New LibreELEC.tv Leia build #0416:
Generic
(Supercedes previous build)
SHA256 Checksum:
dbaad8571b973b8b75d19ac8b377baf71ed96606e9011db8c21342b5857b9547
(Generic)
text:
# uname -a
Linux NUC 4.14.34 #1 SMP Mon Apr 16 21:07:05 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180416210355-#0416-g03ea594 [Build #0416]
# Kodi version
(18.0-ALPHA2 Git:992b393). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (03ea594,
changelog) and tip of
XBMC master (992b393,
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (a488fee, ahead +124)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (34b5af2), inputstream.rtmp (3b5058d), peripheral.joystick (80224e1), pvr.argustv (377f796), pvr.demo (d5e5cd1), pvr.dvblink (c61ea73), pvr.dvbviewer (1ef88c6), pvr.filmon (0ca1665), pvr.hdhomerun (484b91d), pvr.hts (9533cce), pvr.iptvsimple (77156cb), pvr.mediaportal.tvserver (9702684), pvr.mythtv (9d15025), pvr.nextpvr (de30ff2), pvr.njoy (bd6581f), pvr.octonet (54680a3), pvr.pctv (5e95300), pvr.stalker (da6f0f8), pvr.teleboy (a84e5ef), pvr.vbox (3cf15ad), pvr.vdr.vnsi (d6fe796), pvr.vuplus (00a963f), pvr.wmc (2acca13), pvr.zattoo (5e5493b), vfs.libarchive (e7d149e)
- Exclude [env] kodi-0100-temp-add-pr13594.patch: merged upstream
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: fix PR390
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2623 (perma): RPi, Generic: backport proposed patch to reduce IR latency
- Include [env] PR:2627 (perma): linux: update to linux-4.14.34
- Include [env] PR:2631 (perma): kodi: Mid April 2018
- Include [env] PR:2647 (perma): include memtester in image
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:13274 (perma): Mode whitelist
- Include [pkg] PR:13647 (perma): Verify add-on zip authenticity
Build Highlights:
- New 4.14.34 kernel
- Include memtester in build
- Update IR latency patches
Build Details:
- XBMC:
- [guiinfo] Implement time format "m" (TIME_FORMAT_M) (PR:13767, 2 commits, 4 files changed)
- [guiinfo] Fix CGUIInfoManager::GetInt after #13754 (PR:13772, 4 commits, 6 files changed)
- Updated: [env] PR:2623 (perma): RPi, Generic: backport proposed patch to reduce IR latency
- Updated: [env] PR:2627 (perma): linux: update to linux-4.14.34
- Updated: [env] PR:2631 (perma): kodi: Mid April 2018
- Added: [env] PR:2647 (perma): include memtester in image
(2018-04-16, 22:02)WaVe_99 Wrote: [ -> ]Milhouse - hi, it´s not a skin problem, i tested now with Estuary. It will be probably some addon problem, i don´t have today chance test it, which addon specifically. But i will later and i will let you know.
Check if you have a crash log, maybe Kodi is in a restart loop which would explain the lack of a GUI (although this should have resulted in safe mode being triggered, if you left it long enough - 5 crashes within 15 minutes). At the very least a debug log is required. Renaming your .kodi folder would be the quickest way to start without add-ons.
(2018-04-17, 00:27)Milhouse Wrote: [ -> ] (2018-04-16, 22:02)WaVe_99 Wrote: [ -> ]Milhouse - hi, it´s not a skin problem, i tested now with Estuary. It will be probably some addon problem, i don´t have today chance test it, which addon specifically. But i will later and i will let you know.
No, i don´t have a crash log, no restart loop, and the normal kodi log looks pretty same as before (some errors, but i don´t think it´s connected with "no picture" problem). I will try clean install instead and will see - when i have time :-) Thank you :-)
EDIT: Without addons (after rename .kodi folder) it starts after update just fine :-) I will keep looking, which addon exactly...
Milhouse - I believe this may be a known issue, but I wanted provide logs. When playing streams from Fox Sports Go or PS Vue addons, it will often have video freezes, drop audio or just crash. There are a lot of "ActiveAE - large audio sync errors" that show. I've tried various combinations of settings with enabling/disabling hw acceleration, hq scaler %, cache settings, different versions of inputstream adaptive.
Let me know if I can provide any other info.
Debug log, journalctl, etc
Crash Log
I’ve been running these builds for a while and they’ve been great.
However the asteroids screensaver has stopped working a while back. I’ve tried the builds provided here by millhouse and the generic librelelec. All I get is a black screen.
I’ll do a debug log however is it possible for a rebuild?
Thanks in advance
Seems that further changes with ir patches (PR:
2623 broke my remote infrastructure (RC6 with Harmony Hub).
No reaction with build #0416 even with increasing the repeat level to "3" in Harmony settings.
Back to bulid #0415 i had to plug in- and out my RC6 receiver to get my remote working again.
Maybe @
HiassofT has an idea?
(2018-04-17, 11:02)debutanker Wrote: [ -> ]Seems that further changes with ir patches (PR:2623 broke my remote infrastructure (RC6 with Harmony Hub).
What kind of IR receiver are you using? Please post the output of ir-keytable and your dmesg (run "dmesg | paste").
And, could you configure repeat level to 2 or 3 on your remote and run the following tests both on 0415 and 0416 and post the output of the commands after pressing a single button:
First stop kodi and eventlircd:
systemctl stop kodi
systemctl stop eventlircd
Then run
press a button, abort command with ctrl-c and post the output, after that run
press the same button, abort with ctrl-c and post the output.
so long,
Hias
Thanks for knocking on an open door!
