(2018-09-03, 19:22)wishyou Wrote: [ -> ]Hi @Milhouse
Just a quick question, how does the alpha-builds related to your builds now, are they similar?
I.e. can I switch from a mid-august build to the alpha-release without issues?
Wish
At this time the latest 8.90.004 alpha build is fairly close to the latest test build, although the Alpha build uses an older kernel (still 4.18.y though, so that shouldn't make to much difference) and lacks various other changes/updates present in these test builds. Alpha/Beta builds will always trail these test builds by varying amounts, from days to weeks. Obviously as time passes between an alpha (or beta) build and the latest test build, the number of differences (mainly Kodi bug fixes, package and kernel updates) steadily increases until most of those changes appear in the next alpha/beta build at which point the differences reduce (ideally to zero, but that will probably only happen once I stop creating test builds).
I don't actively maintain a list of the differences between the latest official Alpha/Beta release and these test builds - if you need a specific feature you could probably determine from GitHub whether it is present in the Alpha/Beta, or not.
Edit: You can switch from these test builds to the official release, the only issue might be wth PVR add-ons as you'll then be relying on the online repository for PVR add-on updates (latest are always included in my builds) and hopefully those are now fairly recent.
(2018-09-03, 20:31)Milhouse Wrote: [ -> ]At this time the latest 8.90.004 alpha build is fairly close to the latest test build, although the Alpha build uses an older kernel (still 4.18.y though, so that shouldn't make to much difference) and lacks various other changes/updates present in these test builds. Alpha/Beta builds will always trail these test builds by varying amounts, from days to weeks. Obviously as time passes between an alpha (or beta) build and the latest test build, the number of differences (mainly Kodi bug fixes, package and kernel updates) steadily increases until most of those changes appear in the next alpha/beta build at which point the differences reduce (ideally to zero, but that will probably only happen once I stop creating test builds).
Great, thanks for the detailed info!
I don't use PVR addons, but I'm mainly concerned about database/library versions. I guess that is pretty stable now that Kodi 18 i closing in towards a beta.
Wish
New LibreELEC.tv Leia build #0903:
Generic
(Supercedes previous build)
SHA256 Checksum:
572ff4480b916400331379ff3d35b8682af555abacaed8b43df4fde39fc2e4d5
(Generic)
text:
# uname -a
Linux NUC 4.18.5 #1 SMP Mon Sep 3 21:04:17 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180903210243-#0903-g1725942 [Build #0903]
# Kodi version
(18.0-BETA2 Git:a294eb4). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (1725942,
changelog) and tip of
XBMC master (a294eb4,
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (8adc786)
- Includes latest libnfs master (322148b, ahead +6)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (997abf6, +1), inputstream.rtmp (0cc2da1), peripheral.joystick (08e4a1a), peripheral.xarcade (91567dd), pvr.argustv (c57a5c4), pvr.demo (481f2fa), pvr.dvblink (72ef8a0), pvr.dvbviewer (b63e867), pvr.filmon (93ae10d), pvr.hdhomerun (7a607c9), pvr.hts (7c7c6ce), pvr.iptvsimple (e8effad), pvr.mediaportal.tvserver (cc3eaf0), pvr.mythtv (22aa23b, +14), pvr.nextpvr (441edde), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (9d95bab), pvr.stalker (2eb66d1), pvr.teleboy (0f3ccfd), pvr.vbox (40ca81f), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (016a4ff), pvr.wmc (292a819), pvr.zattoo (8de69a1, +2), vfs.libarchive (f93a5f3), vfs.sftp (e69acc9)
- Exclude [env] kodi-995.01-pr14354_wrapper_toolchain_nm.patch: merged upstream
- Include [env] b3b57d4: RPi: fix Alsa card confs for new driver on kernel 4.18
- Include [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:2904 (perma): zlib: add neon optimizations
- Include [env] PR:2908 (perma): linux (Generic): update to linux-4.18.5
- Include [env] PR:2913 (perma): linux (RPi): update to linux-4.18.5
- Include [env] PR:2916 (perma): ffmpegx and tvh
- Include [env] PR:2931 (perma): ffmpeg: cleanup
- Include [env] PR:2943 (perma): scripts/get_archive, tools-distro-tool: fix wget redirection issue when wget running in background
Build Highlights:
- [PVR] PVRChannelGroup::ResetChannelnumberCache - fixes trac#18009
- [Estuary] Music OSD: Remove 'Previous' button for non-seekable stream
Build Details:
- XBMC:
- guilib: do not log empty compile info of pixel shaders (PR:14385, 1 commit, 1 file changed)
- [PVR] PVRChannelGroup::ResetChannelnumberCache - fixes trac#18009 (PR:14378, 2 commits, 3 files changed)
- [Estuary] Music OSD: Remove 'Previous' button for non-seekable stream (PR:14381, 1 commit, 1 file changed)
- [cleanup] silence class memaccess warning (PR:14370, 2 commits, 2 files changed)
- pvr.mythtv:
(2018-08-29, 09:39)dr88dr88 Wrote: [ -> ] (2018-08-28, 15:16)HiassofT Wrote: [ -> ] (2018-08-28, 15:01)dr88dr88 Wrote: [ -> ]Below is the requested output:
working version
http://ix.io/1lr6
http://ix.io/1lr7
non working version
http://ix.io/1lr8
http://ix.io/1lr9
The output is a bit odd, you seem to have 2 air mice / remotes / wireless keyboards connected: SAGE SAGE AirMouse (USB Vendor=400c Product=107a) and FREEWAY TECHNOLOGY RFIC-MOUSE (USB Vendor=0c45 Product=5012).
