thx but my general research offers me that HDR is a no go right now correct? Not with Intel and Kodi.
Milhouse kodi is crashing if i change my deinterlace settings in osd while watching live tv.
Is this a known issue?
I’ on the latest nightly running on my nuc7i5 bnh.
If neede i can provide logs.
(2018-06-15, 18:32)Krautmaster Wrote: [ -> ]thx but my general research offers me that HDR is a no go right now correct? Not with Intel and Kodi.
Correct.
Linux HDR is being worked on still.
We have wide color range support in xorg now so Kodi may need to support that and then they need to work on the metadata for HDR in Linux.
(2018-06-15, 19:47)Pienoet Wrote: [ -> ]@Milhouse kodi is crashing if i change my deinterlace settings in osd while watching live tv.
First report, and I can't reproduce myself (with a video, I don't have live tv). There were some settings issues in #0614 that will be fixed in #0615, so try that and post a crashlog if it continues. Also worth confirming the build when it started if it's not #0614.
New LibreELEC.tv Leia build #0615:
Generic
(Supercedes previous build)
SHA256 Checksum:
d01d9e4f354a98952a026487050b04d86cd22edb120a9ad233db64eda84d0bf1
(Generic)
text:
# uname -a
Linux NUC 4.14.49 #1 SMP Fri Jun 15 21:06:18 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180615210304-#0615-g83c436f [Build #0615]
# Kodi version
(18.0-ALPHA2 Git:37f55e6). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (83c436f,
changelog) and tip of
XBMC master (eea6e88,
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786)
- Includes latest libnfs master (6a33413, ahead +132)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (5756133, +6), inputstream.rtmp (b8e3f39), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (bcd8289), pvr.dvblink (1732e4b), pvr.dvbviewer (d6f1629, +21), pvr.filmon (ba261c9), pvr.hdhomerun (379c62c), pvr.hts (f569808), pvr.iptvsimple (663040c), pvr.mediaportal.tvserver (01af5a0), pvr.mythtv (c18ca9e), pvr.nextpvr (fad3ca9), pvr.njoy (30743c6), pvr.octonet (1e44819), pvr.pctv (d0c7241), pvr.stalker (00f3fc4), pvr.teleboy (dfa68b0), pvr.vbox (d2e61a9), pvr.vdr.vnsi (18c7474), pvr.vuplus (bcfd34d), pvr.wmc (ce4b47a), pvr.zattoo (e72598d, +2), vfs.libarchive (84a4876)
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2449 (perma): Adding support for AMD GPUs
- Include [env] PR:2742 (perma): scripts/image: add BUILDER_NAME, BUILDER_VERSION support
- Include [env] PR:2764 (perma): kodi: June 2018
- Include [env] PR:2772 (perma): linux: update to linux-4.14.49
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:100 (perma): stats: Replace CPU 32/64 bit flag with GPU enumeration (service.libreelec.settings)
Build Highlights:
- Revert "utils/IXmlDeserializable: drop useless interface"
Build Details:
- XBMC:
- Misc code cleanups (PR:14046, 3 commits, 3 files changed)
- Game OSD: Add rotation setting (PR:14019, 9 commits, 68 files changed)
- LinuxRendererGLES: consolidate custom renderers (PR:14030, 1 commit, 4 files changed)
- Revert "utils/IXmlDeserializable: drop useless interface" (PR:14049, 1 commit, 5 files changed)
- [cmake] pass vaapi and vdpau options to internal ffmpeg (PR:14017, 2 commits, 3 files changed)
- libinput: check max pointers (PR:14028, 1 commit, 2 files changed)
- pvr.dvbviewer:
- AutoTimers: Change deduplication default (600ae4b)
- Bump version to 3.6.1 (d6f1629)
(2018-06-15, 21:57)Milhouse Wrote: [ -> ] (2018-06-15, 19:47)Pienoet Wrote: [ -> ]@Milhouse kodi is crashing if i change my deinterlace settings in osd while watching live tv.
Milhouse i just tried build #615 and kodi is still crashing.
I will look wich build start crashing.
crash_log
Milhouse Build #303 is the last working build with working "deinterlace" option in osd live tv settings.
Build #304 is crashing
Hope this is helpful enough.
crash_log build #304
(2018-06-14, 02:25)Milhouse Wrote: [ -> ]Experimental Linux 4.17.1 build #0613x: Generic
LE9 will likely be based on a mainline kernel such as 4.17.y in order to offer improved AMD GPU and Intel CPU support. Please test this build and report any problems.
Changes:
text:
Updated Realtek drivers
Packages disabled/not included:
text:
DVB Driver Addons
Spinelplus support
Packages added/updated:
text:
AMD DC support
Vega 12/Vega 20/Vega M firmware
Latest Vega and Radeon PCI IDs
Latest Intel WiFi firmware
GLK HDMI refresh rate workaround (i915.glkhdmi=2)
Revert Intel i915 eDP Alternate Mode fix
Thanks! I’ll try it Sunday or Monday and report back on my raven ridge.
(2018-06-16, 00:06)Pienoet Wrote: [ -> ] (2018-06-15, 19:47)Pienoet Wrote: [ -> ]@Milhouse kodi is crashing if i change my deinterlace settings in osd while watching live tv.
@Milhouse Build #303 is the last working build with working "deinterlace" option in osd live tv settings.
Many thanks.
It seems to be crashing during VAAPI processing, so presumably it is:
(2018-03-05, 00:36)Milhouse Wrote: [ -> ]Build Details:
- XBMC:
- VideoPlayer: vaapi - do not destruct postproc if buffers are still in (PR:13605, 1 commit, 2 files changed)
I've uploaded a debug-enabled build #0615b:
Generic
Can you try this build and produce a new crash-log which will give more detailed information which may prove useful.
It's a bug yes, but you should not use "Deinterlace". This yadif filter will produce a lot of CPU load by itself and additionaly by copying the surfaces back to system memory with SSE4 intrinsics in order to be able to CPU deinterlace them. The suggest method for intel is: VAAPI Motion compensation.
(2018-06-16, 08:33)fritsch Wrote: [ -> ]It's a bug yes, but you should not use "Deinterlace". This yadif filter will produce a lot of CPU load by itself and additionaly by copying the surfaces back to system memory with SSE4 intrinsics in order to be able to CPU deinterlace them. The suggest method for intel is: VAAPI Motion compensation.
Thank you very much.
Ok so i wanted to use deinterlace cause for me it’s the best live tv playback quality. It’s the most fluid playback but i didn’t know that it uses a high cpu load.
If noticed if using VAAPI Motion compensation it’s not always smooth as deinterlace.
But if it’s suggested i’ll use it..
Milhouse i’ll try build #615b later today and report back.🤗
(2018-06-16, 03:57)Milhouse Wrote: [ -> ] (2018-06-16, 00:06)Pienoet Wrote: [ -> ] (2018-06-15, 19:47)Pienoet Wrote: [ -> ]@Milhouse kodi is crashing if i change my deinterlace settings in osd while watching live tv.
Many thanks.
- XBMC:
I've uploaded a debug-enabled build #0615b: Generic
Milhouse i just installed #615b and produced a new crash_log
crash_log #615b
Milhouse
Can we LIVE boot the 4.17.X kernel image? I don't want to blow away my working Ubuntu 18.04 setup right now but more than willing to test.
(2018-06-16, 13:31)pyrodex Wrote: [ -> ]@Milhouse
Follow these instructions, but use the #0613x tar file as the source for the new SYSTEM and KERNEL files:
https://forum.kodi.tv/showthread.php?tid...pid2741026