Tests with build #0415:
dmesg:
http://ix.io/180A
# LibreELEC #
https://libreelec.tv #
LibreELEC (community): devel-20180415215712-#0415-g03ea594 (Generic.x86_64
ir-ctl -r --->
pulse 600
space 1650
pulse 600
space 1650
pulse 2700
space 850
pulse 500
space 400
pulse 450
space 450
pulse 450
space 850
space 16777215
ir-keytable -t--->
252.053547: event type EV_MSC(0x04): scancode = 0x800f041e
252.053547: event type EV_KEY(0x01) key_down: KEY_UP(0x0067)
252.053547: event type EV_SYN(0x00).
252.160542: event type EV_MSC(0x04): scancode = 0x800f041e
252.160542: event type EV_SYN(0x00).
252.426708: event type EV_KEY(0x01) key_up: KEY_UP(0x0067)
252.426708: event type EV_SYN(0x00).
build #0416
# LibreELEC #
LibreELEC (community): devel-20180416210355-#0416-g03ea594 (Generic.x86_64)
LibreELECWZ:~ # systemctl stop kodi
LibreELECWZ:~ # systemctl stop eventlirc
Failed to stop eventlirc.service: Unit eventlirc.service not loaded.
ir-ctl -r--->
pulse 2650
space 900
pulse 450
space 450
pulse 450
space 400
pulse 500
space 850
space 16777215
ir-keytable -t --->
Testing events. Please, press CTRL-C to abort.
----no output here----
^C
Thanks for the info!
ir-ctl -r output has the same odd very long space as in the other report.
I've dropped the mceusb commit that quite certainly caused that from the PR, today's build should be fine again.
so long,
Hias
Really appreciate your support and keep up the good work!
New LibreELEC.tv Leia build #0417:
Generic
SHA256 Checksum:
36d95d2c8a144b0cb8935d8e9e3dae9f022812e86a0fd3e9f16a0463fe0651a4
(Generic)
text:
# uname -a
Linux NUC 4.14.34 #1 SMP Wed Apr 18 02:12:53 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180418020427-#0417-ga934092 [Build #0417]
# Kodi version
Based on tip of
LibreELEC.tv master (a934092,
XBMC master (e132890,
- Includes latest libnfs master (8b064bf, ahead +125)
- Includes latest addons: inputstream.adaptive (b3aa34c, +1), inputstream.rtmp (3b5058d), peripheral.joystick (80224e1), pvr.argustv (377f796), pvr.demo (d5e5cd1), pvr.dvblink (c61ea73), pvr.dvbviewer (1ef88c6), pvr.filmon (0ca1665), pvr.hdhomerun (484b91d), pvr.hts (9533cce), pvr.iptvsimple (77156cb), pvr.mediaportal.tvserver (9702684), pvr.mythtv (9d15025), pvr.nextpvr (de30ff2), pvr.njoy (bd6581f), pvr.octonet (54680a3), pvr.pctv (5e95300), pvr.stalker (da6f0f8), pvr.teleboy (a84e5ef), pvr.vbox (3cf15ad), pvr.vdr.vnsi (d6fe796), pvr.vuplus (00a963f), pvr.wmc (2acca13), pvr.zattoo (5e5493b), vfs.libarchive (e7d149e)
- Include [env] PR:2536 (perma): kodi: libinput fixes
- Include [pkg] PR:13176 (perma): [RFC] [Linux] add libinput backend for non window system platforms
Build Highlights:
- Drop mceusb from IR latency patches
- Kodi libinput fixes
- Kill infomanager global
Build Details:
- LibreELEC.tv:
- include memtester in image (PR:2647, 2 commits, 3 files changed)
- XBMC:
- more use dynPath instead of changing path (id) (PR:13771, 1 commit, 5 files changed)
- Kill infomanager global (PR:13776, 5 commits, 95 files changed)
- allow playlist items in a playlist for files (PR:13777, 1 commit, 3 files changed)
- libnfs:
- Move win32/win32_compat.h to include/win32/win32_compat.h (PR:245, 1 commit, 34 files changed)
- inputstream.adaptive:
- [Android] Add JNI exception checks (b3aa34c)
- Added: [env] PR:2536 (perma): kodi: libinput fixes
- Added: [pkg] PR:13176 (perma): [RFC] [Linux] add libinput backend for non window system platforms
(2018-04-17, 19:35)HiassofT Wrote: [ -> ][...]
so long,
Hias
Fixed my problem with MCE RC6 IR-Receiver - many thanks.
(2018-04-18, 10:07)debutanker Wrote: [ -> ]Fixed my problem with MCE RC6 IR-Receiver - many thanks.
debutanker thanks a lot for your feedback!
If you have a few minutes it would be great if you could run a few more tests on build #0416 (with the non-functioning remote). The goal of the mceusb patch was to make remotes more snappy, maybe it optimized things too much, maybe that optimization doesn't work with your IR receiver, maybe there's something we missed - would be good to find that out.
On build #0416, with kodi running, run the following command and check if your remote starts working again:
Also test with "ir-ctl -t 125000"
If one of these settings brought remote functionality back it would be good to know if lower values also work. Test with 75000, 50000, 40000, 30000, 25000. You can try other values in between if you like, but if some of these settings work it would already be good to know about it.
so long,
Hias
