(2018-06-28, 14:38)Milhouse Wrote: [ -> ] (2018-06-27, 11:50)Jezze Wrote: [ -> ]Im not sure if i have banned addon but that is the only way how to test it. I think that problem is kodi side because all subtitle addons not working.
I'm pretty sure you do know, as it's clear as day from your log, so try testing on a "clean" kodi installation without the banned addons.
I will say there is only one error in your log which relates to service.subtitles.opensubtitles:
text:
12:45:26.355 T:139813479466752 DEBUG: ### [__main__] - action 'search' called
12:45:26.356 T:139813479466752 ERROR: EXCEPTION: XBMC is not playing any file
12:45:26.356 T:139813479466752 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.RuntimeError'>
Error Contents: XBMC is not playing any file
File "/storage/.kodi/addons/service.subtitles.opensubtitles/service.py", line 141, in <module>
item['file_original_path'] = xbmc.Player().getPlayingFile().decode('utf-8') # Full path of a playing file
RuntimeError: XBMC is not playing any file
12:45:26.356 T:139813479466752 DEBUG: onExecutionDone(17, /storage/.kodi/addons/service.subtitles.opensubtitles/service.py)
But hard to know if this is significant or not.
You said reverting to #0611 is working, are you saying it doesn't work in #0612?
I just upgraded to 0612 version and subtitle search not working, downgraded back to 0611 and works again. I have 3 computers where is have tested and every computer latest version is 0612 where aubtitle search works.
New LibreELEC.tv Leia build #0628:
Generic
(Supercedes previous build)
SHA256 Checksum:
605db520ff6fbc77541836d40640e2a64404b55f19277e5622a919f42dbd82d6
(Generic)
text:
# uname -a
Linux NUC 4.17.3 #1 SMP Thu Jun 28 21:05:08 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180628210348-#0628-g3e3cc3d [Build #0628]
# Kodi version
(18.0-ALPHA3 Git:95de5f5). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (3e3cc3d,
changelog) and tip of
XBMC master (69472d0,
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786)
- Includes latest libnfs master (fa6d63c, ahead +134)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (16a4043, +7), inputstream.rtmp (bf5351e, +1), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (481f2fa, +1), pvr.dvblink (1732e4b), pvr.dvbviewer (fccf48a, +7), pvr.filmon (b41ef25, +1), pvr.hdhomerun (29cb0df, +1), pvr.hts (f569808), pvr.iptvsimple (7db634b, +1), pvr.mediaportal.tvserver (6845fa4, +1), pvr.mythtv (c18ca9e), pvr.nextpvr (6f01a4b, +3), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv (d1aaaa9, +1), pvr.stalker (1a01bc9, +1), pvr.teleboy (0460536, +1), pvr.vbox (8244f9a, +1), pvr.vdr.vnsi (18c7474), pvr.vuplus (e2efab9, +1), pvr.wmc (ce4b47a), pvr.zattoo (baeb316, +3), vfs.libarchive (1bc1517, +1)
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2742 (perma): scripts/image: add BUILDER_NAME, BUILDER_VERSION support
- Include [env] PR:2772 (perma): linux (RPi): update to linux-4.14.52
- Include [env] PR:2788 (perma): kodi: July 2018
- Include [env] PR:2791 (perma): systemd: update to 239
- Include [env] PR:2798 (perma): linux (Generic): update to linux-4.17.3
- Include [env] PR:2799 (perma): [getedid] Add AMD support and react on used kernel
- Include [env] PR:2801 (perma): mesa: only build va tracker if using a gallium driver that uses it
- Include [env] PR:2803 (perma): debug: dependencies don't build with debug by default. use + suffix to enable
- Include [env] PR:2805 (perma): ffmpeg: install ffmpeg from ffmpeg-tools, don't include in image
- Include [pkg] PR:100 (perma): stats: Replace CPU 32/64 bit flag with GPU enumeration (service.libreelec.settings)
Build Highlights:
- Drop ffmpeg from image, rename ffmpegx to ffmpeg in ffmpeg-tools add-on
- inputstream.adaptive and pvr.next API updates
Build Details:
- LibreELEC.tv:
- configure: drop unused build options (PR:2794, 16 commits, 16 files changed)
- XBMC:
- [cmake] always build with -Wall (PR:14107, 1 commit, 1 file changed)
- filesystem: SpecialProtocol - fix possible endless recursion in URIUt (PR:14121, 1 commit, 1 file changed)
- win10: filesystem - catch possible exception (PR:14122, 1 commit, 1 file changed)
- FFmpeg: Bump to 4.0.1-Leia-Alpha3-1 (PR:14123, 1 commit, 4 files changed)
- inputstream.adaptive:
- Rework for renewal after HTTP 403 / kodi api changes (560728d)
- Version bump 2.2.24 (16a4043)
- pvr.nextpvr:
- Add implementation for GetReadStreamChunkSize() (PR:75, 3 commits, 9 files changed)
- Added: [env] PR:2801 (perma): mesa: only build va tracker if using a gallium driver that uses it
- Added: [env] PR:2805 (perma): ffmpeg: install ffmpeg from ffmpeg-tools, don't include in image
(2018-06-28, 17:27)Jezze Wrote: [ -> ]I just upgraded to 0612 version and subtitle search not working, downgraded back to 0611 and works again. I have 3 computers where is have tested and every computer latest version is 0612 where aubtitle search works.