Could you connect only the problematic device so we know where to look at and post dmesg, cat /proc/bus/input/devices and in addition to that "lsusb" output on a non-working build?
so long,
Hias
Below the requested new logs on a non functional build with all my other input devices disconnected:
http://ix.io/1luL
http://ix.io/1luM
http://ix.io/1luN
Thanks for the logs!
One difference on newer builds is that there are now separate input devices for "Keyboard", "Consumer Control", "System Control" from your airmouse (that's due to an upstream kernel change).
But the mouse input device already was a separate input device in your older (working) setup. So I have no idea what's happening here or what could be causing issues. Maybe someone else has some clue.
so long,
Hias
(2018-09-04, 11:06)HiassofT Wrote: [ -> ] (2018-08-29, 09:39)dr88dr88 Wrote: [ -> ] (2018-08-28, 15:16)HiassofT Wrote: [ -> ]The output is a bit odd, you seem to have 2 air mice / remotes / wireless keyboards connected: SAGE SAGE AirMouse (USB Vendor=400c Product=107a) and FREEWAY TECHNOLOGY RFIC-MOUSE (USB Vendor=0c45 Product=5012).
so long,
Hias
http://ix.io/1luL
http://ix.io/1luM
http://ix.io/1luN
so long,
Hias
The problem is that Kodi see it now as an active mouse all the time even if the mouse is deactivated on the remote. As soon as I try to move the remote the mouse pointer is activated in the middle of the screen without any movement of the mouse pointer.
(2018-09-04, 17:33)mglae Wrote: [ -> ] (2018-09-03, 02:26)Milhouse Wrote: [ -> ]Weekly Linux 4.19-rc2 build #0902x: Generic
"404 Not Found"?
Thanks - will fix that. Looks like I'll need to upload a new 4.19-rc2 build.
New LibreELEC.tv Leia build #0904:
Generic
SHA256 Checksum:
001347f2bbc990acf735b434452e6251a5e657df03edbd6510957d0e9e1e3d0a
(Generic)
text:
# uname -a
Linux NUC 4.18.5 #1 SMP Tue Sep 4 21:05:39 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180904210311-#0904-g1725942 [Build #0904]
# Kodi version
(18.0-BETA2 Git:5d7e1db). Platform: Linux x86 64-bit
Based on tip of
XBMC master (5d7e1db,
- Includes latest libnfs master (d86d5d1, ahead +7)
- Includes latest addons: inputstream.adaptive (78b48a1, +3), inputstream.rtmp (0cc2da1), peripheral.joystick (08e4a1a), peripheral.xarcade (91567dd), pvr.argustv (c57a5c4), pvr.demo (481f2fa), pvr.dvblink (72ef8a0), pvr.dvbviewer (b63e867), pvr.filmon (93ae10d), pvr.hdhomerun (7a607c9), pvr.hts (7c7c6ce), pvr.iptvsimple (e8effad), pvr.mediaportal.tvserver (cc3eaf0), pvr.mythtv (22aa23b, +14), pvr.nextpvr (441edde), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (9d95bab), pvr.stalker (2eb66d1), pvr.teleboy (0f3ccfd), pvr.vbox (40ca81f), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (016a4ff), pvr.wmc (292a819), pvr.zattoo (8de69a1, +2), vfs.libarchive (f93a5f3), vfs.sftp (e69acc9)
Build Highlights:
- [PVR] Simple timeshift OSD (optional)
- GLES logging cleanup and unused extension removal
Build Details:
- XBMC:
- [PVR] Simple timeshift OSD (optional). (PR:14386, 1 commit, 5 files changed)
- GLES logging cleanup and unused extension removal (PR:14384, 3 commits, 2 files changed)
- libnfs:
- README: NFSv4 actually works now, update README to reflect this (d86d5d1)
- inputstream.adaptive:
- Add license_flags / persistent_storage (a33fec8)
- Version bump 2.2.26 (78b48a1)
Weekly Linux 4.19-rc2 build #0904x:
Generic
Packages disabled/not included:
text:
DVB Driver Addons (CrazyCat incompatible with 4.19-rc)
Known issues:
text:
RTL8188EU, RTL8192CU/DU/EU, RTL8812AU: driver changes untested
xf86-video-nvidia: driver changes untested
r8169 (Revo 3700/Atom) network interface negotiates 10Mbps/half duplex when resuming from suspend
(2018-09-04, 11:42)dr88dr88 Wrote: [ -> ] (2018-09-04, 11:06)HiassofT Wrote: [ -> ] (2018-08-29, 09:39)dr88dr88 Wrote: [ -> ] Below the requested new logs on a non functional build with all my other input devices disconnected:
http://ix.io/1luL
http://ix.io/1luM
http://ix.io/1luN
so long,
Hias
I have the same problem the remote mouse is unusable.
