Unfortunately your #1016x log with log_buf_len=16M is truncated, which isn't surprising as you waited over 15 minutes before uploading it. I'm not going to be able to progress this without a *complete log* that includes the initial boot process, plus any error.
(2018-11-09, 21:11)Milhouse Wrote: [ -> ]Unfortunately your #1016x log with log_buf_len=16M is truncated, which isn't surprising as you waited over 15 minutes before uploading it. I'm not going to be able to progress this without a *complete log* that includes the initial boot process, plus any error.
New #1016x with dmesg log_buf_len=16M | pastebinit
http://ix.io/1rqw
(2018-11-09, 21:35)supergroover Wrote: [ -> ] (2018-11-09, 21:11)Milhouse Wrote: [ -> ]Unfortunately your #1016x log with log_buf_len=16M is truncated, which isn't surprising as you waited over 15 minutes before uploading it. I'm not going to be able to progress this without a *complete log* that includes the initial boot process, plus any error.
http://ix.io/1rqw
Unfortunately that's not a complete log - it doesn't look like you've added log_buf_len=16M (if you have then you've added it to the wrong file).
New LibreELEC.tv Leia build #1109:
Generic
(Supercedes previous build)
SHA256 Checksum:
0de44ee5ba6ed0093d62c716c14eb64ac35dd3dfa6b6206d9bba7ab8d46d9d50
(Generic)
text:
# uname -a
Linux NUC 4.19.1 #1 SMP Fri Nov 9 21:04:50 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20181109210312-#1109-ge8e2816 [Build #1109]
# Kodi version
(18.0-RC1 Git:a948f99). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (e8e2816,
changelog) and tip of
XBMC master (a948f99,
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (d57d3ac, ahead +7)
- Includes latest libnfs master (6dfc87d, ahead +10)
- Includes latest p8-platform master (1eb12b1, ahead +1)
- Includes latest addons: inputstream.adaptive (0bd5159, +5), inputstream.rtmp (ce7f559), peripheral.joystick (2008fdc, +1), peripheral.xarcade (f09a0e7, +1), pvr.argustv (609a2e7, +2), pvr.demo (964686d), pvr.dvblink (47cbff0, +2), pvr.dvbviewer (a9b204e, +8), pvr.filmon (f736ab4, +2), pvr.hdhomerun (a9d7309, +1), pvr.hts (f4ea60f, +2), pvr.iptvsimple (90a8d6f, +1), pvr.mediaportal.tvserver (e4a9dae, +2), pvr.mythtv (8150695, +8), pvr.nextpvr (7e36106, +2), pvr.njoy (4467cac, +1), pvr.octonet (203f800), pvr.pctv (e28a90f, +2), pvr.stalker (a99ad5e, +2), pvr.teleboy (484db31), pvr.vbox (6ed2f63, +2), pvr.vdr.vnsi (6bbdb78), pvr.vuplus (d77458b, +2), pvr.wmc (e00c895, +2), pvr.zattoo (278d4be, +4), vfs.libarchive (6d39012), vfs.sftp (6749200)
- Include [env] compare (perma): TESTING: increase timeout to ensure OS is able to create core dump/crash log
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:3077 (perma): kodi: use project specific cputemp scripts for all projects
- Include [env] PR:3084 (perma): linux (RPi/Generic): update to linux-4.19.1
- Include [env] PR:3089 (perma): iptables: update to iptables-1.8.1
- Include [env] PR:3092 (perma): samba: update to samba-4.9.2
Build Highlights:
- pvr.zattoo: Fix segfault strlen
Build Details:
- XBMC:
- windowing/gbm: set default plane formats and use the getter methods (PR:14821, 1 commit, 3 files changed)
- windowing/gbm: use the drm render node fd for the vaapi proxy (PR:14820, 3 commits, 9 files changed)
- [cmake] fix building with internal fmt (PR:14830, 1 commit, 1 file changed)
- inputstream.adaptive:
- [WVD] Implement full body encoding (395b7b4)
- [WVD] fix placeholder offsets (0bd5159)
- pvr.mythtv:
- remove special characters in label of built in recording group (2c0289a)
- rename formattedTitle to groupingTitle (bb446c0)
- update travis.yml (8a94280)
- bump version 5.8.16 (8150695)
- pvr.zattoo:
- Fix segfault strlen (PR:30, 3 commits, 4 files changed)
- Update version and changelog (278d4be)
Weekly Linux 4.20-rc1 build #1109x:
Generic
Known issues:
text:
iptables temporarily replaced with nftables due to build issues
xf86-video-nvidia may not be working (or show garbage characters)
(2018-11-09, 17:14)supergroover Wrote: [ -> ] (2018-11-08, 19:10)jwegman Wrote: [ -> ] (2018-11-08, 15:39)jmerrilljr Wrote: [ -> ]That is a gig-ethernet switch. I guess the first thing is to get a new cable. Any other suggestions?
