(2017-01-03, 19:03)Roby77 Wrote: [ -> ]Tried another DVD with last build but same problem
If i Press in DVD ISO i hear the background music but no video and kodi remains in library menú
LibreELEC (community) Version: devel-20170102210640-#0102-g56f05ab
LibreELEC git: 56f05ab4d65147b4a5740c143ce3c6609bfe02bf
LibreELEC:~ # cat /storage/.kodi/temp/kodi.log | pastebinit
http://sprunge.us/NJJC
LibreELEC:~ #
LibreELEC:~ #
LibreELEC:~ #
LibreELEC:~ # dmesg | pastebinit
http://sprunge.us/IOXO
LibreELEC:~ #
LibreELEC:~ #
LibreELEC:~ #
LibreELEC:~ # journalctl -a | pastebinit
http://sprunge.us/HcKZ
LibreELEC:~ #
LibreELEC:~ #
LibreELEC:~ #
LibreELEC:~ # cat /var/log/Xorg.0.log | pastebinit
http://sprunge.us/DGLb
LibreELEC:~ #
Have the same sort of problem with ts(h264) files cutted bij videoredo, wil post log when i am back home.
tested it with recorded ts without cutting and video plays fine, when i cut it with videoredo it shows is playing but stays in kodi menu(cutted files are working on all other players i have incl my tv pc htpc etc etc)
Never used videoredo.... i tried file encoded by me (handbrake, mkvmerge, or dvd with clonedvd2) and by friends
New LibreELEC.tv Krypton build #0103:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.9.0 #1 SMP Tue Jan 3 21:03:36 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170103210216-#0103-g60361c3 [Build #0103]
# Kodi version
(18.0-ALPHA1 Git:5c40b5c). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (60361c30,
changelog) and tip of
XBMC master (1763a95d,
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (2fc92b5f, ahead +4)
- Includes latest libnfs master (43cde9da, ahead +32)
- Includes latest p8-platform master (2d90f986, ahead +9)
- Includes latest addons: inputstream.adaptive (fc862638), inputstream.rtmp (55437ac7), peripheral.joystick (987a818e), pvr.argustv (4702a9e7, +4), pvr.demo (99db6bf5, +3), pvr.dvblink (4e6992d9, +4), pvr.dvbviewer (2b8ab246, +12), pvr.filmon (a23db0c5, +4), pvr.hdhomerun (baeafbde, +3), pvr.hts (117d4020, +5), pvr.iptvsimple (df0649e7, +6), pvr.mediaportal.tvserver (f00ccfd3, +18), pvr.mythtv (41c3201f), pvr.nextpvr (48a7796a, +4), pvr.njoy (d1ad569b, +3), pvr.octonet (8549a31c), pvr.pctv (b8286a23, +4), pvr.stalker (dfda4c51, +4), pvr.vbox (bfa938c7, +10), pvr.vdr.vnsi (7033621d, +14), pvr.vuplus (acd75dc5, +3), pvr.wmc (35be514e, +3)
- Include [env] cefed3e9: TexturePacker: Hack to work around CMAKE_SOURCE_DIR
- Include [env] 96c6e7ee: kodi: disable bluetooth
- Include [env] 8849e543: kodi: fix cmake after move to root
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: cmake: always set -DWITH_CPU and -DWITH_ARCH for target
- Include [env] patch: kodi: fix intel gpu detection patch after kodi/10848
- Include [env] patch: iwlwifi-firmware: update to iwlwifi-firmware-ba301aa
- Include [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
- Include [env] patch: repository.retroplayer.libreelec.addons: add temp repo for testing
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] PR:1025: scripts/create_addon: use PKG_REV as part of the binary addon version
- Include [env] PR:1052: Package updates
- Include [env] PR:1067: vaapi hvec 10bit support
- Include [env] PR:1123: build: dump cmake command and variables before building
- Include [pkg] PR:50: Add (and display) pretty names in release order - not name order (service.libreelec.settings)
- Include [pkg] PR:11163: Fix silent failure when game add-on can't be installed
Build Highlights:
- patch: cmake: always set -DWITH_CPU and -DWITH_ARCH for target
Build Details:
- LibreELEC.tv:
- create_tar.sh: remove a leftover reference to OpenELEC (PR:1127, 1 commit, 1 file changed)
- XBMC:
- [cmake/AddonHelpers] Rework custom binary handling (Fix Android) (PR:11268, 1 commit, 1 file changed)
- [cmake] add imx support (PR:11288, 2 commits, 5 files changed)
- [ScriptInvocationManager] make ExecuteAsync() thread-safe (PR:11289, 1 commit, 1 file changed)
- [osx/windowing] - fix regression introduced in 4b9126649940de22e89619… (PR:11324, 1 commit, 1 file changed)
- osx: adapt to changes in IDispResource (PR:11347, 1 commit, 3 files changed)
- android:debuggable support (PR:11353, 1 commit, 2 files changed)
- spelling: Vietnamese (PR:11350, 1 commit, 3 files changed)
- Hide notifications shown on device connect (PR:11329, 1 commit, 1 file changed)
- PAPlayer: Explicitely cast to 64 bit before doing large multiplications (PR:11356, 1 commit, 1 file changed)
- [cmake] Fixes rpi ARCH (PR:11343, 1 commit, 1 file changed)
- libcec:
- Added: [env] patch: cmake: always set -DWITH_CPU and -DWITH_ARCH for target
- Added: [env] PR:1123: build: dump cmake command and variables before building
Tried 0301 same problem as described in last post
So i reverted to 24/12 and problem still There
So now i must format
(2017-01-04, 01:33)Roby77 Wrote: [ -> ]Tried 0301 same problem as described in last post
Can you try a clean .kodi:
systemctl stop kodi
mv .kodi .kodi.bak
reboot
and then see if the problem is still there with #0103.
