(2018-06-25, 13:38)bobrik73 Wrote: [ -> ]NUC7i3BNH
HDMI Firmware 1.71 or HDMI Firmware 1.72 installed?
If that question is directed at me, then no, I have HDMI firmware 1.66 installed, which is the most recommended version (the 1.72 causes other problems for many). The 1.71 is for a newer NUC version that has two HDMI outputs. By all accounts, the 1.66 firmware fixes any bitstreaming/passthrough issues with the hardware, which is evidenced by my ability to passthrough using Windows 10/Kodi. I just can't get it to work with LibreELEC which is my preferred platform.
Some Testing from my side, i hae an MKV of Alien which is not running when Hardware Acceleration of HVEC is enabled (VAAPI HVEC ENABLED) with my AMDRyzen 5 2400G, wit the Asrocj J5005-ITX Board (Gemeni Lake) it works fine.
So may be an AMD Driver issue.
New LibreELEC.tv Leia build #0625:
Generic
(Supercedes previous build)
SHA256 Checksum:
d731c1a9d28d45987720e30683f24fdff20c0c142a07fb705809afc3cd2a5495
(Generic)
text:
# uname -a
Linux NUC 4.17.2 #1 SMP Mon Jun 25 23:54:00 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180625235242-#0625-g3021cd0 [Build #0625]
# Kodi version
(18.0-ALPHA3 Git:95de5f5). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (3021cd0,
changelog) and tip of
XBMC master (6fcbb13,
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786)
- Includes latest libnfs master (fa6d63c, ahead +134)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (ef3cefb, +5), inputstream.rtmp (bf5351e, +1), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (481f2fa, +1), pvr.dvblink (1732e4b), pvr.dvbviewer (fccf48a, +7), pvr.filmon (b41ef25, +1), pvr.hdhomerun (29cb0df, +1), pvr.hts (f569808), pvr.iptvsimple (7db634b, +1), pvr.mediaportal.tvserver (6845fa4, +1), pvr.mythtv (c18ca9e), pvr.nextpvr (fad3ca9), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv (d1aaaa9, +1), pvr.stalker (1a01bc9, +1), pvr.teleboy (0460536, +1), pvr.vbox (d2e61a9), pvr.vdr.vnsi (18c7474), pvr.vuplus (e2efab9, +1), pvr.wmc (ce4b47a), pvr.zattoo (baeb316, +3), vfs.libarchive (1bc1517, +1)
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2742 (perma): scripts/image: add BUILDER_NAME, BUILDER_VERSION support
- Include [env] PR:2772 (perma): linux (RPi): update to linux-4.14.50
- Include [env] PR:2785 (perma): dash: add package, configure as CONFIG_SHELL
- Include [env] PR:2787 (perma): libbluray: update to libbluray-1.0.2
- Include [env] PR:2788 (perma): kodi: July 2018
- Include [env] PR:2791 (perma): systemd: update to 239
- Include [env] PR:2792 (perma): Python2: remove --with-wctype-functions
- Include [env] PR:2793 (perma): kodi.sh: return zero on succesful exit
- Include [env] PR:2794 (perma): configure: drop unused build options
- Include [env] PR:2797 (perma): linux (Generic): update to linux-4.17.5 #2797
- Include [pkg] PR:100 (perma): stats: Replace CPU 32/64 bit flag with GPU enumeration (service.libreelec.settings)
Build Highlights:
- systemd: update to systemd-239
- Enable Realtek USB/PCI card reader support
Build Details:
- LibreELEC.tv:
- system-tools: add stress-ng (PR:2795, 2 commits, 3 files changed)
- zstd: update to zstd-1.3.4 (PR:2789, 1 commit, 1 file changed)
- xf86-video-intel: update to xf86-video-intel-3d39506, add libdrm depe (PR:2779, 1 commit, 1 file changed)
- XBMC:
- VideoPlayer: opengl - fix color range of subtitle textures (PR:14105, 1 commit, 4 files changed)
- [windows] use recompiled zlib for x64 (PR:14109, 1 commit, 1 file changed)
- Add required package names (PR:14098, 1 commit, 1 file changed)
- [dns-cache] Only use nmblookup if HAS_SMBCLIENT (PR:14024, 1 commit, 1 file changed)
- [Estuary] increase space for sysinfo (PR:14100, 1 commit, 3 files changed)
- libnfs:
- cmake: add include headers to libnfs (PR:258, 1 commit, 1 file changed)
- inputstream.adaptive:
- Allow Rep::BaseUrl for templated AdpSets (ef3cefb)
- Added: [env] PR:2791 (perma): systemd: update to 239
- Added: [env] PR:2797 (perma): linux (Generic): update to linux-4.17.5 #2797
(2018-06-22, 19:08)wishyou Wrote: [ -> ] (2018-06-20, 23:09)Milhouse Wrote: [ -> ]Can you post the zip from your Logfiles Samba share when booting with #0615. Maybe the SD card reader module isn't being loaded.
Here are some logs from a clean #0615 boot, kodi logs and zip file:
Wish
Can you try upgrading to, and then booting, with #0625 - hopefully this build has resolved the issue with your Realtek card reader (the driver started using different config options somewhere between 4.14.y and 4.17.y).
(2018-06-26, 00:38)KarstenL680 Wrote: [ -> ]Some Testing from my side, i hae an MKV of Alien which is not running when Hardware Acceleration of HVEC is enabled (VAAPI HVEC ENABLED) with my AMDRyzen 5 2400G, wit the Asrocj J5005-ITX Board (Gemeni Lake) it works fine.
