(2018-04-18, 22:14)busta.rhymes Wrote: [ -> ]Here is someone with the same problem with this nuc on the libre elec forum:
https://forum.libreelec.tv/thread/12018-...usb-or-sd/
Run memtest86+ on your RAM - the only "installer wouldn't boot" issues I've seen were down to bad RAM DIMMs.
Other than that, I'm not really sure - are you on the latest BIOS? We know that Gemini Lake CPUs will boot the installer so it's unlikely to be a kernel issue, and more likely a BIOS issue - the installer should boot in either "legacy" BIOS or UEFI modes.
Probably best to continue the discussion in the LE forum until it is resolved - I'll keep an eye on it and if any changes are necessary will follow up.
New LibreELEC.tv Leia build #0418:
Generic
(Supercedes previous build)
SHA256 Checksum:
0a6b5a52efa75381299370882c6bdd9d552e64e9e60466ecc363acbf891cbbf7
(Generic)
text:
# uname -a
Linux NUC 4.14.34 #1 SMP Thu Apr 19 01:18:55 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180419011547-#0418-g12716c2 [Build #0418]
# Kodi version
(18.0-ALPHA2 Git:af4a548). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (12716c2,
changelog) and tip of
XBMC master (af4a548,
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (8b064bf, ahead +125)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (b3aa34c), inputstream.rtmp (3b5058d), peripheral.joystick (80224e1), pvr.argustv (377f796), pvr.demo (d5e5cd1), pvr.dvblink (c61ea73), pvr.dvbviewer (7936ba1), pvr.filmon (0ca1665), pvr.hdhomerun (484b91d), pvr.hts (9533cce), pvr.iptvsimple (77156cb), pvr.mediaportal.tvserver (9702684), pvr.mythtv (9d15025), pvr.nextpvr (de30ff2), pvr.njoy (bd6581f), pvr.octonet (54680a3), pvr.pctv (5e95300), pvr.stalker (da6f0f8), pvr.teleboy (a84e5ef), pvr.vbox (3cf15ad), pvr.vdr.vnsi (d6fe796), pvr.vuplus (00a963f), pvr.wmc (2acca13), pvr.zattoo (5e5493b), vfs.libarchive (e7d149e)
- Exclude [env] kodi-0100-temp-add-pr13594.patch: merged upstream
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: fix PR390
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2536 (perma): kodi: libinput fixes
- Include [env] PR:2623 (perma): RPi, Generic: backport proposed patch to reduce IR latency
- Include [env] PR:2627 (perma): linux: update to linux-4.14.34
- Include [env] PR:2653 (perma): samba: fix interleaved config generation/modification
- Include [env] PR:2654 (perma): kodi: Early May 2018
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:13176 (perma): [RFC] [Linux] add libinput backend for non window system platforms
- Include [pkg] PR:13274 (perma): Mode whitelist
- Include [pkg] PR:13647 (perma): Verify add-on zip authenticity
Build Highlights:
- Latest mceusb IR latency fix
- libinput mouse wheel fix
- GUI: Fix file title
Build Details:
- LibreELEC.tv:
- kodi: Mid April 2018 (PR:2631, 5 commits, 41 files changed)
- XBMC:
- [Windows] remote control re-design. (PR:13778, 3 commits, 16 files changed)
- [win10] don't allow browse root of RemoteStorages virtual folder. (PR:13784, 1 commit, 1 file changed)
- [guiinfo] Fix PLAYER_TITLE fallbacks. (PR:13786, 1 commit, 2 files changed)
- [cmake/cosmetics] Driving me nuts for 2+ years... (PR:13789, 1 commit, 55 files changed)
- pvr.dvbviewer:
- Get rid of XMLUtils_GetString (f4a59cb)
- Refactor timers and code cleanup (503355f)
- Bump version to 3.4.3 (7936ba1)
- Updated: [env] PR:2623 (perma): RPi, Generic: backport proposed patch to reduce IR latency
- Added: [env] PR:2653 (perma): samba: fix interleaved config generation/modification
- Added: [env] PR:2654 (perma): kodi: Early May 2018
- Updated: [pkg] PR:13176 (perma): [RFC] [Linux] add libinput backend for non window system platforms
(2018-04-18, 20:15)HiassofT Wrote: [ -> ] (2018-04-18, 13:41)debutanker Wrote: [ -> ]Here we go:
Regarding my NUC, its only the integrated receiver controlled also by Harmony Hub.
Compared to my external MCE receiver, controlling is much more faster.
