New LibreELEC.tv Leia build #0127:
Generic
(Supercedes previous build)
SHA256 Checksum:
dc6ca04fcf21a8a58d5de09e9966b23613d4ea71b1db9df8be45b9bd921175f2
(Generic)
text:
# uname -a
Linux NUC 4.14.15 #1 SMP Sun Jan 28 02:02:33 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180128020105-#0127-g56b38d5 [Build #0127]
# Kodi version
(18.0-ALPHA1 Git:69a6725). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (56b38d5,
changelog) and tip of
XBMC master (e1e969b,
- Includes latest kodi-platform master (36fb493)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (f6e51c3, ahead +115)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (b28d3f0, +1), inputstream.rtmp (b3ffc49, +2), peripheral.joystick (0a20d01), pvr.argustv (a4d3ec7), pvr.demo (0224cbd), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (774943f), pvr.iptvsimple (a00d008), pvr.mediaportal.tvserver (0c5ece3, +1), pvr.mythtv (3200b09), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (c7a13d7), pvr.stalker (c91421d), pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (4db947c), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (fed0aea), vfs.libarchive (568a2a1)
- Include [env] compare (perma): kodi: reduce arm memory fragmentation
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: fix PR390
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2243 (perma): NOOBS: shorten partition labels, add $DEVICE support
- Include [env] PR:2382 (perma): linux: DVB fixes
- Include [env] PR:2384 (perma): kodi: updates for Feb 2018
- Include [env] PR:2432 (perma): buildsystem: avoid if/then/else boiler plate when accessing hierarchy [RFC]
- Include [env] PR:2442 (perma): mesa: update to mesa-17.3.3
- Include [pkg] compare (perma): Updated RPi3/ZeroW(H) WiFi firmware (version 7.45.98.38) (forum, github) (brcmfmac_sdio-firmware-rpi)
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:13274 (perma): Mode whitelist
- Include [pkg] PR:13435 (perma): Fix broken ctrl+shift modifiers
Build Highlights:
- Fix LiveTV OSD issue with OK remote button
- VideoPlayer: rewrite yuv to rgb conversion for OpenGL
Build Details:
- LibreELEC.tv:
- add -J flag to limit race condition during build step (PR:2445, 1 commit, 1 file changed)
- linux: update to linux-4.14.15 (-ish) (PR:2392, 21 commits, 14 files changed)
- docker: depend on systemd (PR:2447, 1 commit, 1 file changed)
- minidlna: initial addon (PR:2437, 1 commit, 12 files changed)
- LibreELEC-settings: update to c8ec6f6 (PR:2450, 1 commit, 1 file changed)
- XBMC:
- Fix crash on exit. (PR:13445, 1 commit, 15 files changed)
- [fix] move virtual window handling to translators to solve issue with remote mappings (PR:13444, 1 commit, 6 files changed)
- VideoPlayer: rewrite yuv to rgb conversion for OpenGL (PR:13428, 8 commits, 50 files changed)
- [GLES] VideoShader cleanup (PR:13416, 5 commits, 40 files changed)
- Added: [env] compare (perma): kodi: reduce arm memory fragmentation
- Updated: [pkg] PR:13435 (perma): Fix broken ctrl+shift modifiers
(2018-01-27, 15:23)Ontige Wrote: [ -> ]Hey Folks,
im having Problems playing a specific bunch of files since release 0123 while the build Prior that Plays the files just fine. My Setup is an NUC6CAYH and here is the log: Log
The file whats causing the error is a bunch of episodes of Black Sails...
Does anybody have a clue?
Greatings
Ontige
What problems? Audio problem? Video problem? Buffering problem? Give us a clue.
Sry, forgot to mention, that it completly refuses to play the file. All prior versions are playing the files just fine.
Thanks and greeting
Ontige
(2018-01-28, 11:28)Ontige Wrote: [ -> ]Sry, forgot to mention, that it completly refuses to play the file. All prior versions are playing the files just fine.
Thanks and greeting
Ontige
No
Debug Log no issue - no crystal balls existing here.
(2018-01-26, 16:16)c--mas Wrote: [ -> ] (2018-01-10, 21:19)c--mas Wrote: [ -> ] (2018-01-07, 15:31)Milhouse Wrote: [ -> ]I asked a colleague more familiar with DVB stuff and this is his reply:
If you have a problem, please upload the requested log.
Thank you for your fast reply. Based on my daily work it was not earlier possible to check it. What did he mean with 4.17-18? My first idea was the kernel ...but there are 4.14 in use....
Please have a look at my dmesg :-) That would be great.
dmesg
my last post is over 2 weeks ago. In the meanwhile i´ve completely reinstalled the system (formatted the sd card) and installed the latest version #0125
After that i installed the hauppauge dvb drivers and done a reboot, but TVheadend furthmore don´t see my hauppauge usb device. I have had a look on my system with the dmesg command, but can´t see the error. Can someone help me with my analzye of the issue? Thanks in advance
dmesg from today
@Milhouse: No further support from your side regarding my problem? ....or only no idea why it doesn´t work? A short information would be fine..... If you or your colleague have no idea why it´s okay for me ... so im going to buy me a new dvb-s card.
(2018-01-28, 17:40)c--mas Wrote: [ -> ]@Milhouse: No further support from your side regarding my problem?
I had intended to ping my colleague, but real life intervened (and I forgot). Have pinged him now.
c--mas my colleague has contacted the upstream developer. In the meantime can you post a link to a new dmesg - please don't scrape your console as this mangles the details, use
dmesg | pastebinit
and post the link.