(2018-09-05, 03:51)InNursery Wrote: [ -> ] (2018-09-04, 11:42)dr88dr88 Wrote: [ -> ] (2018-09-04, 11:06)HiassofT Wrote: [ -> ]Thanks for the logs!
so long,
Hias
Milhouse could you create a build with this kernel patch
https://patchwork.kernel.org/patch/10587369/ added? It's a likely candidate for fixing the mouse issues reported by @
dr88dr88 and @
InNursery
so long,
Hias
from couple of version is problem with GUI - some element stay in backgroud example after switch channels, or download subtitles in movies.
or toggle screen betwean main menu and full screen
New LibreELEC.tv Leia build #0905:
Generic
SHA256 Checksum:
f49b470eb5084d6586094c9c871d3df865fd698a37d0c5e60370c178d79dd8ef
(Generic)
text:
# uname -a
Linux NUC 4.18.6 #1 SMP Wed Sep 5 21:25:03 BST 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20180905210707-#0905-ga3c73c3 [Build #0905]
# Kodi version
(18.0-BETA2 Git:b69ac07). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (a3c73c3,
XBMC master (b69ac07,
- Includes latest addons: inputstream.adaptive (78b48a1, +3), inputstream.rtmp (0cc2da1), peripheral.joystick (08e4a1a), peripheral.xarcade (91567dd), pvr.argustv (c57a5c4), pvr.demo (481f2fa), pvr.dvblink (72ef8a0), pvr.dvbviewer (e571cf8, +3), pvr.filmon (93ae10d), pvr.hdhomerun (7a607c9), pvr.hts (7c7c6ce), pvr.iptvsimple (e8effad), pvr.mediaportal.tvserver (cc3eaf0), pvr.mythtv (22aa23b, +14), pvr.nextpvr (441edde), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (9d95bab), pvr.stalker (2eb66d1), pvr.teleboy (0f3ccfd), pvr.vbox (40ca81f), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (016a4ff), pvr.wmc (292a819), pvr.zattoo (8de69a1, +2), vfs.libarchive (f93a5f3), vfs.sftp (e69acc9)
- Include [env] PR:2908 (perma): linux (Generic): update to linux-4.18.6
- Include [env] PR:2913 (perma): linux (RPi): update to linux-4.18.6
- Include [pkg] patch: HID: core: fix grouping by application (linux)
Build Highlights:
- New 4.18.6 kernel
- HID: core: fix grouping by application (linux)
- [PVR][Estuary] Add support for ACTION_(PREV|NEXT)_ITEM for timeshift buffer navigation
- [Estuary] studio icon fixes
Build Details:
- LibreELEC.tv:
- Inadyn: Update to 2.4 (PR:2911, 1 commit, 3 files changed)
- dotnet-runtime: update to 2.1.3 (PR:2952, 2 commits, 3 files changed)
- librespot: update to a4e0f58 (PR:2953, 2 commits, 17 files changed)
- XBMC:
- [PVR][Estuary] Add support for ACTION_(PREV|NEXT)_ITEM for timeshift buffer navigation (PR:14387, 5 commits, 17 files changed)
- [Estuary] studio icon fixes (PR:14379, 1 commit, 1 file changed)
- [windowing/osx] - fix double release of nsstring when no displayname can be determined (PR:14388, 1 commit, 1 file changed)
- pvr.dvbviewer:
- AutoTimers: Populate the series-field with the timers name (f1e966e)
- Add stream read chunk size as addon setting (15ef0a8)
- Bump version to 3.6.7 (e571cf8)
- Updated: [env] PR:2908 (perma): linux (Generic): update to linux-4.18.6
- Updated: [env] PR:2913 (perma): linux (RPi): update to linux-4.18.6
- Updated: [env] PR:2916 (perma): ffmpegx and tvh
- Added: [pkg] patch: HID: core: fix grouping by application (linux)
(2018-09-06, 00:28)piotrasd Wrote: [ -> ]from couple of version is problem with GUI - some element stay in backgroud example after switch channels, or download subtitles in movies.
Could you mention what version you are currently using, and the first version with this issue?