FYI; I'm also having the same issue in the recent builds, on a Asus Chromebox CN60, so the issue isn't isolate to @jmerrilljr or his network switch. The following keeps repeating:
I have the same "buffering" problems with a Asus Chromebox M004U with the latest builds.
same issue here, was driving me crazy until I realized it was a device/LE issue and not my network
(2018-11-11, 00:39)Matt Devo Wrote: [ -> ]same issue here, was driving me crazy until I realized it was a device/LE issue and not my network
Without two complete before/after kernel logs I'm not wasting any time on it. I won't be asking again.
New LibreELEC.tv Leia build #1110:
Generic
SHA256 Checksum:
57ed26bafca33736fdc14d3d956601f9265e05db6ba270689b03552977664b99
(Generic)
text:
# uname -a
Linux NUC 4.19.1 #1 SMP Sat Nov 10 21:04:07 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20181110210238-#1110-ge8e2816 [Build #1110]
# Kodi version
(18.0-RC1 Git:0364561). Platform: Linux x86 64-bit
Based on tip of
XBMC master (0364561,
- Includes latest addons: inputstream.adaptive (0bd5159, +5), inputstream.rtmp (ce7f559), peripheral.joystick (2008fdc, +1), peripheral.xarcade (f09a0e7, +1), pvr.argustv (609a2e7, +2), pvr.demo (964686d), pvr.dvblink (47cbff0, +2), pvr.dvbviewer (a9b204e, +8), pvr.filmon (f736ab4, +2), pvr.hdhomerun (a9d7309, +1), pvr.hts (f4ea60f, +2), pvr.iptvsimple (90a8d6f, +1), pvr.mediaportal.tvserver (e4a9dae, +2), pvr.mythtv (bf90418, +10), pvr.nextpvr (7e36106, +2), pvr.njoy (4467cac, +1), pvr.octonet (203f800), pvr.pctv (e28a90f, +2), pvr.stalker (a99ad5e, +2), pvr.teleboy (bdbd6b2, +3), pvr.vbox (6ed2f63, +2), pvr.vdr.vnsi (6bbdb78), pvr.vuplus (d77458b, +2), pvr.wmc (e00c895, +2), pvr.zattoo (8ddb060, +7), vfs.libarchive (6d39012), vfs.sftp (6749200)
Build Highlights:
- [PVR] New PVR playback setting: 'Delay mark last watched'.
Build Details:
- XBMC:
- Add missing epoll header (PR:14570, 1 commit, 1 file changed)
- [PVR] New PVR playback setting: 'Delay mark last watched'. (PR:14836, 2 commits, 7 files changed)
- [PVR] Make 'Simple Timeshift OSD' an advanced setting; remove corresponding standard setting. (PR:14840, 1 commit, 6 files changed)
- [filemanager] Fix crash due to multiple busy dialog request. (PR:14839, 1 commit, 2 files changed)
- pvr.mythtv:
- fix unusable wstring_convert for my platform ;-) (52d22cf)
- bump version 5.8.17 (bf90418)
- pvr.teleboy:
- Reduce logging to LOG_NOTICE (c6c4e53)
- Port GetStringOrEmpty from pvr.zattoo (fbf26cb)
- Update version and changelog (bdbd6b2)
- pvr.zattoo:
- modernize & bugfixing (#28) (6188857)
- Fix channels not loading (1831339)
- Update version and changelog (8ddb060)
(2018-11-11, 00:39)Matt Devo Wrote: [ -> ] (2018-11-09, 17:14)supergroover Wrote: [ -> ] (2018-11-08, 19:10)jwegman Wrote: [ -> ]FYI; I'm also having the same issue in the recent builds, on a Asus Chromebox CN60, so the issue isn't isolate to @jmerrilljr or his network switch. The following keeps repeating:
I found the #1022 build to be the last without these issues.
