(2018-08-25, 16:23)phunkyfish Wrote: [ -> ] (2018-08-25, 10:40)fritsch Wrote: [ -> ]There is no xvid video playing in your log, but 720x404 video playing at 3840x2160@60 hz. Does it also stutter if you change the resolution before hand to 1920x1080?
Hah, I can’t believe that was it. Thanks Fritsch!
Could you please play it again a bit longer with 3840x2160 with debug loggin enabled? Then after 2 minutes press some button on the keyboard and enable the OSD? We want to understand what happens, e.g. what is stuck / too slow.
(2018-08-25, 11:13)dr88dr88 Wrote: [ -> ]My remote stopped working properly in version #0819 and higher.
It is a remote with a air mouse and on #0819 and higher the mouse pointer show up on the middel of the screen when it is disabled on the remote.
Every time I move the remote the navigation tries to move to the mouse pointer on the middel of the screen.
I have a Beworth T3 remote from https://www.aliexpress.com/item/Newest-F...4c4dIXi4FE
Could you please post the outputs of
dmesg | paste
cat /proc/bus/input/devices | paste
both from a working and a non-working build?
so long,
Hias
Since some version, my CEC does not terminate the connection properly. If i go with my Nuc or Respberry pi to shutdown. CEC does not terminate the connection. My TV thinks, Kodi is also on. The Problem is not so old. With an Official Libreelec 9 build, i have no problems.
(2018-08-25, 20:34)Mister XY Wrote: [ -> ]Since some version, my CEC does not terminate the connection properly. If i go with my Nuc or Respberry pi to shutdown. CEC does not terminate the connection. My TV thinks, Kodi is also on. The Problem is not so old. With an Official Libreelec 9 build, i have no problems.
That problem seems to have started with #0818, can you confirm that #0817 is working, and #0818 is not? We haven't identified the cause yet, but good to know it's not RPi specific (if it's the same issue).
(2018-08-25, 20:42)Milhouse Wrote: [ -> ] (2018-08-25, 20:34)Mister XY Wrote: [ -> ]Since some version, my CEC does not terminate the connection properly. If i go with my Nuc or Respberry pi to shutdown. CEC does not terminate the connection. My TV thinks, Kodi is also on. The Problem is not so old. With an Official Libreelec 9 build, i have no problems.
On Nuc i can confirm that. On 0817 its ok but in 0818 not. Now i will tested this version on rpi.
edit: same on rpi. 0817 terminate the connection properly and 0818 not.
Hello,
i hope anybody can help me without a log:
When I'm in the main menu and click on for example Kids (created source for animated Movies), I first see all the sources I've created, so movies, kids, tv-shows... So I do not land immediately in the library view.
With Krypton it ran flawlessly. I´m using the Skin Estuary Mod V2 and Aeon Knox Silvo, but have the same issue on both skins
I go to main menu Customize in the skin settings
Then I go to the first menu item and click on Choose an entry for this menu
Then I click on video library
Then on sources
Here I select the source
and last but not least I go to "Create a menu entry here"
that's it, as soon as i go to the main menu on this newly created entry for example movies, then just the folders of my sources appear and that double and triple, even though i have only one folder for each source
This is the created command which works on Kodi 17 but not on 18
ActivateWindow(Videos,special://profile/addon_data/script.skinshortcuts/1.xsp, return
The landing Page is here
https://picload.org/view/dlociwgw/kodi.jpg.html
Everytime i tried to configure the MainMenu in the Skin Settings it creates a new Source Folder
I´m desperate...
(2018-08-25, 21:12)Aquila Wrote: [ -> ]With Krypton it ran flawlessly. I´m using the Skin Estuary Mod V2 and Aeon Knox Silvo, but have the same issue on both skins
You're using specific features of a third-party skin which may need updating to support the latest Kodi 18 Beta 2, so I'd suggest contacting the skin authors for assistance.
Between builds #0817 and #0818, I can no longer timeshift while watching LiveTV (MythTV PVR plugin).
From build #0817 - I can pause Live TV, rewind, skip forward, etc.
From build #0818 - the "pause" icon no longer appears, and I can no longer pause, rewind, or fast forward.
The only change from #0817 to #0818 that seems related is "VideoPlayer: fix player states regarding time", but this looks to have been tested, so I'm not sure why timeshift is no longer working for me.
Can anyone please help?
(2018-08-25, 22:58)dapharsyde Wrote: [ -> ]Between builds #0817 and #0818, I can no longer timeshift while watching LiveTV (MythTV PVR plugin).
Which pvr add-on?
EDIT: nvm
For that, the add-on needs to implement the GetStreamTimes API function (properly).
(2018-08-25, 22:59)ksooo Wrote: [ -> ]Which pvr add-on?
EDIT: nvm
Thanks for the pointer - I will try to contact @
janbar and see if he can update the plugin.
