fritsch
it lacks full hd 1920x1080 Refresh:60.000000 Width:1920 Height:1080 and 4k resolutions
but I also use HDMI and not DP1
(2018-06-08, 04:15)YinYang Wrote: [ -> ]@fritsch
Directly connect to the TV, please and retry. Btw. Gen-1 NUCs use a DP to HDMI converter chip, there is no other Monitor detected in your logs.
Hi i installed #607 over 8.2.5 on my nuc7i5bnh and CEC setting are grey.
I wonder if cec is working under libreelec with intel chips like rpi.
I have a pulse8 cec adaptor bought on their site and it’s working fine.
I wonder if users leave there nuc’s 24/7 on or totally shut down.
Is there a possibility to wake my nuc via CEC just like odroid C2?
(2018-06-08, 12:03)YinYang Wrote: [ -> ]@fritsch
I have now connected directly to my TV and now I get even a maximum resolution of 1280x800p.
Log : https://workupload.com/file/NjF8TcC
Milhouse could you pls explain the poster how to provide logs? IIRC there is an option in LE, right?
There is not much chance of success if we always have to download zips.
(2018-06-08, 17:51)peak3d Wrote: [ -> ] (2018-06-08, 12:03)YinYang Wrote: [ -> ]@fritsch
@Milhouse could you pls explain the poster how to provide logs? IIRC there is an option in LE, right?
Log submission details are in testing note #9 of the first post.
Alternatively (and assuming Kodi is still working), go to Settings > LibreELEC > System > Submit Log
YinYang many people don't have the time to work with zipped logs - for instance they might be reading your post while commuting and using their phone etc., so please use pastebin sites where possible as this means your logs are much more accessible.
(2017-12-11, 03:39)Milhouse Wrote: [ -> ] (2017-12-11, 02:54)wheemer Wrote: [ -> ]I'm trying it on VMware Workstation 14.
I had used the ova available for 8.1.2 which opens and runs perfectly. I then dropped in the latest nightly release from today... It reboots and updates fine, just no text anywhere.
Can you change your virtual hardware version to 12: https://kb.vmware.com/s/article/1010675
https://www.mesa3d.org/vmware-guest.html
Hello @
Milhouse,
i am trying to run your build on VMWare Workstation 14 Player.
Your solution does not work. I switched to virtrual hardware version 12 but i still get a black screen, only the mousecursor views.
Any other suggestions? :/
New LibreELEC.tv Leia build #0608:
Generic
(Supercedes previous build)
SHA256 Checksum:
a98be71e60dd593389adb70cfef06b92f583b80f580c37d68cfbf6811a26f71a
(Generic)
text:
# uname -a
Linux NUC 4.14.48 #1 SMP Fri Jun 8 21:15:47 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180608211311-#0608-gdfdae5e [Build #0608]
# Kodi version
(18.0-ALPHA2 Git:593949a). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (dfdae5e,
changelog) and tip of
XBMC master (ba9c207,
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (6a33413, ahead +132)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (a401504, +5), inputstream.rtmp (b8e3f39), peripheral.joystick (80224e1), pvr.argustv (2bce465), pvr.demo (20d81d8), pvr.dvblink (a87258b), pvr.dvbviewer (884b732), pvr.filmon (470ca1c), pvr.hdhomerun (4639740), pvr.hts (4f7196d), pvr.iptvsimple (e220777), pvr.mediaportal.tvserver (c4e32b0), pvr.mythtv (9d15025), pvr.nextpvr (78a80de), pvr.njoy (5a2c2d3), pvr.octonet (54680a3), pvr.pctv (17c1897), pvr.stalker (0700069), pvr.teleboy (3e9e537), pvr.vbox (48ffcba), pvr.vdr.vnsi (a2880c7), pvr.vuplus (6c94eec), pvr.wmc (a7ec576), pvr.zattoo (73891b1, +1), vfs.libarchive (84a4876)
- Exclude [env] kodi-0100-temp-add-pr13594.patch: merged upstream
- Include [env] compare (perma): init: strip leading / from BOOT_IMAGE & DISK_IMAGE, normalising for all projects
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: fix PR390
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2449 (perma): Adding support for AMD GPUs
- Include [env] PR:2696 (perma): linux: update ouya patch
- Include [env] PR:2725 (perma): Python2: update to Python2-2.7.15, bump Python-related packages