Yeah now works!
Thank You!
HDHomerun PVR add on has an issue with v18.
Performed clean install with LE 7.0.3, and do not have an issue.
Then loaded #0103 v18 and it has a loading issue hopefully viewable in this log here ---->
http://sprunge.us/ifGb
I then reverted back to #1129 v17, and do not have an issue.
I am going to keep troubleshooting to see where I think the issue started.
edit: #1212b works
#1213 does not work
(2017-01-04, 00:17)Roby77 Wrote: [ -> ]Never used videoredo.... i tried file encoded by me (handbrake, mkvmerge, or dvd with clonedvd2) and by friends
Why not if I may aks? it always worked without a problem, use only videoredo to cut commercials and save it backl as ts(so no need for encoding etc)
Here is the log of the ts problem cutted with videoredo, not workings since kodi18, on kodi17 millhouse builds is working fine.
http://sprunge.us/jXGi
and kodi 17 log.
http://sprunge.us/DIhJ
Then post a log with v17 and that very same file.
(2017-01-04, 06:56)boostberry3g Wrote: [ -> ]HDHomerun PVR add on has an issue with v18.
Then loaded #0103 v18 and it has a loading issue hopefully viewable in this log here ----> http://sprunge.us/ifGb
edit: #1212b works
#1213 does not work
You are talking of the SiliconDust addon? If so then it fails trying to connect to the DVR. I opened a trouble ticket with SD but get the impression they won't be looking at v18 for some time.
(2017-01-04, 12:54)fritsch Wrote: [ -> ]Then post a log with v17 and that very same file.
Done edited the post with kodi 17 log.
I have old motherboard with PCI slot and external PCI Nvidia card Geforce GT610. I tried to install your build but I couldn't because I received the message during loading of LE - failed to start xorg server. See systtemctl status xorg.service for details. Dependency failed for fluxbox window manager.
Quote:goga@debian:~/kodi/log$ cat Xorg.0.log
_XSERVTransTransNoListen: unable to find transport: tcp
Failed to disable listen for tcp transport_XSERVTransTransNoListen: unable to find transport: tcp
Failed to disable listen for tcp transport[1787070.120]
X.Org X Server 1.19.0
Release Date: 2016-11-15
[1787070.121] X Protocol Version 11, Revision 0
[1787070.124] Build Operating System: Linux 4.4.0-57-generic x86_64 LibreELEC.tv
[1787070.124] Current Operating System: Linux OpenELEC 4.9.0 #1 SMP Tue Jan 3 21:03:36 GMT 2017 x86_64
[1787070.124] Kernel command line: root=/dev/ram0 rdinit=/init usbcore.autosuspend=-1 BOOT_IMAGE=/KERNEL boot=LABEL=System disk=LABEL=Storage quiet
[1787070.125] Build Date: 03 January 2017 05:42:41PM
[1787070.125]
[1787070.125] Current version of pixman: 0.34.0
[1787070.125] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[1787070.125] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[1787070.125] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Jan 4 17:26:27 2017
[1787070.125] (++) Using config file: "/etc/X11/xorg-nvidia.conf"
[1787070.125] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[1787070.125] (==) No Layout section. Using the first Screen section.
[1787070.125] (**) |-->Screen "screen" (0)
[1787070.125] (**) | |-->Monitor "<default monitor>"
[1787070.126] (**) | |-->Device "nvidia"
[1787070.126] (==) No monitor specified for screen "screen".
Using a default monitor configuration.
