(2018-05-20, 15:31)fritsch Wrote: [ -> ] (2018-05-20, 15:08)TimoJ Wrote: [ -> ] (2018-05-20, 14:32)fritsch Wrote: [ -> ] Depends on many things: hw decoder, Xorg color setting and so on ...
Is it possible to use xorg.conf to enable limited range with Intel graphics? I found messages that indicate it's not available for Intel.
I tried command line with xrand and it worked, now GUI is at the correct brightness (I hope...). I just haven't got it to work inside autostart.sh, not sure why it's not working.
But now I'm confused why I need to use xrand to get the correct brightness. Why there is no LibreELEC GUI setting for it? Kodi's setting effect only Kodi's part, not the underlying Xorg parts? Or am I missing something?
Please check kodi's wiki. I documented this some years ago, cause it is not trivial. In short only the following settings make sense:
1) Xorg Full + Kodi Limited + TV Limited
2) Xorg Limited 16:235 (this scales(!)) + Kodi Full + TV Limited
3) Xorg Full + Kodi Full + TV Full
Thanks, I'll check the Wiki. I think you mean this page:
https://kodi.wiki/view/Video_levels_and_color_space
Looks like xrand limited is not the correct one, picture loses contrast or something. I think my TV is fixed to limited, there is no setting for it.
(2018-05-20, 15:49)TimoJ Wrote: [ -> ] (2018-05-20, 15:31)fritsch Wrote: [ -> ] (2018-05-20, 15:08)TimoJ Wrote: [ -> ]Is it possible to use xorg.conf to enable limited range with Intel graphics? I found messages that indicate it's not available for Intel.
Thanks, I'll check the Wiki. I think you mean this page: https://kodi.wiki/view/Video_levels_and_color_space
Intel's Limited is assuming Full input and scales it down byself - that's why it calls: Limited 16:235 ... if you use this mode, make sure to use kodi in Full.
If your TV is fixed to Limited, the only that makes sense for you then is:
1) Xrandr to full and kodi to limited
2) xrandr to 16:235 Limited and kodi to full
But still the original issue remains, if I use this: "Xorg Full + Kodi Limited + TV Limited" the user interface is too dark. It's correct if I don't select limited range. Still video playback of black levels is correct with limited range selected. Is it possible to adjust just user interface brightness?
(2018-05-20, 16:23)fritsch Wrote: [ -> ] (2018-05-20, 16:19)TimoJ Wrote: [ -> ]But still the original issue remains, if I use this: "Xorg Full + Kodi Limited + TV Limited" the user interface is too dark. It's correct if I don't select limited range. Still video playback of black levels is correct with limited range selected. Is it possible to adjust just user interface brightness?
No.
Are skin graphics and colors correctly converter when limited range is used? Looks like if I manually edit graphic files to black = 16, then the skin starts to look normal again, only thumbnails are still too dark.
I didn't have this problem originally in Kodi, it started sometime last year. There were other posts about it during that time, I think the problem was never fixed (and not seen by all).
(2018-05-20, 16:57)TimoJ Wrote: [ -> ] (2018-05-20, 16:23)fritsch Wrote: [ -> ] (2018-05-20, 16:19)TimoJ Wrote: [ -> ]But still the original issue remains, if I use this: "Xorg Full + Kodi Limited + TV Limited" the user interface is too dark. It's correct if I don't select limited range. Still video playback of black levels is correct with limited range selected. Is it possible to adjust just user interface brightness?
No.
That's odd - cause the gui shader does this conversion already. Make sure if you toy with dirtyregion stuff, most of them make no sense anyways. When debugging such issue make sure that the complte viewport is always repainted - which is the default DR mode.If you want to save power use <gui><smartredraw>true</smartredraw></gui> instead
(2018-05-20, 17:00)fritsch Wrote: [ -> ] (2018-05-20, 16:57)TimoJ Wrote: [ -> ] (2018-05-20, 16:23)fritsch Wrote: [ -> ] No.
I removed that dr-setting, so it's default. But when I enable limited range, shouldn't the interface go brighter? Now it goes darker. It's like gui shader is converting the levels to a wrong direction. Or something, I'm not a programmer...
(2018-05-20, 17:12)TimoJ Wrote: [ -> ] (2018-05-20, 17:00)fritsch Wrote: [ -> ] (2018-05-20, 16:57)TimoJ Wrote: [ -> ]Are skin graphics and colors correctly converter when limited range is used? Looks like if I manually edit graphic files to black = 16, then the skin starts to look normal again, only thumbnails are still too dark.
As I explained before - this setting only makes sense in combination (xrandr, TV) setting. Think what would happen if TV is limited, xrandr is Full (remember: kodi set to limited with driver set to limited makes no sense at all): then with kodi on full kodi would assume black is 0 and white is 255, means if your tv just cuts them out, you neither have blacks nor whites -> washed out completely. Now if you enable Use Limited, kodi sends 16 as black and 235 as white -> perfect picture.
Test it with a gray ramp to see what I mean.
I have Afedchen's Excellent MVC WIP build on my Windows 10 Intel Apollo Lake 3450, hardware MVC 3D plays fine.
In Libreelec latest Milhouse build, I see that in the 3D options you can select HARDWARE, but 3D does not kick in when a 3D MKV is played, is this supposed to be a supported feature?
