(2018-07-05, 06:54)Milhouse Wrote: [ -> ] (2018-07-05, 05:25)Aenima99x Wrote: [ -> ] (2018-07-05, 03:51)Milhouse Wrote: [ -> ]Thanks. Please do test the others, as each of the builds implements a different potential fix, and the results will be fed back to Intel.
Ok I went ahead and tested them all.
#0703b had some minor visual stutter.
#0703c had no visual stutter but seemed to be a little delayed on the audio.
#0703d and #0703e both seem to work flawless. I forgot to check top with #0703e, but with #0703d the cpu seems to be very minimal usage.
Let me know if there's any other info I can provide.
That's perfect, thanks. It would be great if anyone else with stutter could test the same, as I don't see any stutter myself on a Skykake NUC so I'm flying blind.
sorry for the delay.
#0703b worked and i did notice some minor visual slowness/stutter on certain encodes.
#0703c no stutter. audio issues on AAC encodes.
#0703d and #0703e both worked without any issues.
I just want to confirm that I am observing the same issue as TheKraut (CIR stops working after a few keypresses under any Milhouse LE testbuild from #03xx until the latest ones, until a restart).
System: Intel NUC7CJYH (Gemini) with nothing connected but network, HDMI, power. Other control methods (USB keyboard, USB IR receiver, Yatse) work.
Are there any news or indications already besides this thread maybe, or something I missed? It's quite annoying and a showstopper tbh.
(2018-07-05, 05:25)Aenima99x Wrote: [ -> ]#0703b had some minor visual stutter.
(2018-07-05, 08:29)lwrcase Wrote: [ -> ]sorry for the delay.
Thanks again. One last request - in order to try and understand the reported audio issues, would it be possible for you both to re-test #0703c with debug logging enabled, then reproduce the audio issues and upload your debug log?
(2018-07-05, 13:42)coolie Wrote: [ -> ][...]
Nothing I've heard of, except some people over
LE forums confirming the issue for the NUC7C/P series.
Best option is still something @
HiassofT suggested a few weeks ago: File a bug report with some major distro (e.g., Ubuntu), so that they can/will hopefully fix it and LE guys can then backport/merge it.
With kodi leia iptv simple client wont start everytime at start. Need disable and enable addon and then it loads channels. Should i post debug log here or contact to addon developer?
A debug log here should be OK.
(2018-07-05, 22:35)Milhouse Wrote: [ -> ]A debug log here should be OK.
I just wondering if that wait network on boot may fix that. Need test that tomorrow and if not, ill give degub log.
New LibreELEC.tv Leia build #0705:
Generic
(Supercedes previous build)
SHA256 Checksum:
a8f9fd2058223504927c4456d0f1adb4eee6dbd48f2e0aab405bc37655fff1d8
(Generic)
text:
# uname -a
Linux NUC 4.17.4 #1 SMP Thu Jul 5 21:41:18 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180705213937-#0705-g60ee116 [Build #0705]
# Kodi version
(18.0-ALPHA3 Git:5014160). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (60ee116,
changelog) and tip of
XBMC master (b5230a8,
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786)
- Includes latest libnfs master (37d4980, ahead +3)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (aa6c3f4, +8), inputstream.rtmp (bf5351e, +1), peripheral.joystick (6312745), pvr.argustv (37a3a76), pvr.demo (481f2fa, +1), pvr.dvblink (c66203b, +1), pvr.dvbviewer (89344b4, +9), pvr.filmon (93ae10d, +2), pvr.hdhomerun (ced70bd, +2), pvr.hts (83451d3, +2), pvr.iptvsimple (55637c8, +3), pvr.mediaportal.tvserver (6439be6, +2), pvr.mythtv (c4d8899, +5), pvr.nextpvr (6f0515b, +4), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv (32d4b66, +2), pvr.stalker (6026419, +2), pvr.teleboy (0460536, +1), pvr.vbox (48a1ac1, +3), pvr.vdr.vnsi (18c7474), pvr.vuplus (75179a3, +2), pvr.wmc (ec652db, +1), pvr.zattoo (baeb316, +3), vfs.libarchive (1bc1517, +1)
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2742 (perma): scripts/image: add BUILDER_NAME, BUILDER_VERSION support
- Include [env] PR:2772 (perma): linux (RPi): update to linux-4.14.52
- Include [env] PR:2788 (perma): kodi: July 2018
- Include [env] PR:2791 (perma): systemd: update to 239
- Include [env] PR:2798 (perma): linux (Generic): update to linux-4.17.4
- Include [env] PR:2799 (perma): [getedid] Add AMD support and react on used kernel
- Include [env] PR:2803 (perma): debug: dependencies don't build with debug by default. use + suffix to enable
