(2018-07-11, 19:13)TheKraut Wrote: [ -> ] (2018-07-08, 20:49)HiassofT Wrote: [ -> ]OK, then go back to plan A: test with an Ubuntu 16.04 install and if the IR receiver dies there as well with the newer BIOSes report it to Ubuntu. If it's indeed a BIOS issue they should be able to put a bit more pressure on Intel than a few forum users that can easily be ignored.
Well, it appears that after posting the fact of Ubuntu certification to the Intel Community, they have reconsidered. I've given them some config info - hopefully, they'll pass it on to an engineering team.
Thanks for the update! Fingers crossed they find a solution and this gets fixed soon.
so long,
Hias
(2018-07-11, 18:04)Milhouse Wrote: [ -> ] (2018-07-09, 00:09)Milhouse Wrote: [ -> ]@lwrcase, @Aenima99x (for reference), maybe @matt Devo (and anyone else with stutter):
This is the bug I opened for the stuttering issue: https://bugs.freedesktop.org/show_bug.cgi?id=107111
Chris Wilson has been incredibly helpful. He's proposed a 5th (and hopefully final) fix for the stuttering, and would like one last check in case of a regression before (presumably) proceeding upstream.
Could you test build #0708b: Generic
#0708b is the same as #0708 but includes this latest anti-stuttering fix, so please report if the stutter issue is now resolved, or if there are any continuing issues (or new issues not present in #0708).
Many thanks!
@lwrcase (or anyone else with stutter, other than @matt Devo) are you able to verify #0708b is OK? The current revert patch will be dropped from #0711 tonight so it's important there's an upstream patch to replace it.
sorry for the delay here. been dealing with AC issues in this heatwave.
#0708b is good here.
(2018-07-10, 04:47)Matt Devo Wrote: [ -> ]708b seems good here
(2018-07-11, 21:52)lwrcase Wrote: [ -> ]#0708b is good here.
Thanks both - I'll replace the watiboost revert with the updated patch from #0708b in future builds (including #0711). Please post if you notice any further issues.
New LibreELEC.tv Leia build #0711:
Generic
(Supercedes previous build)
SHA256 Checksum:
70bedad5c9301af6fd3b64aa671957f0914442d4e673ea5cb674d26db6e100ae
(Generic)
text:
# uname -a
Linux NUC 4.17.5 #1 SMP Wed Jul 11 22:01:46 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180711220031-#0711-g15061ee [Build #0711]
# Kodi version
(18.0-ALPHA3 Git:5014160). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (15061ee,
changelog) and tip of
XBMC master (b88fe4c,
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786)
- Includes latest libnfs master (3ba7c53, ahead +4)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (faf22f1, +9), inputstream.rtmp (bf5351e, +1), peripheral.joystick (dbdeded, +2), pvr.argustv (37a3a76), pvr.demo (481f2fa, +1), pvr.dvblink (c66203b, +1), pvr.dvbviewer (75e2447, +10), pvr.filmon (93ae10d, +2), pvr.hdhomerun (ced70bd, +2), pvr.hts (306fac5, +3), pvr.iptvsimple (55637c8, +3), pvr.mediaportal.tvserver (6439be6, +2), pvr.mythtv (c4d8899, +5), pvr.nextpvr (6f0515b, +4), pvr.njoy (30aae48, +1), pvr.octonet (1e44819), pvr.pctv (32d4b66, +2), pvr.stalker (6026419, +2), pvr.teleboy (0460536, +1), pvr.vbox (12e1304, +4), pvr.vdr.vnsi (18c7474), pvr.vuplus (75179a3, +2), pvr.wmc (ec652db, +1), pvr.zattoo (12134c8, +4), vfs.libarchive (1bc1517, +1)
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2772 (perma): linux (RPi): update to linux-4.14.54
- Include [env] PR:2788 (perma): kodi: July 2018
- Include [env] PR:2791 (perma): systemd: update to 239
- Include [env] PR:2798 (perma): linux (Generic): update to linux-4.17.5
- Include [env] PR:2799 (perma): [getedid] Add AMD support and react on used kernel
- Include [env] PR:2803 (perma): debug: dependencies don't build with debug by default. use + suffix to enable
- Include [env] PR:2816 (perma): bluez: bump version to 5.50
- Include [env] PR:2818 (perma): ConnMan: use UseGatewaysAsTimeservers option
- Include [env] PR:2822 (perma): graphics: update libva/libva-utils/intel-vaapi-driver to 2.2.0, mesa to 18.1.3
- Include [pkg] PR:10 (perma): Add new ids (RTL8812AU)
- Include [pkg] PR:14137 (perma): addondb: avoid constraint violation
- Include [pkg] PR:14160 (perma): [JSON]Faster access to music library
Build Highlights:
- graphics: update libva/libva-utils/intel-vaapi-driver to 2.2.0, mesa to 18.1.3
- Replace waitboost revert with upstream interactive RPS mode fix (as tested in #0708b)
Build Details:
- LibreELEC.tv:
- retroplayer addons (PR:2817, 22 commits, 22 files changed)
- XBMC:
- Fix Install from zip from addon view (PR:14166, 1 commit, 4 files changed)
- Updated: [env] PR:2798 (perma): linux (Generic): update to linux-4.17.5