What do you mean with "faster"? Quicker response to button presses, quicker button repeat?
so long,
Hias
Thanks much for your explanation!
I mean, if i rapidly press any buttons several times on my harmony remotes (i have one hub in my living room and one hub in my sleeping room), my NUC reacts without any delays, more straighter, compared to my HTPC with my RC6 IR-Receiver.
Both Hub's/Harmony's are having the same setup.
With new build #0418 everything works - many thanks!
I have set my command repeats on level "1", which gives me the best experience for my MCE-IR Receiver so far.
(2018-04-19, 00:44)Milhouse Wrote: [ -> ] (2018-04-18, 22:14)busta.rhymes Wrote: [ -> ]Here is someone with the same problem with this nuc on the libre elec forum:
Thanks... ill install windows to see if everything else works. Its weird that the other person that created the thread had the same problem with the exact same nuc.
(2018-04-19, 09:15)busta.rhymes Wrote: [ -> ] Thanks... ill install windows to see if everything else works. Its weird that the other person that created the thread had the same problem with the exact same nuc.
You can boot memtest86+ off a USB memory stick (in theory).
Booting Ubuntu might also be worth a try.
Yes, the fact an identical system has the same problem is interesting, particularly as someone else with a different Gemini Lake system managed to boot into LE 8.2.4 with 4.11.y kernel (though without graphics due to the older graphics driver, and was then able to update to a working system with one of these 4.14.y builds). The fact syslinux isn't starting smells like a BIOS bug or boot incompatibility of some kind, which might be specific to this particular system or BIOS.
One other thing to try is booting with
a different gptmbr file in case the BIOS is configuring a non-standard boot drive. Try writing (using the LibreELEC USB-SD Creator)
this image of my latest build to your USB memory stick - it's using gptmbr_f.bin as the MBR, see if you have any more luck when booting the installer.
Busta.rhymes - couple of other suggestions:
1. Do you have a "Boot Menu" option when the NUC boots (it's F10 in my i5 Skylake NUC). Make sure you are booting with the
UEFI : USB : Generic Flash Disk <blah blah> : OS Bootloader
device (this is for UEFI booting) and not the
USB : Generic Flash <blah blah> : Boot Drive
device (legacy BIOS).
2.
https://communities.intel.com/thread/123631 <--- this guy seems to lose video after the video mode is switched, are you able to connect the TV to the other video ports on the NUC in case it's outputting video on the wrong port? It may also have switched into a video mode your TV doesn't support.
My only other suggestion is to return it and request a refund. I really find it hard to recommend anything Intel these days.
(2018-04-19, 16:19)Milhouse Wrote: [ -> ]@Busta.rhymes - couple of other suggestions:
1. Do you have a "Boot Menu" option when the NUC boots (it's F10 in my i5 Skylake NUC). Make sure you are booting with the UEFI : USB : Generic Flash Disk <blah blah> : OS Bootloader
device (this is for UEFI booting) and not the USB : Generic Flash <blah blah> : Boot Drive
2. https://communities.intel.com/thread/123631 <--- this guy seems to lose video after the video mode is switched, are you able to connect the TV to the other video ports on the NUC in case it's outputting video on the wrong port? It may also have switched into a video mode your TV doesn't support.
Thanks for the help Milhouse... I installed windows on it this afternoon and that worked fine after that i went ahead and tried one more time to install libreelec. And with the windows install on the ssd the stick was able to boot into installation and i could install it.
After libre elec was installed though i only got black screen again when booting up. I think it has something to do with the device it is trying to boot from or with video modes.
Either way i have lost my nerves and am sending back the NUC. Just wanted to say thanks one more time. I guess early adoption is not a good thing to do with this type of product.
(2018-04-19, 00:28)Milhouse Wrote: [ -> ] (2018-04-19, 00:10)gromgsxr Wrote: [ -> ]Are the intel hd audio patches still included? i just tried the 0417 version on my nuc6cayh and it only passes DD and DTS, even DD+ Eac3 was sketchy and only worked sporadically. and anything like TrueHD all i got was silence, and after trying to play those it killed the 2 channel pcm from the menu and i had no sound until i rebooted.
Yep
oh that's not good they don't fix the hd pass through at all for me.
About the whitelist again:
Up till build 0403 resolution and fps are working oke for me:
Samples from the Kodi sample page:
- H.264 1080p/23.976 (MKV)
- H.264 1080p/24.000 (MKV)
My tv swaps from 60 to 24 fps.
Latest TVHeadend with cable at 1080p/50
My tv swaps from 60 to 50 fps.
