2018-04-18, 12:27
(2018-04-18, 11:54)HiassofT Wrote: [ -> ](2018-04-18, 10:07)debutanker Wrote: [ -> ]Fixed my problem with MCE RC6 IR-Receiver - many thanks.@debutanker thanks a lot for your feedback!
If you have a few minutes it would be great if you could run a few more tests on build #0416 (with the non-functioning remote). The goal of the mceusb patch was to make remotes more snappy, maybe it optimized things too much, maybe that optimization doesn't work with your IR receiver, maybe there's something we missed - would be good to find that out.
On build #0416, with kodi running, run the following command and check if your remote starts working again:
Also test with "ir-ctl -t 125000"Code:ir-ctl -t 100000
If one of these settings brought remote functionality back it would be good to know if lower values also work. Test with 75000, 50000, 40000, 30000, 25000. You can try other values in between if you like, but if some of these settings work it would already be good to know about it.
so long,
Hias
As you guys always have more than only a few minutes for us, i will find of course some minutes for you!
Tested with several values and first value which works for me is "64000".
Edit: would be nice, if my mce receiver shows the same "snappy" behavior as my NUC receiver now does.
