fritsch do you know if the LSPCON stuff has been implemented in the drm-intel mainstream? or is it still experimantal?
No idea. Did not check that stuff lately.
Ok. Just preparing for new Kaby Lake NUCs starting february. And I know, new hardware new problems. Seems like much of the Apollo Lake stuff easily applies to the Kaby Lake platform also.
Thanks for reply
(2017-01-02, 19:03)ptr727 Wrote: [ -> ] (2017-01-02, 03:06)Milhouse Wrote: [ -> ] (2016-12-31, 21:29)ptr727 Wrote: [ -> ]This one sounds promising:
https://bugs.freedesktop.org/show_bug.cgi?id=97330
I'd love for an "Intel Expert" to chime in here on what next steps to take?
I've included the patch referenced in that bug in build #0101 - can you give it a try and see if it has any effect (positive or negative)?
Thank you, but no change, some 24p movies are still black screen on play, stop, play, stop, play, and they eventually play.
How do you suggest I proceed to get attention of Intel/Kodi/LE devs to make some progress with this issue?
Funny .....i had this frustrating problem (bad WAF) for several months , with kernel 4.7(or 4.8...Don't Remember) the problem occurs rarely
Try also to set a delay of 1 sec in Pause during refresh rate change (not related but i tried all
Edit: do You have an avr in your chain ?
(2017-01-02, 22:06)Roby77 Wrote: [ -> ] (2017-01-02, 19:03)ptr727 Wrote: [ -> ] (2017-01-02, 03:06)Milhouse Wrote: [ -> ]I've included the patch referenced in that bug in build #0101 - can you give it a try and see if it has any effect (positive or negative)?
Try also to set a delay of 1 sec in Pause during refresh rate change (not related but i tried all )
Yes on AVR, Marantz NR1603, delay makes it happen less frequently, but not always, and sometimes I get black on movie stop, requiring a reboot.
Teo i Just checked i set 0.5 delay
Reported this problem also on bug.freedesktop many months ago
And i also mapped reboot Key to IR remote Button
Lucky this problem now happens rarely (on my beebox 3150)
Also tried hardware solution like dr HDMI but no luck
(2017-01-02, 19:15)fritsch Wrote: [ -> ]As it has absolutely nothing to do with Kodi - leave them out of the chain. For intel, post another bugreport at bugs.freedesktop.org or try a piotrasd build they use experimental drm-intel kernel.
I found @
piotrasd builds in the referenced in the
Apollo Lake thread
I could not find a LibreELEC-Intel.x86_64 install image, so I had to use .nocompat to overinstall LibreELEC-Generic.x86_64.
Using LibreELEC-Intel.x86_64-8.0-devel-20161231213138-r25071-g99dd0d2, refresh rate switching does not work.
Either the build does not work well with my Gen 4 NUC, or the settings are messed up because I started from generic and went to Intel.
Where can I find LibreELEC-Intel.x86_64 install disk images?
Is there is a better place to find @
piotrasd builds than the Apollo Lake thread?
New LibreELEC.tv Krypton build #0102:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.9.0 #1 SMP Mon Jan 2 21:07:59 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170102210640-#0102-g56f05ab [Build #0102]
# Kodi version
(18.0-ALPHA1 Git:5c40b5c). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (56f05ab4,
changelog) and tip of
XBMC master (2fb0a619,
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (ab18a95b, ahead +3)
- Includes latest libnfs master (43cde9da, ahead +32)
- Includes latest p8-platform master (2d90f986, ahead +9)
- Includes latest addons: inputstream.adaptive (fc862638), inputstream.rtmp (55437ac7), peripheral.joystick (987a818e), pvr.argustv (4702a9e7, +4), pvr.demo (99db6bf5, +3), pvr.dvblink (4e6992d9, +4), pvr.dvbviewer (2b8ab246, +12), pvr.filmon (a23db0c5, +4), pvr.hdhomerun (baeafbde, +3), pvr.hts (117d4020, +5), pvr.iptvsimple (df0649e7, +6), pvr.mediaportal.tvserver (f00ccfd3, +18), pvr.mythtv (41c3201f), pvr.nextpvr (48a7796a, +4), pvr.njoy (d1ad569b, +3), pvr.octonet (8549a31c), pvr.pctv (b8286a23, +4), pvr.stalker (dfda4c51, +4), pvr.vbox (bfa938c7, +10), pvr.vdr.vnsi (7033621d), pvr.vuplus (acd75dc5, +3), pvr.wmc (35be514e, +3)
- Include [env] dba5e31d: TexturePacker: Hack to work around CMAKE_SOURCE_DIR
- Include [env] 30207d1d: kodi: disable bluetooth
- Include [env] 40644b02: kodi: fix cmake after move to root
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: kodi: fix intel gpu detection patch after kodi/10848
- Include [env] patch: iwlwifi-firmware: update to iwlwifi-firmware-ba301aa
- Include [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
- Include [env] patch: repository.retroplayer.libreelec.addons: add temp repo for testing
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] PR:1025: scripts/create_addon: use PKG_REV as part of the binary addon version
- Include [env] PR:1052: Package updates
- Include [env] PR:1067: vaapi hvec 10bit support
- Include [pkg] patch: drm/i915/dsi: Do not clear DPOUNIT_CLOCK_GATE_DISABLE from vlv_init_display_clock_gating (linux)
- Include [pkg] PR:50: Add (and display) pretty names in release order - not name order (service.libreelec.settings)
- Include [pkg] PR:11163: Fix silent failure when game add-on can't be installed
Build Highlights:
- libcec fix (not sure it will affect TV-turning-back-on and other issues, but who knows...)