With the later builds I enabled all the 1920x1080 framerates in the whitelist that are availible (see screenshot and below: xrandr -q)
https://imgur.com/a/VHTBO.
But now:
My tv stays on 60 fps.
My tv swaps from 60 to 25 fps with heavy sound lags, and after about 30/60 sec suddenly to 50 fps.
Here's the output of xrandr -q
1920x1080 60.00*+ 59.94 50.00 29.97 25.00 23.97 60.05 60.00 50.04
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1366x768 59.79
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32
720x576 50.00 50.08
720x480 59.94 60.05
640x480 75.00 72.81 59.94
Are there any logs or things I can provide to have this solved?
Disable the 1080p25 Mode - wondering why this is there at all.
(2018-04-19, 20:56)rudrood Wrote: [ -> ]But how about the 24fps?
Your
Debug Log will tell. @
lrusak Is the code LE ships in sync with your WIP?
Did you also enable Settings > Player > Videos > Adjust display refresh rate and set it to Always?
If it is Off then you won't get any refresh rate switching, even with items in your Whitelist.
Eventually the "Adjust display refresh rate" setting will be removed completely once the Whitelist functionality is ready for prime time.
BTW, here's a small ZIP (55KB) with several different FPS test videos:
https://www.dropbox.com/s/5rbt6vz8dipwe3i/FPS.zip?dl=1
RPi hangs and doesn't return to the GUI at the end of playback, so maybe there's something wrong with Kodi and extremely short duration videos... NUC seems OK though. RPi has this in the log at the end of playback:
text:
20:03:52.913 T:1941303888 WARNING: OnMessage: Suspiciously long time to handle GUI_MSG_PLAYBACK_STARTED (7.58s)
New LibreELEC.tv Leia build #0419:
Generic
SHA256 Checksum:
917f3d60e975ba57e038a2cf511db65b08bbbd578df0030fd18b9a0df22dbacb
(Generic)
text:
# uname -a
Linux NUC 4.14.34 #1 SMP Thu Apr 19 21:07:29 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180419210257-#0419-g6ce3be6 [Build #0419]
# Kodi version
Based on tip of
LibreELEC.tv master (6ce3be6,
XBMC master (5295d8e,
- Includes latest addons: inputstream.adaptive (f61409e, +1), inputstream.rtmp (3b5058d), peripheral.joystick (80224e1), pvr.argustv (377f796), pvr.demo (d5e5cd1), pvr.dvblink (c61ea73), pvr.dvbviewer (7936ba1), pvr.filmon (0ca1665), pvr.hdhomerun (484b91d), pvr.hts (9533cce), pvr.iptvsimple (77156cb), pvr.mediaportal.tvserver (9702684), pvr.mythtv (9d15025), pvr.nextpvr (de30ff2), pvr.njoy (bd6581f), pvr.octonet (54680a3), pvr.pctv (5e95300), pvr.stalker (da6f0f8), pvr.teleboy (a84e5ef), pvr.vbox (3cf15ad), pvr.vdr.vnsi (d6fe796), pvr.vuplus (00a963f), pvr.wmc (2acca13), pvr.zattoo (5e5493b), vfs.libarchive (e7d149e)
- Revert [pkg] PR:13780: bump ffmpeg to 4.0 (reason: LibreELEC needs to bump ffmpeg and patches)
Build Highlights:
- mesa 18.0.1
- Whitelist: include DESKTOP resolution, sort list
- Revert ffmpeg 4.0 for now (revert PR13780)
Build Details:
- LibreELEC.tv:
- mesa: update to 18.0.1 (PR:2655, 1 commit, 2 files changed)
- network-tools update (PR:2606, 13 commits, 15 files changed)
- XBMC:
- Verify add-on zip authenticity (PR:13647, 13 commits, 14 files changed)
- Replace global color_t type with UTILS::Color. (PR:13787, 1 commit, 62 files changed)
- bump ffmpeg to 4.0 (PR:13780, 3 commits, 23 files changed)
- Implement generic DRM CryptoSession interface + python API (PR:13779, 2 commits, 17 files changed)
- Cleanup due to x64 build changes (PR:12382, 1 commit, 7 files changed)
- inputstream.adaptive:
- Added: [pkg] PR:13176 (perma): [RFC] [Linux] add libinput backend for non window system platforms
- Added: [pkg] PR:13274 (perma): Mode whitelist
- Reverted: [pkg] PR:13780: bump ffmpeg to 4.0 (reason: LibreELEC needs to bump ffmpeg and patches)
