No - those settings do not exist, whatever your problem is has nothing to do with them.
fritsch
Log does'nt help ether?
Problem only exist on LE 9.0 (Zotac ZBOX ID84 and an Intel NUC7i3BNH).
Latest Windows developer build is working (uses the same tvheadend server).
(2018-02-27, 23:04)Mitch23 Wrote: [ -> ]Problem only exist on LE 9.0 (Zotac ZBOX ID84 and an Intel NUC7i3BNH).
Has it always existed, or only recently? When (which build) did it start?
New LibreELEC.tv Leia build #0227:
Generic
(Supercedes previous build)
SHA256 Checksum:
38de91521e596d6fedff0bd416868e4dc173619c7292cc1e22bdeca4c45dbe9b
(Generic)
text:
# uname -a
Linux NUC 4.14.22 #1 SMP Tue Feb 27 21:19:00 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180227211652-#0227-g68cbae3 [Build #0227]
# Kodi version
(18.0-ALPHA1 Git:d9c810b). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (68cbae3,
changelog) and tip of
XBMC master (35aefa4,
- Includes latest kodi-platform master (36fb493)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (54405d9, ahead +120)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (b28d3f0), inputstream.rtmp (b3ffc49), peripheral.joystick (12e7d52, +1), pvr.argustv (a4d3ec7), pvr.demo (8f62053), pvr.dvblink (89d1687), pvr.dvbviewer (64c4356), pvr.filmon (2721611), pvr.hdhomerun (7379fbc), pvr.hts (095784b), pvr.iptvsimple (933a5c4), pvr.mediaportal.tvserver (dec444f), pvr.mythtv (59ff911, +5), pvr.nextpvr (aa1c8d2), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (5b47d9f), pvr.stalker (77eec69), pvr.teleboy (3ae0297), pvr.vbox (57f3198), pvr.vdr.vnsi (4db947c), pvr.vuplus (f05f158), pvr.wmc (38e670a), pvr.zattoo (3c46173), vfs.libarchive (128394c)
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: fix PR390
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2487 (perma): dtc: build fdtput and fdtget
- Include [env] PR:2511 (perma): kernel-firmware: use project specific firmwares and cleanup
- Include [env] PR:2520 (perma): linux: update to linux-4.14.24 (ish)
- Include [env] PR:2528 (perma): kodi: Early March 2018 update
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:13274 (perma): Mode whitelist
Build Highlights:
- Minors
Build Details:
- LibreELEC.tv:
- Amlogic: support for AVL6862 DVB driver (PR:2451, 3 commits, 14 files changed)
- busybox: bump package to v1.28.1 (PR:2504, 1 commit, 5 files changed)
- XBMC:
- libmicrohttpd version bump (PR:13593, 2 commits, 9 files changed)
- omxplayer: Avoid hang when skipping to next video (PR:13592, 1 commit, 1 file changed)
- OMXImage: Skip out earlier when image is progressive (PR:13590, 1 commit, 1 file changed)
- [cleanup] remove ifdefs for old lib, os & compiler versions (PR:13595, 10 commits, 26 files changed)
(2018-02-27, 15:45)rudrood Wrote: [ -> ]When watching PVR the progressbar on the OSD is working oke for the first program. But when the next program starts it remains full and doesn't reset.
Happening with the latest Kodi Leia builds (not sure when it started) and plain and modded Estaury skin.
https://imgur.com/a/hn1w9
screenshots are made with Estaury mod skin, but with plain Estaury it is the same.
First image: watching first show (progressbar is oke)
Second image: next program has started but the progressbar remains filled from the previous program.
Does it make sense to post logs or find out when problem started (difficult cause I have to wait for special moment)?
Thanks for pointing this out.
Confirming the issue, root cause found. I will come up with a fix soon.
(2018-02-26, 21:39)fritsch Wrote: [ -> ] (2018-02-26, 18:04)MaxMustermann Wrote: [ -> ] (2018-02-26, 12:44)basco Wrote: [ -> ]I can also confirm the black artefacts are gone. thanks guys!!
I'm still having the artifacts. It's noticeably better with 'limited color range' turned on, but the artifacts are still there.
Here are some images and the log file. I hope you can find a fix. #0205 was the last version without artifacts.
Could you please post a sample?
Have you seen my sample? Do you need anything else to be able to help me?
(2018-02-28, 16:45)MaxMustermann Wrote: [ -> ] (2018-02-26, 21:39)fritsch Wrote: [ -> ] (2018-02-26, 18:04)MaxMustermann Wrote: [ -> ]I'm still having the artifacts. It's noticeably better with 'limited color range' turned on, but the artifacts are still there.
Yes. yol tested it - works perfectly fine, no black artifacts at all. He tested on AMD. I tested on Intel.
(2018-02-27, 11:50)basco Wrote: [ -> ] (2018-02-26, 22:02)MaxMustermann Wrote: [ -> ]OK. Sample
I don't see any **black** artifacts.
Probably not related to the black artefacts issue.
But it also appeared from #0206 on like with others having this issue (e.g. this
post). Maybe it depends more on the model of the graphic card.
Might be the case. Please add all those information to a trac ticket.
Milhouse
February releases are affected for sure.
Can't test former releases at the moment (download tooks more than 2 hours for a release). Trying tomorrow again.
(2018-02-24, 13:53)fritsch Wrote: [ -> ] (2018-02-24, 13:28)kalle2000 Wrote: [ -> ] (2018-02-24, 12:28)fritsch Wrote: [ -> ]No it's not. Your HDMI is a DP converter bridge an lspcon.
Ok, thanks for the explanation.
Still the question is: why are some resolutions not shown in kodi v18?
Debug Log was not enabled when kodi was starting up, therefore no information in the logfile available.
I added loglevel=2 into advancedsettings.xml
However I cannot see any difference. xrandr still shown 1280x800 max. With kodi 17 its upto 4096x...
kodi18 log
Looks like the TV is plain off when you boot kodi ... provide: dmesg | pastebinit
New LibreELEC.tv Leia build #0228:
Generic
SHA256 Checksum:
906633d4814c3b04c3f711bfc07963f75f1185d46f54d4df4bb718afa9486de4
(Generic)
text:
# uname -a
Linux NUC 4.14.22 #1 SMP Wed Feb 28 21:17:25 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180228210338-#0228-g1eb0ca9 [Build #0228]
# Kodi version
Based on tip of
LibreELEC.tv master (1eb0ca9,
XBMC master (d56be60,
Build Highlights:
- DVB: add all new dvb devices that come since 4.9 (in Linux PR)
Build Details:
- LibreELEC.tv:
- binutils: add patch to fix aarch64 ld regression (PR:2525, 1 commit, 1 file changed)
- librespot: update to 685fb4e (PR:2530, 1 commit, 6 files changed)
- crazycat: fix broken patch (PR:2532, 1 commit, 1 file changed)
- XBMC:
- MMAL: Render improvements for 10bit and side-by-side UV (PR:13591, 10 commits, 10 files changed)
- added: option to stick 'add source' on top in listings (PR:13546, 1 commit, 3 files changed)
- [Music]Fix FileItem::IsSamePath for albums and artists (PR:13585, 1 commit, 1 file changed)
- [fix] add back libcdio 0.83 compatibility after 98565c188b (PR:13597, 1 commit, 3 files changed)
- prevent crash when retrieving rating (PR:13598, 1 commit, 1 file changed)
- Added: [env] PR:2520 (perma): linux: update to linux-4.14.24 (ish)