(2018-05-20, 17:28)fritsch Wrote: [ -> ] (2018-05-20, 17:12)TimoJ Wrote: [ -> ] (2018-05-20, 17:00)fritsch Wrote: [ -> ] That's odd - cause the gui shader does this conversion already. Make sure if you toy with dirtyregion stuff, most of them make no sense anyways. When debugging such issue make sure that the complte viewport is always repainted - which is the default DR mode.If you want to save power use <gui><smartredraw>true</smartredraw></gui> instead
But it doesn't seem to do that for the user interface, only for the video content. For the user interface it seems to send black as 0.
So I have to raise TV brightness to compensate this and also adjust Kodi's video brightness to a lower value to compensate raised TV brightness. And now my other videosources connected via the same input thru my AVR have too much brightness.
I watched a greyscale test card picture (jpg) and with Kodi set to full range 16 was black and with Kodi set to limited range 20 was black. Surely it shouldn't be this way? TV limited and xrand full.
Or maybe I'm just too dense to understand this, I'll have to think about this..
That makes sense, depending on your original input: I hope you tested with a picture. With kodi set to Full - the original value should come out - means if you have a full range RGB grey ramp: Black is 0. If your Black is already 16 - then it's clear that it gets 20 when you additionally enable Use Limited. Cause the 16 in full range is a dark grey, so in Limited it needs to be 20, cause if it was 16 there as well the original dark grey would now be black -> not what we want.
^^ This is true for pictures in full range. For Video (especially hw decoded ones) it's different.
(2018-05-20, 18:35)fritsch Wrote: [ -> ]That makes sense, depending on your original input: I hope you tested with a picture. With kodi set to Full - the original value should come out - means if you have a full range RGB grey ramp: Black is 0. If your Black is already 16 - then it's clear that it gets 20 when you additionally enable Use Limited. Cause the 16 in full range is a dark grey, so in Limited it needs to be 20, cause if it was 16 there as well the original dark grey would now be black -> not what we want.
It was a full range picture, you can get it from here:
https://www.cs.cmu.edu/afs/cs/project/se...mg1024.gif
I still think it's not shown correctly. Kodi GUI in limited mode is not mapping full range 16 to 20, it's mapping it to a lower than 16 value and makes it invisible.
Just a quick question. Is HDR working with libreelec and newer Intel NUCs?
Verified it - something is broken. With Use Limited i properly get ~ 219 at maximum, but it seems the low values stay where they are ...
Edit: That means we are shifting 16 in the wrong direction, should be between +16 and + 235 and not 0 and 219
New LibreELEC.tv Leia build #0520:
Generic
(Supercedes previous build)
SHA256 Checksum:
15ccb68d8995a9ae52f5b4aee5677c29c43bad695d41a2c8ef3ac0ea3e3755ee
(Generic)
text:
# uname -a
Linux NUC 4.14.41 #1 SMP Sun May 20 21:06:27 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180520210312-#0520-g6a26f5d [Build #0520]
# Kodi version
(18.0-ALPHA2 Git:5afb532). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (6a26f5d,
changelog) and tip of
XBMC master (f0e5a25,
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (6a33413, ahead +132)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (eb7795e, +1), inputstream.rtmp (8920456), peripheral.joystick (80224e1), pvr.argustv (0ed7cae), pvr.demo (20d81d8), pvr.dvblink (19c178e), pvr.dvbviewer (0ae6207), pvr.filmon (470ca1c), pvr.hdhomerun (4639740), pvr.hts (6455047), pvr.iptvsimple (c8356fc), pvr.mediaportal.tvserver (6fab703), pvr.mythtv (9d15025), pvr.nextpvr (5f8c614), pvr.njoy (5a2c2d3), pvr.octonet (54680a3), pvr.pctv (f0c28e2), pvr.stalker (a7f3e1c), pvr.teleboy (dbdc96e), pvr.vbox (48ffcba), pvr.vdr.vnsi (a2880c7), pvr.vuplus (aca7960), pvr.wmc (b62f80e), pvr.zattoo (94cc7dd), vfs.libarchive (1b00b57)
- Exclude [env] kodi-0100-temp-add-pr13594.patch: merged upstream
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: fix PR390
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2449 (perma): Adding support for AMD GPUs
- Include [env] PR:2679 (perma): eventlircd: don't grab power buttons
- Include [env] PR:2680 (perma): kodi: mid-May 2018
- Include [env] PR:2682 (perma): linux: update to linux-4.14.41
- Include [env] PR:2689 (perma): init: add sky42 enhancements/bug fixes
- Include [env] PR:2696 (perma): linux: update ouya patch
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:13721 (perma): Std thread
- Include [pkg] PR:13904 (perma): Fix whitelistable resolutions on some platforms
- Include [pkg] PR:13909 (perma): [curl] add url option to disable peer verification
- Include [pkg] PR:13910 (perma): Media source dialog tidyup
Build Highlights:
- Resolution: Allow deviation of max 0.01 instead of 0.005
- [curl] add url option to disable peer verification
- Media source dialog tidyup
Build Details:
- LibreELEC.tv:
- RPi, Generic: fix erratic IR timeout behaviour on Topseed mceusb receiver 1784:0011 (PR:2692, 2 commits, 2 files changed)
- Generic: allow lower IR timeouts on ITE CIR devices (PR:2694, 1 commit, 1 file changed)
- rust: rework (PR:2709, 2 commits, 2 files changed)
- addon/librespot: Update to 431be (#2712) (2820ec6)
- XBMC:
- Resolution: Allow deviation of max 0.01 instead of 0.005 (PR:13908, 1 commit, 1 file changed)
- Added: [pkg] PR:13909 (perma): [curl] add url option to disable peer verification
- Added: [pkg] PR:13910 (perma): Media source dialog tidyup
