I will switch over to my new NUC7i3 tomorrow. Will report back any issues on the new HW
(2017-02-15, 08:58)_Spook_ Wrote: [ -> ] (2017-02-14, 23:34)Kwiboo Wrote: [ -> ] (2017-02-14, 22:03)_Spook_ Wrote: [ -> ]I use the profile for the Intel Media Player profile.
Thanks!, I was able to reproduce the double press issue on my gear and have reverted the change in repeat delay that caused this.
Great! Thanks
Just updated from 0211 to 0214, I am now getting the double-press with my Harmony remote.
http://sprunge.us/hFai
(2017-02-16, 02:24)khaoohs Wrote: [ -> ] (2017-02-15, 08:58)_Spook_ Wrote: [ -> ] (2017-02-14, 23:34)Kwiboo Wrote: [ -> ]Thanks!, I was able to reproduce the double press issue on my gear and have reverted the change in repeat delay that caused this.
Great! Thanks
OK, so you should have this:
#0211: No issue
#0212: Harmony users might have double key presses caused by PR1327
#0213: No issue (as PR1327 is not included)
#0214: Harmony users might have double key presses caused by a revised version of PR1327
Kwiboo please correct me if I've got this wrong, but
this is what we currently think is happening with Harmony users:
Quote:After some more testing I am unsure if the repeat delay needs to be reverted to 1000ms. The default setting for Harmony's command repeats was set to 3, meaning it will send IR-commands 3-4 times for each button pressed, lowering this setting to 0, 1 or 2 repeats also makes the double presses go away.
Normally this hasn't been an issue for Harmony users as the original LE/Kodi IR configuration would intentionally ignore button presses either because the back end is responding too slowly or (in the case of Kodi) is programmed to ignore the first key press. Now that these issues have been eliminated by PR1327, the default (and excessive) Harmony setting is starting to cause unintentional button repeats.
We're looking into a solution that doesn't require a change to Harmony settings, but it's possible that this might be the best/only solution if the problem is now being caused by the default Harmony device configuration.
New LibreELEC.tv Leia build #0215:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.9.9 #1 SMP Thu Feb 16 00:48:29 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170216004705-#0215-gfa59578 [Build #0215]
# Kodi version
(18.0-ALPHA1 Git:4c792db). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (fa595784,
changelog) and tip of
XBMC master (a1bf5b14,
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (0a97062d, ahead +22)
- Includes latest libnfs master (91421265, ahead +48)
- Includes latest p8-platform master (2d90f986, ahead +9)
- Includes latest addons: inputstream.adaptive (a347296e), inputstream.rtmp (55437ac7), peripheral.joystick (69c9e5fe, +1), pvr.argustv (5a36c586), pvr.demo (8243935f), pvr.dvblink (0015079e), pvr.dvbviewer (9fb34b3c), pvr.filmon (315e5034), pvr.hdhomerun (98cb8d40), pvr.hts (1caa390d, +1), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (019c7e99), pvr.mythtv (47f0d4c2, +9), pvr.nextpvr (cb1b5415), pvr.njoy (080cd321), pvr.octonet (8549a31c), pvr.pctv (e67e9695), pvr.stalker (a609149c), pvr.vbox (dea8335a), pvr.vdr.vnsi (7033621d), pvr.vuplus (6ff2eb28), pvr.wmc (5f1db43f)
- Include [env] afbd134f: linux: Enable Fair Queue packet scheduling (TEST)
- Include [env] e533a8be: linux: Default to CONFIG_TCP_CONG_BBR (TEST)
- Include [env] patch: repository.retroplayer.libreelec.addons: add temp repo for testing
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: iwlwifi-firmware: update to iwlwifi-firmware-ba301aa
- Include [env] patch: linux: enable in-tree rtl8192cu for RPi/RPi2
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] PR:1287: virtio-gpu support (qemu/kvm)
- Include [env] PR:1326: Build system scripts cleanup
- Include [env] PR:1327: [master] input: change input repeat config
- Include [env] PR:1329: imagedecoder.raw: add add-on
- Include [pkg] patch: alsa-lib: conf: Add card config for Intel HDMI/DP LPE audio (alsa-lib)
- Include [pkg] PR:56: bluetooth: add missing 'Connect' option when device is Trusted (service.libreelec.settings)
- Include [pkg] PR:11163: Fix silent failure when game add-on can't be installed
- Include [pkg] PR:11668: FFmpegImage: Document and change alignment
- Revert [pkg] PR:8966/commits/8d88a547041a2a540bff5217c3b19ffdc4473038: hack: add iso to filedirectory list (Reason: causes navigation/playback issues) (kodi)
Build Highlights:
- New MusicDB schema v61 - forced tag rescan stored in db
- Bump nvidia driver to 375.39 (fixes resume-from-suspend issues) and nvidia-legacy to 340.102
Build Details:
- LibreELEC.tv:
- v4l-utils: update to 1.12.2 and fix streamzap keytable (PR:1330, 2 commits, 2 files changed)
- xf86-video-nvidia*: bump 375.39 and 340.102 (PR:1343, 2 commits, 3 files changed)
- docker: enable journald buildtag (PR:1350, 1 commit, 2 files changed)
- XBMC:
- add dng to mime types (PR:11671, 1 commit, 1 file changed)
- Forced full tag rescans of music files (PR:11557, 2 commits, 7 files changed)
- [addons] auto-disable broken addon on update (PR:11664, 6 commits, 8 files changed)
- cmake: findembedded: fix IMX(FB) header file name (PR:11302, 1 commit, 1 file changed)
- Update SSE3 check to match with the others (PR:11631, 1 commit, 1 file changed)
- pvr.mythtv:
- [cmake] Rename find_package(kodi) to Kodi (PR:66, 2 commits, 3 files changed)
- create pvr launcher (1e6f243b)
- registering source files by glob (9cedf04b)
- initialize pvr struct with 0 (de6c8f7e)
- stop cppmyth error log during connect (f59c60d4)
- init pvr client using launcher (2c3374cd)
- [lang] updated language files (47f0d4c2)
Quite possibly a different suspend issue, in that case - there have been several new suspend issues reported recently on the nvidia forums, which are probably the issues fixed by this release.