Please post
Debug Log and 50 MB sample to reproduce.
billbillw
Also have a NUC7i3BNH.
HDMI version 1.66 has worked only with an adapter from USB-C to HDMI for me (to a Denon AVR X4000).
After an update to the new version, DTS-HD works now with HDMI (but USB-C is no longer working).
#0625 is working with SD-cards, thanks!
BTW is custom EDID working again with this build?
(2018-06-26, 19:59)wishyou Wrote: [ -> ]BTW is custom EDID working again with this build?
Not yet, but try tonight's #0626 build which will include an updated getedid script.
(2018-06-26, 17:12)Mitch23 Wrote: [ -> ]@billbillw
OK, Maybe I'll try the 1.72. At this point, nothing to loose. I can swap back to my Windows SSD tonight and give it a try. Oddly, with 1.66, I had lots of issues with the USB-C-HDMI converter. I had problems with the projector saying unsupported video feed, but it wasn't consistent.
Is it me only but opensubtitles and podnapisi addon not work with these test builds when trying download subtitles? I have tested with two different computers. It just trying to search very long time.
(2018-06-27, 00:27)Jezze Wrote: [ -> ]Is it me only but opensubtitles and podnapisi addon not work with these test builds when trying download subtitles? I have tested with two different computers. It just trying to search very long time.
Without a debug log, nobody knows.
It's either a busy dialog issue (the add-on shouldn't be opening the busy dialog), or a language reuse issue (short term fix is to add
<reuselanguageinvoker>false</reuselanguageinvoker>
(see
PR13814)). Probably best to contact the add-on maintainer for a Kodi 18/Leia compatible fix.
New LibreELEC.tv Leia build #0626:
Generic
SHA256 Checksum:
a82c693a58942b0dabed88a676c92d212f32664186ca5022e4ae1dca6d81d862
(Generic)
text:
# uname -a
Linux NUC 4.17.3 #1 SMP Tue Jun 26 23:15:09 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180626231349-#0626-g259242a [Build #0626]
# Kodi version
Based on tip of
LibreELEC.tv master (259242a,
XBMC master (0910789,
- Includes latest addons: inputstream.adaptive (ef3cefb, +5), inputstream.rtmp (bf5351e, +1), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (481f2fa, +1), pvr.dvblink (1732e4b), pvr.dvbviewer (fccf48a, +7), pvr.filmon (b41ef25, +1), pvr.hdhomerun (29cb0df, +1), pvr.hts (f569808), pvr.iptvsimple (7db634b, +1), pvr.mediaportal.tvserver (6845fa4, +1), pvr.mythtv (c18ca9e), pvr.nextpvr (fad3ca9), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv (d1aaaa9, +1), pvr.stalker (1a01bc9, +1), pvr.teleboy (0460536, +1), pvr.vbox (8244f9a, +1), pvr.vdr.vnsi (18c7474), pvr.vuplus (e2efab9, +1), pvr.wmc (ce4b47a), pvr.zattoo (baeb316, +3), vfs.libarchive (1bc1517, +1)
- Include [env] PR:2798 (perma): linux (Generic): update to linux-4.17.3
- Include [env] PR:2799 (perma): [getedid] Add AMD support and react on used kernel
- Include [env] PR:2800 (perma): samba: update to samba-4.8.3
- Include [env] PR:2803 (perma): debug: dependencies don't build with debug by default. use + suffix to enable
Build Highlights:
- New 4.17.3 kernel
- samba: update to samba-4.8.3
- [getedid] Add AMD support and react on used kernel
Build Details:
- LibreELEC.tv:
- Python2: remove --with-wctype-functions (PR:2792, 1 commit, 1 file changed)
- kodi.sh: return zero on succesful exit (PR:2793, 1 commit, 1 file changed)
- linux (Generic): update to linux-4.17.5 (PR:2797, 1 commit, 1 file changed) (premature merge - ignore title)
- hyperion: update to latest version and add potential fix for Kodi 18 issue (PR:2758, 4 commits, 5 files changed)
- libbluray: bump to 1.0.2 (PR:2787, 3 commits, 3 files changed)
- remove moonlight add (PR:2728, 3 commits, 8 files changed)
- sapphire: update add-on to 6.9 (PR:2684, 1 commit, 2 files changed)
- chrome browser (PR:2790, 28 commits, 87 files changed)
- XBMC:
- VideoPlayer: inputStreamAddon fix interface IsRealtime (PR:14110, 1 commit, 2 files changed)
- [infoscanner] ensure we're only checking for .nomedia in folders (fixes #17651) (PR:13088, 1 commit, 4 files changed)
- windowing/gbm: allow different gui and screen size (PR:14108, 4 commits, 7 files changed)
- [PVR][Log] Introduce component based logging for PVR and EPG. (PR:14112, 1 commit, 29 files changed)
- pvr.vbox:
- Fix recordings playback not working (was broken since v4.2.0). (PR:210, 1 commit, 3 files changed)
- Updated: [env] PR:2794 (perma): configure: drop unused build options
- Added: [env] PR:2798 (perma): linux (Generic): update to linux-4.17.3
- Added: [env] PR:2799 (perma): [getedid] Add AMD support and react on used kernel
- Added: [env] PR:2800 (perma): samba: update to samba-4.8.3
- Added: [env] PR:2803 (perma): debug: dependencies don't build with debug by default. use + suffix to enable
I dont understand a shit what they talking about at github about that
Maybe i need downgrade my kodi so i get it back to work again. When we can wait a fix for that? Isnt that problem is at kodi side?