You can try executing the following:
text:
cd /storage/.kodi/addons/service.subtitles.opensubtitles && mv addon.xml addon.xml.bak && wget -q http://ix.io/1fkM -O ./addon.xml
then restart, and see if the add-on works any better with #0612/#0628.
(2018-06-28, 23:24)Milhouse Wrote: [ -> ] (2018-06-28, 17:27)Jezze Wrote: [ -> ]I just upgraded to 0612 version and subtitle search not working, downgraded back to 0611 and works again. I have 3 computers where is have tested and every computer latest version is 0612 where aubtitle search works.
text:
Thanks for tip, i test when i wakeup. How about that podnapisi addon, not working either 0612 and newer.
Milhouse any guidance on what might be happening here?
Even if I load live from USB the UI is like this:
(2018-06-28, 02:18)phunkyfish Wrote: [ -> ] (2018-06-28, 02:06)Milhouse Wrote: [ -> ]It's as though it were trying to display a 4K image on a 1080p display.
What are the TV specs, and what port on the PC are you using (HDMI, DP etc.)?
4K TV over HDMI
When I originally installed 8.2.5 the install screens were correct, but GPU not supported on boot as expected.
(2018-06-29, 00:33)phunkyfish Wrote: [ -> ]@Milhouse any guidance on what might be happening here?
No sorry, not a clue. It looks totally fscked. Have you tried a different cable? And/or a different HDMI port (on both TV and PC)? Are you using any sort of "Game" mode?
Maybe it's a bug in the 4.17.x kernel.
Try 4.18-rc1 (
#0627x) and see if that is any better.
Are you able to confirm if 4.14.y (#0615) looks correct (at least as far as the installer, assuming you can't get a GUI).
Posting your system (kodi
debug log (wiki) and dmesg) might be useful as you haven't mentioned what CPU/GPU you are using.
(2018-06-28, 23:28)Jezze Wrote: [ -> ]How about that podnapisi addon, not working either 0612 and newer.
Will let you know after you've tested the first add-on.
Hi, milhouse. I have a problem with this testbuilds. When I activate "Settings/Player/Videos/Adjust display refresh rate/On start/stop" and "Settings/Player/Videos/Sync playbacl to display", it don't run. I haven't this issue with Kodi Krypton.
My log is in the next direction:
http://ix.io/1fmm
Thanks in advance and sorry by my poor english.
Set up your whitelist in Settings > System > Display > Whitelist
text:
I upgraded latest build and executed that command, rebooted but still not working.
(2018-06-29, 06:15)Milhouse Wrote: [ -> ] (2018-06-29, 00:33)phunkyfish Wrote: [ -> ]@Milhouse any guidance on what might be happening here?
Try 4.18-rc1 (#0627x) and see if that is any better.
Posting your system (kodi debug log (wiki) and dmesg) might be useful as you haven't mentioned what CPU/GPU you are using.
Happy to provide the logs but I’m unsure how to do so without finishing the install. I believe SSH gets enabled when finishing it in the UI. If I boot live will I have SSH?
I have two of these devices and have tried them with new cables and different TVs. Same result.
I will try #615 this evening and see does it work.
Ross
(2018-06-29, 13:56)phunkyfish Wrote: [ -> ]Happy to provide the logs but I’m unsure how to do so without finishing the install. I believe SSH gets enabled when finishing it in the UI. If I boot live will I have SSH?
Ross
You should have Samba access on a "live" system, try uploading the latest zip file from the Logfiles samba share.
(2018-06-29, 12:43)Jezze Wrote: [ -> ] (2018-06-28, 23:24)Milhouse Wrote: [ -> ] (2018-06-28, 17:27)Jezze Wrote: [ -> ]I just upgraded to 0612 version and subtitle search not working, downgraded back to 0611 and works again. I have 3 computers where is have tested and every computer latest version is 0612 where aubtitle search works.
text:
Not sure in that case, the updated addon.xml added:
text:
<extension point="xbmc.addon.metadata">
<reuselanguageinvoker>false</reuselanguageinvoker>
</extension>
which is the recommendation if having problems with Python re-use. Ping @
peak3d?
Thank you very much. All is ok now.
New LibreELEC.tv Leia build #0629:
Generic
SHA256 Checksum:
9f206666265c17430d8d46a6187b170888e7ef56b4c7c774c43ca6e27872ddd0
(Generic)
text:
# uname -a
Linux NUC 4.17.3 #1 SMP Fri Jun 29 21:04:51 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180629210312-#0629-g3e3cc3d [Build #0629]
# Kodi version
Based on tip of
XBMC master (773ed31,
- Includes latest libnfs master (fa6d63c, ahead +1)
- Include [env] PR:2807 (perma): linux (RPi): disable IR timeout improvement on Formosa e017 receiver
Build Highlights:
- V3 GLK HDMI quirk fix
Build Details:
- XBMC:
- [Skin] add DefaultMusicSources icon (PR:14126, 1 commit, 2 files changed)
- [Estuary] Add setting to show profilename (PR:14007, 1 commit, 4 files changed)
- Estuary fixes (PR:14099, 3 commits, 3 files changed)
- [linux] windowing/gbm: plane selection rework (PR:14113, 4 commits, 7 files changed)
- Settings: GBM - hide "Display mode" setting (PR:14120, 1 commit, 1 file changed)
- Updated: [env] PR:2788 (perma): kodi: July 2018
- Updated: [env] PR:2798 (perma): linux (Generic): update to linux-4.17.3
- Added: [env] PR:2807 (perma): linux (RPi): disable IR timeout improvement on Formosa e017 receiver