- Added: [env] PR:2822 (perma): graphics: update libva/libva-utils/intel-vaapi-driver to 2.2.0, mesa to 18.1.3
New LibreELEC.tv Leia build #0712:
Generic
SHA256 Checksum:
01a73bdb07776469b8472d73d2db668190880af54f9e6d83c5583fef1e1e5b01
(Generic)
text:
# uname -a
Linux NUC 4.17.6 #1 SMP Thu Jul 12 21:04:45 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180712210327-#0712-gb10020d [Build #0712]
# Kodi version
Based on tip of
LibreELEC.tv master (b10020d,
XBMC master (65f9261,
- Includes latest libnfs master (322148b, ahead +6)
Build Highlights:
- New 4.17.6 kernel
- AE: fix sync for transcoding
Build Details:
- LibreELEC.tv:
- snapcast: update to 0.15.0 (PR:2716, 8 commits, 11 files changed)
- ConnMan: use UseGatewaysAsTimeservers option (PR:2818, 1 commit, 4 files changed)
- videolan: fix download url for various videolan packages (PR:2823, 4 commits, 4 files changed)
- XBMC:
- AE: fix sync for transcoding (PR:14173, 1 commit, 1 file changed)
- Fix android resolution selection (PR:14172, 1 commit, 1 file changed)
- libnfs:
- libnfs.c: include <time.h> in libnfs.c (PR:263, 1 commit, 1 file changed)
- fix bug in nfsv4 opendir where it stripped off the final path component (21e208b)
- Merge branch 'master' of github.comahlberg/libnfs (2b93fcf)
- Updated: [pkg] PR:14160 (perma): [JSON]Faster access to music library
I've just updated to latest build and my TV isn't liking the video output from Kodi of SD DVB-S live TV channels. I get unsupported signal error and no video. HD channels are fine. I was on a late May build before this and was ok. Is this something simple I'm missing here or do you need logs?
Always logs, and if possible in backwards through releases to find last working build.
This will help get quicker results for you.
Refresh my memory. I am experiencing issues in live TV with Tvheadend where there will be split seconds of black screen that happens all the time during shows. Not sure if that is considered stuttering as stated in some other posts. I looked back through the thread some but could not find if this was an issue with LibreELEC or Tvheadend.
Music visualisation = crash
Normal or not fixable FOAD?
(2018-07-14, 03:03)badaas Wrote: [ -> ]Music visualisation = crash
Probably just the usual shit and the add-on needs a rebuild. Can't really say for sure without a crashlog, or knowing when it started to crash.
New LibreELEC.tv Leia build #0713:
Generic
SHA256 Checksum:
0d716eeab542978a753229ef9677bd1fb27c012fccc40d6b72b1d92d4234d616
(Generic)
text:
# uname -a
Linux NUC 4.17.6 #1 SMP Sat Jul 14 01:44:49 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180714014332-#0713-gb10020d [Build #0713]
# Kodi version
Based on tip of
XBMC master (b7583e3,
- Include [env] PR:2822 (perma): graphics: update libva/libva-utils/intel-vaapi-driver to 2.2.0, mesa to 18.1.4
Build Highlights:
- Keep protocol options in path databases
- AE: fix handling sink errors in suspend state
- Update mesa-18.1.4
Build Details:
- XBMC:
- [Android] Remove AudioTrack ENFORCE flag / set LegacyStreamType (PR:14174, 1 commit, 1 file changed)
- [Android] Select android audiodecoder by whitelist (PR:14175, 1 commit, 1 file changed)
- Keep protocol options in path databases (PR:14168, 3 commits, 4 files changed)
- [cleanup] silence useless cast warnings (PR:14177, 28 commits, 104 files changed)
- AE: fix handling sink errors in suspend state (PR:14179, 1 commit, 1 file changed)
- X11: egl - make sure that we block in swapBuffers (PR:14178, 1 commit, 2 files changed)
- Updated: [env] PR:2822 (perma): graphics: update libva/libva-utils/intel-vaapi-driver to 2.2.0, mesa to 18.1.4
(2018-07-14, 03:06)Milhouse Wrote: [ -> ] (2018-07-14, 03:03)badaas Wrote: [ -> ]Music visualisation = crash
Usual shit is the response I was hoping for.
Hopefully Kodi gets buried by some NXG none generic dedicated softwares soon that isn't reliant on media focused on piracy.
Keep up the good blogs!
tldr;
Media player ftw
(2018-07-14, 03:18)badaas Wrote: [ -> ] (2018-07-14, 03:06)Milhouse Wrote: [ -> ] (2018-07-14, 03:03)badaas Wrote: [ -> ]Music visualisation = crash
tldr;
Media player ftw
Dude these people do this work for free based on passions or their desire.
You have ZERO right to belittle this project or the people who pour their heart and soles into Kodi.
If you want stable the get off bleeding edge so you can have your needs satisfied but if you want to stay on the edge expect bugs and be humble people are helping when they have time.
TLDR
You’re a dick.
Just ignore those folks ... in germany we say: perhap he has shitten badly (or not :-))
Did not notice any black flashes on live TV this morning on build 0713.