Is there a known issue with latest Builds and my 2820 NUC? I got constant skipped frames. Will dig deeper tomorrow and get some logs.
(2017-02-16, 18:19)john.cord Wrote: [ -> ]Is there a known issue with latest Builds and my 2820 NUC? I got constant skipped frames. Will dig deeper tomorrow and get some logs.
If you can narrow it down to the build when this issue is first seen, that would be helpful.
(2017-02-16, 18:51)Milhouse Wrote: [ -> ] (2017-02-16, 18:19)john.cord Wrote: [ -> ]Is there a known issue with latest Builds and my 2820 NUC? I got constant skipped frames. Will dig deeper tomorrow and get some logs.
I tried different builds back to #101. Maybe its because i tinkered with EDIDs. I will try tomorrow with a clean system with latest build. On my Chromebox (main system) with same Kodi Settings and same file playback is perfect.
I believe ProjectM not working is a known issue. Is there any chance of a fix on the horizon?
17:01:08.974 T:139805841619072 DEBUG: ADDON: Dll Initializing - projectM
17:01:08.974 T:139805841619072 DEBUG: SECTION:LoadDLL(/storage/.kodi/addons/visualization.projectm/visualization.projectm.so.1.1.1)
17:01:08.974 T:139803690653440 DEBUG: DoScan Skipping dir 'smb://192.168.1.100/zpool0/media/music/Sodom - The Art Of Killing Poetry/' due to no change
17:01:08.974 T:139805841619072 DEBUG: Loading: /storage/.kodi/addons/visualization.projectm/visualization.projectm.so.1.1.1
17:01:08.987 T:139805841619072 ERROR: Unable to load /storage/.kodi/addons/visualization.projectm/visualization.projectm.so.1.1.1, reason: /storage/.kodi/addons/visualization.projectm/visualization.projectm.so.1.1.1: undefined symbol: __glewBindFramebufferEXT
http://sprunge.us/fOOC
New LibreELEC.tv Leia build #0216:
Generic
# uname -a
Linux NUC 4.9.10 #1 SMP Thu Feb 16 21:23:07 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170216212145-#0216-gfa59578 [Build #0216]
# Kodi version
Based on tip of
XBMC master (11a15fc0,
- Include [env] compare: linux: update to linux-4.9.10
- Include [env] PR:1355: xorg-server: clean package when nvidia drivers are bumped
Build Highlights:
- New 4.9.10 kernel
Build Details:
- XBMC:
- [codegenerator] initialize pointers with nullptr if they have no value (PR:11677, 1 commit, 1 file changed)
- VideoPlayer: VideoReferenceClock to the right place (PR:11592, 4 commits, 46 files changed)
- Added: [env] compare: linux: update to linux-4.9.10
- Added: [env] PR:1355: xorg-server: clean package when nvidia drivers are bumped
#0214-#0216 has the repeat on harmony remote issue again, revert to #0213 everything is OK
Reverted to #0213x btw because seems the 4.9.x kernel is not so happy for my new NUC7i3BNK as I am
I will try and post logs during the weekend.
(2017-02-17, 18:06)_Spook_ Wrote: [ -> ]#0214-#0216 has the repeat on harmony remote issue again, revert to #0213 everything is OK
Reverted to #0213x btw because seems the 4.9.x kernel is not so happy for my new NUC7i3BNK as I am I will try and post logs during the weekend.
Use BT with yout Harmony Elite. Way better response Time compared to IR.
(2017-02-17, 21:05)john.cord Wrote: [ -> ] (2017-02-17, 18:06)_Spook_ Wrote: [ -> ]#0214-#0216 has the repeat on harmony remote issue again, revert to #0213 everything is OK
I could, but no need for better respons. Just don't need the doubletap that is there now.
Milhouse are the IR settings hardcoded and compiled or is there a config file I can change?
There should be a fix for Harmony in tonight's build (bit delayed, doing a clean build - expect about 2/3am).
