New LibreELEC.tv Leia build #0110:
Generic
(Supercedes previous build)
SHA256 Checksum:
8a1d3efe553a210a60cdb7bd14583b12323a32d24049843d31e5651ad102a8a9
(Generic)
text:
# uname -a
Linux NUC 4.14.13 #1 SMP Wed Jan 10 21:25:55 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180110212429-#0110-g883f1ba [Build #0110]
# Kodi version
(18.0-ALPHA1 Git:138fa39). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (883f1ba,
changelog) and tip of
XBMC master (f638e40,
- Includes latest kodi-platform master (36fb493)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (4dda1f8, ahead +114)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (fb0ca21), inputstream.rtmp (482f5c1), peripheral.joystick (3a93486), pvr.argustv (a4d3ec7), pvr.demo (0224cbd, +1), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (e5e89b1, +5), pvr.iptvsimple (a768d0e), pvr.mediaportal.tvserver (dcf0512), pvr.mythtv (cab8839), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (c4af00a), pvr.pctv (c7a13d7), pvr.stalker (c91421d), pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (66050a9, +1), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (4940bcc), vfs.libarchive (568a2a1)
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: fix PR390
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2243 (perma): NOOBS: shorten partition labels, add $DEVICE support
- Include [env] PR:2378 (perma): moonlight: update to moonlight-4d94439
- Include [env] PR:2382 (perma): linux: DVB fixes
- Include [env] PR:2384 (perma): kodi: updates for Feb 2018
- Include [env] PR:2392 (perma): linux: update to linux-4.14.15 (-ish)
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:13274 (perma): Mode whitelist
Build Highlights:
- New 4.14.13 kernel with latest Intel CPU microcode (including Meltdown fixes for CPU within last 5 years)
- [RFC] Get rid of frames-(m)sec conversion
- VideoPlayer: fix audio/subtitle delay
Build Details:
- LibreELEC.tv:
- projects/Amlogic: update kernel version and kernel config (PR:2404, 2 commits, 3 files changed)
- XBMC:
- Just kidding, remove controller models (PR:13316, 3 commits, 26 files changed)
- release application player if new type does not match old one (PR:13337, 1 commit, 1 file changed)
- [RFC] Get rid of frames-(m)sec conversion (PR:13288, 6 commits, 18 files changed)
- Allow video scrapers/NFO files/library import to add any artwork type (PR:12612, 1 commit, 2 files changed)
- changed: improve iterate variable names and a switch to for each (PR:13342, 1 commit, 1 file changed)
- [cmake] move ifdef conditions to cmake (PR:13336, 4 commits, 34 files changed)
- fixed: use visible, not hidden (PR:13343, 1 commit, 1 file changed)
- VideoPlayer: fix audio/subtitle delay (PR:13345, 1 commit, 1 file changed)
- libnfs:
- nfsv4: add support for utime() (4dda1f8)
- Updated: [env] PR:2392 (perma): linux: update to linux-4.14.15 (-ish)
If you experience a boot issue with 4.14.13, try
disabling KPTI first (even if only to confirm KPTI is the cause of the boot issue).
New LibreELEC.tv Leia build #0111:
Generic
SHA256 Checksum:
b8e07c8b5efa6786d6196fbb2a17d202284dd93120aff008bbc052aefcbe5549
(Generic)
text:
# uname -a
Linux NUC 4.14.13 #1 SMP Thu Jan 11 22:05:20 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180111220352-#0111-g883f1ba [Build #0111]
# Kodi version
Based on tip of
XBMC master (4e01f3d,
- Includes latest addons: inputstream.adaptive (fb0ca21), inputstream.rtmp (482f5c1), peripheral.joystick (3a93486), pvr.argustv (a4d3ec7), pvr.demo (0224cbd, +1), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (e5e89b1, +5), pvr.iptvsimple (a768d0e), pvr.mediaportal.tvserver (dcf0512), pvr.mythtv (cab8839), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (c4af00a), pvr.pctv (c7a13d7), pvr.stalker (c91421d), pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (4db947c, +2), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (4940bcc), vfs.libarchive (568a2a1)
- Include [env] PR:2409 (perma): samba: use documented browseable/writeable properties not synonyms
Build Highlights:
- [fix] boolean condition window.is does not work properly
- RendererDRMPRIME: add atomic support
Build Details:
- XBMC:
- [fix] boolean condition window.is does not work properly (PR:13346, 1 commit, 1 file changed)
- [droid] switch to jni for json and bitmaps (PR:13331, 4 commits, 15 files changed)
- [depends] bump python27 to 2.7.14 (PR:13328, 4 commits, 13 files changed)
- Update RetroPlayer's Render Manager documentation (PR:13341, 2 commits, 3 files changed)
- RendererDRMPRIME: add atomic support (PR:13192, 4 commits, 11 files changed)
- [xbmc][win32] First step in supporting VS2017 (PR:13279, 1 commit, 25 files changed)
- pvr.vdr.vnsi:
- fix osd for legacy OpenGL (4db947c)
- Added: [env] PR:2409 (perma): samba: use documented browseable/writeable properties not synonyms
(2018-01-09, 19:53)Roi Danton Wrote: [ -> ]Thank you for your answer. It is an Intel Celeron N3050. And yes, one of the goals installing this build was to see if Meltdown is taking any or too much performance from the system.