- 3D OSD aspect ratio fix
- Fix update channel listing
Build Details:
- LibreELEC.tv:
- docker: add temporary cleanup method for old systemd service (PR:1115, 1 commit, 3 files changed)
- imx6: update kodi patches, second pass (PR:1119, 1 commit, 3 files changed)
- Update lirc (PR:1101, 3 commits, 12 files changed)
- XBMC:
- [PVR] PVR windows: Fix subfolder item selection on window update. (PR:11336, 1 commit, 1 file changed)
- [cmake] Fixes cpack support and WiiRemote packaging for rpi (PR:11321, 2 commits, 2 files changed)
- [VideoPlayer] WinRenderer: restore rendering transformation with DXVA… (PR:11340, 1 commit, 4 files changed)
- Fix 3D OSD Aspect Ratio (Ticket #16727) (PR:11333, 1 commit, 1 file changed)
- reADD: [amcs] Handle Rotation (PR:11342, 1 commit, 2 files changed)
- libcec:
- fixed: env.h had 'ON' instead of '1' for some values (ab18a95b)
- Added: [pkg] PR:50: Add (and display) pretty names in release order - not name order (service.libreelec.settings)
In "old" CodecInfo overlay the missed (sync) counter is about 2 - 10 with a full movie.
I never got this before and there is no visable glitch.
Testet back until 1221 but all the same.
Should i be worried about that ?
Will try to get a log.
Sorry guys, Iˋm pretty much confused.
From my understanding, Milhouseˋs Kodi 17 and Kodi 18 builds both support Apollo lake. Of course, the v18 builds are newer, but I guess in the v17 builds the Kodi part is more "mature" and contains less errors.
And it seems that Milhouse is still building new v17 builds (
http://milhouse.libreelec.tv/builds/mast...c/?C=M&O=D)
So my question is, which build should I use for my J4205 when I would like to have as less trouble as possible? Which build for the highest WAF?
I donˋt care if the HEVC-support is not top notch.
I guess then the milhouse builds for v17 are the way to go, right?
Don't make any different tested both on the Apollo lake asrock j3355m(non hdmi2.0 version) and both are fine if you grab the latest builds.
(2017-01-03, 10:25)ix400 Wrote: [ -> ]Sorry guys, Iˋm pretty much confused.
And it seems that Milhouse is still building new v17 builds (http://milhouse.libreelec.tv/builds/mast...c/?C=M&O=D)
No, I haven't built Kodi 17 since #1129 which is the final build in the Kodi 17 thread. All builds since then have been based on Kodi 18 - this isn't reflected in the LibreELEC version number as LE hasn't branched yet and LE master is still LE8.
You asked:
(2017-01-02, 14:46)ix400 Wrote: [ -> ]Is the Apollo Lake support in the Milhouse 18 builds superior to the Krypton 17 builds?
You conflated "Milhouse 18 builds" (which is OS+Kodi) with just Kodi (Krypton 17).
Kodi 17 development essentially ended over a month ago, it's now in bug-fix mode pending release. Kodi 18 continues to be developed and improved, with HEVC/10-bit support for Apollo Lake+.
The LE8 OS is also stabilising and seeing fewer changes now that it is nearing an official release, but the builds in this thread (which will one day become LE9) will see more kernel and driver improvements that will benefit Apollo Lake and other newer hardware.
So if you're looking for the most stable Kodi experience with Apollo Lake hardware then you should be looking at beta/nightly builds of Kodi 17, although the HEVC/10-bit support in these builds will be far from top notch, as it will also be completely missing. For LibreELEC with Kodi 17 there is now the official 7.90.010 (LE8 Alpha 10) and soon there will be 7.95.1 (LE8 Beta 1).
If you want the best support for your hardware, then stick with these Kodi 18/proto-LE9 builds. But there will be bugs.
Thanks for clarifying this for me!
Tried another DVD with last build but same problem
If i Press in DVD ISO i hear the background music but no video and kodi remains in library menú
LibreELEC (community) Version: devel-20170102210640-#0102-g56f05ab
LibreELEC git: 56f05ab4d65147b4a5740c143ce3c6609bfe02bf
LibreELEC:~ # cat /storage/.kodi/temp/kodi.log | pastebinit
http://sprunge.us/NJJC
LibreELEC:~ #
LibreELEC:~ #
LibreELEC:~ #
LibreELEC:~ # dmesg | pastebinit
http://sprunge.us/IOXO
LibreELEC:~ #
LibreELEC:~ #
LibreELEC:~ #
LibreELEC:~ # journalctl -a | pastebinit
http://sprunge.us/HcKZ
LibreELEC:~ #
LibreELEC:~ #
LibreELEC:~ #
LibreELEC:~ # cat /var/log/Xorg.0.log | pastebinit
http://sprunge.us/DGLb
LibreELEC:~ #
Mmh also mkv Doesn't work
Also 0101 versiob
Will try later old build or clean install