New LibreELEC.tv Leia build #0128:
Generic
SHA256 Checksum:
3a9882d19ccb8fd4c27830dd64561b0fef96807f8a626ca78bb94dae4fb249b7
(Generic)
text:
# uname -a
Linux NUC 4.14.15 #1 SMP Sun Jan 28 21:12:20 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180128210951-#0128-g0708350 [Build #0128]
# Kodi version
Based on tip of
LibreELEC.tv master (0708350,
XBMC master (f094478,
- Include [env] compare (perma): busybox: 2nd attempt at disabling busybox parallel build
Build Highlights:
- Configurable
MALLOC_MMAP_THRESHOLD_
. Edit /storage/.cache/mmap_threshold.conf
. Prefix entry with #
to disable.
- [videoplayer] Fix vdpau crash after #13428
Build Details:
- LibreELEC.tv:
- crazycat: fix building for amlogic-3.10 (PR:2452, 1 commit, 1 file changed)
- linux: update amlogic-3.10 kernel to amlogic-3.10-02fdb27 (PR:2453, 1 commit, 1 file changed)
- XBMC:
- [Android] default sdk=android-26 / update doc (PR:13420, 1 commit, 13 files changed)
- [videoplayer] Fix vdpau crash after #13428. (PR:13448, 1 commit, 1 file changed)
- Change label name to get multiple ratings (PR:13429, 1 commit, 1 file changed)
- Fix hang on exit. (PR:13447, 1 commit, 2 files changed)
- Update: [env] compare (perma): kodi: reduce arm memory fragmentation
- Added: [env] compare (perma): busybox: 2nd attempt at disabling busybox parallel build
Milhouse
Start at Build #0127 & # 0128 all 4K video files are only output as 1080p, until and with Build # 0126 this works fine and 4k media is output as 4k. (i Play this Movie "Prometheus - Dunkle Zeichen 4k (2012)")
logfile
http://ix.io/ERP
(2018-01-28, 23:23)Milhouse Wrote: [ -> ]@c--mas my colleague has contacted the upstream developer. In the meantime can you post a link to a new dmesg - please don't scrape your console as this mangles the details, use dmesg | pastebinit
and post the link.
Thank you for this information :-) Just a good feeling to know that my help request to you is in place :-) Don´t hurry ... real life is more important.
Here is the link
http://ix.io/ETv
(2018-01-29, 09:35)pacoma2610 Wrote: [ -> ]@Milhouse
logfile http://ix.io/ERP
Presumably
PR13416... I've left a comment on github to your post.
New LibreELEC.tv Leia build #0129:
Generic
SHA256 Checksum:
cf64be7f7d4715f940054bfbb226f354bb87c3fd61fd189b138b60ecf25e305c
(Generic)
text:
# uname -a
Linux NUC 4.14.15 #1 SMP Mon Jan 29 22:06:50 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180129220358-#0129-gb72acb8 [Build #0129]
# Kodi version
Based on tip of
LibreELEC.tv master (b72acb8,
XBMC master (b33ba4d,
- Include [env] PR:2454 (perma): config: enable CONFIG_BPF_SYSCALL and CONFIG_CGROUP_BPF
- Include [env] PR:2456 (perma): xf86-video-nvidia: update to xf86-video-nvidia-390.25
Build Highlights:
- xf86-video-nvidia: update to xf86-video-nvidia-390.25
- [GLES] more shader cleanup
- config: enable CONFIG_BPF_SYSCALL and CONFIG_CGROUP_BPF
Build Details:
- LibreELEC.tv:
- mesa: update to mesa-17.3.3 (PR:2442, 1 commit, 1 file changed)
- NOOBS: shorten partition labels, add $DEVICE support (PR:2243, 1 commit, 2 files changed)
- XBMC:
- [GLES] more shader cleanup (PR:13446, 4 commits, 25 files changed)
- Added: [env] PR:2454 (perma): config: enable CONFIG_BPF_SYSCALL and CONFIG_CGROUP_BPF
- Added: [env] PR:2456 (perma): xf86-video-nvidia: update to xf86-video-nvidia-390.25
Hi Milhouse,
I just buy an Intel NUC NUC7i7BNH (before I had an Intel NUC NUC5i5RYH) but I'm surprised to see that DTS-HD, Dolby True HD, Dolby Digital Plus are not supported in passthrough... Was not this corrected?
That was working on my NUC5i5RYH.
(2018-01-30, 01:08)Guilouz Wrote: [ -> ]Hi Milhouse,
What do you mean by "not supported"? Passthrough options are greyed out in the GUI, or passthrough can be enabled but is not working (silence? noise?)
Is your HDMI firmware the latest (or maybe you need the version before latest, as I recall latest may cause problems)?
Not really an expert on the multitude of problems with Intel gear. Hopefully someone else can suggest something.
Also a debug log would help.
(2018-01-30, 01:40)Milhouse Wrote: [ -> ] (2018-01-30, 01:08)Guilouz Wrote: [ -> ]Hi Milhouse,
I can enable passthrough but I have no sound in passthrough, my receiver doesn't received any audio channel. when I disable passthrough I have sound but not the direct source.
Here my log file :
https://paste.ubuntu.com/26486468/
And sometimes when I try to launch a video with DTS-HD/True HD or Dolby Digital Plus, I have no sound but when I stop it and return on Kodi interface I lost GUI sound too. No issue with Dolby Digital or DTS.
What do you mean by HDMI firmware ? I just use your builds. I have updated NUC BiOS to latest, made a fresh install, I have installed latest LibreELEC build 8.2.3 and updated with your latest nightly.