I do/did not have SSH on the not fully booted system, no.
So I just performed what you suggested. (Did not know until then that there is a live option for the LE stick. ;-) )
Works again, on 0106, downloading 0107 now and won't upgrade until there is kernel 4.14.13 in the build.
Any improvement with 4.14.13?
(2018-01-12, 20:13)kowalmisiek Wrote: [ -> ]Would it be possible to add to the menu kodi (o) an option to show channel and transponder data?
The Feature Requests sub-forum is
here - start a thread and maybe one of the PVR developers will show some interest.
Anyone having issues with YouTube maxing out at 720p resolution? 1080p is not available for some reason. This is with build #0111. Not entirely sure if it is the build or the addon, I did not have these issues with an earlier build. I am using MPEG DASH and Inputstream.Adaptive. Settings there were set to max resolution. If choosing a resolution manually, only 720p appears in the list.
Seems to be issues with the YouTube addon at the moment:
https://github.com/jdf76/plugin.video.yo...issues/230
New LibreELEC.tv Leia build #0112:
Generic
SHA256 Checksum:
302c6f2e5f4f535f9db081fef3f4e42cc146f9f762c330ad570159728050606c
(Generic)
text:
# uname -a
Linux NUC 4.14.13 #1 SMP Fri Jan 12 21:04:32 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180112210307-#0112-gc76dba0 [Build #0112]
# Kodi version
Based on tip of
LibreELEC.tv master (c76dba0,
XBMC master (863266b,
- Includes latest addons: inputstream.adaptive (fb0ca21), inputstream.rtmp (482f5c1), peripheral.joystick (3a93486), pvr.argustv (a4d3ec7), pvr.demo (0224cbd, +1), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (e5e89b1, +5), pvr.iptvsimple (a768d0e), pvr.mediaportal.tvserver (dcf0512), pvr.mythtv (3200b09, +1), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (c4af00a), pvr.pctv (c7a13d7), pvr.stalker (c91421d), pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (4db947c, +2), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (4940bcc), vfs.libarchive (568a2a1)
- Include [env] PR:2410 (perma): mesa/xf86-video-intel: bump to 17.3.2/028c946
Build Highlights:
- Application: Set volume after opening file
- [gui] refactor window is topmost methods and add new boolean conditions
- [xbmc][improvement] Add a platform abstraction for temp files / directories
- mesa/xf86-video-intel: bump to 17.3.2/028c946
Build Details:
- LibreELEC.tv:
- samba: use documented browseable/writeable properties not synonyms (PR:2409, 2 commits, 2 files changed)
- XBMC:
- [gui] refactor window is topmost methods and add new boolean conditions (PR:13348, 7 commits, 11 files changed)
- [xbmc][improvement] Add a platform abstraction for temp files / directories (PR:13253, 1 commit, 9 files changed)
- pvr.mythtv:
- fill major and minor number for channel in group (3200b09)
- Added: [env] PR:2410 (perma): mesa/xf86-video-intel: bump to 17.3.2/028c946
Milhouse : Do you have had time to ask your friend regarding my dmesg?
dmesg Post
I´ve tried several thinks and don´t find the solution. It seems to be the latest plugin version. No updates are found and i think the plugin is working.... maybe some one have a idea what i can investigate in my next steps?!
Thank you for your support
...i hope it´s not an error from the man who´s directly 1m far away from the screen :-O
What's with the new logo?