[1787070.126] (==) Automatically adding devices
[1787070.126] (==) Automatically enabling devices
[1787070.126] (==) Automatically adding GPU devices
[1787070.126] (==) Max clients allowed: 256, resource mask: 0x1fffff
[1787070.126] (==) FontPath set to:
/usr/share/fonts/misc,
built-ins
[1787070.126] (==) ModulePath set to "/usr/lib/xorg/modules"
[1787070.126] (**) Extension "Composite" is disabled
[1787070.126] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[1787070.126] (II) Loader magic: 0x5c6840
[1787070.126] (II) Module ABI versions:
[1787070.126] X.Org ANSI C Emulation: 0.4
[1787070.126] X.Org Video Driver: 23.0
[1787070.126] X.Org XInput driver : 24.1
[1787070.126] X.Org Server Extension : 10.0
[1787070.131] (--) PCI:*(0:2:0:0) 10de:104a:19da:5228 rev 161, Mem @ 0xfa000000/16777216, 0xf0000000/134217728, 0xee000000/33554432, I/O @ 0x0000e800/128, BIOS @ 0x??/131072
[1787070.131] (II) LoadModule: "glx"
[1787070.132] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[1787070.159] (II) Module glx: vendor="NVIDIA Corporation"
[1787070.159] compiled for 4.0.2, module version = 1.0.0
[1787070.159] Module class: X.Org Server Extension
[1787070.159] (II) NVIDIA GLX Module 375.26 Thu Dec 8 17:59:51 PST 2016
[1787070.159] (II) LoadModule: "nvidia"
[1787070.159] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[1787070.164] (II) Module nvidia: vendor="NVIDIA Corporation"
[1787070.164] compiled for 4.0.2, module version = 1.0.0
[1787070.164] Module class: X.Org Video Driver
[1787070.164] (II) NVIDIA dlloader X Driver 375.26 Thu Dec 8 17:37:15 PST 2016
[1787070.164] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[1787070.164] (++) using VT number 1
[1787070.164] (II) Loading sub module "fb"
[1787070.164] (II) LoadModule: "fb"
[1787070.164] (II) Loading /usr/lib/xorg/modules/libfb.so
[1787070.165] (II) Module fb: vendor="X.Org Foundation"
[1787070.165] compiled for 1.19.0, module version = 1.0.0
[1787070.165] ABI class: X.Org ANSI C Emulation, version 0.4
[1787070.165] (II) Loading sub module "wfb"
[1787070.165] (II) LoadModule: "wfb"
[1787070.165] (II) Loading /usr/lib/xorg/modules/libwfb.so
[1787070.166] (II) Module wfb: vendor="X.Org Foundation"
[1787070.166] compiled for 1.19.0, module version = 1.0.0
[1787070.166] ABI class: X.Org ANSI C Emulation, version 0.4
[1787070.166] (II) Loading sub module "ramdac"
[1787070.166] (II) LoadModule: "ramdac"
[1787070.166] (II) Module "ramdac" already built-in
[1787070.171] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[1787070.171] (==) NVIDIA(0): RGB weight 888
[1787070.171] (==) NVIDIA(0): Default visual is TrueColor
[1787070.172] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[1787070.172] (**) NVIDIA(0): Option "NoFlip" "false"
[1787070.172] (**) NVIDIA(0): Option "NoLogo" "true"
[1787070.172] (**) NVIDIA(0): Option "HWcursor" "false"
[1787070.172] (**) NVIDIA(0): Option "ColorRange" "Full"
[1787070.172] (**) NVIDIA(0): Option "ModeValidation" "NoVesaModes, NoXServerModes"
[1787070.172] (**) NVIDIA(0): Option "ConnectToAcpid" "0"
[1787070.172] (**) NVIDIA(0): Option "ModeDebug" "false"
[1787070.172] (**) NVIDIA(0): Enabling 2D acceleration
[1787075.089] (EE) NVIDIA(GPU-0): The NVIDIA kernel module does not appear to be receiving
[1787075.089] (EE) NVIDIA(GPU-0): interrupts generated by the NVIDIA GPU at PCI:2:0:0.
[1787075.089] (EE) NVIDIA(GPU-0): Please see Chapter 8: Common Problems in the README for
[1787075.089] (EE) NVIDIA(GPU-0): additional information.
[1787075.089] (EE) NVIDIA(GPU-0): Failed to initialize the NVIDIA graphics device!
[1787075.089] (EE) NVIDIA(0): Failing initialization of X screen 0
[1787075.089] (II) UnloadModule: "nvidia"
[1787075.089] (II) UnloadSubModule: "wfb"
[1787075.089] (II) UnloadSubModule: "fb"
[1787075.089] (EE) Screen(s) found, but none have a usable configuration.
[1787075.089] (EE)
Fatal server error:
[1787075.090] (EE) no screens found(EE)
[1787075.091] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[1787075.092] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[1787075.092] (EE)
[1787075.353] (EE) Server terminated with error (1). Closing log file.