- Include [env] PR:2805 (perma): ffmpeg: install ffmpeg from ffmpeg-tools, don't include in image
- Include [env] PR:2807 (perma): linux (RPi): disable IR timeout improvement on Formosa e017 receiver
- Include [pkg] PR:10 (perma): Add new ids (RTL8812AU)
- Include [pkg] PR:100 (perma): stats: Replace CPU 32/64 bit flag with GPU enumeration (service.libreelec.settings)
- Include [pkg] PR:101 (perma): remove all attempts to open/close the busydialog which is now verboten (service.libreelec.settings)
- Include [pkg] PR:14137 (perma): addondb: avoid constraint violation
Build Highlights:
- VideoPlayer: fix c/p error in GetRGBYuvCoefs for BT2020
- VideoPlayer: vaapi - fix potential segfault if deinterlace method is active
- Revert cause of crash in #0703
Build Details:
- LibreELEC.tv:
- retroplayer updates (PR:2810, 8 commits, 135 files changed)
- sapphire: fix build (PR:2811, 1 commit, 1 file changed)
- XBMC:
- VideoPlayer: fix c/p error in GetRGBYuvCoefs for BT2020 (PR:14142, 1 commit, 1 file changed)
- VideoPlayer: fix switching to resample method (PR:14141, 1 commit, 2 files changed)
- display resolutions: drop iScreen (PR:14140, 1 commit, 31 files changed)
- VideoPlayer: vaapi - fix potential segfault if deinterlace method is (PR:14145, 1 commit, 3 files changed)
- Revert "[gui][pvr][fix] Prevent the modification of the provider list while using its iterator." (PR:14147, 1 commit, 2 files changed)
- [Estuary] fix mono font (PR:14150, 1 commit, 1 file changed)
- display resolutions: fix after 6aaa0fa013518053105ee55da37af430b7534579 (PR:14151, 1 commit, 5 files changed)
- win10: update python package with a small fix in uwp part (PR:14153, 2 commits, 4 files changed)
- Prevent Basecontainer to scroll animated after reset (PR:14148, 1 commit, 1 file changed)
- inputstream.adaptive:
- [MPD] check MPS::type==dynamic for LIVE streams (aa6c3f4)
- pvr.iptvsimple:
- Add support for #EXT-X-PLAYLIST-TYPE in M3U (PR:189, 1 commit, 4 files changed)
- Updated: [env] PR:2788 (perma): kodi: July 2018
- Updated: [pkg] PR:100 (perma): stats: Replace CPU 32/64 bit flag with GPU enumeration (service.libreelec.settings)
- Added: [pkg] PR:101 (perma): remove all attempts to open/close the busydialog which is now verboten (service.libreelec.settings)
(2018-07-04, 12:40)fritsch Wrote: [ -> ] (2018-07-04, 09:48)Pienoet Wrote: [ -> ] (2018-07-04, 08:26)fritsch Wrote: [ -> ] Please provide a crashlog with the current nightly version. In your log everything gets stuck including the audio sink. Edit: And please reproduce with a recording, not with tvheadend, thx.
@fritsch i reproduced with a recording.
I can't reproduce with #703 cause kodi is crashing till safe mode.
crashlog is from #702
Here is the crash_log
https://github.com/xbmc/xbmc/pull/14145
fritsch @
Milhouse #705 kodi is still crashing when changing to vaapi deinterlace.
I don't know if this pr is related to my issue but it is merged in #705
I reproduced with a recording.
crashlog
(2018-07-05, 23:48)Pienoet Wrote: [ -> ] (2018-07-04, 12:40)fritsch Wrote: [ -> ] (2018-07-04, 09:48)Pienoet Wrote: [ -> ]@fritsch i reproduced with a recording.
@fritsch @Milhouse #705 kodi is still crashing when changing to vaapi deinterlace.
crashlog
Nice - now crashes at the other end of the chain.
(2018-07-06, 08:33)fritsch Wrote: [ -> ] (2018-07-05, 23:48)Pienoet Wrote: [ -> ] (2018-07-04, 12:40)fritsch Wrote: [ -> ] https://github.com/xbmc/xbmc/pull/14145
crashlog
That’s sad if needed i can provide more logs when i’m home.
(2018-07-06, 11:40)Pienoet Wrote: [ -> ] (2018-07-06, 08:33)fritsch Wrote: [ -> ] (2018-07-05, 23:48)Pienoet Wrote: [ -> ]@fritsch @Milhouse #705 kodi is still crashing when changing to vaapi deinterlace.
crashlog
Seems you are the only user of this feature ... not sure if @
FernetMenta wants to fix it or just plain remove it :-)
(2018-07-06, 12:08)fritsch Wrote: [ -> ] (2018-07-06, 11:40)Pienoet Wrote: [ -> ] (2018-07-06, 08:33)fritsch Wrote: [ -> ] Nice - now crashes at the other end of the chain.
Seems you are the only user of this feature ... not sure if @FernetMenta wants to fix it or just plain remove it :-)
Let’s hope for a fix otherwise remove indeed
Thx I sent a PR.
Edit: No crash here, also no error in log, but screen is entirely black in that method. Same btw. for BOB which takes the same path (sse4 copy + gl render).