New LibreELEC.tv Leia build #0825:
Generic
(Supercedes previous build)
SHA256 Checksum:
46ded6157d9f4f0baa25b6bee6be4e4d94ca6d79e1b1c928f300aac8407ed56f
(Generic)
text:
# uname -a
Linux NUC 4.18.5 #1 SMP Sun Aug 26 00:47:45 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180826004411-#0825-g198df11 [Build #0825]
# Kodi version
(18.0-BETA1 Git:1cbdec1a78a35985d8959a3f43dbb3c5b0db6f7f). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (198df11,
changelog) and tip of
XBMC master (c321049,
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786)
- Includes latest libnfs master (322148b, ahead +6)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (430c440), inputstream.rtmp (0cc2da1), peripheral.joystick (08e4a1a), peripheral.xarcade (91567dd), pvr.argustv (c57a5c4, +1), pvr.demo (481f2fa), pvr.dvblink (72ef8a0, +1), pvr.dvbviewer (b63e867, +1), pvr.filmon (93ae10d), pvr.hdhomerun (7a607c9, +1), pvr.hts (7c7c6ce, +1), pvr.iptvsimple (e8effad, +1), pvr.mediaportal.tvserver (cc3eaf0, +5), pvr.mythtv (e61f47c), pvr.nextpvr (441edde, +1), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (9d95bab, +1), pvr.stalker (2eb66d1, +1), pvr.teleboy (0f3ccfd, +2), pvr.vbox (40ca81f, +1), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (016a4ff, +1), pvr.wmc (292a819, +1), pvr.zattoo (12134c8), vfs.libarchive (f93a5f3, +5), vfs.sftp (e69acc9, +6)
- Include [env] b3b57d4: RPi: fix Alsa card confs for new driver on kernel 4.18
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:2872 (perma): update dvb addons
- Include [env] PR:2892 (perma): scripts/image: use maximum lzo and zstd compression level for images
- Include [env] PR:2907 (perma): config/functions: clean up recursion test
- Include [env] PR:2908 (perma): linux (Generic): update to linux-4.18.5
- Include [env] PR:2909 (perma): kodi: next (Sept || kodi bump)
- Include [env] PR:2913 (perma): linux (RPi): update to linux-4.18.4
- Include [env] PR:2915 (perma): linux: fix Module.symvers generation
- Include [env] PR:2920 (perma): mesa: update to mesa-18.1.7
- Include [env] PR:2923 (perma): linux: replace ancient rc6 decode hack with proper fix
- Include [pkg] PR:14316 (perma): [pvr][guiinfo][guilib][estuary] PVR timeshift GUI v2.
Build Highlights:
- linux: replace ancient rc6 decode hack with proper fix
- linux: Updated AMD GPU firmware with 18.30 release
- "Prefer stereo streams if user has configured 2.0 in AE" as advanced setting
- [estuary] Video OSD: Hide 'Previous' button for non-seekable streams.
- [videoplayer] Refactor some CSelectionStreams methods
Build Details:
- LibreELEC.tv:
- mkpkg: use full rev (PR:2922, 1 commit, 6 files changed)
- samba: update to samba-4.8.5 (PR:2919, 1 commit, 2 files changed)
- create_addon now also writes a summary when log writing is used. (PR:2912, 1 commit, 1 file changed)
- XBMC:
- "Prefer stereo streams if user has configured 2.0 in AE" as advanced setting (PR:14348, 1 commit, 3 files changed)
- [estuary] Video OSD: Hide 'Previous' button for non-seekable streams. (PR:14350, 1 commit, 1 file changed)
- [videoplayer] Refactor some CSelectionStreams methods. (PR:14349, 3 commits, 2 files changed)
- [settings/ios]- ensure that RES_CUSTOM is the default. Fixes the "do (PR:14352, 1 commit, 1 file changed)
- [lang][skin.estuary] updated language files from Transifex (4c78e8a)
- [lang][skin.estouchy] updated language files from Transifex (87ee5eb)
- pvr.argustv:
- [lang] updated language files from Transifex (c57a5c4)
- pvr.dvblink:
- [lang] updated language files from Transifex (72ef8a0)
- pvr.dvbviewer:
- [lang] updated language files from Transifex (b63e867)
- pvr.hdhomerun:
- [lang] updated language files from Transifex (7a607c9)
- pvr.hts:
- [lang] updated language files from Transifex (7c7c6ce)
- pvr.iptvsimple:
- [lang] updated language files from Transifex (e8effad)
- pvr.mediaportal.tvserver:
- [lang] updated language files from Transifex (cc3eaf0)
- pvr.nextpvr:
- [lang] updated language files from Transifex (441edde)
- pvr.pctv:
- [lang] updated language files from Transifex (9d95bab)
- pvr.stalker:
- [lang] updated language files from Transifex (2eb66d1)
- pvr.vbox:
- [lang] updated language files from Transifex (40ca81f)
- pvr.vuplus:
- [lang] updated language files from Transifex (016a4ff)
- pvr.wmc:
- [lang] updated language files from Transifex (292a819)
- Updated: [env] PR:2872 (perma): update dvb addons
- Updated: [env] PR:2913 (perma): linux (RPi): update to linux-4.18.4
- Added: [env] b3b57d4: RPi: fix Alsa card confs for new driver on kernel 4.18
- Added: [env] PR:2923 (perma): linux: replace ancient rc6 decode hack with proper fix
- Updated: [pkg] PR:14316 (perma): [pvr][guiinfo][guilib][estuary] PVR timeshift GUI v2.
Good morning Millhouse, my manufacturer of my Zotac has now released a bios update for my ZBOX-CI547 NANO. I thought that would clean up your bulid in conjunction with your now-used kernel. The initial resolution problems are gone now, but not my sound dropouts when playing movies. I want to show you my logs again, so maybe you can help me fix that. Thank you
Log
CrashLog
Quote:Aug 19 17:03:48 LibreELEC kernel: [drm:lspcon_wait_mode] *ERROR* LSPCON mode hasn't settled
^^ they should try again with fixing or contributing Linux kernel fix. Edit: And always use latest and greatest, e.g. his 4.18.x builds - as you most likely have to file kernel bugs yourself.
Kodi still has this weird bug: if I go to Movies/Titles and scroll the list with key pressed down, scrollspeed is too fast, looks like it goes double the speed than it should. But when I go to TV Shows/Titles and scroll the list, speed is normal. Using just keyboard to test this. Same problem also if I go to my movies folder via Videos/Files. And again it's only movies folder that has this effect. Changing view type has no effect to this.
So what causes this?