Quote:cat /proc/interrupts
CPU0
0: 42 XT-PIC timer
1: 2 XT-PIC i8042
2: 0 XT-PIC cascade
3: 7684 XT-PIC uhci_hcd:usb2, uhci_hcd:usb3, snd_hda_intel:card0, eth0
5: 2 XT-PIC ehci_hcd:usb1
8: 0 XT-PIC rtc0
9: 0 XT-PIC acpi
10: 76 XT-PIC sata_via[0000:00:0f.0], uhci_hcd:usb4, uhci_hcd:usb5
12: 4 XT-PIC i8042
14: 6169 XT-PIC pata_via
15: 0 XT-PIC pata_via
16: 0 PCI-MSI 1048576-edge nvidia
NMI: 16 Non-maskable interrupts
LOC: 90357 Local timer interrupts
SPU: 0 Spurious interrupts
PMI: 16 Performance monitoring interrupts
IWI: 0 IRQ work interrupts
RTR: 0 APIC ICR read retries
RES: 0 Rescheduling interrupts
CAL: 0 Function call interrupts
TLB: 0 TLB shootdowns
ERR: 105
MIS: 0
PIN: 0 Posted-interrupt notification event
PIW: 0 Posted-interrupt wakeup event
no any interrupts for nvidia card
here is dmesg
http://paste.ubuntu.com/23740078/
Quote: 201.967680] nvidia 0000:02:00.0: PCI: Disallowing DAC for device
[ 202.458377] nvidia 0000:02:00.0: PCI: Disallowing DAC for device
[ 207.201474] NVRM: RmInitAdapter failed! (0x12:0x45:1819)
[ 207.201635] NVRM: rm_init_adapter failed for device bearing minor number 0
[ 232.653473] kodi.bin[856]: segfault at 20 ip 0000000000000020 sp 00007ffd41fa7f58 error 14 in kodi.bin[400000+1632000]
my configuration is
amibios - 08.00.09 build date 09.30.05
cpu amd sempron 2800+ 1600 MHz
in bios I have choice Primary Graphics Adapter - PCI
motheboard based on chipset VIA VT8237
In
http://us.download.nvidia.com/XFree86/Li...blems.html I read about some advice
- to use "NVreg_EnableMSI=0" option for nvidia module. I created nvidia.conf file in /storage/.config/modprobe.d and added the line options nvidia NVreg_EnableMSI=0. But it didn't help. I still have the same issue with X starting. How be sure that this option is really active ?
Next solution from Nvidia is to use several boot kernel options for grub or LILO as
pci=noacpi don't use ACPI for PCI IRQ routing
pci=biosirq use PCI BIOS calls to retrieve the IRQ routing table
noapic don't use I/O APICs present in the system
acpi=off disable ACPI
But how can I write them in your build ? Is it possible to do it ?
edit: #1212b works
#1213 does not work
Don't see any loading issues in your log.
If you mean you have GUI issues with progress bars etc., then this is the thread for you:
http://forum.kodi.tv/showthread.php?tid=302045
No idea who supports HD Homerun but it looks like it needs an update after the infobools were deprecated.
(2017-01-04, 17:58)Goga777 Wrote: [ -> ]I have old motherboard with PCI slot and external PCI Nvidia card Geforce GT610. I tried to install your build but I couldn't because I received the message during loading of LE - failed to start xorg server. See systtemctl status xorg.service for details. Dependency failed for fluxbox window manager.
Your GPU obviously doesn't work with the latest 375.26 nvidia driver.
Your only option would be to switch to the 340.101 nvidia-legacy driver:
http://forum.kodi.tv/showthread.php?tid=...pid2379208
Edit: You could also try adding one of
these parameters to the end of the APPEND line in /flash/syslinux.conf:
Parameter Behavior
eg.
APPEND boot=LABEL=System disk=LABEL=Storage ssh quiet pci=noacpi
Use the command "mount -o remount,rw /flash" to make /flash read-write.
(2017-01-04, 20:23)Milhouse Wrote: [ -> ] (2017-01-04, 17:58)Goga777 Wrote: [ -> ]I have old motherboard with PCI slot and external PCI Nvidia card Geforce GT610. I tried to install your build but I couldn't because I received the message during loading of LE - failed to start xorg server. See systtemctl status xorg.service for details. Dependency failed for fluxbox window manager.
why do you think so ?
according
http://www.nvidia.com/download/driverRes...2992/en-us
my GT610 should work with 375.26
Quote:GeForce 600 Series:
GeForce GTX 690, GeForce GTX 680, GeForce GTX 670, GeForce GTX 660 Ti, GeForce GTX 660, GeForce GTX 650 Ti BOOST, GeForce GTX 650 Ti, GeForce GTX 650, GeForce GTX 645, GeForce GT 645, GeForce GT 640, GeForce GT 635, GeForce GT 630, GeForce GT 620, GeForce GT 610, GeForce 605
