742fcf1, +2), vfs.libarchive (568a2a1)
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: fix PR390
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2243 (perma): NOOBS: shorten partition labels, add $DEVICE support
- Include [env] PR:2298 (perma): Kodi updates for Jan 2018
- Include [env] PR:2317 (perma): linux: update to linux-4.14.8
- Include [env] PR:2323 (perma): buildsystem: source functions earlier, validate project/arch earlier, refactor show_config
- Include [env] PR:2329 (perma): passthrough: drop kernel patch, force full
- Include [env] PR:2331 (perma): systemd: update to 236
- Include [env] PR:2345 (perma): zstd: update to zstd-1.3.3
- Include [env] PR:2348 (perma): Cleanup path for SOURCES and allow SOURCES and TARGET to be defined
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:55 (perma): Fix deprecated function warnings (pvr.pctv)
- Include [pkg] PR:80 (perma): update jsoncpp methods to non deprecated versions (pvr.filmon)
- Include [pkg] PR:103 (perma): jsoncpp deprecated function change (pvr.stalker)
- Include [pkg] PR:13034 (perma): Cmake cpp14
- Include [pkg] PR:13062 (perma): smbclient changes for smb minprotocol and legacysecurity
Build Highlights:
- [pvr] no delay on switch to previous channel with key 0
Build Details:
- LibreELEC.tv:
- projects/S905: fix project specific u-boot (PR:2351, 1 commit, 1 file changed)
- XBMC:
- [cleanup] silence compiler warnings (PR:13221, 2 commits, 2 files changed)
- fix: powermanagement & linux storageprovider build without dbus (PR:13229, 1 commit, 2 files changed)
- [weather][refactor] kill g_weatherManager global (PR:13227, 6 commits, 20 files changed)
- [pvr] no delay on switch to previous channel with key 0 (PR:13232, 1 commit, 3 files changed)
- [android] switch to clang & libc++ (PR:12634, 3 commits, 8 files changed)
- pvr.iptvsimple:
- Fix multithreading issues (PR:169, 2 commits, 4 files changed)
- pvr.zattoo:
- Mime-Type / gzipped EPG download (3d7d559)
- Update changelog and version (742fcf1)
(2017-12-23, 13:48)jpeg73 Wrote: [ -> ] (2017-12-23, 13:46)jpeg73 Wrote: [ -> ] (2017-12-23, 12:31)nicram Wrote: [ -> ]Are You sure that 30Hz is the correct number?According to the SolidRun D.S., yes
As it's HDMI 1.4b that should work. Get me: dmesg | pastebinit after having booted with drm.debug=0xe also DISPLAY=:0 xrandr --verbose | pastebinit and a nice kodi log - thx.
(2017-12-23, 10:09)fritsch Wrote: [ -> ] (2017-12-23, 03:50)wheemer Wrote: [ -> ]Wow I just tried 1004 and it looks perfect with everything enabled in render options...
I scrolled back 5 pages now - I cannot find a single Debug Log of yours. Therefore nothing can be said.
I think the changelog may be a better place to start looking...
What kind of an attitude is that anyways? Obviously I am not the only one experiencing this problem...
(2017-12-23, 18:32)wheemer Wrote: [ -> ] (2017-12-23, 10:09)fritsch Wrote: [ -> ] (2017-12-23, 03:50)wheemer Wrote: [ -> ]Wow I just tried 1004 and it looks perfect with everything enabled in render options...
Attitude? You realize that you are in a testing thread, helping to test daily builds of bleeding edge mixture?
On topic: your ACPI errors are gone (loglevel, btw. not our fault your have broken dsdt tables); your hw acceleration returned after rebooting. Both logs you showed use of VDPAU (which your AMD uses) just fine.
HEVC-8 bit will work with VDPAU. HEVC-10 bit won't as vdpau does not support it.
Of course I know where I am and what I am testing. You were the one with the blinders on ignoring a problem report for lack of logs that you could have just asked for.
The ACPI errors and hw acceleration I had previously posted about were another machine (my uncle's). Not the one from these logs.
The mention of those video formats have not shed any light on my problem.
Both logs are playing the same file same hardware. Newest doesn't work with horizontal tearing. October 4th one looks perfect.
Hello everyone and Merry Christmas!
I have this version of LE on a nano PC and for the adds I need to install it shows the message "os.libreelec.tv unavailable".
How do I fix this?