New LibreELEC.tv Leia build #0113:
Generic
SHA256 Checksum:
737c98e2ed2f29986966031a3b8dfd29a41286e842dd632bb86958531a96a301
(Generic)
text:
# uname -a
Linux NUC 4.14.13 #1 SMP Sat Jan 13 21:30:21 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180113212854-#0113-gc9da0d3 [Build #0113]
# Kodi version
Based on tip of
LibreELEC.tv master (c9da0d3,
XBMC master (9d12303,
- Include [env] PR:2413 (perma): xorg-server: update to xorg-server-1.19.6
Build Highlights:
- [gui] include now supports nested element processing
- iwlwifi-firmware: update to iwlwifi-firmware-b594d28
- xorg-server: update to xorg-server-1.19.6
Build Details:
- LibreELEC.tv:
- mesa/xf86-video-intel: bump to 17.3.2/028c946 (PR:2410, 2 commits, 2 files changed)
- XBMC:
- VideoPlayer: fix order of outbound events (PR:13351, 2 commits, 3 files changed)
- settings: drop warning log, reduce log spam (PR:13349, 1 commit, 1 file changed)
- WSGI changes (PR:13269, 2 commits, 1 file changed)
- [gui] include now supports nested element processing (PR:11850, 1 commit, 2 files changed)
- Fix crash due to out-of-order resource destruction (PR:13353, 1 commit, 2 files changed)
- [win10] fixes for crashes reported at store (PR:13350, 3 commits, 4 files changed)
- [fix] coverity issues (PR:13355, 4 commits, 3 files changed)
- Added: [env] PR:2413 (perma): xorg-server: update to xorg-server-1.19.6
I updated from Build 1201 to current build but every time i try to play a file (network or local ssd) i got a system freeze on my Beebox. I tried with my Chromebox with same build and it plays the file just fine. Any idea? I will try a fresh install on the Beebox.
(2018-01-14, 12:37)john.cord Wrote: [ -> ]I updated from Build 1201 to current build but every time i try to play a file (network or local ssd) i got a system freeze on my Beebox. I tried with my Chromebox with same build and it plays the file just fine. Any idea? I will try a fresh install on the Beebox.
Anything in the kodi log? Knowing when this issue started (ie. the first non-working build between #1202 and latest) would help.
Could be Meltdown related - with the latest build try adding
nopti
to the kernel command line (see
here) and confirm if that is better/worse/no different.
New LibreELEC.tv Leia build #0114:
Generic
SHA256 Checksum:
6db6b914f35221f77a27e12920b0117e50ad26e967a0bb069315f88fb7b47003
(Generic)
text:
# uname -a
Linux NUC 4.14.13 #1 SMP Sun Jan 14 21:05:31 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180114210355-#0114-gcd45cd6 [Build #0114]
# Kodi version
Based on tip of
LibreELEC.tv master (cd45cd6,
XBMC master (79b9e48,
- Includes latest libnfs master (f6e51c3, ahead +115)
- Include [pkg] PR:13360 (perma): [xbmc] Link against curl instead of using dlopen.
Build Highlights:
- Update new splash screen for v18 alpha
- X11: fix videosync on Intel
- [xbmc] Link against curl instead of using dlopen.
Build Details:
- LibreELEC.tv:
- xorg-server: update to xorg-server-1.19.6 (PR:2413, 1 commit, 1 file changed)
- moonlight: update to moonlight-4d94439 (PR:2378, 3 commits, 4 files changed)
- XBMC:
- [fix] MusicDatabase Songs set real path to avoid passing MusicDB URLs to player/demuxer (PR:13357, 1 commit, 1 file changed)
- [Estuary] fix loss of focus and navigation on the Home screen (PR:13356, 1 commit, 1 file changed)
- paplayer: fix player times for cue sheets (PR:13363, 1 commit, 2 files changed)
- X11: fix videosync on Intel (PR:13362, 1 commit, 1 file changed)
- Update new splash screen for v18 alpha (3873f14)
- libnfs:
- Define F_RDLCK for windows builds (PR:236, 1 commit, 1 file changed)
- Added: [pkg] PR:13360 (perma): [xbmc] Link against curl instead of using dlopen.
(2018-01-13, 17:27)HeresJohnny Wrote: [ -> ]What's with the new logo?
The Kodi logo hasn't changed, but the splash screen has been updated for Kodi 18 "Leia", which is not unusual - it happens about this time with every major release.
I'm not going to give you any spoilers, but guess where the window is.
Excellent work as usual by Sam Fisher.