New LibreELEC.tv Leia build #1111:
Generic
SHA256 Checksum:
2624879699f95a7482bde4280c708a70be1faffdaa9aae4ca11136f2b544ca44
(Generic)
text:
# uname -a
Linux NUC 4.19.1 #1 SMP Sun Nov 11 21:05:02 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20181111210220-#1111-ge496bf6 [Build #1111]
# Kodi version
(18.0-RC1 Git:c895e84). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (e496bf6,
XBMC master (c895e84,
- Includes latest addons: inputstream.adaptive (0bd5159, +5), inputstream.rtmp (ce7f559), peripheral.joystick (2008fdc, +1), peripheral.xarcade (f09a0e7, +1), pvr.argustv (609a2e7, +2), pvr.demo (964686d), pvr.dvblink (47cbff0, +2), pvr.dvbviewer (a9b204e, +8), pvr.filmon (f736ab4, +2), pvr.hdhomerun (a9d7309, +1), pvr.hts (f4ea60f, +2), pvr.iptvsimple (90a8d6f, +1), pvr.mediaportal.tvserver (e4a9dae, +2), pvr.mythtv (0517d4b, +17), pvr.nextpvr (7e36106, +2), pvr.njoy (4467cac, +1), pvr.octonet (203f800), pvr.pctv (e28a90f, +2), pvr.stalker (a99ad5e, +2), pvr.teleboy (bdbd6b2, +3), pvr.vbox (6ed2f63, +2), pvr.vdr.vnsi (6bbdb78), pvr.vuplus (d77458b, +2), pvr.wmc (e00c895, +2), pvr.zattoo (8ddb060, +7), vfs.libarchive (6d39012), vfs.sftp (6749200)
- Include [env] compare (perma): kodi: next
- Include [pkg] PR:14852 (perma): LinuxRenderGL: Properly draw black quads on area we manage
Build Highlights:
- [PVR] Remove 'Use simple Timeshift OSD' setting from settings.xml.
- Fix for visual artefacts when using calibration
Build Details:
- LibreELEC.tv:
- kodi: use project specific cputemp scripts for all projects (PR:3077, 1 commit, 18 files changed)
- samba: update to samba-4.9.2 (PR:3092, 1 commit, 1 file changed)
- projects/WeTek_Core: Load amlvideodri module at startup (PR:3100, 1 commit, 1 file changed)
- XBMC:
- [PVR] Remove 'Use simple Timeshift OSD' setting from settings.xml. (PR:14846, 1 commit, 1 file changed)
- [cmake] Rework FindJsonSchemaBuilder on the model of FindTextureBuilder (PR:14774, 1 commit, 1 file changed)
- Fix screensaver/DPMS interaction (PR:14845, 3 commits, 1 file changed)
- Allow StartPercent property to be 0 (PR:14649, 1 commit, 1 file changed)
- [skin.estouchy] Fix order in Recent Movies (PR:14837, 1 commit, 1 file changed)
- pvr.mythtv:
- fill date of airdate as needed (b00d18d)
- show status of recording (630e0de)
- show status of broadcast (e00e0a0)
- include fr_FR map for eit categories (73b3218)
- bump version 5.8.18 (bd697d5)
- Non zero startTime for recording stream breaks played position (303158e)
- bump version 5.8.19 (0517d4b)
- Added: [env] compare (perma): kodi: next
- Added: [pkg] PR:14852 (perma): LinuxRenderGL: Properly draw black quads on area we manage
Weekly Linux 4.20-rc2 build #1111x:
Generic
Known issues:
text:
(2018-11-11, 20:14)Matt Devo Wrote: [ -> ]1022: http://ix.io/1rzM (4.18.16) - good
1023: http://ix.io/1rzQ (4.19.0) - bad
1109x: http://ix.io/1rzT (4.20.0-rc1) - bad
Guys, I just want a clean, complete, kernel log (
dmesg|pastebinit
) from #1016/#1016x.
My plan, assuming I don't lose the will to live, is to send these logs to a kernel developer who will have no interest in any of the Kodi/Samba/systemd noise. Using #1016/#1016x as a comparison means the only difference between the before/after kernel logs is the switch from 4.18.14 to 4.19-rc8 (although apparently this issue started with 4.19-rc1, ie.
#0827x). Please, do as I ask or fix this yourselves...
Oh, btw 4.20-rc2 is out, might be worth giving that a whirl.