- Include [env] PR:2739 (perma): mesa: change to use meson and update to 18.1.1
- Include [env] PR:2742 (perma): scripts/image: add BUILDER_NAME, BUILDER_VERSION support
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:100 (perma): stats: Replace CPU 32/64 bit flag with GPU enumeration (service.libreelec.settings)
- Include [pkg] PR:13995 (perma): Do not use CURL::proxy for localhost
Build Highlights:
- Normalise BOOT_IMAGE/DISK_IMAGE on all platforms
- [JSON]Music library "lastupdated" property (new Music DB schema v71)
- Do not use CURL::proxy for localhost
- New settings version (prevent log spam / hidden setting value for widevine_api
Build Details:
- LibreELEC.tv:
- linux: update to linux-4.14.48 (PR:2729, 5 commits, 5 files changed)
- xf86-video-nvidia: update to xf86-video-nvidia-390.67 (PR:2753, 1 commit, 2 files changed)
- xf86-video-nvidia-legacy: update to xf86-video-nvidia-legacy-340.107 (PR:2755, 1 commit, 1 file changed)
- XBMC:
- [c-pluff] kill another implicit function declaration warning (PR:13998, 1 commit, 2 files changed)
- kodi-send: Add option to send a key press event (PR:13804, 4 commits, 1 file changed)
- CHelper_libXBMC_addon: Avoid buffer overflow in Log (PR:13984, 1 commit, 1 file changed)
- Log redacted URL in case of CURL failure (PR:13997, 1 commit, 1 file changed)
- [PVR] Addon API documentation cleanup (PR:14000, 3 commits, 6 files changed)
- [videoplayer] DVDDemux::GetStreamType(): Add more codecs and channel (PR:13965, 2 commits, 3 files changed)
- Small GBM code cleanups (PR:13985, 6 commits, 7 files changed)
- [JSON]Music library "lastupdated" property (PR:13969, 2 commits, 6 files changed)
- inputstream.adaptive:
- New settings version (prevent log spam / hidden setting value for widevine_api (a401504)
- Added: [env] compare (perma): init: strip leading / from BOOT_IMAGE & DISK_IMAGE, normalising for all projects
- Added: [pkg] PR:13995 (perma): Do not use CURL::proxy for localhost
There are several logs in the log zip! Which of these logs is relevant? then I can gladly put it over pastebin here.
01_KODI.log
09_Journal-cur.log
03_Hardware.log
02_System.log
06_varlog.log
05_Network.log
07_input.log
08_Filesystem.log
04_Audio.log
10_Journal-prev.log
(2018-06-09, 04:44)YinYang Wrote: [ -> ]There are several logs in the log zip! Which of these logs is relevant? then I can gladly put it over pastebin here.
01_KODI.log
09_Journal-cur.log
03_Hardware.log
02_System.log
06_varlog.log
05_Network.log
07_input.log
08_Filesystem.log
04_Audio.log
10_Journal-prev.log
01_KODI.log. Or you can follow the instructions you've already been given.
Milhouse
I can not make it as ready as it should the forum does not accept the input. In the preview, but as soon as I send it, the field is empty. so just the link sorry
Log
(2018-06-09, 06:21)YinYang Wrote: [ -> ]:
Just paste the link to the log file.
(2018-06-08, 18:59)Milhouse Wrote: [ -> ] (2018-06-08, 17:51)peak3d Wrote: [ -> ] (2018-06-08, 12:03)YinYang Wrote: [ -> ]@fritsch
@YinYang many people don't have the time to work with zipped logs - for instance they might be reading your post while commuting and using their phone etc., so please use pastebin sites where possible as this means your logs are much more accessible.
I sent you the logs again after your instructions!
(2018-06-09, 06:44)YinYang Wrote: [ -> ] (2018-06-08, 18:59)Milhouse Wrote: [ -> ] (2018-06-08, 17:51)peak3d Wrote: [ -> ] @Milhouse could you pls explain the poster how to provide logs? IIRC there is an option in LE, right?
In your above kodi log, it gets clear the kernel driver also only gets 1280 or the 1440 mode - there is nothing kodi can do about that. Find the latest build where it worked and then a bug can be filed with the kernel. Though: I am really wondering that such an issue occurs on a very old lts kernel. Make sure to reset your TV settings / change HDMI cable, just to be sure.
